MBR1045CT
MBR1045CT
    MDD(辰达半导体)
    TO-220AB
    肖特基二极管 VR=45V IF=10A VF=0.55V IR=1000uA
MBR1045CT 数据手册
MBR1020 THRU MBR10100 SCHOTTKY BARRIER RECTIFIER Reverse Voltage - 20 to 100 Volts FEATURES TO-220AC The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Construction utilizes void-free molded plastic technique Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250 C,0.25”(6.35mm) from case for 10 seconds 0.185(4.70) 0.175(4.44) 0.154(3.91) DIA 0.148(3.74) 0.415(10.54) MAX 0.057(1.45) 0.051(1.30) 0.113(2.87) 0.103(2.62) 0.145(3.68) 0.135(3.43) 0.410(10.41) 0.390(9.91) 1 PIN 0.635(16.13) 0.625(15.87) 0.560(14.2) 0.530(13.4) 0.350(8.89) 0.330(8.38) 2 1.148(29.16) 1.118(28.40) 0.160 (4.05) 0.140 (3.55) Forward Current -10.0 Amperes 0.110(2.79) 0.100(2.54) 0.590(14.22) 0.530(13.46) MECHANICAL DATA 0.037(0.94) 0.027(0.68) 0.105 (2.67) 0.095 (2.41) 0.205 (5.20) 0.195 (4.95) Case: TO-220AC molded plastic body Terminals: Leads solderable per MIL-STD-750, Method 2026 Polarity: As marked Mounting Position: Any Weight:0.064 ounce, 1.81 grams 0.022(0.58) 0.014(0.35) PIN 1 PIN 2 CASE Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current (see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 10.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range SYMBOLS VRRM VRMS VDC MBR MBR MBR MBR MBR MBR MBR MBR MBR MBR 1020 1030 1040 1045 1050 1060 1070 1080 1090 10100 20 14 20 30 21 30 45 32 45 50 35 50 60 42 60 70 49 70 80 56 80 90 63 90 100 70 100 VOLTS VOLTS VOLTS I(AV) 10.0 Amps IFSM 150.0 Amps VF IR CJ RθJC TJ TSTG Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to case 40 28 40 UNITS 0.65 0.85 0.75 1.0 15.0 50.0 450 550 3.0 -50 to +125 -50 to +150 -50 to +150 Volts mA pF C/W C C FIG. 1- FORWARD CURRENT DERATING CURVE 10 8 6 Single Phase Half Wave 60Hz Resistive or inductive Load 4 MBR1020-MBR1045 2 MBR1050-MBR10100 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES MBR1020 THRU MBR10100 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 150 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 125 100 75 50 175 25 1 10 AMBIENT TEMPERATURE, C INSTANTANEOUS FORWARD CURRENT,AMPERES 50 10 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.1 MBR1020-MBR1045 MBR1050-MBR1060 MBR1070-MBR10100 0.01 0.2 0.4 0.6 0.8 1.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 1 1.1 100 10 TJ=100 C 1 TJ=75 C 0.1 0.01 20 40 60 80 TJ=25 C 200 MBR1020-MBR1045 MBR1050-MBR10100 TRANSIENT THERMAL IMPEDANCE, C/W 4000 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 20 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF TJ=25 C 0.001 0 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 2000 100 NUMBER OF CYCLES AT 60 Hz 100 t,PULSE DURATION,sec. The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! 100
MBR1045CT 价格&库存
很抱歉,暂时无法提供与“MBR1045CT”相匹配的价格&库存,您可以联系我们找货
MBR1045CT
    • 30000+0.60610
    库存:2000000
    MBR1045CT
    • 10+0.88160
    • 50+0.81548
    • 200+0.76038
    • 600+0.70528
    • 1500+0.66120
    • 3000+0.63365
    库存:100
    MBR1045CT
    • 1+0.98000
    • 30+0.94500
    • 100+0.91000
    • 500+0.84000
    • 1000+0.80500
    • 2000+0.78400
    库存:50
