WST3325
P-Ch MOSFET
General Description
Product Summery
TheWST3325 is the highest performance trench
P-Ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate
charge for most of the small power switching
and load switch applications.
BVDSS
RDSON
ID
-20V
42mΩ
-5.6A
Applications
The WST3325 meet the RoHS and Green
Product requirement , with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
z Load Switch
Features
SOT-23-3L Pin Configuration
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-20
V
VGS
Gate-Source Voltage
±12
V
ID@TC=25℃
Continuous Drain Current, VGS @ -4.5V1
-5.6
A
ID@TC=70℃
1
-4.5
A
-16
A
IDM
Pulsed Drain Current
2
3
PD@TA=25℃
Total Power Dissipation
1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Typ.
Max.
Unit
125
℃/W
80
℃/W
Dec.2014
WST3325
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
Reference to 25℃ , ID=-1mA
-0.016
V/℃
VGS=-4.5V , ID=-3A
42
55
VGS=-2.5V , ID=-2A
56
70
VGS=-1.8V , ID=-1A
mΩ
73
85
-0.3
-0.5
-1.0
V
3.97
mV/℃
VDS=-16V , VGS=0V , TJ=25℃
-1
VDS=-16V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±8V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
14
S
Qg
Total Gate Charge (-4.5V)
12.1
16.9
Qgs
Gate-Source Charge
1.5
2.1
Qgd
Gate-Drain Charge
3.1
4.3
8.8
Td(on)
VDS=-15V , VGS=-4.5V , ID=-3A
Turn-On Delay Time
uA
nC
4.4
Rise Time
VDD=-10V , VGS=-4.5V ,
45
81
Turn-Off Delay Time
RG=3.3Ω, ID=-3A
48.4
97
Fall Time
30.4
60.8
Ciss
Input Capacitance
938
Coss
Output Capacitance
108
Crss
Reverse Transfer Capacitance
96
Min.
Typ.
Max.
-1
A
-16
A
-1
V
28
nS
9
nC
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current
VSD
Diode Forward Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
2,4
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-3A , dI/dt=100A/µs , TJ=25℃
Unit
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST3325”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30400
- 50+0.28120
- 200+0.26220
- 600+0.24320
- 1500+0.22800
- 3000+0.21850
