TLS400VS220M22*40_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS
TLS Series
•105℃ 3,000Hrs assured.
•Non-solvent proof.
•Downsized.
•High Ripple Capability.
•For SMPS, Inverter.
•RoHS compliant.
•Halogen-free capacitors are also available.
TLA
TLS
Downsized
SPECIFICATIONS
Item
Characteristics
Rated Voltage Range
1 6 0 ~ 5 5 0 VDC
Operating Temperature Range
-25 ~ +105℃
Capacitance Tolerance
±20%(M)
(at 20℃, 120Hz)
I=0.02CV or 3m A, whichever is smaller.
Where, I:Leakage Current(μA), C:Nominal capacitance(μ
F), V:Rated voltage(VDC)
(at 20℃, 5minutes)
Leakage Current
※ Dissipation
Rated voltage(VDC)
Factor(Tan δ)
Tan δ(Max.)
160~400
450~550
0.15
0.20
(at 20℃, 120Hz)
Temperature Characteristics
(Max. Impedance ratio)
Rated voltage(VDC)
160~400
450~550
4
8
Z(-25℃)/Z(20℃)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated
voltage is applied for 3,000 hours at 105℃.
Capacitance change ≦ ±20% of the initial value
Tan δ
≦ 200% of the initial specified value
Leakage current
≦ The initial specified value
Load Life
exposing them at 105℃ for 1,000 hours without voltage applied.
The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least
24 hours and not more than 48 hours before the measurements.
Tan δ
Leakage current
Shelf Life
Others
Satisfied characteristics KS C IEC 60384-4
※For capacitors with CV products ≻100,000 higher Tanδvalue may apply.
When the capacitance exceeds 1,000μF, 0.01 shall be added every 1,000μF increase.
DIMENSIONS OF TLS Series
RATED RIPPLE CURRENT
When capacitor are operated in any other condition
at 120Hz, the maximum ripple current must be
multiplied by the figure shown in the table.
ØD=Ø22~Ø35
VN/VS type
PC board pin-out
Frequency multiplying factor
Freq.(Hz)
60
120
300
1k
10k~
160~250VDC
0.81
1.00
1.17
1.32
1.45
315~550VDC
0.77
1.00
1.16
1.30
1.41
VDC
220
Unit(mm)
Marking : BROWN SLEEVE, SILVER INK
The standard design has no bottom plate.
RATINGS OF TLS Series
VDC
ØD
μF
160
22
25.4
200
30
35
22
25.4
250
30
35
22×25
1.11
22×30
1.29
22×35
1.44
22×40
1.61
22×45
1.79
22×50
2.02
270
22×25
1.23
22×30
1.40
22×30
1.54
22×35
1.72
22×40
1.94
22×45
2.17
330
390
22×25
1.47
22×30
1.68
22×35
1.86
22×40
2.12
22×45
2.40
22×50
2.69
470
560
680
820
1,000
1,200
1,500
1,800
25.4×25
1.84
25.4×30
2.08
25.4×35
2.40
25.4×40
2.68
25.4×45
3.05
25.4×50
3.40
2,200
2,700
30×25
2.50
30×30
2.77
30×35
3.17
30×40
3.57
30×45
4.05
30×50
4.56
3,300
VDC
ØD
μF
35×25
2.91
35×30
3.30
35×30
3.62
35×35
4.07
35×40
4.67
35×50
5.40
25.4×25
1.67
25.4×30
1.89
25.4×35
2.17
25.4×40
2.45
25.4×45
2.78
315
22
25.4
30×25
2.05
30×30
2.28
30×30
2.52
30×35
2.83
30×40
3.26
30×50
3.72
35×25
2.66
35×30
2.96
35×35
3.36
35×40
3.81
35×45
4.32
35×50
4.88
30
35
22
25.4
22×25
0.77
22×30
0.90
22×35
1.02
22×40
1.15
22×45
1.29
22×50
1.47
120
150
220
270
330
390
470
560
680
820
1,000
1,200
22×25
0.95
22×30
1.10
22×35
1.24
22×40
1.40
22×45
1.56
22×50
1.70
25.4×25
1.21
25.4×30
1.38
25.4×35
1.57
25.4×40
1.76
25.4×45
1.96
25.4
30×25
1.43
30×30
1.57
30×30
1.73
30×35
1.93
30×40
2.19
30×45
2.47
35×25
1.82
35×30
2.02
35×30
2.20
35×35
2.48
35×40
2.83
35×45
3.18
25.4×25
0.99
25.4×30
1.13
25.4×35
1.30
25.4×40
1.47
25.4×45
1.63
25.4×50
1.82
30
25.4×25
1.40
25.4×30
1.57
25.4×35
1.79
25.4×40
2.02
25.4×45
2.26
25.4×50
2.53
400
30×25
1.87
30×30
2.08
30×35
2.34
30×40
2.66
30×45
2.99
35
35×25
2.19
35×30
2.44
35×30
2.70
35×35
3.00
35×40
3.48
35×50
3.98
450
30
35
22
22×25
0.70
22×30
0.81
22×35
0.92
22×40
1.02
22×45
1.17
100
180
22
30×25
1.29
30×30
1.45
30×35
1.61
30×40
1.82
30×45
2.04
30×50
2.30
35×25
1.65
35×30
1.85
35×35
2.05
35×40
2.34
35×45
2.63
35×50
2.96
25.4
25.4×25
0.90
25.4×35
1.05
25.4×35
1.16
25.4×40
1.32
25.4×45
1.48
25.4×50
1.65
30
30×25
1.06
30×30
1.18
30×30
1.30
30×35
1.51
30×40
1.65
30×45
1.86
35
35×25
1.37
35×30
1.54
35×30
1.67
35×35
1.87
35×40
2.05
35×50
2.44
Case Size ØD×L(mm)
Rated Ripple Current(Arms/105℃, 120Hz)
TLS
Series
221
VDC
ØD
56
68
82
100
120
150
180
220
270
500
22
22×35
0.41
22×40
0.48
22×45
0.56
22×50
0.64
25.4
25.4×30
0.46
25.4×35
0.54
25.4×40
0.63
25.4×45
0.73
25.4×50
0.78
550
30
30×30
0.61
30×35
0.72
30×40
0.85
30×45
0.98
30×50
1.03
30×60
1.24
330
390
222
Case Size ØD×L(mm)
35
25.4
25.4×40
0.52
25.4×50
0.60
25.4×50
0.72
35×30
0.83
35×35
0.96
35×40
1.13
35×45
1.31
35×50
1.38
35×60
1.63
30
30×35
0.55
30×40
0.70
30×45
0.80
30×50
0.95
30×60
0.90
30×70
1.00
35
35×35
0.75
35×40
0.93
35×50
0.95
35×55
1.05
35×60
1.15
35×70
1.50
TLS400VS220M22*40_VS 价格&库存
很抱歉,暂时无法提供与“TLS400VS220M22*40_VS”相匹配的价格&库存,您可以联系我们找货
