SS34 (SMA)
SS34 (SMA)
    LGE(鲁光)
    SMA(DO214AC)
    VR=40V IF=3A
SS34 (SMA) 数据手册
SS32-SS310 Surface Mount Schottky Barrier Rectifiers SMC/DO-214AB Features  Schottky barrier rectifier  Guardring protection  Low forward voltage  Reverse energy tested  High current capability  Extremely low thermal resistance Mechanical Data  Case: SMC molded plastic body  Polarity: Color band denotes cathode end  Mounting position: ANY  Weight: 0.007 ounces, 0.21 gram 1111 Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25oC ambient temperature unless otherwise specified SS32 SS33 SS34 SS35 Device marking code SS36 SS38 SS39 SS310 UNITS Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 V Maximum average forward rectified current at TL=90 IF(AV) 3.0 A Peak forward surge current 8.3ms single halfsine-wave IFSM 100.0 A Maximum instantaneous forward voltage at IFM=3.0A (NOTE1) Maximum DC reverse current TJ=25 at rated DC blocking voltage TJ=125 Maximum thermal resistance Operating temperature range Storage temperature range VF 0.50 0.85 0.5 IR R 0.75 20 JL 10 17.0 V mA o C/W TJ - 55 ---- +125 o C TSTG - 55 ---- +150 o C NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS32-SS310 Surface Mount Schottky Barrier Rectifiers Ratings AND Charactieristic Curves PEAK FORWARD SURGE CURRENT AMPERES FIG.2 -- PEAK FORWARD SURGE CURRENT 4 3 AMPERES AVERAGE FORWARD RECTIFIED CURRENT FIG.1 -- FORWARD DERATING CURVE Resistive or Inductive Load 0.375"(9.5mm)Lead Length 2 1 0 0 25 50 75 100 125 150 175 100 TJ=TJMAX 8.3ms Single Half Sine-Wave 50 0 1 LEAD TEMPERATURE, 100 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS XXXXXXXXX---- 20 10 AMPERES INSTANTANEOUS FORWARD CURRENT 10 SS32--SS34 SS38-SS310 SS35-SS36 1 T J= 2 5 P u ls e w id t h = 3 0 0 1 % D u t y C y c le .1 .1 .3 .5 .7 .9 1 .1 1 .3 1 .5 1 .7 1 .9 s 2 .1 INSTANTANEOUS FORWARD VOLTAGE, VOLTS PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMC 3000/REEL 42000 36X36X36.5 18.50 15.50 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
SS34 (SMA) 价格&库存
很抱歉,暂时无法提供与“SS34 (SMA)”相匹配的价格&库存,您可以联系我们找货
