Surface Mount Resettable PTCs
SCF1206 Series
Description
The SCF1206 Series PTC provides surface mount
over-current protection for applications where space is at a
premium and resettable protection is desired.
Features
u
u
u
u
u
RoHS compliant, Lead-Free and Halogen-Free
Fast time-to-trip
Compact design saves board space
Low resistance
Low-profile
Applications
u
u
u
u
u
u
u
u
PC motherboard - plug and play protection
Mobile phones - battery and port protection
Game console port protection
USB peripherals
Disk drive
PDAS / digital cameras
Power ports
General electronics
Electrical Parameters
Part Number
SCF005-1206R
SCF010-1206R
SCF012-1206R
SCF016-1206R
SCF020-1206R
SCF025-1206R
SCF025-24-1206R
SCF035-1206R
SCF035-30-1206R
SCF050-1206R
SCF050-24-1206R
SCF075-1206R
SCF075-16-1206R
SCF100-1206R
SCF110-1206R
SCF150-1206R
SCF200-1206R
Hold
Current
Trip
Current
I hold (A)
I trip
0.05
0.10
0.12
0.16
0.20
0.25
0.25
0.35
0.35
0.50
0.50
0.75
0.75
1.00
1.10
1.50
2.00
(A)
0.15
0.25
0.39
0.45
0.40
0.50
0.50
0.75
0.75
1.00
1.00
1.50
1.50
1.80
2.20
3.00
3.50
Rated
Voltage
Max
Current
Typical
Power
Maximum Time
To Trip
V max
(Vdc)
I max
(A)
P dtyp.
(W)
Current
(A)
Time
(Sec.)
R min
(Ω)
R 1max
(Ω)
60
60
48
48
30
16
24
16
30
8
24
8
16
6
8
8
6
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
0.4
0.4
0.6
0.6
0.4
0.6
0.6
0.4
0.6
0.4
0.6
0.6
0.6
0.6
0.8
0.8
0.8
0.25
0.50
1.00
1.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
8.00
1.50
1.00
0.20
0.30
0.10
0.08
0.08
0.10
0.10
0.10
0.10
0.20
0.20
0.30
0.30
1.00
1.50
3.600
1.600
1.400
1.100
0.600
0.550
0.550
0.300
0.300
0.150
0.150
0.090
0.090
0.055
0.040
0.040
0.018
50.000
15.000
6.500
5.000
2.500
2.300
2.300
1.200
1.200
0.700
0.750
0.290
0.290
0.210
0.180
0.120
0.080
Resistance
I hold= Hold current: maximum current device will pass without tripping in 23°C still air.
I trip= Trip current: minimum current at which the device will trip in 23°C still air.
V max= Maximum voltage device can withstand without damage at rated current (Imax)
I max= Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pdtyp.= Power dissipated from device when in the tripped state at 23°C still air.
R min= Minimum resistance of device in initial (un-soldered) state.
R 1max= Maximum resistance of device at 23°C measured one hour after tripping.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
SOCAY Electronics Co., Ltd.
Revision December 28, 2015
www.socay.com
1/4
@ SOCAY Electronics Co., Ltd. 2015
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
SCF1206 Series
Temperature Rerating Chart – I hold (A)
Temperature Derating Curve
5Average Time Current Curves
Ambient Temperature (°C)
Fault Current (A)
Z= SCF005-1206R
A= SCF010-1206R
B= SCF012-1206R
C= SCF020-1206R
D= SCF025-1206R
E= SCF025-1206R
/SCF025-24-1206R
F= SCF035-1206R
/SCF035-60-1206R
G= SCF050-1206R
/SCF050-24-1206R
H= SCF075-1206R
/SCF075-16-1206R
I= SCF100-1206R
J= SCF110-1206R
K= SCF150-1206R
L= SCF200-1206R
Material Specifications
Terminal pad material
Pure Tin
Soldering Characteristics
Meets EIA specification RS 186-9E, ANSI/J-std-002 Category 3
Soldering Parameters
TP
Ramp-up
Critical Zone
TL to TP
TS(max)
Temperature
Pb-Free Assembly
Average Ramp-Up Rate (TS max to TP)
3°C/second max.
Preheat :
Temperature Min (TSmin)
Temperature Max (TSmax)
Time (TSmin to TSmax)
Time maintained above:
Temperature(TL)
Time (TL)
TL
Ramp-down
TS(min)
Preheat
25
Time to peak temperature
(t 25℃ to peak)
Profile Feature
Time
150°C
200°C
60-180 seconds
217°C
60-150 seconds
Peak/Classification Temperature(TP):
260°C
Time within 5°C of actual peak:
Temperature
20-40 seconds
Ramp-down Rate:
6°C/ second max.
Time 25°C to Peak Temperature
8 minutes max.
Note: All temperatures refer to of the package, measured on the package body surface.
Solder reflow
Caution:
Due to “Lead Free” nature, Temperature and Dwelling time for the
soldering zone is higher than those for Regular. This may cause
damage to other components.
1. Recommended max past thickness > 0.25mm.
2. Devices can be cleaned using standard methods and aqueous
solvent.
3. Rework use standard industry practices.
4. Storage Environment : < 30℃/ 60%RH
1. If reflow temperatures exceed the recommended profile, devices
may not meet the performance requirements.
2. Devices are not designed to be wave soldered to the bottom side
of the board.
www.socay.com
2/4
SCF1206 Series
Part Marking
Part Numbering
F X
SCF XXX – XX – 1206R
FA
Part Identification
Logo
Device Size Code
Example
Rated Voltage
Hold Current
Socay Product Code
Pad Layouts
Unit: mm
The dimension in the table below provide the recommended
pad layout for each SCF1206 device
A
B
C
Nominal
Nominal
Nominal
2.00
1.00
1.90
Device
1206 Series
Dimensions
FZ= SCF005-1206R
FA= SCF010-1206R
FJ= SCF012-1206R
FK= SCF016-1206R
FB= SCF020-1206R
FL= SCF025-1206R
FP= SCF025-24-1206R
FC= SCF035-1206R
FM= SCF035-30-1206R
FD= SCF050-1206R
FN= SCF050-24-1206R
FE= SCF075-1206R
FO= SCF075-16-1206R
FF= SCF100-1206R
FG= SCF110-1206R
FH= SCF150-1206R
FI = SCF200-1206R
Unit: mm
Part Number
SCF005-1206R
SCF010-1206R
SCF012-1206R
SCF016-1206R
SCF020-1206R
SCF025-1206R
SCF025-24-1206R
SCF035-1206R
SCF035-30-1206R
SCF050-1206R
SCF050-24-1206R
SCF075-1206R
SCF075-16-1206R
SCF100-1206R
SCF110-1206R
SCF150-1206R
SCF200-1206R
A
Min.
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
3.00
B
Max.
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
3.50
Min.
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
1.50
C
Max.
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
Min.
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.30
0.90
0.25
0.80
0.45
0.45
0.45
0.45
0.80
0.85
D
Max.
0.85
0.85
0.85
0.75
0.75
0.75
0.75
0.75
1.30
0.55
1.20
1.25
1.25
1.00
1.00
1.40
1.60
Min.
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.25
0.10
0.25
0.25
0.25
0.25
0.25
0.25
0.25
E
Max.
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.75
Min.
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
Max.
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
www.socay.com
3/4
SCF1206 Series
Packaging
Part Number
Packaging Option
Quantity
SCF005-1206R
Tape & Reel -8mm/7″tape
3000
SCF010-1206R
3000
SCF012-1206R
3000
SCF016-1206R
3000
SCF020-1206R
3000
SCF025-1206R
3000
SCF025-24-1206R
3000
SCF035-1206R
4000
SCF035-30-1206R
3000
SCF050-1206R
4000
SCF050-24-1206R
3000
SCF075-1206R
3000
SCF075-16-1206R
3000
SCF100-1206R
3000
SCF110-1206R
3000
SCF150-1206R
2000
SCF200-1206R
2000
Tape and Reel Specifications
7.0
(177.8)
0.157
(4.0)
Diameter
0.314
(8.0)
0.212
(5.4)
0.157
(4.0)
Cover tape
0.33
(8.4)
Direction of Feed
Dimensions are in inches
(and millimeters)
Warning
u
Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or
flame.
u
PPTC device are intended for occasional over-current protection. Application for repeated over-current condition and/or
prolonged trip are not anticipated.
u
Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance.
www.socay.com
4/4
很抱歉,暂时无法提供与“SCF012-1206R”相匹配的价格&库存,您可以联系我们找货
