版 本
描 述
日 期
客户
CUSTOMER
品名
PART NAME
天泰料号
TENTA Material Number
客户料号
CUSTOMER Material Number
编制/Edition
检查/Checked
确认/Confirmed
陆伟
徐志钦
杨再军
承认/Admit
审核/Auditing
批准/Approved
天泰電機工業有限公司
TENTA ELECTRIC INDUSTRIAL CO., LTD.
台中縣梧棲区自強二街 86 巷 61 號
NO.61, Lane 86, Tzchiang 2st St. Wu-Chi Township, Taichung County 435, TAIWAN R.O.C
TEL:(886-04)26398618 FAX:(886-04)26392549
深圳天泰電器元件有限公司
SHEN ZHEN TENTA ELECTRICAL APPLIANCE LTD.
公司:深圳市南山區白石洲中國原子能第二工業區第二棟六樓
6/F NO.2, Pirector Atom 2th Industry, Baishizhou , Shenzhen, CHINA
TEL:(0755)86327963、26921158 FAX:(0755)86297411
工厂:深圳市寶安區福永街道橋頭社區富橋第四工業區 A5 棟
No.A5,FU Qiao 4th Industrial area,Qiaotou Community,Fuyong Street,Bao An District,Shen Zhen
TEL:(0755)29604898 FAX:(0755)29604891
MAIN INTERFERENCE SUPRESSION CAPACITOR CLASS X2……MEX--X2
SPECIFICATION:
1. REFERENCE STANDARDS:
VDE EN 60384-14,
ENEC IEC 60384-14,
KC APPLIED STANDARD: K60384-14 (CAPACITANCE AREA 0.1 to2.2uF)
CQC THE STANDARDS FOR THE PRODUCTS TO BE TESTED: GBIT14472-1998
UL UL60384-14 (250V/275V AC)
USED FOR ACROSS-THE-LINE CAPACITORS,
ANDTENNA-COUPLINE,
LINE-BY-PASS COMPONENTS,
RADIO INTERFERENCE SUPPRESSION,
ELECTRONMAGNETIC INTERFERENCE FILTERS.
2. RATED VOLTAGE:
275V AC 50/ 60 Hz
3. CAPACITANCE RANGE:
0.001µF to 2.2 µF
4. CAPACITANCE TOLERANCE:
± 5% (J) ± 10% (K) ± 20% (M)
5. DIELECTRIC:
METALLIZED
POLYPROPYLENE
6. DISSIPATION FACTOR Tan δ:
LESS THAN 0.1% AT 1 kHz AND
FLIM
20℃
7. INSULATION RESISTANCE:
BETWEEN ELECTRODES
(1) LESS THAN OR EAUAL TO 0.33μF≧ 15000 MΩ
(2) GREATER THAN 0.33μF≧ 5000s/uF
MEASURED AT 100VDC, 60 SEC. AND 20℃
8. WITHSTAND VOLTAGE:
APPLIED 1183V.DC FOR 60 SEC. OR 2000V.DC FOR 1 SEC
9. CLIMATE CATEGORY: IN ACCORDANCE WITH DIN40040 GMF
G (MINIMUM LIMIT TEMPERATURE)= -40℃
M (MAXIMUM LIMIT TEMPERATURE)= +100℃
F (HUMIDITY CATEGORY)=AVERAGE RELATEIVE HVMIDITY ≦75%, 95% FOR 30
DAYS PER YEAR, CONTINUOUSLY; 85% FOR THE
REMATINING DAYS, OCCASIONALLY
10. HUMIDITY TEST:
TEST CONDIDITON
TEST TEMPER ATURE
RELATIVE HUMIDITY
TEST DURATION
: 40±2℃
: 90 TO 95%
: 500 HRS
TEST CRITERIA
(1) CAPACITANCE DRIFT
: ≦ 5% OF THE INITIAL VALUE
(2) INSULATION RESISTANCE : ≦ 50% OF SPECIFIED VALUE
11. LIFE TEST:
TEST CONDITION
TEST TEMPERATURE
TEST VOLTAGE
TEST DURATION
: 100±3℃
: 343VAC AND 1000VDC 60HZ FOR A PERIOD OF
0.1 SEC. ONCE EACH HOUR
: 1008 HRS
TEST CRITERIA
: ≦10% OF THE INITIAL VALUE
(2) INSULATION RESISTANCE : ≧50% OF SPECIFIED VALUE
(3) VISUAL INSPECTION
: NO DETECTABLE DAMAGE
12. SOLDERABILITY:
TEST CONDITIONS
SOLDER BATH TEMPERATURE : 260±5℃
SOLDER
SOLDER TIME
TEST CRITERIA
75% OF THE SURFACE TINNING
: sn/cu=99.3%/0.7%
: 3±0.5 SEC
13. VIBRATION RESISTANCE: (JIS 5115)
TEST CONDITIONS
FREQUENCY CYCLE : 1 MINUTE PER CYCLE 10-55-10 HZ
TEST DURATION
: PERPENDICULAR DIRECTION WITH THE SAME
METHOD FOR 45 MINUTES EACH, TOTAL 90 MINUTES
TEST CRITERIA
(1) APPERANCE
: NO VISUAL DAMAGE
(2) CONTACT
: NORMAL
14. TENSILE STRENGTH OF ELECTRODES:
TEST CONDITIONS
LOAD CONDITIONS : 1.0KGS
HOLDING TIME
: 10±1 SEC
TEST CRITERIA
NO WIRE BROKEN AND NO DAMAGE OF THE CAPACITOR
15. MARKING:
CAPACITORS ARE MARKED WITH TYPE IDENTIFICATION, CAPACITANCE,
CAPACITANCE TOLERANCE, VOLTAGE AND APPROVED CERTIFICATION MARK
16. APPROVED BY: VDE;ENEC16,EK,CQC; UL;
VDE
ENEC
KC
CQC
UL
FILE NO. 119119
FILE NO. 2014032 A1
FILE NO. SU03019-5001B-5002B-8001B
FILE NO. CQC03001003039
FILE NO. E222911
W ±0.5
±0.5
H ±0.5
MARKING
d ± 0.05
L0
L0 20 min
MARKING
T
H ±0.5
W ±0.5
P ±0.5
P ±0.5
Pediform.E#( 短脚 )
Pediform.A#( 长脚 )
Normal
Size
CAP
W
H
T
P
dØ
CAP
W
H
T
P
dØ
0.001
13.0
9.0
4.0
10.0
0.6
0.068
18.0 12.0
6.0
15.0
0.8
0.0012 13.0
9.0
4.0
10.0
0.6
0.082
18.0 12.0
6.0
15.0
0.8
0.0015 13.0
9.0
4.0
10.0
0.6
0.1
18.0 13.5
6.0
15.0
0.8
0.0018 13.0
9.0
4.0
10.0
0.6
0.12
18.0 13.5
7.5
15.0
0.8
0.0022 13.0
9.0
4.0
10.0
0.6
0.15
18.0 14.5
8.5
15.0
0.8
0.0027 13.0
9.0
4.0
10.0
0.6
0.15
26.5 15.0
6.0
22.5
0.8
0.0033 13.0
9.0
4.0
10.0
0.6
0.18
26.5 16.5
7.0
22.5
0.8
0.0039 13.0
9.0
4.0
10.0
0.6
0.22
26.5 16.5
7.0
22.5
0.8
0.0047 13.0 11.0
5.0
10.0
0.6
0.27
26.5 17.0
8.5
22.5
0.8
0.0056 13.0 11.0
5.0
10.0
0.6
0.33
26.5 17.0
8.5
22.5
0.8
0.0068 13.0 11.0
5.0
10.0
0.6
0.39
26.5 19.0 10.0 22.5
0.8
0.0082 13.0 11.0
5.0
10.0
0.6
0.47
26.5 19.0 10.0 22.5
0.8
0.01
13.0 11.0
5.0
10.0
0.6
0.47
32.0 20.0 11.0 27.5
0.8
0.012
13.0 11.0
5.0
10.0
0.6
0.56
32.0 20.0 11.0 27.5
0.8
0.015
13.0 11.0
5.0
10.0
0.6
0.68
32.0 20.0 11.0 27.5
0.8
0.018
13.0 12.0
6.0
10.0
0.6
0.82
32.0 22.0 13.0 27.5
0.8
0.022
13.0 12.0
6.0
10.0
0.6
1.0
32.0 22.0 13.0 27.5
0.8
0.027
13.0 12.0
6.0
10.0
0.6
1.0
37.0 25.0 13.5 31.5
0.8
0.033
18.0 11.0
5.0
15.0
0.8
1.2
37.0 25.0 13.5 31.5
0.8
0.039
18.0 11.0
5.0
15.0
0.8
1.5
37.0 26.0 15.0 31.5
0.8
0.047
18.0 11.0
5.0
15.0
0.8
1.8
38.0 26.0 17.0 31.5
0.8
0.056
18.0 12.0
6.0
15.0
0.8
2.2
37.0 29.0 19.0 31.5
0.8
Compact Size
0.1
18.0 12.0
6.0
15.0
0.8
0.33
26.5 16.5
7.0
22.5
0.8
0.15
18.0 13.5
7.5
15.0
0.8
0.47
26.5 17.0
8.5
22.5
0.8
0.18
18.0 14.5
8.5
15.0
0.8
0.47
18.0 19.0 11.0 15.0
0.8
0.22
18.0 14.5
8.5
15.0
0.8
0.56
26.5 19.0 10.0 22.5
0.8
0.33
0.8
18.0 16.0 10.0 15.0
0.8
1.0
32.0 20.0 11.0 27.5
*Please contact us for special item or size not listed * 当 W 大 于 2 6 . 5 m m 时 其 外 壳 尺 寸 误 差 为 ± 1 . 0 m m
µF / V
Tolerance
W
H
T
Pediform
P
L0
dØ
C
Q
C
17.印字說明:
MEX/TENTA MKP
0.33uF
K X2
275VAC
40/100/21
V
DE
EN 60384-14 xx-xx
250VAC
TENTA:天泰商標
MEX:产品类型
X2:产品名稱
MKP:材质
0.33uF:標準容量
K:標準容量允差值±10%
275VAC:額定電壓
40/100/21:
40: 表示电容能承受的下限类别温度为-40Ċ
100:表示电容能承受的上限类别温度为 100Ċ
21:表示穩態濕熱的持續時間 21 天
:德国安规认证
:欧盟安规认证
:韩国安规认证
C
Q
C
:中国安规认证
:美國證符號及電壓
EN60384-14:行业标准编号
XX-XX:月期-年期
备注:以此为例,不同规格随着容量不同,其测试后标准容量与标准容量部分(划线部位)也随着改变
容量大于或等于 0.1UF 的有 KC 认证,小于 0.1UF 的没有 KC 认证。
很抱歉,暂时无法提供与“MEX104K300A01”相匹配的价格&库存,您可以联系我们找货
