P0080SB
P0080SB
    SOCAY(硕凯)
    SMB(DO-214AA)
    SMB SMT 6V 2.2A
P0080SB 数据手册
Thyristor Surge Suppressors (TSS) P0080SB – P4200SB Series - DO-214AA(SMB) @10/700μS, 4KV Description P0080SB - P4200SB Series are designed to protect broadband equipment such as modems, line card, CPE and DSL from damaging over-voltage transients. The series provides a surface mount solution that enables equipment to comply with global regulatory standards. Features and Benefits  Low voltage overshoot  Low on-state voltage  Does not degrade surge capability after multiple surge events within limit  Fails short circuit when surged in excess of ratings  Low Capacitance Schematic Symbol Applicable Global Standards          TIA-968-A ITU K.20/21 Enhanced level ITU K.20/21 Basic Level GR 1089 Inter building GR 1089 Inter building IEC 6100-4-5 YD/T 1082 YD/T 993 YD/T 950 Electrical Parameters Parameter Definition IS Switching Current - maximum current required to switch to on state IDRM Leakage Current - maximum peak off-state current measured at VDRM IH Holding Current - minimum current required to maintain on state IT On-state Current - maximum rated continuous on-state current VS Switching Voltage - maximum voltage prior to switching to on stat VDRM Peak Off-state Voltage - maximum voltage that can be applied while maintaining off state VT On-state Voltage - maximum voltage measured at rated on-state current C0 Off-state Capacitance - typical capacitance measured in off state SOCAY Electronics Corp., Ltd. Revision July 27, 2016 +I IT IS IH -V IDRM +V VT VDRM VS -I www.socay.com 1/5 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Thyristor Surge Suppressors (TSS) P0080SB – P4200SB Series - DO-214AA(SMB) @10/700μS, 4KV Electrical Characteristics VDRM VS VT @IDRM=5μA @100V/μS @IT=2.2A V min V max P008B 6 P0300SB P03B P0640SB P0720SB C0 IS IT IH V max mA max A max mA min pF min pF max 25 4 800 2.2 50 25 150 25 40 4 800 2.2 50 15 140 P06B 58 77 4 800 2.2 150 40 60 P07B 65 88 4 800 2.2 150 35 60 P0900SB P09B 75 98 4 800 2.2 150 25 55 P1100SB P11B 90 130 4 800 2.2 150 30 50 P1300SB P13B 120 160 4 800 2.2 150 25 45 P1500SB P15B 140 180 4 800 2.2 150 25 40 P1800SB P18B 170 220 4 800 2.2 150 25 35 P2000SB P20B 180 220 4 800 2.2 150 20 60 P2300SB P23B 190 260 4 800 2.2 150 25 35 P2600SB P26B 220 300 4 800 2.2 150 20 35 P3100SB P31B 275 350 4 800 2.2 150 20 35 P3500SB P35B 320 400 4 800 2.2 150 20 35 P4000SB P40B 360 460 4 800 2.2 150 20 35 P4200SB P42B 400 520 4 800 2.2 150 20 35 Part Number Marking P0080SB @1MHz Notes: - Absolute maximum ratings measured at TA= 25ºC (unless otherwise noted). - Devices are bi-directional. Surge Ratings Series B 2/10μS1 8/20μS1 10/160μS1 10/560μS1 10/1000μS1 5/310μS1 2/10μS2 1.2/50μS2 10/160μS2 10/560μS2 10/1000μS2 10/700μS2 A min A min A min A min A min A min 250 150 100 80 100 250 Notes: 1. Current waveform in µs 2. Voltage waveform in µs ITSM 50/60 Hz A min 30 di/dt Amps/µs max 500 - Peak pulse current rating (IPP) is repetitive and guaranteed for the life of the product. - IPP ratings applicable over temperature range of -40ºC to +85ºC - The device must initially be in thermal equilibrium with -40°C < TJ < +150°C Thermal Considerations Package Symbol Parameter Value Unit DO-214AA TJ Operating Junction Temperature Range - 40 to + 150 °C TS Storage Temperature Range - 40 to +150 °C RθJA Thermal Resistance: Junction to Ambient 90 °C/W SOCAY Electronics Corp., Ltd. Revision July 27, 2016 www.socay.com 2/5 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Thyristor Surge Suppressors (TSS) P0080SB – P4200SB Series - DO-214AA(SMB) @10/700μS, 4KV Characteristic Curves Figure 2 - tr × td Pulse Waveform Figure 1 - V-I Characteristics +I Ipp – Peak Pulse Current - % Ipp IT IS IH IDRM -V +V VT VDRM VS tr=rise time to peak value td=decay time to half value 100 Waveform=tr×td 50 Half Value 50 tr td 0 -I Figure 3 - Normalized VS Change Versus Junction Temperature t – Time (μs) Figure 4 - Normalized DC Holding Current Versus Case Temperature 2.0 14 1.8 12 IH IH (TC=25℃) 10 8 6 25℃ 4 2 Ration of Percent of VS Change - % Waveform=tr×td Peak Value 9 -4 -6 -8 -40 -20 0 20 40 60 80 100 120 140 1.4 25℃ 1.2 1.0 0.8 0.6 0.4 160 -40 -20 0 20 40 60 80 100 120 140 160 Case Temperature (TC) - ℃ Junction Temperature (TJ) - ℃ SOCAY Electronics Corp., Ltd. Revision July 27, 2016 1.6 www.socay.com 3/5 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Thyristor Surge Suppressors (TSS) P0080SB – P4200SB Series - DO-214AA(SMB) Environmental Specifications Physical Specifications 80% Rated VDRM (VAC Peak ) +125°C or +150°C, High Temp Voltage Lead Material Copper Alloy High Temp Voltage Blocking Blocking 504 or 1008 hrs. MIL-STD-750 (Method 1040) JEDEC, JESD22-A-101 -65°C to +150°C, 15 min. dwell, 10 up to 100 cycles. Temp Cycling MIL-STD-750 @10/700μS, 4KV (Method 1051) EIA/JEDEC, Lead Material Copper Alloy Terminal Finish 100% Matte-Tin Plated Body Material UL recognized epoxy meeting flammability classification 94V-0 JESD22-A104 Biased Temp & 52 VDC (+85°C) 85%RH, 504 up to 1008 hrs. Humidity JEDEC, JESD22-A-101 +150°C 1008 hrs. High Temp Storage EIA/ MIL-STD-750 (Method 1031) JEDEC, JESD22-A-101 Low Temp Storage -65°C, 1008 hrs. 0°C to +100°C, 5 min. dwell, 10 sec. transfer, Thermal Shock Thermal Shock 10 cycles. MIL-STD-750 (Method 1056) JEDEC, JESD22-A-106 Autoclave (Pressure +121°C, Cooker Test) EIA/Cooker Test) JEDEC, JESD22-A-102 +260°C, 30 secs. MIL-STD-750 (Method 2031 Resistance to Solder Heat 100%RH, 2atm, 24 up to 168 hrs. Moisture Sensitivity 85%RH, +85°C, 168 hrs., 3 reflow cycles Level Level (+260°C Peak). JEDEC-J-STD-020, Level 1 Soldering Parameters Reflow Condition TP Ramp-up TL Critical Zone TL to TP Pre Heat Temperature TS(max) Ramp-down TS(min) Time to peak temperature (t 25℃ to peak) SOCAY Electronics Corp., Ltd. Revision July 27, 2016 +150°C -Temperature Max (Ts(max)) +200°C -Time (min to max) (Ts) 60 -180 Seconds 3°C/Second Max TS(max) to TL - Ramp-up Rate 3°C/Second Max Reflow Time -Temperature Min (Ts(min)) Average ramp up rate ( Liquidus Temp TL) to peak Preheat 25 Lead–free assembly - Temperature (TL) (Liquidus) +217°C - Time (min to max) (TL) 60 -150 Seconds Peak Temperature (TP) 260 +0/-5°C Time within 5°C of actual peak Temperature (tp) 30 Seconds Max Ramp-down Rate 6°C/Second Max Time 25°C to peak Temperature (TP) 8 minutes Max Do not exceed +260°C www.socay.com 4/5 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Thyristor Surge Suppressors (TSS) P0080SB – P4200SB Series - DO-214AA(SMB) Part Numbering @10/700μS, 4KV Part Marking Part Marking Code (Refer to Electrical Characteristics Table) Dimensions DO-214AA Dimensions Inch (millimeter) Pad outline Inches Millimeters Min Max Min Max A 0.130 0.156 3.30 3.95 B 0.201 0.220 5.10 5.60 C 0.077 0.087 1.95 2.20 D 0.159 0.181 4.05 4.60 E 0.030 0.063 0.76 1.60 F 0.076 0.096 1.90 2.45 G 0.002 0.008 0.05 0.20 H 0.077 0.104 1.95 2.65 K 0.006 0.016 0.15 0.41 Packaging Part Number Component Package Quantity Packaging Option Packaging Specification Pxxx0SB DO-214AA 2500 Tape & Reel -12mm/13″tape EIA -481 - D Tape and Reel Specifications 12.99 (330.0) 0.157 (4.0) 0.512(13.0) Arbor Hole Diameter 0.472 (12.0) 0.36 (9.2) 0.315 (8.0) 0.49 (12.4) Direction of Feed SOCAY Electronics Corp., Ltd. Revision July 27, 2016 0.059 Diameter (1.5) Cover tape Dimensions are in inches (and millimeters) www.socay.com 5/5 @ SOCAY Electronics Corp., Ltd. 2016 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
P0080SB 价格&库存
很抱歉,暂时无法提供与“P0080SB”相匹配的价格&库存,您可以联系我们找货
