Approval Specification for Thick Film Chip Resistors - Type CR
1.Scope
This specification prescribes lead free thick film chip resistors for use in electronics
system
2.Designation
Chip Resistor 0805 1/8W ±5% 4K7Ω
CR0805J80472G
CR
0805
J
8
0472
G
Value
SPECIAL VALUE
1= 1W
4digitals
G= reel
C=± 0.25%
2= 1/2W
49R9=49.9
V= bulk
0603
D=± 0.5%
3= 1/3W
0472=4K7
D= special
0805
F=± 1%
4= 1/4W
0103=10K
1206
G=± 2%
8= 1/8W
0564=560K
1210
J=± 5%
A= 1/10W
2010
K=± 10%
F= 1/16W
Series
Size Code
Tolerance
Name
0201
B=± 0.1%
Product..
0402
CR=Chip
Resistor
2512
Power Rating
requirement
H=1/20W
2.2 Remark:
(1) Common code for chip resistors
(2) Normal resistance value for tolerance ±0.1% , ±0.25%, ±0.5% ±1% :
the first three digits are significant figures of resistance value and the
X
fourth one denotes the power number of 10, (10 )
Example: 330 ohm: 3300, 4.7K ohm: 4701
22K ohm: 2202, 100K ohm: 1003
(3) Normal resistance value for tolerance ±2% , ±5%, ±10%:
the first digit is zero, the second and third digit are significant figures
X
of resistance value and the fourth one denotes the power number of 10, (10 )
Example: 330 ohm: 0331, 4.7K ohm: 0472
22K ohm: 0223, 100K ohm: 0104
(3)EXPLANATION OF PART NUMBER FOR 0603, ±1%
1
文件編號:613-00-001 版本:V14.0
EIA-96 Marking
code R Value code R Value code R Value code R Value code R Value code R Value code R Value code R Value
01
02
03
04
05
06
07
08
09
10
11
12
100
102
105
107
110
113
115
118
121
124
127
130
13
14
15
16
17
18
19
22
23
24
133
137
140
143
147
150
154
158
162
165
169
174
25
26
27
28
29
30
31
32
33
34
35
36
178
182
187
191
196
200
205
210
215
221
226
223
37
38
39
40
41
42
43
44
45
46
47
48
237
243
249
255
261
267
274
280
287
294
301
309
49
50
51
52
53
54
55
56
57
58
59
60
316
324
332
340
348
357
365
374
383
392
402
412
61
62
63
64
65
66
67
68
69
70
71
72
422
432
442
453
464
475
487
499
511
523
536
549
73
74
75
76
77
78
79
80
81
82
83
84
562
576
590
604
619
634
649
665
681
698
715
732
85
86
87
88
89
90
91
92
93
94
95
96
750
768
787
806
825
845
866
887
909
931
953
976
This table shows the first two digits for the tree-digit EIA-96 part marking scheme
the third character is a letter multiplier:
(4)
Y=10-2, X=10-1, A=100, B=101, C=102, D=103, E=104, F=105
If the resistance value is not found in the table for 0603 product, will use normal
three digits to show the value, but will add a special mark “-“ under the three
digits. Example as following:
“ 331 "indicates that it is 0603 ±1% 330ohm product.
3.Rating
3.1 Rated Power (%)
Rated power shall be load power corresponding to normal wattage suitable for
continuous use at 70℃ ambient temperature in case the ambient temperature exceeds
70℃ reduce the load power in accordance with derating curve shown as
Max. Working
Max. Overload
TYPE
Rated Power
Voltage
Voltage
CR0201
1/20W
25V
50V
CR0402
1/16W
50V
100V
CR0603
1/10W
50V
100V
CR0805
1/8W
150V
300V
CR1206
1/4W
200V
400V
CR1210
1/3W
200V
400V
CR2010
1/2W
200V
400V
CR2512
1W
200V
400V
2
3.2 Derating Curve
3.3 Operating Temperature Range -55℃~+125℃;
storage condition is 5~30℃, 30~75%RH.
3.4 Rated Voltage
The rated voltage is calculated form the rated power and normal resistance by
the following formula: E= RP
Where:E:Rated Voltage (V)
P:Rated Power (W)
R:Normal Resistance (ohm)
In case the value calculated by the formula exceed the maximum working voltage as
3.1 the maximum working voltage shall be regarded as rated
3.5 Resistance Range and Resistance Tolerance
TYPE
NO.
CR0402
CR0603
CR0805
CR1206
CR0201
CR0402
CR0603
CR0805
CR1206
CR1210
CR2010
CR2512
Tolerance
Symbol
Resistance
Range(ohm)
Standard Resistance
Values
±0.5%
D
10~1M
E96
±1%
±2%
±5%
F
G
J
1R0-10M
E96
±10%
K
1R0~22M
(0201:1R0-10M)
E24
±20%
M
3
4.Dimension
4.1 Dimension
E
DIMENSIONS
e
Type
CR0201
CR0402
CR0603
CR0805
CR1206
CR1210
CR2010
CR2512
L
0.60±0.03
1.00±0.05
1.60±0.15
2.00±0.15
3.10±0.15
3.10±0.15
5.00±0.20
6.25±0.20
W
0.30±0.03
0.50±0.05
0.80±0.10
1.25±0.15
1.60±0.15
2.50±0.15
2.50±0.20
3.10±0.20
T
0.23±0.03
0.35±0.05
0.45±0.10
0.50±0.10
0.55±0.10
0.55±0.15
0.55±0.15
0.55±0.15
E
0.15±0.05
0.15±0.10
0.25±0.20
0.35±0.20
0.45±0.25
0.35±0.25
0.65±0.25
0.85±0.25
e
0.15±0.05
0.20±0.10
0.30±0.20
0.40±0.20
0.40±0.25
0.60±0.35
0.50±0.25
0.95±0.25
4.2.Construction and materials
Marking
Protective layer
Inner protective
Resistive layer
Conductive layer
Side conductive
Barrier layer
Termination layer
Ceramic Substrate
4
No.
construction
Major material
Ceramic substrate
Al2O3
1
Conductive layer
Ag
2
Side conductive layer
NiCr
3
Resistive layer
RuO2 + glass
4
Inner protective layer
Glass
5
Protective layer
Epoxy
6
Marking
Epoxy
7
Termination barrier layer
Ni
8
Termination layer
Matte Tin
9
4.3 Electrical Characteristics:
Rated
Max.
Max.
Power
Working Overload
Type
at
Voltage Voltage
70℃
0201 1/20W
25V
50V
0402 1/16W
50 V
100V
0603 1/10W
50V
100V
0805 1/8W
150V
300V
1206 1/4W
200V
400V
1210 1/3W
200V
400V
2010 1/2W
200V
400V
2512 1W
200V
400V
Resistance Range
T.C.R
(ppm/℃)
D(±0.5%)
E96
F(±1%)
E96
G(±2%)
E24
J(±5%)
E24
±600
1Ω~25Ω
1Ω~25Ω
1Ω~25Ω
±250
+500~-250
±200
±100
10Ω~1MΩ
+500~-250
±200
±100
---------10Ω~1MΩ
+500~-250
±200
±100
---------10Ω~1MΩ
+500~-250
±200
±100
---------10Ω~1MΩ
+500~-250
±200
±100
+500~-250
±200
±100
+500~-250
±200
±100
25Ω~10MΩ 25Ω~10MΩ 25Ω~10MΩ
1Ω~10Ω
1Ω~10Ω
1Ω~10Ω
10Ω~10MΩ 10Ω~10MΩ 10Ω~22MΩ
---------------------------1Ω~10Ω
1Ω~10Ω
1Ω~10Ω
---------10Ω~10MΩ 10Ω~22MΩ
10Ω~10MΩ
1Ω~10Ω
1Ω~10Ω
10Ω~10MΩ
1Ω~10Ω
1Ω~10Ω
10Ω~10MΩ
1Ω~10Ω
1Ω~10Ω
10Ω~10MΩ
1Ω~10Ω
1Ω~10Ω
10Ω~10MΩ
1Ω~10Ω
1Ω~10Ω
10Ω~10MΩ
Jumper
Jumper
Resistance Rated
Value
Current
50mΩ
MAX
0.5A
50mΩ
MAX
1A
50mΩ
MAX
1A
50mΩ
MAX
1.5A
50mΩ
MAX
1.9A
50mΩ
MAX
2.2A
50mΩ
MAX
3A
50mΩ
MAX
3A
*ZERO OHM JUMPER
很抱歉,暂时无法提供与“CR1206J40182G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04410
- 100+0.02500
- 1000+0.01560
- 2500+0.01000
- 5000+0.00740
