Preliminary Datasheet
技术索样QQ:1378271156
1.5A 380KHz 32V Buck LED Constant Current Driver
XL3002
Features
General Description
n
n
n
n
n
n
n
n
n
n
n
n
n
The XL3002 is a 380 KHz fixed frequency
PWM buck (step-down) DC/DC converter,
capable of driving a 1.5A load with high
efficiency, low ripple and excellent line and
load regulation. Requiring a minimum
number of external components, the regulator
is simple to use and include internal
frequency
compensation
and
a
fixed-frequency oscillator.
Wide 5V to 32V Input Voltage Range
Output Current Sense Voltage is 0.24V
Minimum Drop Out 0.3V
Fixed 380KHz Switching Frequency
1.5A Constant Output Current Capability
Internal Optimize Power MOSFET
Excellent line and load regulation
High efficiency up to 96%
TTL shutdown capability
EN pin with hysteresis function
Built in thermal shutdown function
Built in current limit function
SOIC-8 package
The PWM control circuit is able to adjust the
duty ratio linearly from 0 to 100%. An enable
function, an over current protection function
is built inside. An internal compensation
block is built in to minimize external
component count.
Applications
n
n
MR16 LED Lamp
LED Lighting
Figure1. Package Type of XL3002
Rev 2.3
www.xlsemi.com
1
XL3002
Pin Configurations
Figure2. Pin Configuration of XL3002 (Top View)
Table 1 Pin Description
Pin Number
Pin Name
1
CS
2
EN
3
NC
4
VIN
5,6
SW
7,8
GND
Description
Output constant current sense Pin (CS). The CS reference
voltage is 0.24V.
Enable Pin. Drive EN pin low to turn off the device, drive it
high to turn it on.
No connected.
Supply Voltage Input Pin. XL3002 operates from a 5V to 32V
DC voltage.
Power Switch Output Pin (SW). Output is the switch node that
supplies power to the output.
Ground Pin.
Function Block
Figure3. Function Block Diagram of XL3002
Rev 2.3
www.xlsemi.com
2
XL3002
Typical Application Circuit (MR16 LED Lamp)
Figure4. XL3002 Typical Application Circuit (MR16 LED Lamp)
Figure5. XL3002 Typical Application Circuit Efficiency
Rev 2.3
www.xlsemi.com
3
XL3002
Figure6. XL3002 Efficiency VS Load current & Input voltage
Rev 2.3
www.xlsemi.com
4
XL3002
Ordering Information
Order Information
XL3002E1
Marking ID
XL3002E1
Package Type
SOIC-8
Packing Type Supplied As
2500 Units on Tape & Reel
XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant.
Absolute Maximum Ratings(Note1)
Parameter
Symbol
Vin
VCS
VEN
VSW
PD
Value
-0.3 to 36
-0.3 to Vin
-0.3 to Vin
-0.3 to Vin
Internally limited
Unit
V
V
V
V
mW
Input Voltage
CS Pin Voltage
EN Pin Voltage
SW Pin Voltage
Power Dissipation
Thermal Resistance
(Junction to Ambient, No Heatsink, Free Air)
Operating Junction Temperature
Storage Temperature
Lead Temperature (Soldering, 10 sec)
ESD (HBM)
RJA
100
ºC/W
TJ
TSTG
TLEAD
-40 to 125
-65 to 150
260
3000
ºC
ºC
ºC
V
Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage
to the device. This is a stress rating only and functional operation of the device at these or any
other conditions above those indicated in the operation is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect reliability.
Rev 2.3
www.xlsemi.com
5
XL3002
XL3002 Electrical Characteristics
Ta = 25℃;unless otherwise specified.
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Unit
System parameters test circuit figure4
VCS
Current
Sense
Voltage
Vin = 8V to 32V, Vout=5V
Iload=0.3A
0.228
0.24
0.252
V
ŋ
Vin=12V ,Vout=9.6V
Iout=1A
96
Efficiency
Electrical Characteristics (DC Parameters)
Vin = 12V, GND=0V, Vin & GND parallel connect a 220uf/25V capacitor; Iout=500mA, Ta =
25℃; the others floating unless otherwise specified, system parameters reference figure4.
Parameters
Input operation voltage
Symbol
Test Condition
Vin
Min.
Typ.
5
Max.
Unit
32
V
Shutdown Supply Current
ISTBY
VEN=0V
60
200
uA
Quiescent Supply Current
Iq
VEN =2V,
VFB =Vin
2.5
5
mA
380
456
KHz
Oscillator Frequency
Fosc
EN Pin Threshold
VEN
Output Power PMOS
RDS(ON)
304
High (Regulator ON)
Low (Regulator OFF)
VFB=0V
ISW=1A
Rev 2.3
1.7
1.1
150
V
250
mohm
www.xlsemi.com
6
XL3002
Schottky Diode Selection Table
Current
1A
3A
Surface Through VR (The same as system maximum input voltage)
Mount Hole
20V
30V
40V
50V
1N5817
1N5818
1N5819
SS12
SS13
SS14
1N5820
1N5821
1N5822
MBR320
MBR330
MBR340 MBR350
MBR360
SK32
SK33
SK34
SK36
30WQ03
30WQ04 30WQ05
31DQ03
31DQ04
31DQ05
SR303
SR304
SR305
SR302
Rev 2.3
SS15
60V
SK35
SS16
SR306
www.xlsemi.com
7
XL3002
Package Information
SOP8 Package Mechanical Dimensions
Rev 2.3
www.xlsemi.com
8
很抱歉,暂时无法提供与“XL3002”相匹配的价格&库存,您可以联系我们找货
