RTL8201BL-LF
RTL8201BL-LF
    REALTEK(瑞昱)
    单芯片 单端口 10/100M
RTL8201BL-LF 数据手册
RTL8201BL RTL8201BL-LF SINGLE CHIP SINGLE PORT 10/100M FAST ETHERNET PHYCEIVER DATASHEET Rev. 1.3 26 July 2005 Track ID: JATR-1076-21 RTL8201BL Datasheet COPYRIGHT ©2005 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document “as is”, without warranty of any kind, neither expressed nor implied, including, but not limited to, the particular purpose. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. USING THIS DOCUMENT This document is intended for the hardware and software engineer’s general information on the Realtek RTL8201BL chip. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. In that event, please contact your Realtek representative for additional information that may help in the development process. REVISION HISTORY Revision 1.1 Release Date 2002/02/01 1.2 2002/03/29 Summary Power Dissipation: Remove 2.5V power consumption 100Mbps Network Interface: R5 is changed from 5.6K to 5.9K Reset, and Transmit Bias(RTSET): R5 is changed from 5.6K to 5.9K Schematic Layout: R5 is changed from 5.6K to 5.9K Reset and other pins: Add pin description for pin 32 and pin 8 Power and Ground pins: Remove pin description of pin 32 and pin 8 3.3V power supply and voltage conversion circuit: Add description: “Strongly emphasize here, could not provide external 2.5V produced by any other power device for PWFBOUT and PWFBIN”. Schematic Layout: 1. Modify net label: Pin32: AVDD25 -> PWFBOUT Pin8: DVDD25-> PWFBIN 1.3 2005/07/26 2. Add pull-high resistor for MDIO 3. Modify ResetB circuit to meet wake-on-LAN application Cosmetic layout changes Single Chip Single Port 10/100M Fast Ethernet Phyceiver ii Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet Table of Contents 1. INTRODUCTION ...............................................................................................................................1 2. SYSTEM APPLICATIONS................................................................................................................1 3. FEATURES ..........................................................................................................................................2 4. BLOCK DIAGRAM............................................................................................................................3 5. PIN ASSIGNMENTS ..........................................................................................................................4 5.1. 6. PIN DESCRIPTION............................................................................................................................5 6.1. 6.2. 6.3. 6.4. 6.5. 6.6. 6.7. 6.8. 7. 100MBPS MII & PCS INTERFACE ..................................................................................................5 SNI (SERIAL NETWORK INTERFACE): 10MBPS ONLY .....................................................................5 CLOCK INTERFACE .........................................................................................................................6 100MBPS NETWORK INTERFACE ....................................................................................................6 DEVICE CONFIGURATION INTERFACE.............................................................................................6 LED INTERFACE/PHY ADDRESS CONFIG ......................................................................................7 RESET AND OTHER PINS .................................................................................................................7 POWER AND GROUND PINS ............................................................................................................7 REGISTER DESCRIPTIONS............................................................................................................8 7.1. 7.2. 7.3. 7.4. 7.5. 7.6. 7.7. 7.8. 7.9. 7.10. 7.11. 7.12. 7.13. 7.14. 7.15. 7.16. 7.17. 8. LEAD (PB)-FREE PACKAGE AND VERSION IDENTIFICATION ...........................................................4 REGISTER 0 BASIC MODE CONTROL REGISTER ..............................................................................8 REGISTER 1 BASIC MODE STATUS REGISTER .................................................................................9 REGISTER 2 PHY IDENTIFIER REGISTER 1......................................................................................9 REGISTER 3 PHY IDENTIFIER REGISTER 2......................................................................................9 REGISTER 4 AUTO-NEGOTIATION ADVERTISEMENT REGISTER(ANAR).......................................10 REGISTER 5 AUTO-NEGOTIATION LINK PARTNER ABILITY REGISTER(ANLPAR).......................10 REGISTER 6 AUTO-NEGOTIATION EXPANSION REGISTER(ANER)................................................11 REGISTER 16 NWAY SETUP REGISTER(NSR) ...............................................................................11 REGISTER 17 LOOPBACK, BYPASS, RECEIVER ERROR MASK REGISTER(LBREMR)....................12 REGISTER 18 RX_ER COUNTER(REC) ........................................................................................12 REGISTER19 10MBPS NETWORK INTERFACE CONFIGURATIONREGISTER ......................................................12 REGISTER 20 PHY 1_1 REGISTER ................................................................................................13 REGISTER 21 PHY 1_2 REGISTER ................................................................................................13 REGISTER 22 PHY 2 REGISTER ....................................................................................................13 REGISTER 23 TWISTER_1 REGISTER .............................................................................................13 REGISTER 24 TWISTER_2 REGISTER .............................................................................................13 REGISTER 25 TEST REGISTER .......................................................................................................13 FUNCTIONAL DESCRIPTION......................................................................................................14 8.1. MII AND MANAGEMENT INTERFACE ............................................................................................14 Single Chip Single Port 10/100M Fast Ethernet Phyceiver iii Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.1.1. Data Transition ....................................................................................................................14 8.1.2. Serial Management...............................................................................................................15 8.2. AUTO-NEGOTIATION AND PARALLEL DETECTION ........................................................................15 8.3. FLOW CONTROL SUPPORT ............................................................................................................17 8.4. HARDWARE CONFIGURATION AND AUTO-NEGOTIATION..............................................................17 8.5. LED AND PHY ADDRESS CONFIGURATION .................................................................................18 8.6. SERIAL NETWORK INTERFACE .....................................................................................................18 8.7. POWER DOWN, LINK DOWN, POWER SAVING, ANDISOLATIONMODES..........................................................19 8.8. MEDIA INTERFACE .......................................................................................................................19 8.8.1. 100Base-TX ..........................................................................................................................19 8.8.2. 100Base-FX Fiber Mode Operation.....................................................................................20 8.8.3. 10Base-Tx/Rx........................................................................................................................20 8.9. REPEATER MODE OPERATION ......................................................................................................20 8.10. RESET, AND TRANSMIT BIAS (RTSET) ........................................................................................20 8.11. 3.3V POWER SUPPLY AND VOLTAGE CONVERSION CIRCUIT ........................................................21 8.12. FAR END FAULT INDICATION .......................................................................................................21 9. ELECTRICAL CHARACTERISTICS ...........................................................................................22 9.1. D.C. CHARACTERISTICS ...............................................................................................................22 9.1.1. Absolute Maximum Ratings..................................................................................................22 9.1.2. Operating Conditions ...........................................................................................................22 9.1.3. Power Dissipation ................................................................................................................22 9.1.4. Supply Voltage: Vcc .............................................................................................................22 9.2. A.C. CHARACTERISTICS ...............................................................................................................23 9.2.1. MII Timing of Transmission Cycle.......................................................................................23 9.2.2. MII Timing of Reception Cycle ............................................................................................24 9.2.3. SNI Timing of Transmission Cycle.......................................................................................26 9.2.4. SNI Timing of Reception Cycle ............................................................................................27 9.2.5. MDC/MDIO timing ..............................................................................................................28 9.2.6. Transmission Without Collision ...........................................................................................28 9.2.7. Reception Without Error ......................................................................................................29 9.3. CRYSTAL AND TRANSFORMER SPECIFICATIONS ...........................................................................30 9.3.1. Crystal Specifications...........................................................................................................30 9.3.2. Transformer Specifications ..................................................................................................30 10. MECHANICAL DIMENSIONS ..................................................................................................31 11. ORDERING INFORMATION.....................................................................................................32 Single Chip Single Port 10/100M Fast Ethernet Phyceiver iv Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 1. Introduction The RTL8201BL is a single-port Phyceiver with an MII (Media Independent Interface)/SNI(Serial Network Interface). It implements all 10/100M Ethernet Physical-layer functions including the Physical Coding Sublayer (PCS), Physical Medium Attachment (PMA), Twisted Pair Physical Medium Dependent Sublayer (TP-PMD), 10Base-Tx Encoder/Decoder and Twisted Pair Media Access Unit (TPMAU). A PECL interface is supported to connect with an external 100Base-FX fiber optical transceiver. The chip is fabricated with an advanced CMOS process to meet low voltage and low power requirements. The RTL8201BL can be used in a NIC, MAU, CNR, ACR, Ethernet Hub, or Ethernet Switch. Additionally, it can be used in any embedded system with an Ethernet MAC that needs a twisted pair physical connection or fiber PECL interface to an external 100Base-FX optical transceiver module. 2. System Applications „ LOC (LAN on Chipset) „ NIC (Network Interface Card) „ MAU (Media Attachment Unit) „ CNR (Communication and Networking Riser) „ ACR (Advanced Communication Riser) „ Ethernet Hub, Ethernet Switch Single Chip Single Port 10/100M Fast Ethernet Phyceiver 1 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 3. Features The Realtek RTL8201BL is a Fast Ethernet Phyceiver with selectable MII or SNI interface to the MAC chip. It provides the following features: „ Supports MII/7-wire SNI (Serial Network Interface) interface „ Supports 10/100Mbps operation „ Supports half/full duplex operation „ Support of twisted pair or Fiber mode output „ Speed/duplex/auto negotiation adjustable „ 3.3V operation with 5V IO signal tolerance „ Low operation power consumption and only need single supply 3.3V „ IEEE 802.3/802.3u compliant „ Adaptive Equalization „ Supports IEEE 802.3u clause 28 auto „ 25MHz crystal/oscillator as clock negotiation source „ Supports power down mode „ Multiple network status LED support „ Supports operation under Link Down „ Flow control ability support to co-work Power Saving mode „ Supports Base Line Wander (BLW) with MAC (by MDC/MDIO) „ 48 pin LQFP package compensation „ Supports repeater mode Single Chip Single Port 10/100M Fast Ethernet Phyceiver 2 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 4. Block Diagram Single Chip Single Port 10/100M Fast Ethernet Phyceiver 3 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 5. Pin Assignments 5.1. Lead (Pb)-Free Package and Version Identification Lead (Pb)-free package is indicated by an ‘L’ in the location marked ‘T’ in the figure above. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 4 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 6. Pin Description LI: Latched Input in power up or reset I: Input P: Power I/O: Bi-directional input and output O: Output 6.1. 100Mbps MII & PCS Interface Symbol Type Pin No. Description TXC O 7 TXEN I 2 TXD[3:0] I 3, 4, 5, 6 RXC O 16 COL CRS RXDV O O O 1 23 22 RXD[3:0] O 18, 19, 20, 21 O/LI 24 Transmit Clock: This pin provides a continuous clock as a timing reference for TXD[3:0] and TXEN. Transmit Enable: The input signal indicates the presence of a valid nibble data on TXD[3:0]. Transmit Data: MAC will source TXD[0..3] synchronous with TXC when TXEN is asserted. Receive Clock: This pin provides a continuous clock reference for RXDV and RXD[0..3] signals. RXC is 25MHz in the 100Mbps mode and 2.5Mhz in the 10Mbps mode. Collision Detected: COL is asserted high when a collision is detected on the media. Carrier Sense: This pin’s signal is asserted high if the media is not in IDEL state. Receive Data Valid: This pin’s signal is asserted high when received data is present on the RXD[3:0] lines; the signal is deasserted at the end of the packet. The signal is valid on the rising of the RXC. Receive Data: These are the four parallel receive data lines aligned on the nibble boundaries driven synchronously to the RXC for reception by the external physical unit (PHY). Receive error: if any 5B decode error occurs, such as invalid J/K, T/R, invalid symbol, this pin will go high. Fiber/UTP Enable: During power on reset, this pin status is latched to determine at which media mode to operate: 1: Fiber mode 0: UTP mode An internal weak pull low resistor, sets this to the default of UTP mode. It is possible to use an external 5.1KΩ pull high resistor to enable fiber mode. After power on, the pin operates as the Receive Error pin. Management Data Clock: This pin provides a clock synchronous to MDIO, which may be asynchronous to the transmit TXC and receive RXC clocks. The clock rate can be up to 2.5MHz. Management Data Input/Output: This pin provides the bi-directional signal used to transfer management information. RXER/ FXEN MDC I MDIO I/O 25 26 6.2. SNI (Serial Network Interface): 10Mbps only Symbol COL RXD0 CRS RXC TXD0 TXC TXEN Type Pin No. O O O O I O I 1 21 23 16 6 7 2 Description Collision Detect Received Serial Data Carrier Sense Receive Clock: Resolved from received data Transmit Serial Data Transmit Clock: Generate by PHY Transmit Enable: For MAC to indicate transmit operation Single Chip Single Port 10/100M Fast Ethernet Phyceiver 5 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 6.3. Clock Interface Symbol X2 X1 Type O Pin No. 47 I 46 Description 25MHz Crystal Output: This pin provides the 25MHz crystal output. It must be left open when X1 is driven with an external 25MHz oscillator. 25MHz Crystal Input: This pin provides the 25MHz crystal input. If a 25MHz oscillator is used, connect X1 to the oscillator’s output. Refer to section 8.3 to obtain clock source specifications. 6.4. 100Mbps Network Interface Symbol Type Pin No. Description TPTX+ TPTX- O O 34 33 RTSET I 28 TPRX+ TPRX- I I 31 30 Transmit Output: Differential pair shared by 100Base-TX, 100Base-FX and 10Base-T modes. When configured as 100Base-TX, output is an MLT-3 encoded waveform. When configured as 100Base-FX, the output is pseudo-ECL level. Transmit Bias Resistor Connection: This pin should be pulled to GND by a 5.9KΩ (1%) resistor to define driving current for transmit DAC. The resistance value may be changed, depending on experimental results of the RTL8201BL. Receive Input: Differential pair shared by 100Base-TX, 100Base-FX, and 10Base-T modes. 6.5. Device Configuration Interface Symbol ISOLATE Type I Pin No. 43 RPTR I 40 SPEED LI 39 DUPLEX LI 38 ANE LI 37 LDPS I 41 LI/O 44 MII/SNIB/ RTT3(test) Description Set high to isolate the RTL8201BL from the MAC. This will also isolate the MDC/MDIO management interface. In this mode, the power consumption is minimum. This pin can be directly connected to GND or VCC. Set high to put the RTL8201BL into repeater mode. This pin can be directly connected to GND or VCC. This pin is latched to input during a power on or reset condition. Set high to put the RTL8201BL into 100Mbps operation. This pin can be directly connected to GND or VCC. This pin is latched to input during a power on or reset condition. Set high to enable full duplex. This pin can be directly connected to GND or VCC. This pin is latched to input during a power on or reset condition. Set high to enable Auto-negotiation mode, set low to force mode. This pin can be directly connected to GND or VCC. Set high to put the RTL8201BL into LDPS mode. This pin can be directly connected to GND or VCC. Refer to Section 7.7 for more information. This pin is latched to input during a power on or reset condition. Pull high to set the RTL8201BL into MII mode operation. Set low for SNI mode. This pin can be directly connected to GND or VCC. In test mode, this pin is an output pin and redefined as RTT3 Single Chip Single Port 10/100M Fast Ethernet Phyceiver 6 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 6.6. LED Interface/PHY Address Config These five pins are latched into the RTL8201BL during power up reset to configure PHY address [0:4] used for MII management register interface. And then, in normal operation after initial reset, they are used as driving pins for status indication LED. The driving polarity, active low or active high, is determined by each latched status of the PHY address [4:0] during power-up reset. If latched status is High then it will be active low, and if latched status is Low then it will be active high. Refer to Section 7.5 for more information. Symbol PHYAD0/ LED0 PAD1/ LED1 PHYAD2/ LED2 Type LI/O Pin No. 9 LI/O 10 LI/O 12 PHYAD3/ LED3 LI/O 13 PHYAD4/ LED4 LI/O 15 Description PHY Address [0] Link LED: Active when linked. PHY Address [1] Full Duplex LED: Active when in Full Duplex operation. PHY Address [2] Link 10/ACT LED: Active when linked in 10Base-T mode, and blinking when transmitting or receiving data. PHY Address [3] Link 100/ACT LED: Active when linked in 100Base-TX and blinking when transmitting or receiving data. PHY Address [4] Collision LED: Active when collisions occur. 6.7. Reset and Other Pins Symbol RESETB Type I Pin No. 42 PWFBOUT O 32 PWFBIN NC I 8 27 Description Set low to reset the chip. For a complete reset function, this pin RESETB: must be asserted low for at least 10ms. Power Feedback Output: Be sure to connect a 22uF tantalum capacitor for frequency compensation and a 0.1uF capacitor for noise de-coupling. Then connect this pin through a ferrite bead to PWFBIN(pin8). The connection method is figured in section 7.11. Power Feedback Input: see the description of PWFBOUT. Not connection 6.8. Power and Ground Pins Symbol AVDD33 Type P Pin No. 36 AGND DVDD33 DGND P P P 29,35 14,48 11,17,45 Description 3.3V Analog power input: 3.3V power supply for analog circuit; should be well decoupled. Analog Ground: Should be connected to a larger GND plane 3.3V Digital Power input: 3.3V power supply for digital circuit. Digital Ground: Should be connected to a larger GND plane. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 7 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 7. Register Descriptions This section will describe definitions and usage for each of the registers available in the RTL8201BL. 7.1. Register 0 Basic Mode Control Register Address 0: Name Reset 0: Loopback 0: Spd_Set 0: Auto Negotiation Enable 0: Power Down 0: 0: Reserved Restart Auto Negotiation 0: Duplex Mode 0: Reserved Description/Usage This bit sets the status and control registers of the PHY in a default state. This bit is self-clearing. 1 = software reset 0 = normal operation This bit enables loopback of transmit data nibbles TXD to the receive data path. 1 = enable loopback 0 = normal operation This bit sets the network speed. 1 = 100Mbps 0 = 10Mbps When 100Base-FX mode is enabled, this bit=1 and is read only. This bit enables/disables the Nway auto-negotiation function. 1 = enable auto-negotiation; bits 0: and 0: will be ignored. 0 = disable auto-negotiation; bits 0: and 0: will determine the link speed and the data transfer mode, respectively. When 100Base-FX mode is enabled, this bit=0 and is read only. This bit turns down the power of the PHY chip including internal crystal oscillator circuit. The MDC, MDIO is still alive for accessing the MAC. 1 = power down 0 = normal operation Default/Attribute 0, RW This bits allows the Nway auto-negotiation function to be reset. 1 = re-start auto-negotiation 0 = normal operation This bit sets the duplex mode if auto negotiation is disabled (bit 0:=0) 1 = full duplex 0 = half duplex After completing auto negotiation, this bit will reflect the duplex status.(1: Full duplex, 0: Half duplex) When 100Base-FX mode is enabled, this bit can be set through the MDC/MDIO SMI interface or DUPLEX pin. 0, RW Single Chip Single Port 10/100M Fast Ethernet Phyceiver 8 0, RW 1, RW 1, RW 0, RW 1, RW Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 7.2. Register 1 Basic Mode Status Register Address 1: 1: 1: 1: 1: 1: 1: 1: 1: 1: 1: 1: 1: Name 100Base-T4 Description/Usage 1 = enable 100Base-T4 support 0 = suppress 100Base-T4 support 100Base_TX_ 1 = enable 100Base-TX full duplex support FD 0 = suppress 100Base-TX full duplex support 100BASE_TX_ 1 = enable 100Base-TX half duplex support HD 0 = suppress 100Base-TX half duplex support 10Base_T_FD 1 = enable 10Base-T full duplex support 0 = suppress 10Base-T full duplex support 10_Base_T_HD 1 = enable 10Base-T half duplex support 0 = suppress 10Base-T half duplex support Reserved MF Preamble The RTL8201BL will accept management frames Suppression with preamble suppressed. The RTL8201BL accepts management frames without preamble. A Minimum of 32 preamble bits are required for the first SMI read/write transaction after reset. One idle bit is required between any two management transactions as per IEEE802.3u specifications Auto 1 = auto-negotiation process completed Negotiation 0 = auto-negotiation process not completed Complete Remote Fault 1 = remote fault condition detected (cleared on read) 0 = no remote fault condition detected When in 100Base-FX mode, this bit means an in-band signal Far-End-Fault is detected. Refer to Section 7.11. Auto 1 = Link had not been experienced fail state Negotiation 0 = Link had been experienced fail state Link Status 1 = valid link established 0 = no valid link established Jabber Detect 1 = jabber condition detected 0 = no jabber condition detected Extended 1 = extended register capability Capability 0 = basic register capability only Default/Attribute 0, RO 1, RO 1, RO 1, RO 1, RO 1, RO 0, RO 0, RO 1, RO 0, RO 0, RO 1, RO 7.3. Register 2 PHY Identifier Register 1 Address 2: Name PHYID1 PHY identifier RTL8201BL Description/Usage ID for software recognize Default/Attribute 0000, RO 7.4. Register 3 PHY Identifier Register 2 Address 3: Name PHYID2 Description/Usage PHY identifier ID for software recognize RTL8201 Single Chip Single Port 10/100M Fast Ethernet Phyceiver 9 Default/Attribute 8201, RO Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 7.5. Register 4 Auto-negotiation Advertisement Register(ANAR) This register contains the advertised abilities of this device as they will be transmitted to its link partner during Auto-negotiation. Address 4: Name NP 4: ACK 4: RF 4: 4: Reserved Pause 4: T4 4: TXFD 4: TX 4: 10FD 4: 10 4: Selector Description/Usage Next Page bit. 0 = transmitting the primary capability data page 1 = transmitting the protocol specific data page 1 = acknowledge reception of link partner capability data word 0 = do not acknowledge reception 1 = advertise remote fault detection capability 0 = do not advertise remote fault detection capability Default/Attribute 0, RO 1 = flow control is supported by local node 0 = flow control is NOT supported by local node 1 = 100Base-T4 is supported by local node 0 = 100Base-T4 not supported by local node 1 = 100Base-TX full duplex is supported by local node 0 = 100Base-TX full duplex not supported by local node 1 = 100Base-TX is supported by local node 0 = 100Base-TX not supported by local node 1 = 10Base-T full duplex supported by local node 0 = 10Base-T full duplex not supported by local node 1 = 10Base-T is supported by local node 0 = 10Base-T not supported by local node Binary encoded selector supported by this node. Currently only CSMA/CD is specified. No other protocols are supported. 0, RW 0, RO 0, RW 0, RO 1, RW 1, RW 1, RW 1, RW , RW 7.6. Register 5 Auto-Negotiation Link Partner Ability Register(ANLPAR) This register contains the advertised abilities of the Link Partner as received during Auto-negotiation. The content changes after the successful Auto-negotiation if Next-pages are supported. Address 5: Name NP 5: ACK 5: RF 5: 5: Reserved Pause 5: T4 5: TXFD Description/Usage Next Page bit. 0 = transmitting the primary capability data page 1 = transmitting the protocol specific data page 1 = link partner acknowledges reception of local node’s capability data word 0 = no acknowledgement 1 = link partner is indicating a remote fault 0 = link partner does not indicate a remote fault Default/Attribute 0, RO 1 = flow control is supported by Link partner 0 = flow control is NOT supported by Link partner 1 = 100Base-T4 is supported by link partner 0 = 100Base-T4 not supported by link partner 1 = 100Base-TX full duplex is supported by link partner 0 = 100Base-TX full duplex not supported by link partner 0, RO Single Chip Single Port 10/100M Fast Ethernet Phyceiver 10 0, RO 0, RO 0, RO 0, RO Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 5: 100BASE-TX 5: 10FD 5: 10Base-T 5: Selector 1 = 100Base-TX is supported by link partner 0 = 100Base-TX not supported by link partner This bit will also be set after the link in 100Base is established by parallel detection. 1 = 10Base-T full duplex is supported by link partner 0 = 10Base-T full duplex not supported by link partner 1 = 10Base-T is supported by link partner 0 = 10Base-T not supported by link partner This bit will also be set after the link in 10Base is established by parallel detection. Link Partner’s binary encoded node selector Currently only CSMA/CD is specified 1, RO 0, RO 0, RO , RO 7.7. Register 6 Auto-negotiation Expansion Register(ANER) This register contains additional status for NWay auto-negotiation. Address 6: 6: 6: 6: 6: 6: Name Reserved MLF Description/Usage This bit is always set to 0. Status indicating if a multiple link fault has occurred. 1 = fault occurred 0 = no fault occurred LP_NP_ABLE Status indicating if the link partner supports Next Page negotiation. 1 = supported 0 = not supported NP_ABLE This bit indicates if the local node is able to send additional Next Pages. PAGE_RX This bit is set when a new Link Code Word Page has been received. It is automatically cleared when the auto-negotiation link partner’s ability register (register 5) is read by management. LP_NW_ABLE 1 = link partner supports Nway auto-negotiation. Default/Attribute 0, RO 0, RO 0, RO 0, RO 0, RO 7.8. Register 16 Nway Setup Register(NSR) Address 16: 16: 16: 16: 16: 16: 16: 16: Name Reserved ENNWLE Testfun NWLPBK Reserved FLAGABD FLAGPDF FLAGLSC Description/Usage Default/Attribute 1 = LED4 Pin indicates linkpulse 1 = Auto-neg speeds up internal timer 1 = set Nway to loopback mode. 0, RW 0, RW 0, RW 1 = Auto-neg experienced ability detect state 1 = Auto-neg experienced parallel detection fault state 1 = Auto-neg experienced link status check state 0, RO 0, RO 0, RO Single Chip Single Port 10/100M Fast Ethernet Phyceiver 11 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 7.9. Register 17 Loopback, Bypass, Receiver Error Mask Register(LBREMR) Address 17: 17: Name RPTR BP_4B5B 17: BP_SCR 17: 17: LDPS AnalogOFF 17: DetectLength 17: LB 17: F_Link_100 17: 17: Reserved CODE_err 17: PME_err 17: LINK_err 17: PKT_err 17: RWPara Description/Usage Set to 1 to put the RTL8201BL into repeater mode Assertion of this bit allows bypassing of the 4B/5B & 5B/4B encoder. Assertion of this bit allows bypassing of the scrambler/descrambler. Set to 1 to enable Link Down Power Saving mode Set to 1 to power down analog function of transmitter and receiver. Detect length OK indication. Assert low to indicate detect length OK. LB are register bits for loopback control as defined below: 1) 0 0 for normal mode; 2) 0 1 for PHY loopback; 3) 1 0 for twister loopback Used to logic force good link in 100Mbps for diagnostic purposes. Default/Attribute 0, RW 0, RW Assertion of this bit causes a code error detection to be reported. Assertion of this bit causes a pre-mature end error detection to be reported. Assertion of this bit causes a link error detection to be reported. Assertion of this bit causes a detection of packet errors due to 722 ms time-out to be reported. Parameter access enable, set 1 to access register 20~24 0, RW 0, RW 0, RW 0, RW 0, RO , RW 1, RW 0, RW 0, RW 0, RW 0, RW 7.10. Register 18 RX_ER Counter(REC) Address 18: Name RXERCNT Description/Usage This 16-bit counter increments by 1 for each valid packet received. Default/Attribute H’[0000], RW 7.11. Register 19 10Mbps Network Interface Configuration Register Address 19: 19: Name Reserved LD 19: 19: 19: Reserved HBEN JBEN Description/Usage Default/Attribute This bit is the active low TPI link disable signal. When low TPIstilltransmit link pulses and TPI stays in good link state. 1, RW Heart beat enable 1 = enable jabber function 0 = disable jabber function 1, RW 1, RW Single Chip Single Port 10/100M Fast Ethernet Phyceiver 12 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 7.12. Register 20 PHY 1_1 Register Address 20: Name PHY1_1 Description/Usage PHY 1 register (functions as RTL8139C) Default/Attribute R/W 7.13. Register 21 PHY 1_2 Register Address 21: Name PHY1_2 Description/Usage PHY 1 register (functions as RTL8139C) Default/Attribute R/W 7.14. Register 22 PHY 2 Register Address 22 Name PHY2_76 22: PHY2_80 Description/Usage PHY2 register for cable length test (functions as RTL8139C) PHY2 register for PLL select (functions as RTL8139C) Default/Attribute RO R/W 7.15. Register 23 Twister_1 Register Address 23: Name TW_1 Description/Usage Twister register (functions as RTL8139C) Default/Attribute R/W 7.16. Register 24 Twister_2 Register Address 24: Name TW_2 Description/Usage Twister register (functions as RTL8139C) Default/Attribute R/W 7.17. Register 25 Test Register Address 25 25 25: Name Test Reserved PHYAD[4:0] 25 25 Test LINK10 25 LINK100 Description/Usage Reserved for internal testing Default/ Attribute R/W Reflects the PHY address defined by external PHY address configuration pins Reserved for internal testing 1: Link established in 10Base OK 0: No link established in 10Base 1: Link established in 100Base OK 0: No link established in 100Base Single Chip Single Port 10/100M Fast Ethernet Phyceiver 13 RO RO RO RO Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8. Functional Description The RTL8201BL Phyceiver is a physical layer device that integrates 10Base-T and 100Base-TX functions and some extra power manage features into a 48 pin single chip which is used in 10/100 Fast Ethernet applications. This device supports the following functions: z z z z z z z z z z z z z z MII interface with MDC/MDIO SMI management interface to communicate with MAC IEEE 802.3u clause 28 Auto-Negotiation ability Flow control ability support to cooperate with MAC Speed, duplex, auto-negotiation ability configurable by hard wire or MDC/MDIO. Flexible LED configuration. 7-wire SNI(Serial Network Interface) support, works only on 10Mbps mode. Power Down mode support 4B/5B transform Scrambling/De-scrambling NRZ to NRZI, NRZI to MLT3 Manchester Encode and Decode for 10 BaseT operation Clock and Data recovery Adaptive Equalization Far End Fault Indication (FEFI) in fiber mode 8.1. MII and Management Interface 8.1.1. Data Transition To set the RTL8201BL for MII mode operation, pull MII/SNIB pin high and properly set the ANE, SPEED, and DUPLEX pins. The MII (Media Independent Interface) is an 18-signal interface which is described in IEEE 802.3u supplying a standard interface between PHY and MAC layer. This interface operates in two frequencies – 25Mhz and 2.5Mhz to support 100Mbps/10Mbps bandwidth for both the transmit and receive function. While transmitting packets, the MAC will first assert the TXEN signal and change byte data into 4 bits nibble and pass to the PHY by TXD[0..3]. PHY will sample TXD[0..] synchronously with TXC — the transmit clock signal supplied by PHY – during the interval TXEN is asserted. While receiving a packet, the PHY will assert the RXEN signal, pass the received nibble data RXD[0..3] clocked by RXC, which is recovered from the received data. CRS and COL signals are used for collision detection and handling. In 100Base-TX mode, when decoded signal in 5B is not IDLE, the CRS signal will assert and when 5B is recognized as IDLE it will be de-asserted. In 10Base-T mode, CRS will assert when the 10M preamble been confirmed and will be de-asserted when the IDLE pattern been confirmed. The RXDV signal will be asserted when decoded 5B are /J/K/and will be deasserted if the 5B are /T/R/or IDLE in 100Mbps mode. In 10Mbps mode, the RXDV signal is the same as the CRS signal. The RXER (Receive Error) signal will be asserted if any 5B decode errors occur such as invalid J/K, T/R, invalid symbol, this pin will go high for one or more clock period to indicate to the reconciliation sublayer that an error was detected somewhere in the frame. The RTL8201BL does not use the TXER signal and will not affect the transmit function. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 14 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.1.2. Serial Management The MAC layer device can use the MDC/MDIO management interface to control a maximum of 31 RTL8201BL devices, configured with different PHY addresses (00001b to 11111b). During a hardware reset, the logic levels of pins 9,10,12,13,15 are latched into the RTL8201BL to be set as the PHY address for serial management interface communication. Setting the PHY address to 00000b will put the RTL8201BL into power down mode. The read and write frame structure for the management interface follows. MDC MDIO 32 1s 0 Preamble 1 0 ST 1 A4 OP A3 A2 A1 A0 R4 PHYAD[4:0] R3 R2 R1 R0 1 REGAD[4:0] 0 D15 D14 D13 D12 D11 D10 D9 D8 TA D7 D6 D5 D4 D3 D2 D1 D0 DATA Idle MDIO is sourced by MAC. Clock data into PHY on rising edge of MDC Write Cycle MDC MDIO 32 1s Preamble 0 1 ST 1 0 OP A4 A3 A2 A1 A0 PHYAD[4:0] R4 R3 R2 R1 REGAD[4:0] R0 Z 0 D15 D14 D13 D12 D11 D10 D9 TA D8 D7 D6 D5 D4 D3 D2 D1 DATA MDIO is sourced by MAC. Clock data into PHY on rising edge of MDC D0 Idle MDIO is sourced by PHY. Clock data from PHY on rising edge of MDC Read Cycle Preamble ST OP PHYAD REGAD TA DATA IDLE 32 contiguous logic '1's sent by the MAC on MDIO along with 32 corresponding cycles on MDC. This provides synchronization for the PHY. Start of Frame. Indicated by a 01 pattern. Operation code. Read = 10. Write = 01. PHY Address. Up to 31 PHYs can be connected to one MAC. This 5 bit field selects which PHY the frame is directed to. Register Address. This is a 5 bit field that selects which one of the 32 registers of the PHY this operation refers to. Turnaround. This is a two bit time spacing between the register address and the data field of a frame to avoid contention during a read transaction. For a read transaction, both the STA and the PHY shall remain in a high-impedance state for the first bit time of the turnaround. The PHY shall drive a zero bit during the second bit time of the turnaround of a read transaction. Data. These are the 16 bits of Data. Idle Condition, not actually part of the management frame. This is a high impedance state. Electrically, the PHY's pull-up resistor will pull the MDIO line to a logic one. 8.2. Auto-negotiation and Parallel Detection The RTL8201BL supports IEEE 802.3u clause 28 Auto-negotiation operation which can cooperate with other transceivers supporting auto-negotiation. By this mechanism, the RTL8201BL can auto detect the link partner’s ability and determine the highest speed/duplex configuration and transmit/receive in this configuration. If the link partner does not support Auto-negotiation, then the RTL8201BL will enable half duplex mode and enter parallel detection. The RTL8201BL will default to transmit FLP and wait for the link partner to respond. If the RTL8201BL receives FPL, then the auto-negotiation process will go on. If it receives NLP, then the RTL8201BL will change to 10Mbps and half duplex mode. If it receives a 100Mbps IDLE pattern, it will change to 100Mbps and half duplex mode. To enable the auto-negotiation mode operation on the RTL8201BL, just pull the ANE pin high. And the SPEED pin and DUPLEX pin will set the ability content of auto-negotiation register. The auto-negotiation mode can be externally disabled by pulling the ANE pin low. In this case, the SPEED pin and DUX pin will change the media configuration of the RTL8201BL. Below is a list for all configurations of the ANE/SPEED/DUPLEX pins and their operation in Fiber or UTP mode. Select Medium type and interface mode to MAC Single Chip Single Port 10/100M Fast Ethernet Phyceiver 15 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet FX (pin 24) L L H MII/SNIB (pin 44) H L X Operation mode UTP mode and MII interface UTP mode and SNI interface Fiber mode and MII interface UTP mode and MII interface ANE (Pin 37) SPEED (Pin 39) DUPLEX (Pin 38) H L L H H L H H L H H H L L L L L L H H L H L H Operation Auto-negotiation enable, the ability field does not support 100Mbps and full duplex mode operation Auto-negotiation enable, the ability field does not support 100Mbps operation Auto-negotiation enable, the ability field does not support full duplex mode operation Default setup, auto-negotiation enable, the RTL8201BL will support 10BaseT /100BaseTX, half/full duplex mode operation Auto-negotiation disable, force the RTL8201BL into 10BaseT and half duplex mode Auto-negotiation disable, force the RTL8201BL into 10BaseT and full duplex mode Auto-negotiation disable, force the RTL8201BL into 100BaseTX and half duplex mode Auto-negotiation disable, force the RTL8201BL into 100BaseTX and full duplex mode UTP mode and SNI interface SNI interface to MAC. It only works in 10Base-T when the SNI interface is enabled. ANE (Pin 37) X SPEED (Pin 39) X DUPLEX (Pin 38) L X X H Operation The duplex pin is pulled low to support the 10Base-T half duplex function.10Base-T half duplex is the specified default mode in the SNI interface. The RTL8201BL also supports full duplex in SNI mode. The duplex pin is pulled high to support 10Base-T full duplex function. Fiber mode and MII interface The RTL8201BL only supports 100Base-FX when Fiber mode is enabled. Ignore ANE and Speed hardwire configuration. ANE (Pin 37) X X SPEED (Pin 39) X X DUPLEX (Pin 38) H L Operation The duplex pin is pulled high to support 100Base-FX full duplex function. The duplex pin is pulled low to support 100Base-FX half duplex function. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 16 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.3. Flow Control Support The RTL8201BL supports flow control indications. The MAC can program the MII register to indicate to the PHY that flow control is supported. When MAC supports the Flow Control mechanism, setting bit 10 of the ANAR register by MDC/MDIO SMI interface, then the RTL8201BL will add the ability to its N-Way ability. If the Link partner also supports Flow Control, then the RTL8201BL can recognize the Link partner’s N-Way ability by examining bit 10 of ANLPAR (register 5). 8.4. Hardware Configuration and Auto-negotiation This section describes methods to configure the RTL8201BL and set the auto-negotiation mode. This list will show the various pins and their setting to provide the desired result. z Isolate pin: Set high to isolate the RTL8201BL from the MAC. This will also isolate the MDC/MDIO management interface. In this mode, power consumption is minimum. Please refer to the section covering Isolation mode and Power Down mode. z RPTR pin: Pull high to set the RTL8201BL into repeater mode. This pin is pulled low by default. Please refer to the section covering Repeater mode operation. z LDPS pin: Pull high to set the RTL8201BL into LDPS mode. This pin is pulled low by default. Please refer to the section covering Power Down mode and Link Down Power Saving. z MII/SNIB: Pull high to set RTL8201BL into MII mode operation, which is the default mode for the RTL8201. This pin pulled low will set the RTL8201BL into SNI mode operation. When set to SNI mode, the RTL8201BL will work at 10Mbps. Please refer to the section covering Serial Network Interface for more detail information. z ANE pin: Pull high to enable Auto-negotiation (default). Pull low to disable auto-negotiation and activate the parallel detection mechanism. Please refer to the section covering Auto-negotiation and Parallel Detection z Speed pin: When ANE is pulled high, the ability to adjust speed is setup. When ANE is pulled low, pull this pin low to force 10Mbps operation and high to force 100Mbps operation. Please refer to the section on Auto-negotiation and Parallel Detection. z DUPLEX pin: When ANE is pulled high, the ability to adjust the DUPLEX pin will be setup. When ANE is pulled low, pull this pin low to force half duplex and high to force full duplex operation. Please refer to the section covering Auto-negotiation and Parallel Detection. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 17 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.5. LED and PHY Address Configuration In order to reduce the pin count on the RTL8201BL, the LED pins are duplexed with the PHY address pins. Because the PHYAD strap options share the LED output pins, the external combinations required for strapping and LED usage must be considered in order to avoid contention. Specifically, when the LED outputs are used to drive LEDs directly, the active state of each output driver is dependent on the logic level sampled by the corresponding PHYAD input upon power-up/reset. For example, as following left figure shows, if a given PHYAD input is resistively pulled high then the corresponding output will be configured as an active low driver. As right figure shows, if a given PHYAD input is resistively pulled low then the corresponding output will be configured as an active high driver. The PHY address configuration pins should not be connected to GND or VCC directly, but must be pulled high or low through a resistor (ex 5.1KΩ). If no LED indications are needed, the components of the LED path (LED+510Ω) can be removed. VCC PAD[0:4]/ LED[0:4] LED 5.1K ohm 510 ohm LED 510 ohm 5.1K ohm PAD[0:4]/ LED[0:4] PHY address[:] = logic 1 LED indication = active low LED0 LED1 LED2 LED3 LED4 PHY address[:] = logic 0 LED indication = active High Link Full Duplex Link 10-Activity Link 100-Activity Collision LED Definitions 8.6. Serial Network Interface The RTL8201BL also supports the traditional 7-wire serial interface to cooperate with legacy MACs or embedded systems. To setup for this mode of operation, pull the MII/SNIB pin low and by doing so, the RTL8201BL will ignore the setup of the ANE and SPEED pins. In this mode, the RTL8201BL will set the default to work in 10Mbps and Half-duplex mode. But the RTL8201BL may also support full duplex mode operation if the DUPLEX pin has been pulled high. This interface consists of 10Mbps transmit and receive clock generated by PHY, 10Mbps transmit and receive serial data, transmit enable, collision detect, and carry sense signals. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 18 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.7. Power Down, Link Down, Power Saving, and Isolation Modes The RTL8201BL supplies 4 kinds of Power Saving mode operation. This section will discuss all four, including how to implement each mode. The first three modes are configured through software, and the fourth through hardware. z Analog off: Setting bit 11 of register 17 to 1 will put the RTL8201BL into analog off state. In analog off state, the RTL8201BL will power down all analog functions such as transmit, receive, PLL, etc. However, the internal 25MHz crystal oscillator will not be powered down. The digital functions in this mode are still available which allows reacquisition of analog functions. z LDPS mode: Setting bit 12 of register 17 to 1 or pulling the LDPS pin high will put the RTL8201BL into LDPS (Link Down Power Saving) mode. In LDPS mode, the RTL8201BL will detect the link status to decide whether or not to turn off the transmit function. If the link is off, FLP or 100Mbps IDLE/10Mbps NLP will not be transmitted. However, some signals similar to NLP will be transmitted. Once the receiver detects any leveled signals, it will stop the signal and transmit FLP or 100Mbps IDLE/10Mbps NLP again. This may save about 60%~80% power when the link is down. z PWD mode: Setting bit 11 of register 0 to 1 will put the RTL8201BL into power down mode. This is the maximum power saving mode while the RTL8201BL is still alive. In PWD mode, the RTL8201BL will turn off all analog/digital functions except the MDC/MDIO management interface. Therefore, if the RTL8201BL is put into PWD mode and the MAC wants to recall the PHY, it must create the MDC/MDIO timing by itself (this is done by software). z Isolation mode: This mode is different from the three previous software configured power saving modes. This mode is configured by hardware pin 43. Setting pin 43 high will isolate the RTL8201BL from the Media Access Controller (MAC) and the MDC/MDIO management interface. In this mode, power consumption is minimum. 8.8. Media Interface 8.8.1. 100Base-TX 1) 100Base-TX Transmit Function: The 100Base-TX transmit function is performed as follows: First the transmit data in 4 bit nibbles (TXD[3:0]), clocked in 25MHz (TXC) will be transformed into 5B symbol code, called 4B/5B encoding. Scrambling, serializing and conversion to 125Mhz, and NRZ to NRZI will then take place. After this process, the NRZI signal will pass to the MLT3 encoder, then to the transmit line driver. The transmitter will first assert TXEN. Before transmitting the data pattern, it will send a /J/K/ symbol (Start-of-frame delimiter), the data symbol, and finally a /T/R/ symbol known as the End-Of-Frame delimiter. The 4B/5B and the scramble process can be bypassed by setting the PHY register. For better EMI performance consideration, the seed of the scrambler is related to the PHY address. Therefore in a hub/switch environment, every RTL8201BL will be set into a different PHY address so that they will use different scrambler seeds, which will spread the output of the MLT3 signals. 2) 100Base-TX Receive Function: The 100Base-TX receive function is performed as follows: The received signal will first be compensated by the adaptive equalizer to make up for the signal loss due to cable attenuation and ISI. The Baseline Wander Corrector will monitor the process and dynamically apply corrections to the process of signal equalization. The PLL will then recover the timing information from the signals and form the receive clock. With this, the received signal may be sampled to form NRZI data. The next steps are the NRZI to NRZ process, unscrambling of the data, serial to parallel and 5B to 4B conversion and passing of the 4B nibble to the MII interface. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 19 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.8.2. 100Base-FX Fiber Mode Operation RTL8201BL can be configured as 100Base-FX by hardware configuration. The priority of setting 100Base-FX is greater than Nway. Scrambler is not needed in 100Base-FX. z 100Base-FX Transmit Function: The 100Base-FX transmit function is performed as follows: Di-bits of TXD are processed as 100Base-TX, except without scrambler before the NRZI stage. Instead of converting to MLT-3 signals, as in 100Base-TX, the serial data stream is driven out as NRZI PECL signals, which enter the fiber transceiver in differential-pairs form. z In 100Base-FX Receive Function: The 100Base-FX receive function is performed as follows: The signal is received through PECL receiver inputs from the fiber transceiver, and directly passed to the clock recovery circuit for data/clock recovery. The scrambler/de-scrambler is bypassed in 100Base-FX. 8.8.3. 10Base-Tx/Rx 1) 10Base Transmit Function: The 10Base transmit function is performed as follows: The transmit 4 bits nibbles(TXD[0:3]) clocked in 2.5MHz(TXC) is first feed to parallel to serial converter, then put the 10Mbps NRZ signal to Manchester coding. The Manchester encoder converts the 10 Mbps NRZ data into a Manchester Encoded data stream for the TP transmitter and adds a start of idle pulse (SOI) at the end of the packet as specified in IEEE 802.3. Then, the encoded data stream is shaped by bandlimited filter embedded in RTL8201BL and then transmitted to TP line. 2) 10Base Receive function: The 10Base receive function is performed as follows: In 10Base receive mode, The Manchester decoder in RTL8201BL converts the Manchester encoded data stream from the TP receiver into NRZ data by decoding the data and stripping off the SOI pulse. Then, the serial NRZ data stream is converted to parallel 4 bit nibble signal(RXD[0:3]). 8.9. Repeater Mode Operation Setting bit 15 of register 17 to 1 or pulling the RPTR pin high will set the RTL8201BL into repeater mode. In repeater mode, the RTL8201BL will assert CRS high only when receiving a packet. In NIC mode, the RTL8201BL will assert CRS high both in transmitting and receiving packets. If using the RTL8201BL in a repeater, please set the RTL8201BL to Repeater mode, and if using the RTL8201BL in a NIC or switch application, please set the default mode. NIC/Switch mode is the default setting and has the RPTR pin pulled low or bit 15 of register 17 is set to 0. 8.10. Reset, and Transmit Bias (RTSET) The RTL8201BL can be reset by pulling the RESETB pin low for about 10ms, then pulling the pin high. It can also be reset by setting bit 15 of register 0 to 1, and then setting it back to 0. Reset will clear the registers and re-initialize them, and the media interface will first disconnect and restart the auto-negotiation/parallel detection process. The RTSET pin must be pulled low by a 5.9KΩ resister with 1% accuracy to establish an accurate transmit bias, this will affect the signal quality of the transmit waveform. Keep it’s circuitry away from other clock traces or transmit/receive paths to avoid signal interference. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 20 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 8.11. 3.3V Power Supply and Voltage Conversion Circuit The RTL8201BL is fabricated in a 0.25um process. The core circuit needs to be powered by 2.5V , however, the circuit of digital IO and DAC need 3.3V power supply. RTL8201BL has embedded a regulator to convert 3.3V to 2.5V. Just like many commercial voltage conversion devices, The 2.5V output pin(PWFBOUT) of this circuit requires the use of an output capacitor(22uF tantalum capacitor) as part of the device frequency compensation and another small capacitor(0.1uF) for high frequency noise de-coupling. And PWFBIN is fed with the 2.5V power from PWFBOUT through a ferrite bead as below figure shown. Strongly emphasize here, could not provide external 2.5V produced by any other power device for PWFBOUT and PWFBIN. The analog and digital Ground planes should be as large and intact as possible. If the ground plane is large enough, the analog and digital grounds can be separated, which is a more ideal configuration. However, if the total ground plane is not sufficiently large, partition of the ground plane is not a good idea. In this case, all the ground pins can be connected together to a larger single and intact ground plane. RTL8201B(L) DVDD33(pin14) AVDD33(pin36) 3.3V-drived circuit 3.3V Ferrite Bead 3.3V 0.1uF 0.1uF DVDD33(pin48) Error Amp - 0.1uF MOSFET P + PWFBOUT(pin32) 1.2V bandgap voltage 22uF Ferrite Bead 0.1uF PWFBIN(pin8) 2.5V-drived circuit 0.1uF 8.12. Far End Fault Indication The MII Reg.1.4 (Remote Fault) is theFar End Fault Indication (FEFI) bit when 100FX mode is enabled which indicates that FEFI has been detected. FEFI is an alternative in-ba nd signaling method which is composed of 84 consecutive ‘1’ followed by one ‘0’. From the point of view of the RTL8201BL, when this pattern is detected three times, Reg.1.4 is set, which means the transmit path (the Remote side’s receive path) has a problem. On the other hand, the incoming signal failure in causing a link OK will force the RTL8201BL to start sending this pattern, which in turn causes the remote side to detect a Far-End-Fault. This means that the receive path has a problem from the point of view of the RTL8201BL. The FEFI mechanism is used only in 100Base-FX mode. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 21 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9. Electrical Characteristics 9.1. D.C. Characteristics 9.1.1. Absolute Maximum Ratings Symbol Supply Voltage Storage Temp. 9.1.2. Minimum 3.0V -55°C Typical 3.3V Maximum 3.6V 125°C Minimum 3.0V 0°C Typical 3.3V Maximum 3.6V 70°C Operating Conditions Symbol Vcc 3.3V TA 9.1.3. Conditions Conditions 3.3V Supply voltage Operating Temperature Power Dissipation Test condition: VCC=3.3V Symbol Condition PLDPS Link down power saving mode PAnaOff Analog off mode PPWD Power down mode PIsolate Isolate mode P100F 100Base full duplex P10F 10Base full duplex P10TX 10Base transmit P10RX 10Base receive P10IDLE 10Base idle 9.1.4. Symbol TTL VIH TTL VIL TTL VOH TTL VOL TTL IOZ IIN Icc PECL VIH PECL VIL PECL VOH PECL VOL Total Current Consumption 17 mA 13 mA 3 mA 3 mA 64 mA 82 mA 82 mA 25 mA 24 mA Supply Voltage: Vcc Conditions Input High Vol. Input Low Vol. Output High Vol. IOH=-8mA Output Low Vol. IOL=8mA Tri-state Leakage Vout=Vcc GND Input Current Vin=Vcc GND Average Operating Iout=0mA Supply Current PECL Input High Vol PECL Input Low Vol. PECL Output High Vol. PECL Output Low Vol. Minimum 0.5*Vcc -0.5V 0.9*Vcc or -10uA Maximum Vcc+0.5V 0.3*Vcc Vcc 0.1*Vcc 10uA or -1.0uA 1.0uA Single Chip Single Port 10/100M Fast Ethernet Phyceiver Typical 200mA Vdd-1.16V Vdd-1.81V Vdd-1.02V Vdd-0.88V Vdd-1.47V Vdd-1.62V 22 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9.2. A.C. Characteristics 9.2.1. MII Timing of Transmission Cycle Shown is an example transfer of a packet from MAC to PHY in MII interface. Symbol t1 t2 t3 t4 t5 t6 t7 Description TXCLK high pulse width 100Mbps Minimum 14 Typical 20 Maximum 26 Unit ns 10Mbps 140 200 260 ns 14 140 20 200 40 400 24 26 260 ns ns ns ns ns 10 25 ns ns 40 400 160 ns ns ns ns 2000 ns 70 140 ns 100 400 170 ns ns ns TXCLK low pulse width 100Mbps 10Mbps TXCLK period 100Mbps 10Mbps TXEN, TXD[0:3] setup to TXCLK 100Mbps rising edge 10Mbps TXEN, TXD[0:3] hold after 100Mbps TXCLK rising edge 10Mbps TXEN sampled to CRS high 100Mbps 10Mbps TXEN sampled to CRS low 100Mbps 10 5 5 10Mbps t8 Transmit latency 100Mbps t9 10Mbps Sampled TXEN inactive to end of 100Mbps frame 10Mbps 60 t3 VIH(min VIL(max TXCLK t4 t5 t1 VIH(min VIL(max TXD[0:3] TXEN Single Chip Single Port 10/100M Fast Ethernet Phyceiver t2 23 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet TXCLK TXEN TXD[0:3] t6 t7 CRS t8 TPTX+- 9.2.2. t9 MII Timing of Reception Cycle Shown is an example of transfer of a packet from PHY to MAC in MII interface Symbol Description Minimum t1 RXCLK high pulse width 100Mbps 14 10Mbps 140 t2 RXCLK low pulse width 100Mbps 14 t3 10Mbps 100Mbps RXCLK period t6 10Mbps RXER, RXDV, RXD[0:3] setup to 100Mbps RXCLK rising edge 10Mbps RXER, RXDV, RXD[0:3] hold after 100Mbps RXCLK rising edge 10Mbps Receive frame to CRS high 100Mbps t4 t5 140 Typical 20 200 20 Maximum 26 260 26 Unit ns ns ns 200 40 260 ns ns 400 ns ns ns ns 10 6 10 130 ns ns t7 End of receive frame to CRS low 10Mbps 100Mbps 600 240 ns ns t8 10Mbps Receive frame to sampled edge of 100Mbps RXDV 10Mbps 600 150 ns ns 3200 120 ns ns 800 ns t9 6 End of receive frame to sampled 100Mbps edge of RXDV 10Mbps t3 VIH(min VIL(max RXCLK RXD[0:3] RXDV RXER t4 Single Chip Single Port 10/100M Fast Ethernet Phyceiver t5 t1 t2 VIH(min VIL(max 24 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet RXCLK t8 t9 RXDV RXD[0:3] t6 t7 CRS TPRX+- Single Chip Single Port 10/100M Fast Ethernet Phyceiver 25 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9.2.3. SNI Timing of Transmission Cycle Shown is an example transfer of a packet from MAC to PHY in SNI interface. SNI mode only runs in 10Mbps. Symbol t1 t2 t3 t4 t5 t8 Description TXCLK high pulse width TXCLK low pulse width TXCLK period TXEN, TXD0 setup to TXCLK rising edge TXEN, TXD0 hold after TXCLK rising edge Transmit latency Minimum 36 36 80 20 10 Typical Maximum 120 50 Unit ns ns ns ns ns ns t3 VIH(min VIL(max TXCLK t4 t5 t1 t2 VIH(min VIL(max TXD0 TXEN TXCLK TXEN TXD0 TPTX+- t8 Single Chip Single Port 10/100M Fast Ethernet Phyceiver t9 26 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9.2.4. SNI Timing of Reception Cycle Shown is an example of transfer of a packet from PHY to MAC in SNI interface. SNI mode only runs in 10Mbps. Symbol Description Minimum Typical Maximum t1 RXCLK high pulse width 36 t2 RXCLK low pulse width 36 t3 RXCLK period 80 120 t4 RXD0 setup to RXCLK rising edge 40 t5 RXD0 hold after RXCLK rising edge 40 t6 Receive frame to CRS high 50 t7 End of receive frame to CRS low 160 t8 Decoder acquisition time 600 1800 Unit ns ns ns ns ns ns ns ns t3 VIH(min VIL(max RXCLK t4 t5 t1 t2 VIH(min VIL(max RXD0 RXCLK t8 RXD0 t6 t7 CRS TPRX+- Single Chip Single Port 10/100M Fast Ethernet Phyceiver 27 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9.2.5. Symbol t1 t2 t3 t4 t5 t6 MDC/MDIO timing Description MDC high pulse width MDC low pulse width MDC period MDIO setup to MDC rising edge MDIO hold time from MDC rising edge MDIO valid from MDC rising edge Minimum 160 160 400 10 10 0 Typical Maximum 300 Unit ns ns ns ns ns ns t3 VIH(min) VIL(max MDC MDIO sourced by STA t4 MDIO sourced by RTL8201B 9.2.6. t5 t1 t2 VIH(min) VIL(max t6 VIH(min VIL(max Transmission Without Collision Shown is an example transfer of a packet from MAC to PHY. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 28 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9.2.7. Reception Without Error Shown is an example of transfer of a packet from PHY to MAC. Single Chip Single Port 10/100M Fast Ethernet Phyceiver 29 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 9.3. Crystal and Transformer Specifications 9.3.1. Item 1 2 3 Crystal Specifications Parameter Range Nominal Frequency Oscillation Mode 25.000 MHz Base wave ±50 ppm 4 Frequency Tolerance at 25℃ Temperature Characteristics 5 Operating Temperature Range 6 7 8 9 10 11 12 Equivalent Series Resistance Drive Level Load Capacitance Shunt Capacitance Insulation Resistance Test Impedance Meter Aging Rate A Year -10℃ ~ +70℃ 30 ohm Max. 0.1 mV 20 pF 7 pF Max. Mega ohm Min./DC 100V Saunders 250A 9.3.2. ±50 ppm ±0.0003% Transformer Specifications Parameter Turn ratio Inductance (min.) Leakage inductance Capacitance (max) DC resistance (max) Transmit End 1:1 CT 350 uH @ 8mA 0.05-0.15 uH 15 pF 0.4 ohm Single Chip Single Port 10/100M Fast Ethernet Phyceiver Receive End 1:1 350 uH @ 8mA 0.05-0.15 uH 15 pF 0.4 ohm 30 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 10. Mechanical Dimensions Symbo l A A1 A2 b b1 c c1 D D1 E E1 e L L1 θ θ1 θ2 θ3 Dimension in inch Min Nom Max 0.067 0.000 0.004 0.008 0.051 0.055 0.059 0.006 0.009 0.011 0.006 0.008 0.010 0.004 0.008 0.004 0.006 0.354 BSC 0.276 BSC 0.354 BSC 0.276 BSC 0.020 BSC Dimension in mm Min Nom Max 1.70 0.00 0.20 0.1 1.30 1.50 1.40 0.29 0.22 0.15 0.15 0.25 0.20 0.09 0.20 0.09 0.16 9.00 BSC 7.00 BSC 9.00 BSC 7.00 BSC 0.50 BSC 0.016 0.40 0° 0° 0.024 0.031 0.039 REF 3.5° 9° 12° TYP 12° TYP 0° 0° 0.60 0.80 1.00 REF 3.5° 9° 12° TYP 12° TYP Single Chip Single Port 10/100M Fast Ethernet Phyceiver Notes: 1.To be determined at seating plane -c2.Dimensions D1 and E1 do not include mold protrusion. D1 and E1 are maximum plastic body size dimensions including mold mismatch. 3.Dimension b does not include dambar protrusion. Dambar can not be located on the lower radius of the foot. 4.Exact shape of each corner is optional. 5.These dimensions apply to the flat section of the lead between 0.10 mm and 0.25 mm from the lead tip. 6. A1 is defined as the distance from the seating plane to the lowest point of the package body. 7.Controlling dimension: millimeter. 8. Reference document: JEDEC MS-026, BBC TITLE: 48LD LQFP ( 7x7x1.4mm) PACKAGE OUTLINE DRAWING, FOOTPRINT 2.0mm LEADFRAME MATERIAL: APPROVE DOC. NO. VERSION 1 PAGE OF CHECK DWG NO. SS048 - P1 DATE Sept. 25.2000 REALTEK SEMI-CONDUCTOR CORP. 31 Track ID: JATR-1076-21 Rev. 1.3 RTL8201BL Datasheet 11. Ordering Information Table 1. Ordering Information Part Number Package RTL8201BL 48-Pin LQFP RTL8201BL-LF RTL8201BL with Lead (Pb)-Free package Note: See page 4 for lead (Pb)-free package and version identification. Status Realtek Semiconductor Corp. Headquarters No. 2, Industry East Road IX, Science-based Industrial Park, Hsinchu, 300, Taiwan, R.O.C. Tel: 886-3-5780211 Fax: 886-3-5776047 www.realtek.com.tw Single Chip Single Port 10/100M Fast Ethernet Phyceiver 32 Track ID: JATR-1076-21 Rev. 1.3
RTL8201BL-LF 价格&库存
很抱歉,暂时无法提供与“RTL8201BL-LF”相匹配的价格&库存,您可以联系我们找货
RTL8201BL-LF
    • 1+7.38046
    • 30+7.12596
    • 100+6.61696
    • 500+6.10797
    • 1000+5.85347
