SS32-SS310
Surface Mount Schottky Barrier Rectifiers
SMC/DO-214AB
Features
Schottky barrier rectifier
Guardring protection
Low forward voltage
Reverse energy tested
High current capability
Extremely low thermal resistance
Mechanical Data
Case: SMC molded plastic body
Polarity: Color band denotes cathode end
Mounting position: ANY
Weight: 0.007 ounces, 0.21 gram
1111
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
SS32 SS33 SS34 SS35
Device marking code
SS36 SS38 SS39 SS310 UNITS
Maximum repetitive peak reverse voltage
VRRM
40
50
60
80
90
100
V
Maximum RMS voltage
VRWS
14
21
28
35
42
56
63
70
V
Maximum DC blocking voltage
VDC
40
50
60
80
90
100
V
Maximum average forward rectified current at
TL=90
IF(AV)
3.0
A
Peak forward surge current 8.3ms single halfsine-wave
IFSM
100.0
A
Maximum instantaneous forward voltage
at IFM=3.0A (NOTE1)
Maximum DC reverse current
TJ=25
at rated DC blocking voltage
TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
VF
0.50
0.85
0.5
IR
R
0.75
JL
10
17.0
V
mA
o
C/W
TJ
- 55 ---- +125
o
C
TSTG
- 55 ---- +150
o
C
NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 %
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SS32-SS310
Ratings AND Charactieristic Curves
PEAK FORWARD SURGE CURRENT
AMPERES
FIG.2 -- PEAK FORWARD SURGE CURRENT
4
3
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT
FIG.1 -- FORWARD DERATING CURVE
Resistive or
Inductive Load
0.375"(9.5mm)Lead
Length
2
1
50
75
100
125
150
175
100
TJ=TJMAX
8.3ms Single Half
Sine-Wave
50
LEAD TEMPERATURE,
100
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
XXXXXXXXX----
AMPERES
INSTANTANEOUS FORWARD CURRENT
10
SS32--SS34
SS38-SS310
SS35-SS36
1
T J= 2 5
P u ls e w id t h = 3 0 0
1 % D u t y C y c le
.1
.1
.3
.5
.7
.9
1 .1
1 .3
1 .5
1 .7
1 .9
s
2 .1
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMC
3000/REEL
42000
36X36X36.5
18.50
15.50
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“SS310 (SMA)”相匹配的价格&库存,您可以联系我们找货
