Surface Mount Resettable PTCs
SCF1210 Series
Description
The SCF1210 Series PTC provides surface mount
over-current protection for applications where space is at a
premium and resettable protection is desired.
Features
u
u
u
u
u
RoHS compliant, Lead-Free and Halogen-Free
Fast time-to-trip
Compact design saves board space
Low resistance
Low-profile
Applications
u
u
u
u
u
u
u
u
PC motherboard - plug and play protection
Mobile phones - battery and port protection
Game console port protection
USB peripherals
Disk drive
PDAS / digital cameras
Power ports
General electronics
Electrical Parameters
Part Number
Hold
Current
Trip
Current
I hold (A)
I trip
(A)
Rated
Voltage
Max
Current
Typical
Power
Maximum Time
To Trip
V max
(Vdc)
I max
(A)
P dtyp.
(W)
Current
(A)
Time
(Sec.)
R min
(Ω)
R 1max
(Ω)
Resistance
SCF005-1210R
0.05
0.15
60
100
0.60
0.25
3.00
3.600
50.000
SCF010-1210R
0.10
0.25
60
100
0.60
0.50
1.50
1.600
15.000
SCF020-1210R
0.20
0.40
30
100
0.60
8.00
0.02
0.800
5.000
SCF035-1210R
0.35
0.70
16
100
0.60
8.00
0.20
0.320
1.3000
SCF050-1210R
0.50
1.00
16
100
0.60
8.00
0.10
0.250
0.900
SCF075-1210R
0.75
1.50
8
100
0.60
8.00
0.10
0.130
0.400
SCF075-24-1210R
0.75
1.50
24
100
0.60
8.00
0.10
0.130
0.400
SCF110-1210R
1.10
2.20
6
100
0.80
8.00
0.30
0.060
0.210
SCF150-1210R
1.50
3.00
6
100
0.80
8.00
0.50
0.040
0.110
SCF175-1210R
1.75
4.00
6
100
0.80
8.00
0.60
0.020
0.080
SCF200-1210R
2.00
4.00
6
100
0.80
8.00
1.00
0.015
0.070
I hold= Hold current: maximum current device will pass without tripping in 23°C still air.
I trip= Trip current: minimum current at which the device will trip in 23°C still air.
V max= Maximum voltage device can withstand without damage at rated current (Imax)
I max= Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pdtyp.= Power dissipated from device when in the tripped state at 23°C still air.
R min= Minimum resistance of device in initial (un-soldered) state.
R 1max= Maximum resistance of device at 23°C measured one hour after tripping.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
SOCAY Electronics Co., Ltd.
Revision December 25, 2015
www.socay.com
1/4
@ SOCAY Electronics Co., Ltd. 2015
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
SCF1210 Series
Temperature Rerating Chart – I hold (A)
Average Time Current Curves
Temperature Derating Curve
Ambient Temperature (°C)
Fault Current (A)
A= SCF005-1210R
B= SCF010-1210R
C= SCF020-1210R
D= SCF035-1210R
E= SCF050-1210R
F= SCF075-1210R
/SCF075-24-1210R
G= SCF110-1210R
H= SCF150-1210R
I = SCF175-1210R
J= SCF200-1210R
Material Specifications
Terminal pad material
Pure Tin
Soldering Characteristics
Meets EIA specification RS 186-9E, ANSI/J-std-002 Category 3
Soldering Parameters
TP
Ramp-up
Critical Zone
TL to TP
TL
Temperature
TS(max)
Ramp-down
TS(min)
Preheat
25
Time to peak temperature
(t 25℃ to peak)
Time
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate (TS max to TP)
3°C/second max.
Preheat :
Temperature Min (TSmin)
Temperature Max (TSmax)
Time (TSmin to TSmax)
Time maintained above:
Temperature(TL)
Time (TL)
217°C
60-150 seconds
Peak/Classification Temperature(TP):
260°C
Time within 5°C of actual peak:
Temperature
20-40 seconds
Ramp-down Rate:
6°C/ second max.
Time 25°C to Peak Temperature
8 minutes max.
150°C
200°C
60-180 seconds
Note: All temperatures refer to of the package, measured on the package body surface.
Solder reflow
Caution:
Due to “Lead Free” nature, Temperature and Dwelling time for the
soldering zone is higher than those for Regular. This may cause
damage to other components.
1. Recommended max past thickness > 0.25mm.
2. Devices can be cleaned using standard methods and aqueous
solvent.
3. Rework use standard industry practices.
4. Storage Environment : < 30℃/ 60%RH
1. If reflow temperatures exceed the recommended profile, devices
may not meet the performance requirements.
2. Devices are not designed to be wave soldered to the bottom side
of the board.
www.socay.com
2/4
SCF1210 Series
Part Marking
Part Numbering
F XX
SCF XXX – XX – 1210R
F75
Hold Current
Logo
Device Size Code
F XX
X
Rated Voltage
F75
F
Hold Current
Socay Product Code
Hold Current
Logo
Example
Pad Layouts
Unit: mm
The dimension in the table below provide the recommended
pad layout for each SCF1210 device
1210 Series
Dimensions
A
B
C
Nominal
Nominal
Nominal
2.00
1.00
2.80
Device
Unit: mm
A
B
C
D
E
Part Number
SCF005-1210R
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
3.00
3.43
2.35
2.80
0.60
1.15
0.25
0.75
0.10
0.45
SCF010-1210R
3.00
3.43
2.35
2.80
0.60
1.15
0.25
0.75
0.10
0.45
SCF020-1210R
3.00
3.43
2.35
2.80
0.40
0.85
0.25
0.75
0.10
0.45
SCF035-1210R
3.00
3.43
2.35
2.80
0.40
0.80
0.25
0.75
0.10
0.45
SCF050-1210R
3.00
3.43
2.35
2.80
0.30
0.75
0.25
0.75
0.10
0.45
SCF075-1210R
3.00
3.43
2.35
2.80
0.30
0.70
0.25
0.75
0.10
0.45
SCF075-24-1210R
3.00
3.43
2.35
2.80
0.80
1.20
0.25
0.75
0.10
0.45
SCF110-1210R
3.00
3.43
2.35
2.80
0.60
1.00
0.25
0.75
0.10
0.45
SCF150-1210R
3.00
3.43
2.35
2.80
0.50
0.90
0.25
0.75
0.10
0.45
SCF175-1210R
3.00
3.43
2.35
2.80
0.80
1.40
0.25
0.75
0.10
0.45
SCF200-1210R
3.00
3.43
2.35
2.80
0.80
1.40
0.25
0.75
0.10
0.45
www.socay.com
3/4
SCF1210 Series
Packaging
Part Number
Packaging Option
Quantity
SCF005-1210R
Tape & Reel -8mm/7″tape
3000
SCF010-1210R
3000
SCF020-1210R
3000
SCF035-1210R
4000
SCF050-1210R
4000
SCF075-1210R
4000
SCF075-24-1210R
3000
SCF110-1210R
3000
SCF150-1210R
3000
SCF175-1210R
3000
SCF200-1210R
3000
Tape and Reel Specifications
7.0
(177.8)
0.157
(4.0)
Packag
0.059 Diameter
(1.5)
0.314
(8.0)
0.212
(5.4)
0.512(13.0)
Arbor Hole Diameter
0.157
(4.0)
Cover tape
0.33
(8.4)
Direction of Feed
Dimensions are in inches
(and millimeters)
Warning
u
Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or
flame.
u
PPTC device are intended for occasional over-current protection. Application for repeated over-current condition and/or
prolonged trip are not anticipated.
u
Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance.
www.socay.com
4/4
很抱歉,暂时无法提供与“SCF005-1210R”相匹配的价格&库存,您可以联系我们找货
