ME1117A12B3G
ME1117A12B3G
    MICRONE(南京微盟)
    SOT-223
    VIN=20V Vo=1.2V Io=100mA Pd=750mW
ME1117A12B3G 数据手册
ME1117 1.0A Adjustable Voltage High Speed LDO Regulators ME1117 Series General Description Features ME1117 series are highly accurate, low noise, LDO Voltage Regulators that are capable of providing an output current that is in excess of 1.0 A with a maximum dropout voltage of 1.3 V at 1.0A. This series contains six fixed output voltages of 1.2 V, 1.5V,1.8 V, 2.5 V, 3.3 V, and 5.0 V that have no minimum load requirement to maintain regulation. Also included is an adjustable output version that can be programmed from 1.25 V to 20 V with two external resistors. On chip trimming adjusts the reference/output voltage to within ±2.0% accuracy. Internal protection features consist of output current Selection Guide area compensation, and limiting, safe operating thermal shutdown. The ME1117 series can operate with up to 20 V input. Typical Application         Output Current in Excess of 1.0A Dropout Voltage:1.07V@ IOUT =100mA Operating Voltage Range: 4.8V~20V(ME1117A33) Highly Accuracy: ±2% Adjustable Output Voltage Option Standby Current:3mA(TPY.) High Ripple Rejection:60dB@1KHz(ME1117A33) Line Regulation: 0.1%(TYP.) Temperature Stability≤0.5% Current Limit(1.3A) Thermal Shutdown Protection(160℃) Package   Consumer and Industrial Equipment Point of Regulation Switching Power Supply Post Regulation Hard Drive Controllers  Battery Chargers      3-pin SOT223、、TO-252-2L Typical Application Circuit V09 www.microne.com.cn Page 1 of 14 ME1117 Selection Guide ME 1117X X X X X G Environment mark Package: B3:SOT223 K3:TO-252-2L Output Voltage Function Product Type Product Series Microne product series ME1117A15B3G VOUT =1.5V; Package:SOT223 ME1117A18B3G VOUT =1.8V; Package:SOT223 ME1117A25B3G VOUT =2.5V; Package:SOT223 ME1117A33B3G VOUT =3.3V; Package:SOT223 ME1117A50B3G VOUT =3.3V; Package:SOT223 ME1117A33K3G VOUT =3.3V; Package:TO-252-2L ME1117A50K3G VOUT =3.3V; Package: TO-252-2L ME1117FB3G NOTE: V09 product description VFB =1.25V; Package:SOT223 At present ,there are six kinds of voltage value:1.25V(VFB)、 1.5V、1.8V、2.5V、3.3V、 5.0V。If you need other voltage and package, please contact our sales staff。 www.microne.com.cn Page 2 of 14 ME1117 Pin Configuration SOT223 TO252-2L Pin Assignment ME1117A Pin Number Pin Name Functions 1 VSS Ground 2 VOUT Output 3 VIN Power Input Pin Number Pin Name Functions 1 VADJ Adjustable Output 2 VOUT Output 3 VIN Power Input ME1117F Absolute Maximum Ratings Parameter Symbol Ratings Units Input Voltage VIN 20 V Output Current IOUT 1.3 A Output Voltage VOUT Vss-0.3~VIN +0.3 V 750 mW 2000 mW Power Dissipation SOT223 TO252-2L PD Operating Temperature Range TOPR -40~+125 ℃ Storage Temperature Range TSTG -40~+150 ℃ Junction Temperature Range TJ 0~+150 ℃ Lead Temperature Thermal Resistance Junction-to-Case Thermal Resistance Junction-to-Ambient (No heat sink; No air flow) V09 SOT223 260℃,4sec TO252-2L 260℃,10sec SOT223 15 °C/W TO252-2L 10 °C/W SOT223 136 °C/W TO252-2L 92 °C/W www.microne.com.cn Page 3 of 14 ME1117 Block Diagram Electrical Characteristics ME1117F (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC ,unless otherwise noted) Parameter Symbol Conditions VIN= VOUT+1.5V,IOUT =10mA 10mA≤IOUT≤1A , VOUT+1.5V ≤VIN≤20V Min. Typ. Max. Units ×0.98 ×0.98 1.25 1.25 ×1.02 ×1.02 V Reference Voltage VREF Maximum Output Current IOUTMAX VIN= VOUT+1.5V 1000 mA Minimum Output Current IOUTMIN VIN= VOUT+1.5V 2 mA Line Regulation ∆ VREF-LINE IOUT =10mA VOUT+1.5V ≤VIN≤20V Load Regulation ∆VREF-LOAD Adjustment Pin Current IADJ 0.03 0.2 % VIN= VOUT+1.5V ,0mA≤IOUT≤1A 9 13 mV VIN= VOUT+1.5V 12 30 uA Adjust Pin Current Change 10mA≤ IOUT≤ 1A, 1.5V ≤ VIN-VOUT ≤ 20V 0.2 5 uA Thermal Shutdown Junction Temperature 150 V09 www.microne.com.cn ℃ Page 4 of 14 ME1117 ME1117A12 (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC ,unless otherwise noted) Parameter Symbol Output Voltage VOUT Maximum Output Current IOUTMAX Load Regulation ∆VOUT-LOAD Dropout Voltage (Note 1) IOUT=10mA,VIN= VOUT+1.5V 10mA≤IOUT≤1A, VOUT+1.5V ≤VIN≤20V Min. Typ. Max. Units ×0.98 ×0.98 1.2 1.2 ×1.02 ×1.02 V VIN= VOUT+1.5V 1000 VIN= VOUT+1.5V , 0mA≤IOUT≤1A mA 9 15 mV VDIF1 IOUT =100mA 1.05 1.10 V VDIF2 IOUT =500mA 1.20 1.30 V VDIF3 IOUT =1A 1.30 1.40 V VIN= VOUT+1.5V 3.3 8 mA 1 6 mV Quiescent Current ISS Line Regulation ∆VOUT-LINE Ripple Rejection Rate PSRR Thermal Shutdown Conditions TJ IOUT =10mA, VOUT+1.5V ≤VIN≤20V VIN = 12V +1Vp-pAC IOUT=10mA,1kHZ 65 IOUT=100mA,1kHZ 60 Junction Temperature dB 150 ℃ ME1117A15 (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC ,unless otherwise noted) Parameter Symbol Output Voltage VOUT Maximum Output Current IOUTMAX Load Regulation ∆VOUT-LOAD Dropout Voltage (Note 1) Max. Units ×0.98 ×0.98 1.5 1.5 ×1.02 ×1.02 V 1000 VIN= VOUT+1.5V , 0mA≤IOUT≤1A mA 12 16 mV 1.05 1.10 V VDIF2 IOUT =500mA 1.20 1.30 V VDIF3 IOUT =1A 1.30 1.40 V VIN= VOUT+1.5V 3.3 8 mA 1 6 mV Line Regulation ∆VOUT-LINE V09 VIN= VOUT+1.5V Typ. IOUT =100mA ISS Thermal Shutdown IOUT=10mA,VIN= VOUT+1.5V 10mA≤IOUT≤1A, VOUT+1.5V ≤VIN≤20V Min. VDIF1 Quiescent Current Ripple Rejection Rate Conditions PSRR TJ IOUT =10mA, VOUT+1.5V ≤VIN≤20V VIN = 12V +1Vp-pAC IOUT=10mA,1k HZ 65 IOUT=100mA,1 kHZ 60 Junction Temperature www.microne.com.cn dB 150 ℃ Page 5 of 14 ME1117 ME1117A18 (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC ,unless otherwise noted) Parameter Symbol Output Voltage VOUT Maximum Output Current IOUTMAX Load Regulation ∆VOUT-LOAD Dropout Voltage (Note 1) Conditions IOUT=10mA,VIN= VOUT+1.5V 10mA≤IOUT≤1A, VOUT+1.5V ≤VIN≤20V Min. Typ. Max. Units ×0.98 ×0.98 1.8 1.8 ×1.02 ×1.02 V VIN= VOUT+1.5V 1000 VIN= VOUT+1.5V , 0mA≤IOUT≤1A mA 13 18 mV VDIF1 IOUT =100mA 1.05 1.10 V VDIF2 IOUT =500mA 1.20 1.30 V VDIF3 IOUT =1A 1.30 1.40 V VIN= VOUT+1.5V 3.5 8 mA 1 6 mV Quiescent Current ISS Line Regulation ∆VOUT-LINE Ripple Rejection Rate PSRR Thermal Shutdown IOUT =10mA, VOUT+1.5V ≤VIN≤20V VIN = 12V +1Vp-pAC IOUT=10mA,1kHZ 65 IOUT=100mA,1kHZ 60 Junction Temperature dB 150 ℃ ME1117A25 (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Output Voltage VOUT Maximum Output Current IOUTMAX Load Regulation ∆VOUT-LOAD Dropout Voltage (Note 1) VIN= VOUT+1.5V VIN=VOUT+1.5V 0mA≤IOUT≤1000mA Typ. Max. Units ×0.98 ×0.98 2.5 2.5 ×1.02 ×1.02 V 1000 , mA 17 25 mV IOUT =100mA 1.05 1.10 V VDIF2 IOUT =800mA 1.20 1.30 V VDIF3 IOUT =1A 1.30 1.40 V VIN= VOUT+1.5V 3.5 8 mA 2 6 mV ISS Line Regulation ∆VOUT-LINE Ripple Rejection Rate PSRR V09 IOUT=10mA,VIN= VOUT+1.5V 10mA≤IOUT≤1A, VOUT+1.5V ≤VIN≤20V Min. VDIF1 Quiescent Current Thermal Shutdown Conditions IOUT =10mA, VOUT+1.5V ≤VIN≤20V VIN = 12V +1Vp-pAC IOUT=10mA,1kHZ 65 IOUT=100mA,1kHZ 60 Junction Temperature www.microne.com.cn dB 150 ℃ Page 6 of 14 ME1117 ME1117A33 (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Output Voltage VOUT Maximum Output Current IOUTMAX Load Regulation ∆VOUT-LOAD Dropout Voltage (Note 1) Conditions IOUT=10mA,VIN= VOUT+1.5V 10mA≤IOUT≤1A, VOUT+1.5V ≤VIN≤20V Min. Typ. Max. Units ×0.98 ×0.98 3.3 3.3 ×1.02 ×1.02 V VIN= VOUT+1.5V 1000 VIN= VOUT+1.5V , 0mA≤IOUT≤1A mA 24 33 mV VDIF1 IOUT =100mA 1.07 1.10 V VDIF2 IOUT =800mA 1.20 1.30 V VDIF3 IOUT =1A 1.30 1.40 V VIN= VOUT+1.5V 3.5 8 mA 2 6 mV Quiescent Current ISS Line Regulation ∆VOUT-LINE Ripple Rejection Rate PSRR Thermal Shutdown IOUT =10mA, VOUT+1.5V ≤VIN≤20V VIN = 12V +1Vp-pAC IOUT=10mA,1kHZ 65 IOUT=100mA,1kHZ 60 Junction Temperature dB 150 ℃ ME1117A50 (VIN= VOUT+1.5V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Output Voltage VOUT Maximum Output Current IOUTMAX Load Regulation ∆VOUT-LOAD Dropout Voltage (Note 1) Quiescent Current IOUT=10mA,VIN= VOUT+1.5V 10mA≤IOUT≤1A, VOUT+1.5V ≤VIN≤20V VIN= VOUT+1.5V VIN= VOUT+1.5V , 0mA≤IOUT≤1A Min. Typ. Max. Units ×0.98 ×0.98 5.0 5.0 ×1.02 ×1.02 V 1000 mA 35 50 mV VDIF1 IOUT =100mA 1.05 1.10 V VDIF2 IOUT =800mA 1.20 1.30 V VDIF3 IOUT =1A 1.30 1.40 V VIN= VOUT+1.5V 3.8 8 mA 2 10 mV ISS Line Regulation ∆VOUT-LINE Ripple Rejection Rate PSRR Thermal Shutdown Conditions IOUT =10mA VOUT+1.5V ≤VIN≤20V VIN = 12V +1Vp-pAC IOUT=10mA,1kHZ 65 IOUT=100mA,1kHZ 60 Junction Temperature dB 150 ℃ Note :1 .VDIF:VIN1 –VOUT (E)’ VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased. VOUT (E)’=A voltage equal to 99% of the output voltage whenever an amply stabilized Iout and {V OUT (T)+1.5V} is input. V09 www.microne.com.cn Page 7 of 14 ME1117 Type Characteristics (1) Output Voltage VS. Output Current (VIN=VOUT+1.5V) (2) Output Voltage VS. Input Voltage (Vout=3.3V , IOUT=10mA) ME1117A33 ME1117A33 Output Voltage VS.Output Current Output Voltage VS.Input Voltage(Vout=3.3V,Iout=10mA) 3.350 Output Voltage(V) Output Voltage(V) 3.45 3.35 3.25 3.15 T=25℃ 3.05 T=75℃ 2.95 2.85 3.300 3.250 T=25℃ T=75℃ 3.200 3.150 0 200 400 600 800 1000 4 6 8 10 Output Current (mA) 16 18 20 (4)Load Regulation VS.Temp(Iout from 10mA to 1A) ME1117A33 ME1117A33 Dropout Voltage VS.Output Current Load Regulation VS.Temp(Iout from 10mA to 1A) 1.00 1.8 1.5 △ Vout/Vout*100% Dropout Voltage(V) 14 Input Voltage(V) (3) Dropout Voltage VS. Output Current 1.2 0.9 0.6 T=25℃ 0.3 T=75℃ 0 0 200 400 600 800 0.50 0.00 -0.50 -1.00 1000 -40 -25 0 Output Current(mA) 25 50 75 100 125 Temperature(℃) (5)Output Voltage VS. Temperature (6)Output Voltage Change VS. Temperature ME1117A33 ME1117A33 Output Voltage VS.Temperature Output Voltage (Vout=3.3V)VS. Temperature 4.0 1.50 3.5 1.00 △ Vout/Vout*100% Output Voltage(V) 12 3.0 2.5 2.0 1.5 1.0 0.50 0.00 -0.50 -1.00 -1.50 -2.00 0.5 -40 -25 0 25 50 75 100 125 150 -25 0 25 50 75 100 125 Temperature(℃) Temperature(℃) V09 -40 www.microne.com.cn Page 8 of 14 150 ME1117 (7)Adj Pin Current VS.Temperature (8)Ripple Rejection vs. Frequency ME1117F ME1117A33 Adj Pin Current VS.Temperature Ripple Rejection VS. Frequency Ripple Rejection (dB) Adj Pin Current(uA) 24 18 12 6 70 60 50 40 30 20 0 -40 -25 0 25 50 75 100 125 150 10 1000 10000 100000 Frequency(Hz) Temperature(℃) (9)Line Transient Response ME1117A33 Ch1:Output Voltage Ch3:Input Voltage VIN=8V~12V,IOUT=0mA,Ta = 25 °C V09 100 (10)Load Transient Response ME1117A33 Ch1:Output Voltage Ch2:Load Current VIN=4.8V, IOUT=0mA ~240mA,Ta = 25 °C www.microne.com.cn Page 9 of 14 ME1117 Applications Information  Introduction The ME1117 features a significant reduction in dropout voltage along with enhanced output voltage accuracy and temperature stability when compared to older industry standard three−terminal adjustable regulators.  Output Voltage The typical application circuit for adjustable output regulator is shown in following Figure. They develop and maintain the nominal 1.25 V reference voltage between the output and adjust pins. The reference voltage is programmed to a constant current source by resistor R1, and this current flows through R2 to ground to set the output voltage. The programmed current level is usually selected to be greater than the specified 3.0mA minimum that is required for regulation. Since the adjust pin current, IADJ, is significantly lower and constant with respect to the programmed load current, it generates a small output voltage error that can usually be ignored. stability and transient response with the additional benefit of reducing output noise. The output ripple will increase linearly for fixed and adjustable devices as the ratio of output voltage to the reference voltage increases.  Protection Diodes The ME1117 has two internal low impedance diode paths that normally do not require protection when used in the typical regulator applications. The first path connects between VOUT and VIN , and it can withstand a peak surge current of about 15 A. Only when VIN is shorted to ground and COUT is greater than 100uF, it becomes possible for device damage to occur. Under these conditions, diode D1 is required to protect the device. The second path connects between CADJ and VOUT, and it can withstand a peak surge current of about 150mA. Protection diode D2 is required if the output is shorted to ground and CADJ is greater than 10uF.  External Capacitors Input bypass capacitor CIN may be required for regulator stability. This capacitor will reduce the circuit’s sensitivity when powered from a complex source. A 10uF ceramic or tantalum capacitor should be adequate for most applications. Frequency compensation for the regulator is provided by capacitor COUT and its use is mandatory to ensure output stability. A minimum capacitance value of 4.7uF with an equivalent series resistance (ESR) that is within the limits of 0.25 ohm to 2.2 ohm is required. Higher values of output capacitance can be used to enhance loop V09  Thermal Considerations This series contains an internal thermal limiting circuit that is designed to protect the regulator in the event that the maximum junction temperature is exceeded. When activated, typically at 175°C, the regulator output switches off and then back on as the die cools. www.microne.com.cn Page 10 of 14 ME1117 Other Application Circuit (1) Constant Current Regulator (2)Slow Turn−On Regulator (3)Regulator with Shutdown (4)Digitally Controlled Regulator Resistor R2 sets the maximum output voltage. Each transistor reduces the output voltage when turned on. (5)Battery Backed−Up Power Supply (6)Adjusting Output of Fixed Voltage Regulators The 50 ohm resistor that is in series with the ground pin of the upper regulator level shifts its output 300 mV higher than the lower regulator. This keeps the lower regulator off until the input source is removed. V09 www.microne.com.cn Page 11 of 14 ME1117 Packaging Information ● SOT223 V09 www.microne.com.cn Page 12 of 14 ME1117 ● TO252-2L V09 www.microne.com.cn Page 13 of 14 ME1117      The information described herein is subject to change without notice. Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. V09 www.microne.com.cn Page 14 of 14
ME1117A12B3G 价格&库存
很抱歉,暂时无法提供与“ME1117A12B3G”相匹配的价格&库存,您可以联系我们找货
