MB6M
MB6M
    MDD(辰达半导体)
    MBM
    Vr=600V IF=500mA VF=1V@400mA
MB6M 数据手册
MB2M THRU MB10M SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS Voltage Range - 200 to 1000 Volts Current - 0.5/0.8 Ampere FEATURES MBM Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique High temperature soldering guaranteed: 260 /10 seconds at 5 lbs., (2.3kg) tension Small size, simple installation High surge current capability C0.5 ~ + .031(0.8) .019(0.5) ~ - .165(4.2) .146(3.7) .051(1.3) .035(0.9) .014(.35) .006(.15) .106(2.7) .090(2.3) .256(6.5) .217(5.5) .193(4.9) .177(4.5) MECHANICAL DATA .106(2.7) .090(2.3) .217(5.5) .177(4.5) Case: Molded plastic body Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Polarity symbols marked on case Mounting Position: Any Weight:0.0044 ounce, 0.125 grams .031(0.8) .019(0.5) .106(2.7) .090(2.3) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load derate current by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TC=30 On glass-epoxy P.C.B. On aluminum substrate Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage drop per leg at 0.4A Maximum DC reverse current TA=25 at rated DC blocking voltage TA=125 Typical junction capactiance per leg(Note3) Typical thermal resistance per leg Operating temperature range storage temperature range SYMBOLS VRRM VRMS VDC IF(AV) MDD MB2M 200 140 200 MDD MB4M MDD MB6M MDD MB8M MDD MB10M UNITS 400 280 400 600 420 600 800 560 800 1000 700 1000 VOLTS VOLTS VOLTS 0.5 Amps 0.8 IFSM 30 Amps VF 1.0 Volts 5.0 500 15 75 -55 to +150 -55 to +150 uA uA IR CJ R JA TJ TSTG pF /W NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads 2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad 3.Measured at 1.0MHz and applied reverse voltage of 4.0 volts. AVERAGE FORWARD RECTIFIED CURRENT(A) FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT FOR 0.8 Aluminum Substrate 0.7 0.6 0.5 0.4 Glass Epoxy P.C.B. 0.3 0.2 0.1 PEAK FORWARD SURGE CURRENT.(A) RATINGS AND CHARACTERISTIC CURVES MB2M THRU MB10M FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 35 30 Ta=40 Single Half Sine-Wave (JEDEC Method) 25 f=60Hz 20 15 f=50Hz 10 5 1Cycle 0 0 20 40 60 80 100 120 140 160 0 1 10 AMBIENT TEMPERATURE,( ) 1 0.01 0.2 0.4 TJ=25 Pulse Width=300us 1% Duty Cycle 0.6 0.8 1.0 1.2 1.4 FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS PER LEG INSTANTANEOUS REVERSE LEAKAGE CURRENT.(uA) 10 100 TJ=125 10 1 0.1 TJ=25 1.6 0.01 0 20 FIG. 5-TYPICAL JUNCTION CAPACTITANE PER LEG 30 25 TJ=25 f=1.0MHZ Vsig=50mV p-p 20 15 10 5 0 0.1 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE(%) INSTANTANEOUS FORWARD VOLTAGE.(V) JUNCTION CAPACITANCE.(pF) INSTANTANEOUS FORWARD CURRENT(A) FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS PER LEG 0.1 100 NUMBER OF CYCLES 1 10 REVERSE VOLTAGE.(V) 100 200
很抱歉,暂时无法提供与“MB6M”相匹配的价格&库存,您可以联系我们找货
