NXQ16VB2200M12.5*20_3.2CC
    SAMYOUNG(韩国三莹)
    插件,D12.5xL20mm
    直插铝电解电容 插件,D12.5xL20mm 2.2mF ±20% Ф12.50 x 20.00mm 16V 25mΩ 2.6A 10000Hrs@105℃
NXQ16VB2200M12.5*20_3.2CC 数据手册
삼영내지104-145 06.13 페이지107 2012.9.14 10:2 PM mac2 EAGLERIP/F9000-1130-175-CMYK MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NXQ Series 쪾105℃ 6,000 ~ 10,000Hrs assured. 쪾Non-solvent proof. 쪾Low impedance, High ripple 쪾For LCD, LED TV BLU Inverter, SMPS, IP-Board, Adaptor 쪾RoHS compliant. 쪾Halogen-free capacitors are also available. NXH NXQ High Ripple SPECIFICATIONS ltem Characteristics Rated Voltage Range 6.3 ~ 100 VDC ℃ Operating Temperature Range -40 ~ +105 Capacitance Tolerance ±20%(M) Leakage Current I=0.01CV( A) or 3 A, whichever is greater. Where, I:Max. Leakage current( A), C:Nominal capacitance( F), V:Rated voltage(VDC) (at 20 , 2minutes) μ Rated Voltage(VDC) Tan (Max.) Dissipation Factor δ (Tan ) μ δ ℃ (at 20 , 120Hz) μ 6.3 0.22 10 0.19 μ μ 16 0.16 25 0.14 35 0.12 50 0.10 ℃ μ 63 0.09 80 0.08 100 0.08 ℃ When the capacitance exceeds 1,000 F, 0.02 shall be added every 1,000 F increase (at 20 , 120Hz) ℃ ℃ ℃ ℃ Z(-25 )/Z(+20 ) Z(-40 )/Z(+20 ) Temperature Characteristics (Max. Impedance ratio) 2 3 (at 120Hz) ℃ The following specifications shall be satisfied when the capacitors are restored to 20 after the rated voltage with the rated ripple current is applied at 105 for the specified period of time. ℃ Load Life Rated voltage(VDC) Capacitance change Tan δ Leakage current 6.3~10 D 6.3V 6,000hours 8,000hours 9,000hours DC Life Time 10~50V 7,000hours 9,000hours 10,000hours 9,000hours 10,000hours DC 63~100V 6,000hours 8,000hours 9,000hours DC ℃ Rated voltage(VDC) Capacitance change Tan δ Leakage current Others Ø The following specifications shall be satisfied when the capacitors are restored to 20 after exposing them for 500 hours at 105 without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. ℃ Shelf Life 16~100 쬩±30% of the initial value 쬩±25% of the initial value Ø5~Ø6.3 Ø8 X 11.5L 쬩 200% of the initial specified value Ø8 X 15L~20L 쬩 The initial specified value Ø10 X 12.5L Ø10ØX12.5~ 16L~25L 6.3~10 16~100 쬩±30% of the initial value 쬩±25% of the initial value 쬩 200% of the initial specified value 쬩 The initial specified value Satisfied characteristics W of KS C 6421 Unit(mm) Ø Ø ØÇ Ç Ø 107 Series Marking : DARK BROWN SLEEVE, SILVER INK D 5 6.3 8 10 12.5 16 18 d 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 D D+0.5 max. L L+1.5 max. L+2.0 max. NXQ DIMENSIONS OF NXQ Series 삼영내지104-145 06.13 2012.9.14 10:2 PM 페이지108 mac2 EAGLERIP/F9000-1130-175-CMYK MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NXQ Series VDC ØD×L(mm) × × × × × × × × × × × × × × × 5 11 6.3 11 8 11.5 8 15 8 20 10 12.5 10 16 10 20 10 25 12.5 20 12.5 25 12.5 30 12.5 35 16 20 16 25 VDC ØD×L(mm) × × × × × × × × × × × × × × × 5 11 6.3 11 8 11.5 8 15 8 20 10 12.5 10 16 10 20 10 25 12.5 20 12.5 25 12.5 30 12.5 35 16 20 16 25 6.3 10 ㎌ IMP. Ripple ㎌ IMP. Ripple ㎌ IMP. Ripple 220 470 820 1,000 1,500 1,200 1,800 2,700 3,300 3,900 4,700 5,600 6,800 6,800 8,200 0.40 0.17 0.075 0.059 0.041 0.053 0.038 0.028 0.024 0.025 0.019 0.018 0.016 0.021 0.017 345 540 945 1,250 1,500 1,500 1,760 1,960 2,250 2,480 2,900 3,450 3,570 3,250 3,630 150 330 560 680 1,000 820 1,200 1,800 2,200 2,700 3,300 4,700 5,600 4,700 5,600 0.40 0.17 0.075 0.059 0.041 0.053 0.038 0.028 0.024 0.025 0.019 0.018 0.016 0.021 0.017 450 700 1,200 1,600 1,960 1,700 2,000 2,500 2,900 2,600 3,050 3,500 3,600 3,250 3,630 120 270 470 560 820 680 1,000 1,500 1,800 2,200 2,700 3,300 3,900 3,300 4,700 0.40 0.17 0.075 0.059 0.041 0.053 0.038 0.028 0.024 0.025 0.019 0.018 0.016 0.021 0.017 450 700 1,200 1,600 1,960 1,700 2,000 2,500 2,900 2,600 3,050 3,500 3,600 3,250 3,630 25 35 50 ㎌ IMP. Ripple ㎌ IMP. Ripple ㎌ IMP. Ripple 68 150 330 390 560 470 680 1,000 1,200 1,500 1,800 2,200 2,700 2,200 3,300 0.40 0.17 0.075 0.059 0.041 0.053 0.038 0.028 0.024 0.025 0.019 0.018 0.016 0.021 0.017 450 700 1,200 1,600 1,960 1,700 2,000 2,500 2,900 2,600 3,050 3,500 3,600 3,250 3,630 47 100 180 220 330 270 390 560 680 820 1,200 1,500 1,800 1,500 1,800 0.40 0.17 0.075 0.059 0.041 0.053 0.038 0.028 0.024 0.025 0.019 0.018 0.016 0.021 0.017 450 700 1,200 1,600 1,960 1,700 2,000 2,500 2,900 2,600 3,050 3,500 3,600 3,250 3,630 27 56 100 120 180 150 220 330 390 470 680 820 1,000 820 1,000 0.48 0.22 0.120 0.082 0.058 0.073 0.053 0.038 0.032 0.032 0.025 0.023 0.021 0.026 0.022 310 500 950 1,230 1,580 1,280 1,650 2,060 2,240 2,200 2,500 3,100 3,250 2,730 3,010 ℃ Rated Ripple Current (mArms/105 , 100kHz) Impedance ( max./20 , 100kHz) Nominal Capacitance( ) Ω 108 16 ℃ ㎌ 삼영내지104-145 06.13 2012.9.14 10:2 PM 페이지109 mac2 EAGLERIP/F9000-1130-175-CMYK MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NXQ Series VDC ØD×L(mm) × × × × × × × × × × × × × × × 5 11 6.3 11 8 11.5 8 15 8 20 10 12.5 10 16 10 20 10 25 12.5 20 12.5 25 12.5 30 12.5 35 16 20 16 25 VDC ØD×L(mm) ㎌ IMP. Ripple 18 47 82 100 150 120 180 270 330 390 470 560 680 560 820 0.71 0.28 0.18 0.13 0.096 0.110 0.076 0.056 0.046 0.041 0.031 0.028 0.024 0.032 0.025 240 420 720 990 1,200 990 1,200 1,570 1,990 1,990 2,460 2,760 3,040 2,150 2,550 80 100 ㎌ IMP. Ripple ㎌ IMP. Ripple 12 27 47 56 82 68 100 150 180 150 220 270 330 390 470 330 470 560 680 820 470 680 820 1,000 1,200 1.2 0.46 0.29 0.20 0.16 0.17 0.11 0.084 0.069 0.110 0.062 0.047 0.042 0.036 0.032 0.048 0.038 0.032 0.029 0.027 0.045 0.036 0.030 0.027 0.026 220 370 620 780 1,040 780 1,040 1,430 1,620 1,430 1,750 2,210 2,400 2,600 2,860 1,950 2,430 2,640 2,860 3,510 2,270 2,500 2,860 3,510 3,860 8.2 18 33 47 68 47 68 100 120 100 150 220 270 330 390 270 390 470 560 680 390 470 560 680 820 1.2 0.46 0.29 0.20 0.16 0.17 0.11 0.084 0.069 0.11 0.062 0.047 0.042 0.036 0.032 0.048 0.038 0.032 0.029 0.027 0.045 0.036 0.030 0.027 0.026 220 370 620 780 1,040 780 1,040 1,430 1,620 1,430 1,750 2,210 2,400 2,600 2,860 1,950 2,430 2,640 2,860 3,510 2,270 2,500 2,860 3,510 3,860 NXQ × × × × × × × × × × × × × × × × × × × × × × × × × 5 11 6.3 11 8 11.5 8 15 8 20 10 12.5 10 16 10 20 10 25 12.5 16 12.5 20 12.5 25 12.5 30 12.5 35 12.5 40 16 20 16 25 16 31.5 16 35.5 16 40 18 20 18 25 18 31.5 18 35.5 18 40 63 ℃ Ω ℃ ㎌ Series Rated Ripple Current (mArms/105 , 100kHz) Impedance ( max./20 , 100kHz) Nominal Capacitance( ) RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers Cap.( ㎌) Freq.(Hz) 8.2 ~ 33 47 ~ 270 330 ~ 680 820 ~ 1,800 2,200 ~ 8,200 120 1k 10k 50k 100k 0.42 0.50 0.55 0.60 0.70 0.70 0.73 0.77 0.80 0.85 0.90 0.92 0.94 0.96 0.98 0.93 0.95 0.96 0.97 0.99 1.00 1.00 1.00 1.00 1.00 109
NXQ16VB2200M12.5*20_3.2CC 价格&库存
很抱歉,暂时无法提供与“NXQ16VB2200M12.5*20_3.2CC”相匹配的价格&库存,您可以联系我们找货
