NFC500VB22M16*25_3.5CC 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
NFC Series
•105℃ 2,000~5,000Hrs assured.
•Non-solvent proof.
•High Ripple, Long Life.
•For SMPS, IP-Board, Adaptor.
•RoHS compliant.
•Halogen-free capacitors are also available.
NZE
NFC
Long Life
SPECIFICATIONS
ltem
Characteristics
Rated Voltage Range
160 ~ 400 VDC
Operating Temperature Range
420~ 500 VDC
-40 ~+ 105℃
-25 ~ +105℃
Capacitance Tolerance
±20%(M)
Time
c・v
Leakage Current
After 1 minute
(at 20℃, 120Hz)
After 5 minutes
≦ 1000
I=0.1CV+40
I=0.03CV+15
> 1000
I=0.04CV+100
I=0.02CV+25
Where, I:Max. Leakage current(㎂) C:Nominal capacitance (㎌) V:Rated voltage (VDC) (at 20℃)
Dissipation Factor(Tan δ)
Temperature Characteristics
(Max. Impedance ratio)
Rated Voltage(VDC)
160~250
350~500
Tanδ(Max.)
0.20
0.24
(at 20℃, 120Hz)
Rated Voltage(VDC)
160~250
350~400
420~500
Z(–25℃)/Z(+20℃)
3
5
6
Z(–40℃)/Z(+20℃)
6
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the
rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the
rated voltage) for 5,000 hours at 105℃. (where, 2,000 hours for Ø6.3)
Load Life
Shelf Life
Capacitance change
Tan δ
Leakage current
exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be
applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48
hours before the measurements.
Capacitance change
Tan δ
Leakage current
Satisfied characteristics KS C IEC 60384-4
Unit(mm)
Marking : DARK BROWN SLEEVE, SILVER INK
ØD 6.3 8
10 12.5 16
Ød 0.5 0.6 0.6 0.6 0.8 0.8 0.8
F
2.5 3.5 5.0 5.0 7.5 7.5 7.5
ØD′
ØD+0.5 max.
L′ L+1.5 max.
L+2.0 max.
※Ø8 x 50L, L′
≦ L+2.0
22
0.8
10.0
147
Series
DIMENSIONS OF NFC Series
≦ ±20% of the initial value
≦ 200% of the initial specified value
≦ 500% of the initial specified value
NFC
Others
≦ The initial specified value
RATINGS OF NFC Series
160
V DC
ltems
ØD×L(mm)
Rated Ripple Current
(mArms/105℃,120Hz)
3.3
10
33
47
68
82
100
150
220
330
ltems
6.8
10
22
33
47
68
100
150
220
330
(mArms/105℃,120Hz)
6.3 ×11
8 ×11.5
8 ×20
10 ×20
12.5 ×20
12.5 ×20
12.5 ×25
8 ×50
16 ×20
16 ×25
16 ×25
18 ×31.5
36
75
135
192
262
312
409
320
462
548
701
906
350
ØD×L(mm)
(mArms/105℃,120Hz)
8×11.5
8×20
10×20
10×20
12.5×20
70
95
130
193
214
12.5×25
285
250
340
452
591
748
936
1,196
8×50
12.5×25
16×25
16×31.5
18×31.5
18×35.5
20×40
ØD×L(mm)
(mArms/105℃,120Hz)
8 ×15
8 ×20
10 ×20
65
90
126
12.5 ×20
207
8 ×50
16 ×20
245
284
16 ×25
364
16 ×31.5
18 ×31.5
18 ×40
22 ×45
472
591
760
970
400
V DC
ltems
1
3.3
6.8
8.2
148
ØD×L(mm)
250
V DC
10
22
27
33
47
68
82
100
120
150
180
220
135
192
236
312
380
409
360
548
701
876
1,110
8×20
10×20
10×20
12.5×20
10×20
12.5×25
8×50
16×25
16×25
16×31.5
18×31.5
22
200
420
ØD×L(mm)
(mArms/105℃,120Hz)
6.3×11
8×11.5
8×15
8×20
10×16
12.5×25
8×50
16×20
16×25
16×31.5
18×31.5
18×35.5
18×40
18×40
20×40
22×45
19
42
66
80
85
225
240
284
364
472
536
611
680
760
855
996
ØD×L(mm)
(mArms/105℃,120Hz)
18×31.5
18×31.5
18×35.5
18×40
18×45
500
560
720
740
753
450
V DC
ltems
500
ØD×L(mm)
(mArms/105℃,120Hz)
6.3×11
8×11.5
8×15
8×15
8×20
10×20
10×25
12.5×20
12
23
38
42
62
100
121
135
8×50
16×25
230
267
16×31.5
319
10×50
18×25
334
368
1
1.5
2.2
3.3
4.7
6.8
8.2
10
15
22
27
33
39
40
47
56
60
12.5×42.5
18×31.5
12.5×50
18×31.5
12.5×60
18×35.5
18×40
18×45
20×40
22×50
68
82
100
120
150
180
476
500
473
594
630
720
740
753
757
910
ØD×L(mm)
(mArms/105℃,120Hz)
10×20
100
12.5×20
12.5×25
12.5×30
10×50
18×25
16×31.5
12.5×50
12.5×50
18×31.5
135
182
210
253
308
319
358
360
393
12.5×60
12.5×60
440
455
18×35.5
489
18×40
594
18×45
20×40
22×45
22×50
620
618
702
827
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
Freq.(Hz)
120
1k
10k
50k
100k
Factor
1.00
1.25
1.50
1.60
1.75
NFC
Series
149
NFC500VB22M16*25_3.5CC 价格&库存
很抱歉,暂时无法提供与“NFC500VB22M16*25_3.5CC”相匹配的价格&库存,您可以联系我们找货
