PESD1LIN
LIN-bus ESD protection diode
Rev. 3 — 31 May 2011
Product data sheet
1. Product profile
1.1 General description
PESD1LIN in a very small SOD323 (SC-76) Surface-Mounted Device (SMD) plastic
package designed to protect one automotive Local Interconnect Network (LIN) bus line
from the damage caused by ElectroStatic Discharge (ESD) and other transients.
1.2 Features and benefits
ESD protection of one automotive LIN-bus line
Asymmetrical diode configuration ensures an optimized protection against
ElectroMagnetic Interferences (EMI) of a LIN Electronic Control Unit (ECU)
Max. peak pulse power: PPP = 160 W at tp = 8/20 s
Low clamping voltage: VCL = 40 V at IPP = 1 A
Ultra low leakage current: IRM < 1 nA
ESD protection of up to 23 kV
IEC 61000-4-2, level 4 (ESD)
IEC 61000-4-5 (surge); IPP = 3 A at tp = 8/20 s
AEC-Q101 qualified
1.3 Applications
LIN-bus protection
Automotive applications
1.4 Quick reference data
Table 1.
Tamb = 25 C unless otherwise specified.
Symbol
Parameter
VRWM
reverse standoff voltage
Cd
Min
Typ
Max
Unit
PESD1LIN (15 V)
15
V
PESD1LIN (24 V)
24
V
13
17
pF
diode capacitance
Conditions
VR = 0 V;
f = 1 MHz
PESD1LIN
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
Simplified outline
1
cathode 1 (15 V)
2
cathode 2 (24 V)
1
Graphic symbol
2
1
2
006aab041
3. Ordering information
Table 3.
Type number
PESD1LIN
Package
Name
Description
Version
SC-76
plastic surface-mounted package; 2 leads
SOD323
4. Marking
Table 4.
Marking codes
Type number
Marking code
PESD1LIN
AM
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
tp = 8/20 s
[1]
PPP
peak pulse power
IPP
peak pulse current
160
W
tp = 8/20 s
[1]
3
A
Tj
junction temperature
150
C
Tamb
ambient temperature
65
+150
C
Tstg
storage temperature
65
+150
C
[1]
PESD1LIN
Product data sheet
Non-repetitive current pulse 8/20 s exponential decay waveform according to IEC 61000-4-5.
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
PESD1LIN
Nexperia
Table 6.
ESD maximum ratings
Symbol
Parameter
Conditions
electrostatic discharge
voltage
VESD
IEC 61000-4-2
(contact discharge)
MIL-STD-883
(human body model)
[1]
[1]
Min
Max
Unit
23
kV
10
kV
Device stressed with ten non-repetitive ESD pulses.
Table 7.
ESD standards compliance
Standard
Conditions
IEC 61000-4-2; level 4 (ESD)
> 15 kV (air); > 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
001aaa631
IPP
001aaa630
120
100 %
90 %
100 % IPP; 8 μs
IPP
80
e−t
50 % IPP; 20 μs
40
10 %
30 ns
40
t (μs)
Fig 1.
t
tr = 0.7 ns to 1 ns
8/20 s pulse waveform according to
IEC 61000-4-5
PESD1LIN
Product data sheet
60 ns
Fig 2.
ESD pulse waveform according to
IEC 61000-4-2
3 of 12
PESD1LIN
Nexperia
6. Characteristics
Table 8.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
PESD1LIN (15 V)
15
V
PESD1LIN (24 V)
24
V
reverse leakage current
IRM
PESD1LIN (15 V)
VRWM = 15 V
很抱歉,暂时无法提供与“PESD1LIN,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.479521+0.30026
- 15+1.9385415+0.23475
- 75+1.5688675+0.18998
- 300+1.27132300+0.15395
- 1500+0.928701500+0.11246
- 国内价格 香港价格
- 3000+0.419273000+0.05077
- 9000+0.417319000+0.05054
- 15000+0.4173015000+0.05054
- 45000+0.4172945000+0.05054
- 75000+0.4172875000+0.05053
- 国内价格
- 5+0.57121
- 20+0.52081
- 100+0.47041
- 500+0.42001
- 1000+0.39649
- 2000+0.37969
