TLC500VS470M35*60_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS
TLC(LXG) Series
•1 0 5 ℃ 5 , 0 0 0 H r s a s s u r e d .
•Non-solvent proof.
•Long Life.
•For SMPS, Inverter.
•RoHS compliant.
•Halogen-free capacitors are also available.
TLC
TLA
(LXG)
High Reliability
Long Life
SPECIFICATIONS
ltem
Characteristics
Rated Voltage Range
Operating Temperature Range
10 ~ 100 VDC
200 ~ 500 VDC
-40 ~ +105℃
-25 ~ +105℃
Capacitance Tolerance
±20%(M)
Leakage Current
I=0.02CV or 3mA, whichever is smaller.
Where, I: Leakage current (㎂) C: Nominal capacitance (㎌) V: Rated voltage (VDC)
(at 20℃, 5 minutes)
※ Dissipation Factor(Tan δ)
Temperature Characteristics
(Max.Impedance ratio)
Rated Voltage(VDC)
Tanδ(Max.)
(at 20℃, 120Hz)
10
0.60
16
0.45
25
0.30
35
0.25
50
0.20
Rated Voltage(VDC)
Z(-25℃)/Z(20℃)
10~16
25
35
50~63
80~100
4
3
3
2
2
Z(-40℃)/Z(20℃)
15
10
8
6
5
63~400 420~500
0.15
0.20
(at 20℃,120Hz)
200~400 420~500
8
4
(at 120Hz)
Load Life
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the
rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the
rated voltage) for 5,000 hours at 105℃.
Capacitance change ≦ ±25% of the initial value
Tanδ
≦ 250% of the initial specified value
Leakage current
≦ The initial specified value
Shelf Life
exposing them at 105℃ for 1,000 hours without voltage applied.
The rated voltage shall be applied to the capacitors for a minimum of 30 minutes,
at least 24 hours and not more than 48 hours before the measurements.
Capacitance change ≦ ±20% of the initial value
Tanδ
≦ 150% of the initial specified value
Leakage current
Others
Satisfied characteristics KS C IEC 60384-4
※ For capacitors with CV products 100,000 higher Tanδvalue may apply.
When the capacitance exceeds 1,000㎌ , 0.01 shall be added every 1,000㎌ increase.
DIMENSIONS OF TLC(LXG) Series
RATED RIPPLE CURRENT
When capacitors are operated in any other conditions
at 120Hz the maximum ripple current must be
multiplied by the figure shown in the table.
ØD=Ø22~Ø35
VN/VS type
PC board pin-out
Frequency multiplying factor
Freq.(Hz)
VDC
1 0 ~ 5 0 V DC
60
0.95
120
1.00
300
1.03
1k
1.05
10k~
1.08
6 3 ~ 1 0 0 V DC
0.92
1.00
1.07
1.13
1.19
2 0 0 ~ 2 5 0 V DC
3 5 0 ~ 5 0 0 V DC
0.81
0.77
1.00
1.00
1.17
1.16
1.32
1.30
1.45
1.41
228
Unit(mm)
Marking : BROWN SLEEVE, SILVER INK
The standard design has no bottom plate.
RATINGS OF TLC(LXG) Series
VDC
ØD
10
22
25.4
16
30
35
22
25
25.4
30
35
22×25
1.31
22×30
1.51
22×35
1.70
22×40
1.92
22×45
2.05
22×50
2.45
3,900
4,700
22×25
1.44
22×30
1.66
22×35
1.87
22×40
2.12
22×45
2.32
22×50
2.74
5,600
6,800
8,200
10,000
12,000
15,000
18,000
22×25
1.30
22×30
1.49
22×30
1.65
22×35
1.85
22×40
2.12
22×50
2.45
22,000
27,000
25.4×25
1.64
25.4×30
1.85
25.4×35
2.16
25.4×40
2.43
25.4×45
2.62
25.4×50
3.11
33,000
39,000
30×25
1.89
30×25
2.06
30×30
2.37
30×35
2.73
30×40
3.13
30×45
3.34
30×50
3.99
47,000
VDC
ØD
35×25
2.42
35×30
2.79
35×30
3.00
35×35
3.49
35×40
3.96
35×50
4.62
25.4×25
1.66
25.4×30
1.87
25.4×30
2.07
25.4×35
2.37
25.4×40
2.71
25.4×50
3.11
35
22
25.4
30×25
2.11
30×30
2.37
30×30
2.58
30×35
3.02
30×40
3.46
30×50
4.07
35×25
2.42
35×25
2.63
35×30
3.09
35×35
3.49
35×40
4.04
35×45
4.29
35×50
5.16
30
35
22
25.4
22×25
1.02
22×30
1.17
22×35
1.33
22×40
1.51
22×45
1.68
22×50
1.91
1,500
1,800
2,700
3,300
3,900
4,700
5,600
6,800
8,200
12,000
18,000
25.4×25
1.51
25.4×30
1.69
25.4×30
1.87
25.4×35
2.14
25.4×40
2.43
25.4×50
2.78
30×25
1.77
30×30
1.98
30×30
2.14
30×35
2.50
30×40
2.86
30×50
3.32
35×25
2.03
35×25
2.20
35×30
2.55
35×35
2.88
35×40
3.30
35×50
4.29
30×25
1.90
30×30
2.15
30×30
2.31
30×35
2.70
30×40
3.13
30×50
3.64
35
35×25
2.19
35×25
2.35
35×30
2.76
35×35
3.16
35×40
3.61
35×45
4.00
35×50
4.70
30
35
30×25
1.50
30×30
1.70
30×30
1.84
30×35
2.11
30×40
2.39
30×50
2.79
22
22×25
1.00
22×30
1.15
22×35
1.32
22×40
1.49
22×45
1.63
22×50
1.92
35×25
1.74
35×25
1.89
35×30
2.16
35×35
2.41
35×40
2.78
35×45
3.06
35×50
3.57
25.4
25.4×25
1.15
25.4×25
1.28
25.4×30
1.45
25.4×35
1.67
25.4×40
1.90
25.4×50
2.20
30
30×25
1.48
30×30
1.68
30×35
1.93
30×35
2.07
30×40
2.41
30×50
2.80
35
35×25
1.71
35×25
1.83
35×30
2.18
35×35
2.43
35×40
2.78
35×45
3.04
35×50
3.55
TLC(LXG)
10,000
25.4×25
1.41
25.4×30
1.58
25.4×30
1.70
25.4×35
1.98
25.4×40
2.24
25.4×50
2.57
25.4×25
1.17
25.4×30
1.32
25.4×30
1.47
25.4×35
1.70
25.4×40
1.89
25.4×45
2.05
25.4×50
2.38
30
63
1,200
22×25
1.10
22×25
1.21
22×30
1.42
22×35
1.58
22×40
1.78
22×45
1.96
22×50
2.26
25.4
50
1,000
2,200
22
Case Size ØD×L(mm)
Rated Ripple Current(Arms/105℃, 120Hz)
Series
229
VDC
ØD
80
22
25.4
100
30
35
22
25.4
200
30
35
180
270
330
22×25
0.78
22×25
0.85
22×30
0.99
22×35
1.12
22×40
1.26
22×45
1.39
22×50
1.60
390
470
560
680
820
1,000
1,200
1,500
1,800
22×25
0.97
22×30
1.12
22×35
1.27
22×40
1.42
22×45
1.60
22×50
1.84
2,200
25.4×25
1.23
25.4×30
1.39
25.4×35
1.62
25.4×40
1.82
25.4×50
2.11
2,700
3,300
30×25
1.41
30×25
1.57
30×30
1.78
30×35
2.05
30×40
2.35
30×50
2.75
4,700
VDC
ØD
25.4×25
0.98
25.4×25
1.08
25.4×30
1.23
25.4×35
1.41
25.4×40
1.59
25.4×50
1.86
35×25
1.82
35×30
2.09
35×35
2.37
35×40
2.73
35×50
3.46
250
22
25.4
30×25
1.25
30×30
1.42
30×35
1.61
30×40
1.87
30×45
2.07
30×50
2.40
35
22
25.4
22×25
0.49
22×30
0.61
22×35
0.65
22×40
0.70
22×45
0.79
22×50
0.91
82
100
120
180
220
270
330
390
470
560
680
1,000
230
25.4×25
0.83
25.4×25
0.91
25.4×30
1.04
25.4×35
1.20
25.4×40
1.34
25.4×50
1.53
30×25
1.06
30×30
1.20
30×30
1.30
30×35
1.49
30×40
1.69
30×50
1.98
35×25
1.28
35×25
1.38
35×30
1.53
35×35
1.70
35×40
1.96
35×50
2.53
25.4×25
0.64
25.4×30
0.69
25.4×35
0.75
25.4×40
0.90
25.4×50
1.16
30
25.4×25
1.01
25.4×30
1.15
25.4×30
1.25
25.4×35
1.44
25.4×40
1.60
25.4×50
1.85
350
30
68
22×25
0.71
22×30
0.83
22×35
0.94
22×40
1.06
22×45
1.15
22×50
1.35
25.4
35×25
1.45
35×25
1.58
35×30
1.85
35×35
2.07
35×40
2.39
35×50
2.81
30×25
1.18
30×25
1.28
30×30
1.44
30×35
1.63
30×40
1.86
30×45
2.04
30×50
2.39
35
35×25
1.53
35×25
1.66
35×30
1.84
35×35
2.06
35×40
2.38
35×50
2.76
400
30
35
56
150
22
22×25
0.79
22×30
1.01
22×35
1.15
22×40
1.28
22×50
1.46
30×25
0.70
30×25
0.78
30×30
0.89
30×35
1.03
30×40
1.18
30×50
1.49
35×25
0.86
35×25
0.94
35×30
1.04
35×35
1.30
35×40
1.49
35×45
1.54
35×50
1.73
Case Size ØD×L (mm)
Rated Ripple Current (Arms/105℃, 120Hz)
22
22×25
0.47
22×30
0.57
22×35
0.65
22×35
0.71
22×40
0.81
22×50
0.92
25.4
25.4×25
0.53
25.4×25
0.58
25.4×30
0.71
25.4×35
0.81
25.4×40
0.90
25.4×45
1.03
25.4×50
1.16
30
30×25
0.71
30×25
0.80
30×30
0.92
30×35
1.03
30×40
1.18
30×50
1.35
35
35×25
0.82
35×25
0.93
35×30
1.05
35×35
1.26
35×40
1.33
35×45
1.50
35×50
1.70
VDC
ØD
420
22
25.4
450
30
35
47
56
68
82
100
120
150
180
220
270
330
390
470
22×30
0.58
22×30
0.65
22×35
0.73
22×40
0.83
22×45
0.95
22×50
1.07
25.4×30
0.66
25.4×30
0.73
25.4×35
0.83
25.4×40
0.95
25.4×40
1.07
25.4×50
1.21
30×30
0.83
30×30
0.95
30×35
1.07
30×40
1.21
30×45
1.38
30×50
1.60
22
22×25
0.47
22×30
0.53
22×35
0.59
22×35
0.66
22×40
0.75
22×45
0.84
22×50
0.95
35×30
1.08
35×30
1.22
35×35
1.41
35×40
1.60
35×45
1.80
35×50
1.92
25.4
25.4×30
0.59
25.4×30
0.66
25.4×35
0.73
25.4×35
0.83
25.4×40
0.95
25.4×45
1.07
25.4×50
1.21
500
30
30×30
0.74
30×30
0.83
30×35
0.95
30×35
1.07
30×40
1.21
30×45
1.38
30×50
1.60
35
35×30
0.84
35×30
0.96
35×30
1.08
35×35
1.22
35×40
1.41
35×45
1.61
35×50
1.80
22
25.4
30
22×35
0.37
22×35 25.4×30 30×30
0.45
0.44
0.41
22×40 25.4×35 30×30
0.52
0.51
0.54
22×45 25.4×35 30×35
0.58
0.62
0.62
25.4×40 30×35
0.64
0.63
25.4×45 30×40
0.71
0.71
30×45
0.76
30×50
0.89
30×60
1.05
35
35×30
0.72
35×30
0.80
35×40
0.90
35×45
1.01
35×50
1.44
35×60
1.55
Case Size ØD×L(mm)
TLC(LXG)
Series
231
