BZT52C2V4-BZT52C43
东莞市通科电子有限公司
DongGuan Tongke Electronic Co.,LTD
SOD- 123 Plastic-Encapsulate Diodes
Features
ZENER DIODE
SOD-123
z
Planar Die Construction
z
500mW Pow er Dissipation on Ceramic PCB
z
General Purpose, Medium Current
z
Ideally Suited for Automated Assembly Processes
z
Available in Lead Free Version
Maximum Ratings(Ta=25℃ unless otherwise specified)
Characteristic
Forward Voltage (Note 2)
Symbol
Value
Unit
VF
0.9
V
PD
500
mW
@ IF = 10mA
Power Dissipation(Note 1)
Thermal Resistance from Junction to Ambient
RθJA
357
Junction Temperature
TJ
150
℃ /W
Storage Temperature
TSTG
-55~+150
BZT52C2V4-BZT52C43
1
www.tongke888.com
400-6922-883
BZT52C2V4-BZT52C43
东莞市通科电子有限公司
ELECTRICAL CHARACTERISTICS
Type
Type
Number
Code
Zener Voltage Range (Note 2)
Maximum
Typical
Maximum Zener Impedance
Reverse
Temperature
(Note 3)
Current
Coefficent
@IZTC
(Note 2)
VZ@IZT
IZT
Nom(V)
Min(V)
Max(V)
mA
ZZT@IZT
ZZK@IZK
Ω
Test
Current
IZTC
IZK
IR
VR
mV/°C
mA
uA
V
Min
Max
mA
BZT52C2V4
WX
2.4
2.20
2.60
5
100
600
1.0
50
1.0
-3.5
BZT52C2V7
W1
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZT52C3V0
W2
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZT52C3V3
W3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZT52C3V6
W4
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZT52C3V9
W5
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZT52C4V3
W6
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7
W7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1
W8
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6
W9
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2
WA
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
BZT52C6V8
WB
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5
WC
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2
WD
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1
WE
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10
WF
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11
WG
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12
WH
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13
WI
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
BZT52C15
WJ
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
BZT52C16
WK
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
BZT52C18
WL
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
BZT52C20
WM
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
BZT52C22
WN
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
BZT52C24
WO
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
BZT52C27
WP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30
WQ
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
BZT52C33
WR
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36
WS
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39
WT
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
BZT52C43
WU
43
40.0
46.0
5
100
700
1.0
0.1
32
10.0
12.0
5
Notes:
1. Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm
2
2. Short duration test pulse used to minimize self-heating effect
3. f=1kHZ
BZT52C2V4-BZT52C43
2
www.tongke888.com
400-6922-883
BZT52C2V4-BZT52C43
东莞市通科电子有限公司
Features
Breakdown characteristics
at Tj=constant (pulsed)
Forward characteristics
BZT52C2V4-BZT52C43
Admissible power dissipation versus ambient temperature
3
www.tongke888.com
400-6922-883
BZT52C2V4-BZT52C43
东莞市通科电子有限公司
Features
Pulse thermal resistance versus pulse duration
Dynamic resistance versus Zener current
Capacitance versus Zener voltage
Thermal differential resistance versus Zener voltage
BZT52C2V4-BZT52C43
4
www.tongke888.com
400-6922-883
东莞市通科电子有限公司
BZT52C2V4-BZT52C43
Features
Dynamic resistance versus Zener voltage
Temperature dependence of Zener voltage versus Zener voltage
Change of Zener voltage versus junction temperature
Change of Zener voltge from turn-on up to the point of thermal
equilibrium versus Zener voltage
BZT52C2V4-BZT52C43
5
www.tongke888.com
400-6922-883
BZT52C2V4-BZT52C43
东莞市通科电子有限公司
Features
SOD-123 Package Outline Dimensions
Dimensions In Millimeters
Max
Min
1.050
1.250
0.000
0.100
1.050
1.150
0.450
0.650
0.080
0.150
1.500
1.700
2.600
2.800
3.550
3.850
0.500 REF
0.250
0.450
0°
8°
Symbol
A
A1
A2
b
c
D
E
E1
L
L1
θ
BZT52C2V4-BZT52C43
6
Dimensions In Inches
Min
Max
0.041
0.049
0.000
0.004
0.041
0.045
0.018
0.026
0.003
0.006
0.059
0.067
0.102
0.110
0.140
0.152
0.020 REF
0.010
0.018
0°
8°
www.tongke888.com
400-6922-883
很抱歉,暂时无法提供与“BZT52C10”相匹配的价格&库存,您可以联系我们找货
