LM4861
1.1W Audio Power Amplifier with Shutdown Mode
FEATURES
DESCRIPTION
The LM4861 is a bridge-connected audio power
amplifier capable of delivering 1.1W of continuous
average power to an 8Ω load with 1% THD+N using
a 5V power supply.
1
2
No output coupling capacitors, bootstrap
capacitors, or snubber circuits are necessary
Small Outline (SOIC) packaging
Compatible with PC power supplies
Thermal shutdown protection circuitry
Unity-gain stable
External gain configuration capability
Boomer audio power amplifiers were designed
specifically to provide high quality output power with a
minimal amount of external components using
surface mount packaging. Since the LM4861 does
not require output coupling capacitors, bootstrap
capacitors, or snubber networks, it is optimally suited
for low-power portable systems.
APPLICATIONS
Personal computers
Portable consumer products
Self-powered speakers
Toys and games
The LM4861 features an externally controlled, lowpower consumption shutdown mode, as well as an
internal thermal shutdown protection mechanism.
The unity-gain stable LM4861 can be configured by
external gain-setting resistors for differential gains of
up to 10 without the use of external compensation
components. Higher gains may be achieved with
suitable compensation.
KEY SPECIFICATIONS
THD+N for 1kHz at 1W continuous average
output power into 8Ω 1.0% (max)
Output power at 10% THD+N at 1kHz into 8Ω
1.5 W (typ)
Shutdown Current 0.6µA (typ)
Connection Diagram
Figure 1. 8-Lead SOIC - Top View
See D Package
http://www.hgsemi.com.cn
1
2018 MAR
LM4861
Typical Application
Figure 2. Typical Audio Amplifier Application Circuit
These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam
during storage or handling to prevent electrostatic damage to the MOS gates.
2
2018 MAR
LM4861
Absolute Maximum Ratings
(1) (2)
Supply Voltage
6.0V
−65°C to +150°C
Storage Temperature
−0.3V to VDD + 0.3V
Input Voltage
Power Dissipation
(3)
Internally limited
ESD Susceptibility
(4)
3000V
ESD Susceptibility
(5)
250V
Junction Temperature
150°C
Soldering Information
(1)
(2)
(3)
(4)
(5)
SOIC Package
Vapor Phase (60 sec.)
215°C
Infrared (15 sec.)
220°C
Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for
which the device is functional, but do not ensure specific performance limits. Electrical Characteristics state DC and AC electrical
specifications under particular test conditions which ensure specific performance limits. This assumes that the device is within the
Operating Ratings. Specifications are not ensured for parameters where no limit is given, however, the typical value is a good indication
of device performance.
Military/Aerospace specified devices are required, please contact the Texas Instruments Sales Office/ Distributors for availability and
specifications.
The maximum power dissipation must be derated at elevated temperatures and is dictated by TJMAX, θJA, and the ambient temperature
TA. The maximum allowable power dissipation is PDMAX = (TJMAX − TA)/θJA or the number given in the Absolute Maximum Ratings,
whichever is lower. For the LM4861, TJMAX = 150°C, and the typical junction-to-ambient thermal resistance, when board mounted, is
140°C/W.
Human body model, 100pF discharged through a 1.5kΩ resistor.
Machine Model, 220pF–240pF discharged through all pins.
Operating Ratings
TMIN ≤ TA ≤ TMAX
Temperature Range
−40°C ≤ TA ≤ +85°C
2.0V ≤ VDD ≤ 5.5V
Supply Voltage
Thermal Resistance
θJC (typ)—M08A
35°C/W
θJA (typ)—M08A
140°C/W
θJC (typ)—N08E
37°C/W
θJA (typ)—N08E
107°C/W
(1) (2)
The following specifications apply for VDD = 5V, unless otherwise specified. Limits apply for TA = 25°C.
Symbol
Parameter
Conditions
VDD
Supply Voltage
IDD
Quiescent Power Supply Current
VIN = 0V, IO = 0A
ISD
Shutdown Current
VOS
PO
LM4861
Typical (3)
Limit (4)
Units
(Limits)
2.0
V (min)
5.5
V (max)
6.5
10.0
mA (max)
VSHUTDOWN = VDD
0.6
10.0
μA (max)
Output Offset Voltage
VIN = 0V
5.0
50.0
mV (max)
Output Power
THD = 1% (max); f = 1 kHz
1.1
1.0
W (min)
THD+N
Total Harmonic Distortion + Noise
PO = 1Wrms; 20 Hz ≤ f ≤ 20 kHz
0.72
PSRR
Power Supply Rejection Ratio
VDD = 4.9V to 5.1V
65
dB
(1)
(2)
(3)
(4)
(5)
(5)
All voltages are measured with respect to the ground pin, unless otherwise specified.
Typicals are measured at 25°C and represent the parametric norm.
Limits are specified to TI's AOQL (Average Outgoing Quality Level).
The quiescent power supply current depends on the offset voltage when a practical load is connected to the amplifier.
3
2018 MAR
LM4861
High Gain Application Circuit
Figure 3. Audio Ampiifier with AVD = 20
Single Ended Application Circuit
*CS and CB size depend on specific application requirements and constraints. Typical vaiues of CS and CB are 0.1 μF.
**Pin 1 should be connected to VDD to disable the amplifier or to GND to enable the amplifier. This pin should not be
left floating.
***These components create a “dummy” load for pin 8 for stability purposes.
Figure 4. Single-Ended Amplifier with AV = −1
4
2018 MAR
LM4861
External Components Description
(Figure 2 and Figure 3)
Components
Functional Description
1. Ri
Inverting input resistance which sets the closed-loop gain in conjunction with Rf. This resistor also forms a high pass
filter with Ci at fC = 1 / (2π Ri Ci).
2. Ci
Input coupling capacitor which blocks DC voltage at the amplifier's input terminals. Also creates a high pass filter with
Ri at fC = 1 / (2π Ri Ci).
3. Rf
Feedback resistance which sets closed-loop gain in conjunction with Ri.
4. CSApplication
Information
Supply bypass capacitor which provides power supply filtering. Refer to for proper placement and selection of supply
bypass capacitor.
5. CB
Bypass pin capacitor which provides half supply filtering. Refer to Application Information for proper placement and
selection of bypass capacitor.
6. Cf (1)
Cf in conjunction with Rf creates a low-pass filter which bandwidth limits the amplifier and prevents possible high
frequency oscillation bursts. fC = 1 / (2π Rf Cf)
(1)
Optional component dependent upon specific design requirements. Refer to Application Information for more information.
5
2018 MAR
LM4861
Typical Performance Characteristics
THD+N
vs
Frequency
THD+N
vs
Frequency
Figure 5.
Figure 6.
THD+N
vs
Frequency
THD+N
vs
Output Power
Figure 7.
Figure 8.
THD+N
vs
Output Power
Output Power vs
Load Resistance
Figure 9.
Figure 10.
6
2018 MAR
LM4861
Typical Performance Characteristics (continued)
Output Power vs
Supply Voltage
Power Dissipation vs
Output Power
Figure 11.
Figure 12.
Noise Floor
vs
Frequency
Supply Current Distribution
vs Temperature
Figure 13.
Figure 14.
Supply Current vs
Supply Voltage
Power Derating Curve
Figure 15.
Figure 16.
7
2018 MAR
LM4861
Power Supply
Rejection Ratio
Open Loop
Frequency Response
Figure 17.
Figure 18.
8
2018 MAR
LM4861
APPLICATION INFORMATION
BRIDGE CONFIGURATION EXPLANATION
As shown in Figure 2 , the LM4861 has two operational amplifiers internally, allowing for a few different amplifier
configurations. The first amplifier's gain is externally configurable, while the second amplifier is internally fixed in
a unity-gain, inverting configuration. The closed-loop gain of the first amplifier is set by selecting the ratio of Rf to
Ri while the second amplifier's gain is fixed by the two internal 40kΩ resistors. Figure 2 shows that the output of
amplifier one serves as the input to amplifier two which results in both amplifiers producing signals identical in
magnitude, but out of phase 180°. Consequently, the differential gain for the IC is:
Avd = 2 * (Rf/ Ri)
(1)
By driving the load differentially through outputs VO1 and VO2, an amplifier configuration commonly referred to as
“bridged mode” is established. Bridged mode operation is different from the classical single-ended amplifier
configuration where one side of its load is connected to ground.
A bridge amplifier design has a few distinct advantages over the single-ended configuration, as it provides
differential drive to the load, thus doubling output swing for a specified supply voltage. Consequently, four times
the output power is possible as compared to a single-ended amplifier under the same conditions. This increase in
attainable output power assumes that the amplifier is not current limited or clipped. In order to choose an
amplifier's closed-loop gain without causing excessive clipping which will damage high frequency transducers
used in loudspeaker systems, please refer to AUDIO POWER AMPLIFIER DESIGN.
A bridge configuration, such as the one used in Boomer Audio Power Amplifiers, also creates a second
advantage over single-ended amplifiers. Since the differential outputs, VO1 and VO2, are biased at half-supply, no
net DC voltage exists across the load. This eliminates the need for an output coupling capacitor which is required
in a single supply, single-ended amplifier configuration. Without an output coupling capacitor in a single supply,
single-ended amplifier, the half-supply bias across the load would result in both increased internal IC power
dissipation and also permanent loudspeaker damage. An output coupling capacitor forms a high pass filter with
the load requiring that a large value such as 470μF be used with an 8Ω load to preserve low frequency response.
This combination does not produce a flat response down to 20Hz, but does offer a compromise between printed
circuit board size and system cost, versus low frequency response.
POWER DISSIPATION
Power dissipation is a major concern when designing a successful amplifier, whether the amplifier is bridged or
single-ended. A direct consequence of the increased power delivered to the load by a bridge amplifier is an
increase in internal power dissipation. Equation 3 states the maximum power dissipation point for a bridge
amplifier operating at a given supply voltage and driving a specified output load.
PDMAX = 4*(VDD)2 / (2π2RL)
(2)
Since the LM4861 has two operational amplifiers in one package, the maximum internal power dissipation is 4
times that of a single-ended amplifier. Even with this substantial increase in power dissipation, the LM4861 does
not require heatsinking. From Equation 3, assuming a 5V power supply and an 8Ω load, the maximum power
dissipation point is 625mW.The maximum power dissipation point obtained from Equation 3 must not be greater
than the power dissipation that results from Equation 3:
PDMAX = (TJMAX − TA) / θJA
(3)
For the LM4861 surface mount package, θJA = 140°C/W and TJMAX = 150°C. Depending on the ambient
temperature, TA, of the system surroundings, Equation 3 can be used to find the maximum internal power
dissipation supported by the IC packaging. If the result of Equation 3 is greater than that of Equation 3, then
either the supply voltage must be decreased or the load impedance increased. For the typical application of a 5V
power supply, with an 8Ω load, the maximum ambient temperature possible without violating the maximum
junction temperature is approximately 62.5°C provided that device operation is around the maximum power
dissipation point. Power dissipation is a function of output power and thus, if typical operation is not around the
maximum power dissipation point, the ambient temperature can be increased. Refer to the Typical Performance
Characteristics curves for power dissipation information for lower output powers.
9
2018 MAR
LM4861
POWER SUPPLY BYPASSING
As with any power amplifier, proper supply bypassing is critical for low noise performance and high power supply
rejection. The capacitor location on both the bypass and power supply pins should be as close to the device as
possible. As displayed in the Typical Performance Characteristics, the effect of a larger half supply bypass
capacitor is improved low frequency THD+N due to increased half-supply stability. Typical applications employ a
5V regulator with 10μF and a 0.1μF bypass capacitors which aid in supply stability, but do not eliminate the need
for bypassing the supply nodes of the LM4861. The selection of bypass capacitors, especially CB, is thus
dependant upon desired low frequency THD+N, system cost, and size constraints.
SHUTDOWN FUNCTION
In order to reduce power consumption while not in use, the LM4861 contains a shutdown pin to externally turn off
the amplifier's bias circuitry. The shutdown feature turns the amplifier off when a logic high is placed on the
shutdown pin. Upon going into shutdown, the output is immediately disconnected from the speaker. A typical
quiescent current of 0.6μA results when the supply voltage is applied to the shutdown pin. In many applications,
a microcontroller or microprocessor output is used to control the shutdown circuitry which provides a quick,
smooth transition into shutdown. Another solution is to use a single-pole, single-throw switch that when closed, is
connected to ground and enables the amplifier. If the switch is open, then a soft pull-up resistor of 47kΩ will
disable the LM4861. There are no soft pull-down resistors inside the LM4861, so a definite shutdown pin voltage
must be applied externally, or the internal logic gate will be left floating which could disable the amplifier
unexpectedly.
HIGHER GAIN AUDIO AMPLIFIER
The LM4861 is unity-gain stable and requires no external components besides gain-setting resistors, an input
coupling capacitor, and proper supply bypassing in the typical application. However, if a closed-loop differential
gain of greater than 10 is required, a feedback capacitor may be needed, as shown in Figure 3, to bandwidth
limit the amplifier. This feedback capacitor creates a low pass filter that eliminates possible high frequency
oscillations. Care should be taken when calculating the −3dB frequency in that an incorrect combination of Rf and
Cf will cause rolloff before 20kHz. A typical combination of feedback resistor and capacitor that will not produce
audio band high frequency rolloff is Rf = 100kΩ and Cf = 5pF. These components result in a −3dB point of
approximately 320kHz. Once the differential gain of the amplifier has been calculated, a choice of Rf will result,
and Cf can then be calculated from the formula stated in External Components Description .
VOICE-BAND AUDIO AMPLIFIER
Many applications, such as telephony, only require a voice-band frequency response. Such an application
usually requires a flat frequency response from 300Hz to 3.5kHz. By adjusting the component values of Figure 3,
this common application requirement can be implemented. The combination of Ri and Ci form a highpass filter
while Rf and Cf form a lowpass filter. Using the typical voice-band frequency range, with a passband differential
gain of approximately 100, the following values of Ri, Ci, Rf, and Cf follow from the equations stated in External
Ri = 10kΩ, Rf = 510k ,Ci = 0.22μF, and Cf = 15pF
(4)
Five times away from a −3dB point is 0.17dB down from the flatband response. With this selection of
components, the resulting −3dB points, fL and fH, are 72Hz and 20kHz, respectively, resulting in a flatband
frequency response of better than ±0.25dB with a rolloff of 6dB/octave outside of the passband. If a steeper
rolloff is required, other common bandpass filtering techniques can be used to achieve higher order filters.
SINGLE-ENDED AUDIO AMPLIFIER
Although the typical application for the LM4861 is a bridged monoaural amp, it can also be used to drive a load
single-endedly in applications, such as PC cards, which require that one side of the load is tied to ground.
Figure 4 shows a common single-ended application, where VO1 is used to drive the speaker. This output is
coupled through a 470μF capacitor, which blocks the half-supply DC bias that exists in all single-supply amplifier
configurations. This capacitor, designated CO in Figure 4, in conjunction with RL, forms a highpass filter. The
−3dB point of this high pass filter is 1/(2πRLCO), so care should be taken to make sure that the product of RL and
CO is large enough to pass low frequencies to the load. When driving an 8Ω load, and if a full audio spectrum
reproduction is required, CO should be at least 470μF. VO2, the output that is not used, is connected through a
0.1 μF capacitor to a 2kΩ load to prevent instability. While such an instability will not affect the waveform of VO1,
it is good design practice to load the second output.
10
2018 MAR
LM4861
Design a 1W / 8Ω Audio Amplifier
Given:
Power Output
1 Wrms
Load Impedance
8Ω
Input Level
1 Vrms
Input Impedance
20 kΩ
Bandwidth
100 Hz–20 kHz ± 0.25 dB
A designer must first determine the needed supply rail to obtain the specified output power. By extrapolating from
Figure 11 in Typical Performance Characteristics, the supply rail can be easily found. A second way to determine
the minimum supply rail is to calculate the required Vopeak using Equation 5 and add the dropout voltage. Using
this method, the minimum supply voltage would be (Vopeak + VOD , where VOD is typically 0.6V.
(5)
For 1W of output power into an 8Ω load, the required Vopeak is 4.0V. A minumum supply rail of 4.6V results from
adding Vopeak and Vod. But 4.6V is not a standard voltage that exists in many applications and for this reason, a
supply rail of 5V is designated. Extra supply voltage creates dynamic headroom that allows the LM4861 to
reproduce peaks in excess of 1Wwithout clipping the signal. At this time, the designer must make sure that the
power supply choice along with the output impedance does not violate the conditions explained in the POWER
DISSIPATION.
Once the power dissipation equations have been addressed, the required differential gain can be determined
from Equation 6.
(6)
(7)
Rf/Ri = AVD / 2
From Equation 6, the minimum Avd is 2.83: Avd = 3
Since the desired input impedance was 20kΩ, and with a Avd of 3, a ratio of 1:1.5 of Rf to Ri results in an
allocation of Ri = 20kΩ, Rf = 30kΩ. The final design step is to address the bandwidth requirements which must
be stated as a pair of −3dB frequency points. Five times away from a −3db point is 0.17dB down from passband
response which is better than the required ±0.25dB specified. This fact results in a low and high frequency pole
of 20Hz and 100kHz respectively. As stated in External Components Description , Ri in conjunction with Ci create
a highpass filter.
Ci ≥ 1 / (2π*20kΩ*20Hz) = 0.397μF; use 0.39μF.
(8)
The high frequency pole is determined by the product of the desired high frequency pole, fH, and the differential
gain, Avd. With a Avd = 2 and fH = 100kHz, the resulting GBWP = 100kHz which is much smaller than the LM4861
GBWP of 4MHz. This figure displays that if a designer has a need to design an amplifier with a higher differential
gain, the LM4861 can still be used without running into bandwidth problems.
11
2018 MAR
