Axial Lead Transient Voltage Suppressors (TVS)
P6KE Series
6.8 To 600 V
600W
Uni-directional
Description
Bi-directional
The P6KE series is designed specifically to protect sensitive electronic
equipment from voltage transients induced by lightning and other transient
voltage events.
Features
u
u
u
u
u
u
u
u
u
u
u
u
u
u
u
u
u
Glass passivated chip junction in DO-15 Package
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
600W Peak power capability at 10 × 1000µs waveform Repetition rate
(duty cycle):0.01%
Fast response time: typically less than 1.0ps from 0 Volts to VBR min
Typical IR less than 5μA above 12V.
High Temperature soldering: 260°C/40 seconds at terminals
Typical maximum temperature coefficient ΔVBR = 0.1% ×
VBR@25°C× ΔT
Plastic package has Underwriters Laboratory Flammability 94V-0
Matte tin lead–free Plated
Halogen free and RoHS compliant
Typical failure mode is short from over-specified voltage or current
Whisker test is conducted based on JEDEC JESD201A per its table
4a and 4c
IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact)
ESD protection of data lines in accordance with IEC 61000-4-2
(IEC801-2)
EFT protection of data lines in accordance with IEC 61000-4-4
(IEC801-4)
Functional Diagram
Bi-directional
Cathode
Anode
Uni-direction
Agency Approvals
AGENCY
Applications
AGENCY FILE NUMBER
TVS devices are ideal for the protection of I/O interfaces, VCC bus and other
vulnerable circuits used in Telecom, Computer, Industrial and Consumer
electronic applications.
Maximum Ratings
E341027
(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note
1), (Note 2)
PPPM
600
Watts
Amps
Peak Pulse Current with a 10/1000µs waveform.(Note1,Fig.3)
IPP
See Next Table
PM(AV)
5.0
Watt
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
IFSM
100
Amps
Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only
(Note 4)
VF
3.5/5.0
Voltage
TJ , TSTG
-55 to +150
°C
Power Dissipation on Infinite Heat Sink at TL=75°C
Operating junction and Storage Temperature Range.
Notes:
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
4. VF < 3.5V for VBR < 200V and VF< 6.5V for VBR > 201V.
SOCAY Electronics Co., Ltd.
Revision September 25, 2013
www.socay.com
1/6
@ SOCAY Electronics Co., Ltd. 2013
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
P6KE Series
6.8 To 600 V
Electrical Characteristics
Part Number
Uni
P6KE6.8
P6KE6.8A
P6KE7.5
P6KE7.5A
P6KE8.2
P6KE8.2A
P6KE9.1
P6KE9.1A
P6KE10
P6KE10A
P6KE11
P6KE11A
P6KE12
P6KE12A
P6KE13
P6KE13A
P6KE15
P6KE15A
P6KE16
P6KE16A
P6KE18
P6KE18A
P6KE20
P6KE20A
P6KE22
P6KE22A
P6KE24
P6KE24A
P6KE27
P6KE27A
P6KE30
P6KE30A
P6KE33
P6KE33A
P6KE36
P6KE36A
P6KE39
P6KE39A
P6KE43
P6KE43A
P6KE47
P6KE47A
P6KE51
P6KE51A
P6KE56
P6KE56A
P6KE62
P6KE62A
P6KE68
P6KE68A
P6KE75
P6KE75A
P6KE82
P6KE82A
600W
Bi
P6KE6.8C
P6KE6.8CA
P6KE7.5C
P6KE7.5CA
P6KE8.2C
P6KE8.2CA
P6KE9.1C
P6KE9.1CA
P6KE10C
P6KE10CA
P6KE11C
P6KE11CA
P6KE12C
P6KE12CA
P6KE13C
P6KE13CA
P6KE15C
P6KE15CA
P6KE16C
P6KE16CA
P6KE18C
P6KE18CA
P6KE20C
P6KE20CA
P6KE22C
P6KE22CA
P6KE24C
P6KE24CA
P6KE27C
P6KE27CA
P6KE30C
P6KE30CA
P6KE33C
P6KE33CA
P6KE36C
P6KE36CA
P6KE39C
P6KE39CA
P6KE43C
P6KE43CA
P6KE47C
P6KE47CA
P6KE51C
P6KE51CA
P6KE56C
P6KE56CA
P6KE62C
P6KE62CA
P6KE68C
P6KE68CA
P6KE75C
P6KE75CA
P6KE82C
P6KE82CA
Reverse
Stand-Off
Voltage
VRWM (V)
5.5
5.8
6.1
6.4
6.6
7.0
7.4
7.8
8.1
8.6
8.9
9.4
9.7
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.2
41.3
43.6
45.4
47.8
50.2
53.0
55.1
58.1
60.7
64.1
66.4
70.1
Breakdown
Voltage VBR (V)
@IT
MIN
6.12
6.46
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.45
10.80
11.40
11.70
12.35
13.50
14.25
14.40
15.20
16.20
17.10
18.00
19.00
19.80
20.90
21.60
22.80
24.30
25.65
27.00
28.50
29.70
31.35
32.40
34.20
35.10
37.05
38.70
40.85
42.30
44.65
45.90
48.45
50.40
53.20
55.80
58.90
61.20
64.60
67.50
71.25
73.80
77.90
MAX
7.48
7.14
8.25
7.88
9.02
8.61
10.01
9.56
11.00
10.50
12.10
11.55
13.20
12.60
14.30
13.65
16.50
15.75
17.60
16.80
19.80
18.90
22.00
21.00
24.20
23.10
26.40
25.20
29.70
28.35
33.00
31.50
36.30
34.65
39.60
37.80
42.90
40.95
47.30
45.15
51.70
49.35
56.10
53.55
61.60
58.80
68.20
65.10
74.80
71.40
82.50
78.75
90.20
86.10
Test
Current
IT (mA)
Maximum
Clamping
Voltage VC
@IPP (V)
Maximum
Peak
Pulse
Current
IPP (A)
Maximum
Reverse
Leakage IR
@VRWM
(μA)
10
10
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.2
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
70.1
80.5
77.0
89.0
85.0
98.0
92.0
108.0
103.0
118.0
113.0
55.56
57.14
51.28
53.10
48.00
49.59
43.48
44.78
40.00
41.38
37.04
38.46
34.68
35.93
31.58
32.97
27.27
28.30
25.53
26.67
22.64
23.81
20.62
21.66
18.81
19.61
17.29
18.07
15.35
16.00
13.79
14.49
12.58
13.13
11.54
12.02
10.64
11.13
9.69
10.12
8.85
9.26
8.16
8.56
7.45
7.79
6.74
7.06
6.12
6.52
5.56
5.83
5.08
5.31
1000
1000
500
500
200
200
50
50
10
10
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
www.socay.com
2/6
P6KE Series
6.8 To 600 V
600W
(TA=25℃ unless otherwise noted) (Continue)
Part Number
Uni
Bi
P6KE91
P6KE91A
P6KE100
P6KE100A
P6KE110
P6KE110A
P6KE120
P6KE120A
P6KE130
P6KE130A
P6KE150
P6KE150A
P6KE160
P6KE160A
P6KE170
P6KE170A
P6KE180
P6KE180A
P6KE200
P6KE200A
P6KE220
P6KE220A
P6KE250
P6KE250A
P6KE300
P6KE300A
P6KE350
P6KE350A
P6KE380
P6KE380A
P6KE400
P6KE400A
P6KE440
P6KE440A
P6KE500
P6KE500A
P6KE520
P6KE520A
P6KE550
P6KE550A
P6KE600
P6KE600A
P6KE91C
P6KE91CA
P6KE100C
P6KE100CA
P6KE110C
P6KE110CA
P6KE120C
P6KE120CA
P6KE130C
P6KE130CA
P6KE150C
P6KE150CA
P6KE160C
P6KE160CA
P6KE170C
P6KE170CA
P6KE180C
P6KE180CA
P6KE200C
P6KE200CA
P6KE220C
P6KE220CA
P6KE250C
P6KE250CA
P6KE300C
P6KE300CA
P6KE350C
P6KE350CA
P6KE380C
P6KE380CA
P6KE400C
P6KE400CA
P6KE440C
P6KE440CA
P6KE500C
P6KE500CA
P6KE520C
P6KE520CA
P6KE550C
P6KE550CA
P6KE600C
P6KE600CA
Reverse
Stand-Off
Voltage
VRWM (V)
73.7
77.8
81.0
85.5
89.2
94.0
97.2
102.0
105.0
111.0
121.0
128.0
130.0
136.0
138.0
145.0
146.0
154.0
162.0
171.0
175.0
185.0
202.0
214.0
243.0
256.0
284.0
299.3
308.6
324.9
324.8
342.0
357.3
376.2
406.0
427.5
422.2
444.6
446.6
470.3
487.2
513.0
Breakdown
Voltage VBR (V)
@IT
MIN
MAX
81.90
86.45
90.00
95.00
99.00
104.50
108.00
114.00
117.00
123.50
135.00
142.50
144.00
152.00
153.00
161.50
162.00
171.00
180.00
190.00
198.00
209.00
225.00
237.50
270.00
285.00
315.00
332.50
342.00
361.00
360.00
380.00
396.00
418.00
450.00
475.00
468.00
494.00
495.00
522.50
540.00
570.00
100.10
95.55
110.00
105.00
121.00
115.50
132.00
126.00
143.00
136.50
165.00
157.50
176.00
168.00
187.00
178.50
198.00
189.00
220.00
210.00
242.00
231.00
275.00
262.50
330.00
315.00
385.00
367.50
418.00
399.00
440.00
420.00
484.00
462.00
550.00
525.00
572.00
546.00
605.00
577.50
660.00
630.00
Test
Current
IT (mA)
Maximum
Clamping
Voltage VC
@IPP (V)
Maximum
Peak
Pulse
Current
IPP (A)
Maximum
Reverse
Leakage IR
@VRWM
(μA)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
131.0
125.0
144.0
137.0
158.0
152.0
173.0
165.0
187.0
179.0
215.0
207.0
230.0
219.0
244.0
234.0
258.0
246.0
287.0
274.0
344.0
328.0
360.0
344.0
430.0
414.0
504.0
482.0
547.2
524.4
576.0
552.0
633.6
607.2
720.0
690.0
748.8
717.6
792.0
759.0
864.0
828.0
4.58
4.80
4.17
4.38
3.80
3.95
3,47
3.64
3.21
3.35
2.79
2.90
2.61
2.74
2.46
2.56
2.33
2.44
2.09
2.19
174
1.83
1.67
1.74
1.40
1.45
1.19
1.24
1.10
1.14
1.05
1.09
0.95
0.99
0.83
0.87
0.80
0.84
0.76
0.79
0.69
0.72
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
Note:
1. Suffix 'A ' denotes 5% tolerance device. Without 'A' denotes 10% tolerance device
2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices
3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double
www.socay.com
3/6
P6KE Series
6.8 To 600 V
600W
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
100
80
60
40
0.1
1
10
100
td - Pulse Width (μs)
1000
Figure 3 - Pulse Waveform
150
175
10000
tr=10µsec
Bi-directional
@zero bins
TJ=25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
Uni-directional
@zero bins
1000
100
Uni-directional @VRWM
Cj (pF)
IPPM - Peak Pulse Current, % IRSM
50
75
100
125
TA-Ambient temperature(°C)
Figure 4 - Typical Junction Capacitance
150
Half Value
IPPM (IPPM/2)
50
100
10/1000µsec. Waveform
as defined by R.E.A
10
Tj=25°C
f=1.0MHz
Vsig=50mVp-p
tc
Bi-directional @VRWM
1
1.0
2.0
t - Time (ms)
3.0
1.0
4.0
10.0
100.0
1000.0
VBR-Reverse Breakdown Voltage (V)
Figure 5 - Steady State Power Derating Curve
Figure 6 - Maximum Non-Repetitive Surge Current
5.0
100
IFSM-Peak Forward Surge Current
(A)
PM(AV), Steady State Power Dissipation (W)
25
4.0
3.0
2.0
1.0
0.0
TJ=TJ max.
8.3 ms Single Half Sine-Wave
80
60
40
50
75
100
125
150
175
200
1
TL - Lead Temperature(°C)
10
Number of Cycles at 60Hz
100
www.socay.com
4/6
P6KE Series
6.8 To 600 V
600W
I-V Curve Characteristics
Physical Specifications
Environmental Specifications
Weight
0.015 ounce, 0.4 gram
Temperature Cycle
JESD22-A104
Case
JEDEC DO-204AC (DO-15) Molded
Plastic over glass passivated junction
Pressure Cooker
JESD22-A102
Color band denotes cathode except
Bipolar
High Temp. Storage
JESD22-A103
Polarity
HTRB
JESD22-A108
Terminal
Matte Tin-plated leads, Solderable per
JESD22-B102D
Thermal Shock
JESD22-A106
Soldering Parameters
Reflow Condition
Lead–free assembly
TP
Ramp-up
Critical Zone
TL to TP
TL
Pre Heat
-Temperature Min (Ts(min))
150°C
-Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
60 -180 Seconds
Temperature
TS(max)
Ramp-down
TS(min)
Average ramp up rate ( Liquidus Temp TL)
to peak
3°C/second max
TS(max) to TL - Ramp-up Rate
3°C/second max
Preheat
25
Time to peak temperature
(t 25℃ to peak)
- Temperature (TL) (Liquidus)
217°C
60 -150 Seconds
Reflow
Time
Peak Temperature (TP)
Time within 5°C
Temperature (tp)
260 +0/-5°C
of
actual
peak
20 -40 Seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max
Do not exceed
280°C
www.socay.com
5/6
P6KE Series
6.8 To 600 V
600W
Dimensions
Inches
DO-204AC (DO-15)
Millimeters
Dimensions
Min
Max
Min
Max
A
1.000
25.40
B
0.230
0.300
5.85
7.63
C
0.028
0.033
0.71
0.84
D
0.102
0.142
2.60
3.61
Cathode Band
Part Marking
Part Numbering
P6KE×××CA
Cathode Band
Socay Logo
5% VBR VOLTAGE TOLERANCE
P6KEXXX
BI-DIRECTIONAL
Product Type
VR VOLTAGE
SERIES
Packaging
Part Number
Component
Package
Quantity
Packaging
Option
P6KEXXXXX
DO-204AC (DO-15)
2000
Box
Packaging Dimensions
Unit: Inches (Millimeters)
2.56
(65.00)
0.25
(6.35)
0.20±0.020
(5.08±0.508)
www.socay.com
6/6
很抱歉,暂时无法提供与“P6KE30CA”相匹配的价格&库存,您可以联系我们找货
