MINIATURE SMD CHIP CHOKE COILS
非 屏 蔽 贴 片 功 率 电 感
Unshielded SMD Power Inductors
O p e r a t i n g Te m p : - 2 0 ℃ ~ 8 5 ℃
特征:
FEATURES:
镀银型,低成本的设计。
● Silver plated type, Low cost design.
具有高功率,强力高饱和电流。
● High power, high saturation inductors.
交易电感器的直流-直流转换。
适用于编带和自动电器表面安装。
● Available on tape and reelfor auto surface mounting.
Ideal inductorsfor DC-DC conversion.
用途:
APPLICATIONS:
录影机。
Power supply for VTRs.
液晶电视。
LCD televisions.
笔记本电脑。
Notebook PCs.
小型通信机器。
Portable communication equipment.
DC/DC 变压器之电源供应器等。
DC/DC converters, etc.
PRODUCT
产品型号:
IDENTIFICATION:
SM
1054
100
K
T
①
②
③
④
⑤
①
②
③
类型 Type
非屏蔽贴片功率电感
SM
外形尺寸(L×H) (mm)
Inductance
External Dimensions (L×H) (mm)
10 uH
Unshielded SMT Power
Inductors
④
1054
10×5.4
⑤
Tolerance
包装 Packing
J:±5%,K: ±10%, L: ±15%
B
散装 Bulk Package
M: ±20%,P: ±25%, N: ±30%
T
编带Tape & Reel
Shape and Size(Dimension are in mm):
※48.0
Part
No
A
B
C
H
I
J
SM3511
3.5±0.3
3.0±0.3
1.1±0.2
3.5
1.6
0.8
SM3516
3.5±0.3
3.0±0.3
1.6±0.2
3.5
1.6
0.8
SM3521
3.5±0.3
3.0±0.3
2.1±0.3
3.5
1.6
0.8
SM4532
4.5±0.3
4.0±0.3
3.2±0.3
4.5
1.75
1.5
SM5825
5.8±0.3
5.2±0.3
2.5±0.3
5.5
2.15
1.7
SM5835
5.8±0.3
5.2±0.3
3.5±0.3
5.5
2.15
1.7
SM5845
5.8±0.3
5.2±0.3
4.5±0.35
5.5
2.15
1.7
SM7835
7.8±0.3
7.0±0.3
3.5±0.5
7.5
3.0
2.0
SM7850
7.8±0.3
7.0±0.3
5.0±0.5
7.5
3.0
2.0
SM1040
10.0±0.3
9.0±0.3
4.0±0.5
9.5
3.75
2.5
SM1054
10.0±0.3
9.0±0.3
5.4±0.5
9.5
3.75
2.5
SM3511 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM3511-2R2M
2.2
M
100KHz
1MHz
0.24
62
1.0
SM3511-3R3M
3.3
M
100KHz
1MHz
0.27
47
0.90
SM3511-4R7M
4.7
M
100KHz
30
1MHz
0.30
38
0.80
SM3511-6R8M
6.8
M
100KHz
30
1MHz
0.47
31
0.76
SM3511-8R2M
8.2
M
100KHz
30
1MHz
0.52
27
0.72
SM3511-100M
10.0
M
100KHz
30
1MHz
0.55
23
0.66
SM3511-120M
12.0
M
100KHz
30
1MHz
0.75
21
0.54
SM3511-150M
15.0
M
100KHz
30
1MHz
0.91
19
0.45
SM3511-220M
22.0
M
100KHz
30
1MHz
1.20
15
0.36
SM3511-270M
27.0
M
100KHz
30
1MHz
1.50
14
0.30
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
SM3516 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM3516-2R2M
2.2
M
100KHz
1MHz
0.24
62
1.20
SM3516-3R3M
3.3
M
100KHz
1MHz
0.27
47
1.08
SM3516-4R7M
4.7
M
100KHz
30
1MHz
0.30
38
1.00
SM3516-6R8M
6.8
M
100KHz
30
1MHz
0.47
31
0.80
SM3516-8R2M
8.2
M
100KHz
30
1MHz
0.52
27
0.76
SM3516-100M
10.0
M
100KHz
30
1MHz
0.55
23
0.70
SM3516-120M
12.0
M
100KHz
30
1MHz
0.75
21
0.60
SM3516-150M
15.0
M
100KHz
30
1MHz
0.91
19
0.50
SM3516-220M
22.0
M
100KHz
30
1MHz
1.20
15
0.40
SM3516-270M
27.0
M
100KHz
30
1MHz
1.50
14
0.36
※49.0
SM3521 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
Test
Spec.
Test
Freq
Min
Freq.
Max
Min
(Amp)Max
SM3521-1R0M
1.0
M
100KHz
1MHz
0.045
120
2.20
SM3521-1R2M
1.2
M
100KHz
1MHz
0.050
100
2.10
SM3521-1R5M
1.5
M
100KHz
1MHz
0.055
85
1.70
SM3521-1R8M
1.8
M
100KHz
1MHz
0.070
75
1.65
SM3521-2R2M
2.2
M
100KHz
1MHz
0.085
62
1.60
SM3521-2R7M
2.7
M
100KHz
1MHz
0.100
53
1.40
SM3521-3R3M
3.3
M
100KHz
1MHz
0.120
47
1.04
SM3521-3R9M
3.9
M
100KHz
1MHz
0.125
41
1.00
SM3521-4R7M
4.7
M
100KHz
30
1MHz
0.135
38
1.00
SM3521-5R6M
5.6
M
100KHz
30
1MHz
0.145
33
0.95
SM3521-6R8M
6.8
M
100KHz
30
1MHz
0.20
31
0.95
SM3521-8R2M
8.2
M
100KHz
30
1MHz
0.25
27
0.92
SM3521-100M
10
M
100KHz
35
1MHz
0.32
23
0.90
SM3521-120M
12
M
100KHz
35
1MHz
0.35
21
0.85
SM3521-150M
15
M
100KHz
35
1MHz
0.46
19
0.75
SM3521-180M
18
M
100KHz
35
1MHz
0.52
17
0.70
SM3521-220M
22
M
100KHz
35
1MHz
0.65
15
0.60
SM3521-270M
27
M
100KHz
35
1MHz
0.75
14
0.55
SM3521-330M
33
M
100KHz
35
1MHz
0.92
12
0.50
SM3521-390M
39
M
100KHz
35
1MHz
1.12
11
0.48
SM3521-470M
47
M
100KHz
35
1MHz
1.27
10
0.45
SM3521-560M
56
M
100KHz
35
1MHz
1.50
9.3
0.30
SM3521-680M
68
M
100KHz
35
1MHz
2.00
8.4
0.26
SM3521-820M
82
M
100KHz
35
1MHz
2.15
7.5
0.23
SM3521-101M
100
M
100KHz
40
796MHz
2.80
6.8
0.20
SM3521-121K
120
K
100KHz
40
796MHz
3.40
6.2
0.18
SM3521-151K
150
K
100KHz
40
796MHz
4.20
5.5
0.16
SM3521-181K
180
K
100KHz
40
796MHz
4.50
5.0
0.15
SM3521-221K
220
K
100KHz
40
796MHz
5.70
4.5
0.14
SM3521-271K
270
K
100KHz
40
796MHz
8.50
4.0
0.10
SM3521-331K
330
K
100KHz
40
796MHz
9.50
3.6
0.09
※50.0
SM4532 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
(OHM)
(MHz)
Current
Min
(Amp)Max
Test
Spec.
Test
Freq
Min
Freq.
Max
Rated DC
SM4532-1R0M
1.0
M
100KHz
1MHz
0.0487
120
2.56
SM4532-1R4M
1.4
M
100KHz
1MHz
0.0562
95
2.52
SM4532-1R8M
1.8
M
100KHz
1MHz
0.0637
75
1.95
SM4532-2R2M
2.2
M
100KHz
1MHz
0.0712
62
1.75
SM4532-2R7M
2.7
M
100KHz
1MHz
0.0787
53
1.58
SM4532-3R3M
3.3
M
100KHz
1MHz
0.0862
47
1.44
SM4532-3R9M
3.9
M
100KHz
1MHz
0.0937
41
1.33
SM4532-4R7M
4.7
M
100KHz
30
1MHz
0.1087
38
1.15
SM4532-5R6M
5.6
M
100KHz
30
1MHz
0.1257
33
0.99
SM4532-6R8M
6.8
M
100KHz
30
1MHz
0.1312
31
0.95
SM4532-8R2M
8.2
M
100KHz
30
1MHz
0.1462
27
0.84
SM4532-100M
10
M
100KHz
35
1MHz
0.182
23
1.04
SM4532-120M
12
M
100KHz
35
1MHz
0.210
21
0.97
SM4532-150M
15
M
100KHz
35
1MHz
0.235
19
0.85
SM4532-180M
18
M
100KHz
35
1MHz
0.338
17
0.74
SM4532-220M
22
M
100KHz
35
1MHz
0.378
15
0.68
SM4532-270M
27
M
100KHz
35
1MHz
0.522
14
0.62
SM4532-330M
33
M
100KHz
35
1MHz
0.540
12
0.56
SM4532-390M
39
M
100KHz
35
1MHz
0.587
11
0.52
SM4532-470K
47
K
100KHz
35
1MHz
0.844
10
0.44
SM4532-560K
56
K
100KHz
35
1MHz
0.937
9.3
0.42
SM4532-680K
68
K
100KHz
35
1MHz
1.117
8.4
0.37
※51.0
SM5825 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
(OHM)
(MHz)
Current
Min
(Amp)Max
Test
Spec.
Test
Freq
Min
Freq.
Max
Rated DC
SM5825-1R2M
1.2
M
100KHz
1MHz
0.050
100
4.20
SM5825-1R5M
1.5
M
100KHz
1MHz
0.060
85
4.00
SM5825-1R8M
1.8
M
100KHz
1MHz
0.065
75
3.70
SM5825-2R2M
2.2
M
100KHz
1MHz
0.07
62
3.50
SM5825-2R7M
2.7
M
100KHz
1MHz
0.08
53
3.20
SM5825-3R3M
3.3
M
100KHz
1MHz
0.10
47
2.70
SM5825-3R9M
3.9
M
100KHz
1MHz
0.12
41
2.40
SM5825-4R7M
4.7
M
100KHz
30
1MHz
0.14
38
2.00
SM5825-5R6M
5.6
M
100KHz
30
1MHz
0.15
33
1.80
SM5825-6R8M
6.8
M,
100KHz
30
1MHz
0.16
31
1.50
SM5825-8R2M
8.2
M
100KHz
30
1MHz
0.18
27
1.40
SM5825-100M
10
M
100KHz
35
1MHz
0.20
23
1.30
SM5825-120M
12
M
100KHz
35
1MHz
0.23
21
1.10
SM5825-150M
15
M
100KHz
35
1MHz
0.25
19
1.05
SM5825-180M
18
M
100KHz
35
1MHz
0.30
17
1.00
SM5825-220M
22
M
100KHz
35
1MHz
0.35
15
0.90
SM5825-270M
27
M
100KHz
35
1MHz
0.40
14
0.85
SM5825-330M
33
M
100KHz
35
1MHz
0.50
12
0.75
SM5825-390M
39
M
100KHz
35
1MHz
0.55
11
0.70
SM5825-470K
47
K
100KHz
35
1MHz
0.65
10
0.60
SM5825-560K
56
K
100KHz
35
1MHz
0.75
9.3
0.55
SM5825-680K
68
K
100KHz
35
1MHz
0.95
8.4
0.50
SM5825-820K
82
K
100KHz
35
1MHz
1.20
7.5
0.45
SM5825-101K
100
K
100KHz
40
796MHz
1.40
6.8
0.40
SM5825-121K
120
K
100KHz
40
796MHz
1.75
6.2
0.35
SM5825-151K
150
K
100KHz
40
796MHz
2.00
5.5
0.25
SM5825-181K
180
K
100KHz
40
796MHz
2.60
5.0
0.22
SM5825-221K
220
K
100KHz
40
796MHz
3.00
4.5
0.20
SM5825-271K
270
K
100KHz
40
796MHz
3.70
4.0
0.18
SM5825-331K
330
K
100KHz
40
796MHz
4.30
3.6
0.17
SM5825-391K
390
K
100KHz
40
796MHz
6.00
3.0
0.16
SM5825-471
470
K
100KHz
40
796MHz
6.70
2.7
0.15
※52.0
SM5830 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM5830-1R0M
1.0
M
100KHz
1MHz
0.03
120
4.50
SM5830-1R2M
1.2
M
100KHz
1MHz
0.03
100
4.20
SM5830-1R5M
1.5
M
100KHz
1MHz
0.03
85
4.10
SM5830-1R8M
1.8
M
100KHz
1MHz
0.03
75
3.70
SM5830-2R2M
2.2
M
100KHz
1MHz
0.03
62
3.50
SM5830-2R7M
2.7
M
100KHz
1MHz
0.04
53
3.20
SM5830-3R3M
3.3
M
100KHz
1MHz
0.05
47
2.80
SM5830-3R9M
3.9
M
100KHz
1MHz
0.06
41
2.60
SM5830-4R7M
4.7
M
100KHz
30
1MHz
0.07
38
2.50
SM5830-5R6M
5.6
M
100KHz
30
1MHz
0.08
33
2.40
SM5830-6R8M
6.8
M
100KHz
30
1MHz
0.09
31
2.20
SM5830-8R2M
8.2
M
100KHz
30
1MHz
0.10
27
2.00
SM5830-100M
10
M
100KHz
35
1MHz
0.13
23
1.80
SM5830-120M
12
M
100KHz
35
1MHz
0.16
21
1.75
SM5830-150M
15
M
100KHz
35
1MHz
0.19
19
1.70
SM5830-180M
18
M
100KHz
35
1MHz
0.21
17
1.60
SM5830-220M
22
M
100KHz
35
1MHz
0.28
15
1.50
SM5830-270M
27
M
100KHz
35
1MHz
0.32
14
1.40
SM5830-330M
33
M
100KHz
35
1MHz
0.38
12
1.10
SM5830-390M
39
M
100KHz
35
1MHz
0.42
11
1.00
SM5830-470K
47
K
100KHz
35
1MHz
0.52
10
0.90
SM5830-560K
56
K
100KHz
35
1MHz
0.56
9.3
0.85
SM5830-680K
68
K
100KHz
35
1MHz
0.68
8.4
0.80
SM5830-820K
82
K
100KHz
35
1MHz
0.82
7.5
0.65
SM5830-101K
100
K
100KHz
40
796MHz
1.10
6.8
0.60
SM5830-121K
120
K
100KHz
40
796MHz
1.20
6.2
0.58
SM5830-151K
150
K
100KHz
40
796MHz
1.50
5.5
0.43
SM5830-181K
180
K
100KHz
40
796MHz
1.80
5.0
0.41
SM5830-221K
220
K
100KHz
40
796MHz
2.00
4.5
0.37
SM5830-271K
270
K
100KHz
40
796MHz
2.90
4.0
0.35
SM5830-331K
330
K
100KHz
40
796MHz
3.30
3.6
0.28
SM5830-391K
390
K
100KHz
40
796MHz
3.70
3.0
0.260
SM5830-471K
470
K
100KHz
40
796MHz
4.90
2.7
0.200
※53.0
SM5845 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
(OHM)
(MHz)
Current
Min
(Amp)Max
Test
Spec.
Test
Freq.
Min
Freq.
Max
Rated DC
SM5845-100M
10
M
100KHz
35
1MHz
0.10
23
1.44
SM5845-120M
12
M
100KHz
35
1MHz
0.12
21
1.40
SM5845-150M
15
M
100KHz
35
1MHz
0.14
19
1.30
SM5845-180M
18
M
100KHz
35
1MHz
0.15
17
1.23
SM5845-220M
22
M
100KHz
35
1MHz
0.18
15
1.11
SM5845-270M
27
M
100KHz
35
1MHz
0.20
14
0.97
SM5845-330M
33
M
100KHz
35
1MHz
0.23
12
0.88
SM5845-390M
39
M
100KHz
35
1MHz
0.32
11
0.80
SM5845-470K
47
K
100KHz
35
1MHz
0.37
10
0.72
SM5845-560K
56
K
100KHz
35
1MHz
0.42
9.3
0.68
SM5845-680K
68
K
100KHz
35
1MHz
0.46
8.4
0.61
SM5845-820K
82
K
100KHz
35
1MHz
0.60
7.5
0.58
SM5845-101K
100
K
100KHz
40
796MHz
0.70
6.8
0.52
SM5845-121K
120
K
100KHz
40
796MHz
0.93
6.2
0.48
SM5845-151K
150
K
100KHz
40
796MHz
1.10
5.5
0.40
SM5845-181K
180
K
100KHz
40
796MHz
1.83
5.0
0.38
SM5845-221K
220
K
100KHz
40
796MHz
1.57
4.5
0.35
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
SM7835 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM7835-100M
10
M
100KHz
1MHz
0.0803
120
1.44
SM7835-120M
12
M
100KHz
1MHz
.0897
100
1.39
SM7835-150M
15
M
100KHz
1MHz
0.104
95
1.24
SM7835-180M
18
M
100KHz
1MHz
0.111
85
1.12
SM7835-220M
22
M
100KHz
1MHz
0.129
75
1.07
SM7835-270M
27
M
100KHz
1MHz
0.153
62
0.94
SM7835-330M
33
M
100KHz
1MHz
0.170
53
0.85
SM7835-390M
39
M
100KHz
1MHz
0.217
47
0.74
SM7835-470K
47
K
100KHz
1MHz
0.252
41
0.68
SM7835-560K
56
K
100KHz
30
1MHz
0.282
38
0.64
SM7835-680K
68
K
100KHz
30
1MHz
33
0.59
SM7835-820K
82
K
100KHz
30
1MHz
0.406
31
0.54
SM7835-101K
100
K
100KHz
30
1MHz
0.481
27
0.51
SM7835-121K
120
K
100KHz
35
1MHz
0.536
23
0.49
0.332
※54.0
SM7835 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM7835-121K
120
K
100KHz
35
1MHz
0.536
23
0.49
SM7835-151K
150
K
100KHz
35
1MHz
0.755
21
0.40
SM7835-181K
180
K
100KHz
35
1MHz
1.022
19
0.36
SM7835-221K
220
K
100KHz
35
1MHz
1.200
17
0.31
SM7835-271K
270
K
100KHz
35
1MHz
1.306
15
0.29
SM7835-331K
330
K
100KHz
35
1MHz
1.495
14
0.28
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
SM7850 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM7850-100M
10
M
100KHz
1MHz
0.07
120
2.30
SM7850-120M
12
M
100KHz
1MHz
0.08
100
2.00
SM7850-150M
15
M
100KHz
1MHz
0.09
95
1.80
SM7850-180M
18
M
100KHz
1MHz
0.10
85
1.60
SM7850-220M
22
M
100KHz
1MHz
0.11
75
1.50
SM7850-270M
27
M
100KHz
1MHz
0.12
62
1.30
SM7850-330M
33
M
100KHz
1MHz
0.13
53
1.20
SM7850-390M
39
M
100KHz
1MHz
0.16
47
1.10
SM7850-470K
47
K
100KHz
1MHz
0.18
41
1.10
SM7850-560K
56
K
100KHz
30
1MHz
0.24
38
0.94
SM7850-680K
68
K
100KHz
30
1MHz
0.28
33
0.85
SM7850-820K
82
K
100KHz
30
1MHz
0.37
31
0.78
SM7850-101K
100
K
100KHz
30
1MHz
0.43
27
0.72
SM7850-121K
120
K
100KHz
35
1MHz
0.47
23
0.66
SM7850-151K
150
K
100KHz
35
1MHz
0.64
21
0.58
SM7850-181K
180
K
100KHz
35
1MHz
0.71
19
0.51
SM7850-221K
220
K
100KHz
35
1MHz
0.96
17
0.49
SM7850-271K
270
K
100KHz
35
1MHz
1.11
15
0.42
SM7850-331K
330
K
100KHz
35
1MHz
1.26
14
0.40
SM7850-391K
390
K
100KHz
35
1MHz
1.77
12
0.36
SM7850-471K
470
K
100KHz
35
1MHz
1.96
11
0.34
※55.0
SM1040Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM1040-100M
10
M
100KHz
1MHz
0.053
120
2.38
SM1040-120M
12
M
100KHz
1MHz
0.061
100
2.13
SM1040-150M
15
M
100KHz
1MHz
0.070
95
1.87
SM1040-180M
18
M
100KHz
1MHz
0.071
85
1.73
SM1040-220M
22
M
100KHz
1MHz
0.088
75
1.60
SM1040-270M
27
M
100KHz
1MHz
0.100
62
1.44
SM1040-330M
33
M
100KHz
1MHz
0.120
53
1.26
SM1040-390M
39
M
100KHz
1MHz
0.151
47
1.20
SM1040-470K
47
K
100KHz
1MHz
0.170
41
1.10
SM1040-560K
56
K
100KHz
30
1MHz
0.199
38
1.01
SM1040-680K
68
K
100KHz
30
1MHz
0.223
33
0.91
SM1040-820K
82
K
100KHz
30
1MHz
0.252
31
0.85
SM1040-101K
100
K
100KHz
30
1MHz
0.344
27
0.74
SM1040-121K
120
K
100KHz
35
1MHz
0.396
23
0.69
SM1040-151K
150
K
100KHz
35
1MHz
0.544
21
0.61
SM1040-181K
180
K
100KHz
35
1MHz
0.621
19
0.56
SM1040-221K
220
K
100KHz
35
1MHz
0.721
17
0.53
SM1040-271K
270
K
100KHz
35
1MHz
0.949
15
0.45
SM1040-331K
330
K
100KHz
35
1MHz
1.100
14
0.42
SM1040-391K
390
K
100KHz
35
1MHz
1.245
12
0.38
SM1040-471K
470
K
100KHz
35
1MHz
1.526
11
0.35
SM1040-561K
560
K
100KHz
35
1MHz
1.904
10
0.32
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
SM1054 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM1054-100M
10
M
100KHz
1MHz
0.06
120
2.60
SM1054-120M
12
M
100KHz
1MHz
0.07
100
2.45
SM1054-150M
15
M
100KHz
1MHz
0.08
95
2.27
SM1054-180M
18
M
100KHz
1MHz
0.09
85
2.15
SM1054-220M
22
M
100KHz
1MHz
0.10
75
1.95
SM1054-270M
27
M
100KHz
1MHz
0.11
62
1.76
SM1054-330M
33
M
100KHz
1MHz
0.12
53
1.50
SM1054-390M
39
M
100KHz
1MHz
0.14
47
1.37
※56.0
SM105 Series
Inductance(uH)
Part
No.
Nominal
Value
Tole.
Quality Factor
DCR
SRF
Rated DC
(OHM)
(MHz)
Current
Test
Spec.
Test
Freq.
Min
Freq.
Max
Min
(Amp)Max
SM1054-470K
47
K
100KHz
1MHz
0.17
41
1.28
SM1054-560K
56
K
100KHz
30
1MHz
0.19
38
1.17
SM1054-680K
68
K
100KHz
30
1MHz
0.22
33
1.11
SM1054-820K
82
K
100KHz
30
1MHz
0.25
31
1.00
SM1054-101K
100
K
100KHz
30
1MHz
0.35
27
0.97
SM1054-121K
120
K
100KHz
35
1MHz
0.40
23
0.89
SM1054-151K
150
K
100KHz
35
1MHz
0.47
21
0.78
SM1054-181K
180
K
100KHz
35
1MHz
0.63
19
0.72
SM1054-221K
220
K
100KHz
35
1MHz
0.73
17
0.66
SM1054-271K
270
K
100KHz
35
1MHz
0.97
15
0.57
SM1054-331K
330
K
100KHz
35
1MHz
1.15
14
0.52
SM1054-391K
390
K
100KHz
35
1MHz
1.30
12
0.48
SM1054-471K
470
K
100KHz
35
1MHz
1.48
11
0.42
SM1054-561K
560
K
100KHz
35
1MHz
1.90
10
0.33
SM1054-681K
680
K
100KHz
35
1MHz
2.25
9.3
0.28
SM1054-821K
820
K
100KHz
35
1MHz
2.55
8.4
0.24
※57.0
很抱歉,暂时无法提供与“SM5845-101KT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48348
- 100+0.43844
- 500+0.39339
- 1000+0.34835
- 2000+0.31832
- 4000+0.30931
