SS14 (SMAF)
SS14 (SMAF)
    LGE(鲁光)
    SMA(DO-214AC)
    表面贴装肖特基势垒整流器
SS14 (SMAF) 数据手册
SS12-SS120 1.0AMP. Surface Mount Schottky Barrier Rectifiers SMA/DO-214AC Features          0. 181( 4. 60) 0. 161( 4. 10) For surface mounted application Easy pick and place Metal to silicon rectifier, majority carrier conduction Low power loss, high efficiency High current capability, low VF High surge current capability Plastic material used carriers Underwriters Laboratory Classification 94V-0 Epitaxial construction High temperature soldering: 260oC / 10 seconds at terminals 0. 209( 5. 30) 0. 193( 4. 90) 0. 012(0.30) 0. 006(0.15) 0.096(2.45) 0.078(2.00) 0. 059( 1. 50) 0. 035( 0. 90) Mechanical Data      0. 108( 2. 75) 0. 096( 2. 45) 0. 063(1.60) 0. 051(1.30) Case: JEDEC SMA/DO-214AC Molded plastic Terminals: Pure tin plated, lead free Polarity: Indicated by cathode band Packaging: 12mm tape Weight: 0.064 gram 0.008(0.20) 0. 002(0.05) Dimensions in inches and(millimeters) Maximum Ratings and Electrical Characteristics Rating at 25oC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Symbol SS SS SS SS Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current at TL(See Fig. 1) Peak Forward Surge Current, 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method ) Maximum Instantaneous Forward Voltage o IF= 1.0A @ 25 C (Note 1) o @ 100 C o Maximum DC Reverse Current @ TA =25 C at Rated DC Blocking Voltage @ TA=125 oC Maximum DC Reverse Current at VR=33V o & TA=50 C Typical Junction Capacitance (Note 3) Typical Thermal Resistance ( Note 2 ) VRRM VRMS VDC 12 20 14 20 13 30 21 30 14 40 28 40 SS 16 60 42 60 15 50 35 50 SS 19 90 63 90 SS SS SS Units 110 115 120 100 150 200 V V 70 105 150 100 150 200 V I(AV) 1.0 A IFSM 30 A 0.5 0.4 VF 0.75 0.65 0.4 IR 10 5.0 - HTIR Cj 0.80 0.70 0.1 2.0 0.90 0.85 V mA mA 5.0 uA 50 R ΘJL 28 88 R θJA TJ Operating Temperature Range -65 to +125 -65 to +150 Storage Temperature Range TSTG -65 to +150 Notes: 1. Pulse Test with PW=300 usec, 1% Duty Cycle 2. Measured on P.C.Board with 0.2” x 0.2” (5.0mm x 5.0mm) Copper Pad Areas. 3. Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C. pF o C/W o o C C - 32 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS12-SS120 1.0AMP. Surface Mount Schottky Barrier Rectifiers RATINGS AND CHARACTERISTIC CURVES (SS12 THRU SS120) FIG.1- MAXIMUM FORWARD CURRENT DERATING CURVE 50 RESISTIVE OR INDUCTIVE LOAD SS12- SS14 SS15-SS120 0.5 PCB MOUNTED ON 0.2X0.2" (5.0X5.0mm) COPPER PAD AREAS 0 PEAK FORWARD SURGE CURRENT. (A) AVERAGE FORWARD CURRENT. (A) 1.0 FIG.2- MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT AT RATED TL 8.3ms Single Half Sine Wave JEDEC Method 40 30 20 10 0 50 60 70 80 90 100 110 120 130 140 150 160 1 170 10 NUMBER OF CYCLES AT 60Hz o LEAD TEMPERATURE. ( C) 100 FIG.4- TYPICAL REVERSE CHARACTERISTICS FIG.3- TYPICAL FORWARD CHARACTERISTICS 100 50 SS12-SS14 SS15-SS120 SS15-SS16 10 INSTANTANEOUS FORWARD CURRENT. (A) INSTANTANEOUS REVERSE CURRENT. (mA) SS19-SS110 SS12-SS14 1 SS120 0.1 10 Tj=125 0C 1 Tj=75 0C 0.1 0.01 Tj=25OC PULSE WIDTH=300 S 1% DUTY CYCLE 0.001 0.01 0 .2 .4 .6 .8 1.0 1.2 1.4 1.6 FORWARD VOLTAGE. (V) 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE. (%) FIG.6- TYPICAL TRANSIENT THERMAL CHARACTERISTICS FIG.5- TYPICAL JUNCTION CAPACITANCE 0 Tj=25 C f=1.0MHz Vsig=50mVp-p SS12-SS14 SS15-SS16 SS19-SS120 100 10 0.1 1.0 10 TRANSIENT THERMAL IMPEDANCE. (OC/W) 100 400 JUNCTION CAPACITANCE.(pF) 0 100 10 1 0.1 0.01 0.1 REVERSE VOLTAGE. (V) 100 PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMA 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 1 10 T, PULSE DURATION. (sec) www.lgesemi .c o m mail:lge@lgesemi.com
SS14 (SMAF) 价格&库存
很抱歉,暂时无法提供与“SS14 (SMAF)”相匹配的价格&库存,您可以联系我们找货
