SMF11A
SMF11A
    MDD(辰达半导体)
    SOD123FL
    辰达行 SOD-123FL 200W 11V
SMF11A 数据手册
SMF5.0(C)A THRU SMF170(C)A TRANSIENT VOLTAGE SUPPRESSOR Standoff Voltage: 5.0-170 Volts Peak Pulse Power: 200 Watts SOD-123FL FEATURE 200W Peak Pulse Power Dissipation 5.0V - 170V Standoff Voltages Glass Passivated Die Construction Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Material: UL Flammability Classification Rating 94V-0 1.0 0.2 1.8 ± 0.1 Cathode Band Top View 1.0 ± 0.1 0.20 0.10 2.8±0.1 0.6 MECHANICAL DATA · · 0.25 · 3.7±0.2 · Dimensions in millimeters · · Case:JEDEC SOD-123FL molded plastic body Terminals: Solderable per MIL-STD-750, Method 2026 Polarity Indicator: Cathode Band (Note: Bi-directional devices have no polarity indicator.) Marking: Date Code and Marking Code See Page 3 Weight: 0.064 grams (approx.) Ordering Info: See Page 3 DEVICES FOR BIDIRECTIONAL APPLICATIONS For bidirectional use suffix A or CA for types SMF5.0A thru SMF170A (e.g. SMF5.0CA,SMF170CA) Electrical characteristics apply in both directions. Maximum Ratings @ TA = 25°C unless otherwise specified Characteristic Peak Pulse Power Dissipation (Non repetitive current pulse derated above TA = 25°C) (Note 1) Peak Forward Surge Current, 8.3ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Notes 1, 2, & 3) Steady State Power Dissipation @ TL = 75°C Instantaneous Forward Voltage (Notes 1, 2, & 3) Operating Temperature Range Storage Temperature Range Notes: @ IPP = 30A Symbol Value Unit PPK 200 W IFSM 30 A PM(AV) 1.0 W VF 3.5 V Tj -55 to +150 °C TSTG -55 to +175 °C 1. Valid provided that terminals are kept at ambient temperature. 2. Measured with 8.3ms single half sine-wave. Duty cycle = 4 pulses per minute maximum. 3. Unidirectional units only. TRANSIENT VOLTAGE SUPPRESSOR SMF5.0(C)A THRU SMF170(C)A Part Number Add C For Bi-Directional (Note 4) Reverse Standoff Voltage Breakdown Voltage VBR @ IT (Note 5) Test Current Max. Reverse Max. Clamping Leakage @ VRWM (Note 6) Voltage @ Ipp Max. Peak Pulse Current Ipp Marking Code VRWM (V) Min (V) Max (V) IT (mA) IR (mA) VC (V) (A) UNI- BI- SMF5.0(C)A 5.0 6.40 7.25 10 800 9.2 21.7 5.0A 5.0CA SMF6.0(C)A 6.0 6.67 7.37 10 800 10.3 19.4 6.0A 6.0CA SMF6.5(C)A 6.5 7.22 7.98 10 500 11.2 17.9 6.5A 6.5CA SMF7.0(C)A 7.0 7.78 8.60 10 200 12.0 16.7 7.0A 7.0CA SMF7.5(C)A 7.5 8.33 9.21 1.0 100 12.9 15.5 7.5A 7.5CA SMF8.0(C)A 8.0 8.89 9.83 1.0 50 13.6 14.7 8.0A 8.0CA SMF8.5(C)A 8.5 9.44 10.4 1.0 10 14.4 13.9 8.5A 8.5CA SMF9.0(C)A 9.0 10.0 11.1 1.0 5.0 15.4 13.0 9.0A 9.0CA SMF10(C)A 10 11.1 12.3 1.0 5.0 17.0 11.8 10A 10CA SMF11(C)A 11 12.2 13.5 1.0 5.0 18.2 11.0 11A 11CA SMF12(C)A 12 13.3 14.7 1.0 5.0 19.9 10.1 12A 12CA SMF13(C)A 13 14.4 15.9 1.0 5.0 21.5 9.3 13A 13CA SMF14(C)A 14 15.6 17.2 1.0 5.0 23.2 8.6 14A 14CA SMF15(C)A 15 16.7 18.5 1.0 5.0 24.4 8.2 15A 15CA SMF16(C)A 16 17.8 19.7 1.0 5.0 26.0 7.7 16A 16CA SMF17(C)A 17 18.9 20.9 1.0 5.0 27.6 7.2 17A 17CA SMF18(C)A 18 20.0 22.1 1.0 5.0 29.2 6.8 18A 18CA SMF20(C)A 20 22.2 24.5 1.0 5.0 32.4 6.2 20A 20CA SMF22(C)A 22 24.4 26.9 1.0 5.0 35.5 5.6 22A 22CA SMF24(C)A 24 26.7 29.5 1.0 5.0 38.9 5.1 24A 24CA SMF26(C)A 26 28.9 31.9 1.0 5.0 42.1 9.5 26A 26CA SMF28(C)A 28 31.1 34.4 1.0 5.0 45.4 8.8 28A 28CA SMF30(C)A 30 33.3 36.8 1.0 5.0 48.4 8.3 30A 30CA SMF33(C)A 33 36.7 40.6 1.0 5.0 53.3 7.5 33A 33CA SMF36(C)A 36 40.0 44.2 1.0 5.0 58.1 6.9 36A 36CA SMF40(C)A 40 44.4 49.1 1.0 5.0 64.5 6.2 40A 40CA SMF43(C)A 43 47.8 52.8 1.0 5.0 69.4 5.7 43A 43CA SMF45(C)A 45 50.0 55.3 1.0 5.0 72.7 5.5 45A 45CA SMF48(C)A 48 53.3 58.9 1.0 5.0 77.4 5.2 48A 48CA SMF51(C)A 51 56.7 62.7 1.0 5.0 82.4 4.9 51A 51CA SMF54(C)A 54 60.0 66.3 1.0 5.0 87.1 4.6 54A 54CA SMF58(C)A 58 64.4 71.2 1.0 5.0 93.6 4.3 58A 58CA SMF60(C)A 60 66.7 73.7 1.0 5.0 96.8 4.1 60A 60CA SMF64(C)A 64 71.1 78.6 1.0 5.0 103 3.9 64A 64CA SMF70(C)A 70 77.8 86.0 1.0 5.0 113 3.5 70A 70CA SMF75(C)A 75 83.3 92.1 1.0 5.0 121 3.3 75A 75CA SMF78(C)A 78 86.7 95.8 1.0 5.0 126 2.2 78A 78CA SMF85(C)A 85 94.4 104 1.0 5.0 137 2.9 85A 85CA SMF90(C)A 90 100 111 1.0 5.0 146 2.7 90A 90CA SMF100(C)A 100 111 123 1.0 5.0 162 2.5 100A 100CA SMF110(C)A 110 122 135 1.0 5.0 177 2.3 110A 110CA SMF120(C)A 120 133 147 1.0 5.0 193 2.0 120A 120CA SMF130(C)A 130 144 159 1.0 5.0 209 1.9 130A 130CA SMF150(C)A 150 167 185 1.0 5.0 243 1.6 150A 150CA SMF160(C)A 160 178 197 1.0 5.0 259 1.5 160A 160CA SMF170(C)A 170 189 209 1.0 5.0 275 1.4 170A 170CA Notes: 4. Suffix C denotes Bi-directional device. 5. VBR measured with IT current pulse = 300ms 6. For Bi-Directional devices having VRWM of 10V and under, the IR is doubled. TRANSIENT VOLTAGE SUPPRESSOR SMF5.0(C)A THRU SMF170(C)A 10000 100 CT , JUNCTION CAPACITANCE (pF) PEAK PULSE DERATING IN % OF PEAK POWER OR CURRENT Tj = 25°C 75 50 25 Unidirectional 1000 Bidirectional 100 10 X 1000 Waveform as defined by REA 0 10 0 25 50 75 10 1 100 125 150 175 200 TA, AMBIENT TEMPERATURE (°C) Fig. 1 Pulse Derating Curve 100 1000 VWM, STANDOFF VOLTAGE (V) Fig. 2 Typical Total Capacitance IP, PEAK PULSE CURRENT (%Ipp) Tj = 25°C Non Repetitive Pulse Waveform Shown in Fig. 4 10 1.0 100 Peak Value I pp Half Value I pp/2 50 tp 10 X 1000 Waveform as defined by R.E.A. 0 0.1 10 1.0 0.1 100 1000 0 10000 1 3 2 t, TIME (ms) Fig. 4 Pulse Waveform PM(AV), STEADY STATE POWER DISSIPATION (W) 60 PEAK FORWARD SURGE CURRENT, (A) Pd, PEAK PULSE POWER (kW) 100 Pulse Width 8.3ms Single Half-Sine-Wave (JEDEC METHOD) 50 40 30 20 10 0 1 2 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz Fig. 5 Maximum Non-Repetitive Surge Current 1.0 0.8 0.6 0.4 60Hz Resistive or Inductive Load 0.2 0.0 0 25 50 75 100 125 150 175 TL, LEAD TEMPERATURE (°C) Fig. 6 Steady State Power Derating Curve 200
SMF11A 价格&库存
很抱歉,暂时无法提供与“SMF11A”相匹配的价格&库存,您可以联系我们找货
SMF11A
  • 45000+0.07810
