版 本
描 述
日 期
客户
CUSTOMER
品名
PART NAME
天泰料号
TENTA Material Number
客户料号
CUSTOMER Material Number
编制/Edition
检查/Checked
确认/Confirmed
孙兰金
徐志钦
杨再军
承认/Admit
审核/Auditing
批准/Approved
天泰電機工業有限公司
TENTA ELECTRIC INDUSTRIAL CO., LTD.
台中縣梧棲区自強二街 86 巷 61 號
NO.61, Lane 86, Tzchiang 2st St. Wu-Chi Township, Taichung County 435, TAIWAN R.O.C
TEL:(886-04)26398618 FAX:(886-04)26392549
深圳天泰電器元件有限公司
SHEN ZHEN TENTA ELECTRICAL APPLIANCE LTD.
公司:深圳市南山區白石洲中國原子能第二工業區第二棟六樓
6/F NO.2, Pirector Atom 2th Industry, Baishizhou , Shenzhen, CHINA
TEL:(0755)86327963、26921158 FAX:(0755)86297411
工厂:深圳市寶安區福永街道橋頭社區富橋第四工業區 A5 棟
No.A5,FU Qiao 4th Industrial area,Qiaotou Community,Fuyong Street,Bao An District,Shen Zhen
TEL:(0755)29604898 FAX:(0755)29604891
SPECIFICATIONS
METALLIZED POLYPROPYLENE FILM CAPACITORS FOR DC VOLTAGE ……PMPR
SPECIFICATIONS:
1. Flame retardation epoxy resin powder coating provides safety and the identical outer appearance
2. The flame-retarded rating meet UL94V-0 requirement
3. CAPACITANCE TOLERANCE:
J (±5%), K( ±10%)
4. RATED VOLTAGE:
100VDC, 250VDC, 400VDC, 630V DC
5. CAPACITANCE RANGE:
0.001µF to 10 µF
6. OPERATING TEMPERATURE:
-40℃ to +85℃
7. WITHSTAND VOLTAGE:
Between Electrodes 175% of the rated voltage for 5 sec.
8. DISSIPATION FACTOR (tan δ) :
Max. 0.1% when measured at 1 kHz & 25℃
9. INSULATION RESISTGANCE:
Between Electrodes
(1) Less than or equal to 0.33µF≧30,000 MΩ
(2) More than 0.33µF≧10,000 MΩ/µF
MEASURED AT 100VDC, 60 SEC. AND 20℃
10. TENSILE STRANGTH OF ELECTRODES:
TEST CONDITION
Load force : 1.0kg
Holding Times: 10±1 sec.
TEST CRITERIA
No wire breakage and no damage of the capacitor.
11. BENDING STRENGTH OF ELECTRODES:
TEST CONDITION
Load Force : 0.5kg
Bending Times: Two consecutive bends(4X90℃)in 5 sec.
TEST CRITERIA
12. VIBR ATION RESISTANCE:
TEST CONDITION
Frequency cycle : 1 minute per cycles 10-55-10Hz
Test Duration
: Perpendicular direction with the same method for 45
minutes esth, total of 90 mimutes.
TEST CRITERIA
(1) Appearance : No visible damage
(2) Contact
: Normal
13. SOLDERABILITY:
TEST CONDITION
Solder Bath Temperature : 260±5℃
Solder Time
: 2±0.5 sec.
TEST CRITERIA
3/4 of the surface tinning
14. HEAT SHOCK TEST:
TEST CONDITION
The Electrodes of capacitor shall be immersed in the emitting solder.
Solder Time
: 3±0.5sec.
Testing Voltage
: 175% of the rated voltage for 1 minute
TEST CRITERIA
(1) Appearance
: No visible damage
(2) Withstand Voltage : Normal
(3) Capacitance Change : ≦ ±3% of the initial value.
15. COLD RESISTANCE:
TEST CONDITION
Test Temperature : -40 ± 2 ℃
Test Duration
: 2 hrs
TEST CRITERIA
(1) Appearance
: No visible damage
(2) Capacitance Change : ≦ +0%, -5%(-40℃) of the initial value.
16. DRY HEAT RESISTANCE:
TEST CONDITION
Test Temperature : 85 ± 2℃
Test Duration
: 2 hrs
TEST CRITERIA(at 85℃)
Capacitance Change : ≦ +5%, -2% of the initial value
17. HUMIDITY RESISTANCE:
TEST CONDITION
Test Temperature : 40 ± 2℃
Relative Humidity: 90 to 95%
Test Duration
: 240 ± 8 hrs than condition at standard state 16 hrs.
Test Voltage
TEST CRITERIA
(1) Appearance
: No visible damage
(2) Capacitance Change : ≦ ± 5% of the initial value
(3) IR
: Over 3000MΩ/µF
(4) Withstand Voltage : Normal
1.5max
W max
MARKING
T max
MARKING
MARKING
5mm(max)
P
p
2A(100VDC)
W H
T
P dØ
5mm(max)
p
Lo
Lo
Pediform.C#(内弯)
Pediform.B#(弯脚)
Pediform.A#(长脚)
5mm(max)
p
L0
d+/-0.05
Lo20min
Capacitance
MARKING
MARKING
H max
2E(250VDC)
W H
T
P dØ
p
Pediform.E#(短脚)
Pediform.D#(外弯)
2G(400VDC)
W H
T
P dØ
L0
2J(630VDC)
W H
T
P dØ
symbo
uf
102
0.001
9.5
8.5
4.5
7.5
0.6
152
0.0015
9.5
8.5
4.5
7.5
0.6
222
0.0022
9.5
9.0
5.0
7.5
0.6
332
0.0033
9.5
8.5
5.0
7.5
0.6
13.0
9.0
5.0
10.0
0.6
472
0.0047
9.5
.9.5
5.0
7.5
0.6
13.0
9.0
5.0
10.0
0.6
682
0.0068
9.5
9.5
5.0
7.5
0.6
13.0
9.0
5.0
10.0
0.6
103
0.01
13.0
8.5
5.0
10.0
0.6
13.0
10.0
6.0
10.0
0.6
153
0.015
13.0
9.0
5.0
10.0
0.6
13.0
12.0
7.0
10.0
0.6
223
0.022
13.0
9.0
5.0
10.0
0.6
13.0
10.5
5.5
10.0
0.6
18.0
10.5
6.5
15.0
0.6
333
0.033
13.0
9.0
5.0
10.0
0.6
13.0
12.0
6.5
10.0
0.6
18.0
12.5
7.5
15.0
0.6
473
0.047
13.0
9.0
5.0
10.0
0.6
13.0
10.0
5.5
10.0
0.6
13.0
13.0
7.5
10.0
0.6
18.0
14.0
8.5
15.0
0.8
683
0.068
13.0
9.5
5.0
10.0
0.6
13.0
11.5
6.5
10.0
0.6
18.0
12.5
6.5
15.0
0.8
18.0
15.5
10.0
15.0
0.8
104
0.1
13.0
10.5
6.0
10.0
0.6
13.0
12.5
7.5
10.0
0.6
18.0
13.5
8.0
15.0
0.8
24.0
15.0
9.0
20.0
0.8
154
0.15
13.0
11.5
7.0
10.0
0.6
13.0
11.0
6.0
15.0
0.6
18.0
15.5
9.0
15.0
0.8
24.0
16.0
10.0
20.0
0.8
224
0.22
18.0
12.0
6.0
15.0
0.6
18.0
13.0
7.0
15.0
0.6
26.0
15.5
8.0
22.5
0.8
26.0
17.0
9.5
22.5
0.8
334
0.33
18.0
13.0
7.0
15.0
0.8
18.0
14.5
8.0
15.0
0.8
26.0
17.0
9.0
22.5
0.8
26.0
18.0
10.0
22.5
0.8
474
0.47
18.0
14.0
8.5
15.0
0.8
18.0
16.0
10.0
15.0
0.8
26.0
18.0
10.0
22.5
0.8
31.0
18.0
11.0
27.5
0.8
684
0.68
24.0
15.0
8.0
20.0
0.8
24.0
17.0
10.0
20.0
0.8
26.0
19.0
10.0
22.5
0.8
31.0
20.0
12.0
27.5
0.8
105
1.0
24.0
16.0
9.0
20.0
0.8
24.0
18.0
11.0
20.0
0.8
31.0
20.0
12.0
27.5
0.8
31.0
24.0
15.0
27.5
0.8
155
1.5
24.0
18.0
10.0
20.0
0.8
24.0
21.0
13.0
20.0
0.8
31.0
23.0
13.0
27.5
0.8
225
2.2
31.0
18.0
11.0
27.5
0.8
31.0
21.0
13.0
27.5
0.8
31.0
26.0
15.5
27.5
0.8
335
3.3
31.0
21.0
12.0
27.5
0.8
31.0
25.0
15.5
27.5
0.8
475
4.7
31.0
26.0
15.0
27.5
0.8
685
6.8
34.0
28.0
16.0
31.0
0.8
P
10.0
15.0
22.5
27.5
31.0
106
10.0
34.0
31.0
18.5
31.0
0.8
TOL
±1.0
±1.0
±1.0
±1.5
±1.5
*Please contact us for special item or size not listed
我司料号
µF / V
Tolerance
Wmax
Hmax
Tmax Pediform
P
L0
dØ
PMPR103J630D01
PMPR104J630D03
PMPR104J400D02
0.01µF / 630VDC
0.1µF / 630VDC
0.1µF / 400VDC
±5%
±5%
±5%
13.0
18.0
13.0
11.0
14.0
13.0
7.0
8.5
7.5
A#
A#
A#
10.0
15.0
10.0
0.6
0.8
0.6
PMPR104J100D01
0.1µF / 100VDC
±5%
13.0
11.0
7.0
A#
10.0
0.6
PMPR224K100D01
0.22µF / 100VDC
±10%
18.0
12.0
7.5
A#
15.0
0.8
PMPR473J630D02
0.047µF / 630VDC
±5%
18.5
14.0
8.5
A#
15.0
0.8
PMPR224J400D02
0.22µF / 400VDC
±5%
18.0
15.5
10.0
A#
15.0
0.8
很抱歉,暂时无法提供与“PMPR104J100D01”相匹配的价格&库存,您可以联系我们找货
