Datasheet
3A 150kHz 40V Buck Li Battery Charger
XL4101
Features
General Description
n
n
n
n
n
n
n
n
n
n
n
n
The XL4101 is a 150KHz fixed frequency
PWM buck (step-down) DC/DC converter,
capable of driving a 3A load with high
efficiency, low ripple and excellent line and
load regulation. Requiring a minimum
number of external components, the regulator
is simple to use and include internal
frequency
compensation
and
a
fixed-frequency oscillator.
Wide 4.5V to 40V Input Voltage Range
Output Adjustable from 1.235V to 37V
Minimum Drop Out 1.5V
Fixed 150kHz Switching Frequency
3A Constant Output Current Capability
Internal Optimize Power Transistor
Excellent line and load regulation
With output constant current loop
Built in thermal shutdown function
Built in current limit function
Built in output over voltage protection
TO263-5L package
The PWM control circuit is able to adjust the
duty ratio linearly from 0 to 100%. An over
current protection function is built inside.
An internal compensation block is built in to
minimize external component count.
Applications
n
n
Car Charger
Battery Charger
Figure1. Package Type of XL4101
Rev 1.2
www.xlsemi.com
1
Datasheet
XL4101
Pin Configurations
Figure2. Pin Configuration of XL4101 (Top View)
Table 1 Pin Description
Pin Number
Pin Name
1
VIN
2
SW
3
GND
4
FB
5
CS
Description
Supply Voltage Input Pin. XL4101 operates from a 4.5V to 40V
DC voltage. Bypass Vin to GND with a suitably large capacitor
to eliminate noise on the input.
Power Switch Output Pin (SW). Output is the switch node that
supplies power to the output.
Ground Pin.(Note: Connected the back exposed PAD to Pin3.)
Feedback Pin (FB). Through an external resistor divider
network, Feedback senses the output voltage and regulates it.
The feedback threshold voltage is 1.235V.
Output Current Sense Pin; (Iload=0.155V/Rcs)
Rev 1.2
www.xlsemi.com
2
Datasheet
XL4101
Function Block
Figure3. Function Block Diagram of XL4101
Typical Application Circuit (Car Charger)
Figure4. XL4101 Typical Application Circuit (Li Battery Charger)
Rev 1.2
www.xlsemi.com
3
Datasheet
XL4101
Typical Application Circuit (Buck LED Constant Current Driver)
Figure5. XL4101 Typical Application Circuit (LED Constant Current Driver)
Ordering Information
Order Information
XL4101E1
Marking ID
XL4101E1
Package Type
TO263-5L
Packing Type Supplied As
800 Units on Tape & Reel
XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant.
Absolute Maximum Ratings(Note1)
Parameter
Symbol
Value
-0.3 to 45
-0.3 to Vin
-0.3 to Vin
Internally limited
Unit
V
V
V
mW
Input Voltage
Vin
FB Pin Voltage
VFB
SW Pin Voltage
VSW
Power Dissipation
PD
Thermal Resistance
30
ºC/W
RJA
(Junction to Ambient, No Heatsink, Free Air)
Operating Junction Temperature
-40 to 125
ºC
TJ
Storage Temperature
-65 to 150
ºC
TSTG
Lead Temperature (Soldering, 10 sec)
260
ºC
TLEAD
ESD (HBM)
2000
V
Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage
to the device. This is a stress rating only and functional operation of the device at these or any
other conditions above those indicated in the operation is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect reliability.
Rev 1.2
www.xlsemi.com
4
Datasheet
XL4101
XL4101 Electrical Characteristics
Ta = 25℃;unless otherwise specified.
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Unit
System parameters test circuit figure4
Feedback
Voltage
VFB
ŋ
Efficiency
Vin = 8V to 32V, Vout=5V
Iload=0.2A to 3A
Vin=12V ,Vout=5V
Iout=3A
1.198 1.235 1.272
80
V
Electrical Characteristics (DC Parameters)
Vin = 12V, GND=0V, Vin & GND parallel connect a 220uf/50V capacitor; Iout=500mA, Ta =
25℃; the others floating unless otherwise specified.
Parameters
Symbol
Input operation voltage
Quiescent Supply Current
Test Condition
Min.
Vin
Iq
Typ.
Max.
Unit
40
V
2
5
mA
150
172
Khz
4.5
VFB =Vin
Oscillator Frequency
Fosc
Switch Current Limit
IL
VFB =0
3.6
Output Saturation Voltage
VCE
VFB=0V
ISW=2A
1.1
Constant
Voltage
VCS
current
sense
127
A
1.4
0.140 0.155 0.170
V
V
Schottky Diode Selection Table
Current
1A
3A
Surface Through VR (The same as system maximum input voltage)
Mount Hole
20V
30V
40V
50V
1N5817
1N5818
1N5819
60V
1N5820
1N5821
1N5822
MBR320
MBR330
MBR340 MBR350
MBR360
SK32
SK33
SK34
SK36
30WQ03
30WQ04 30WQ05
31DQ03
31DQ04
31DQ05
SR303
SR304
SR305
SR302
Rev 1.2
SK35
SR306
www.xlsemi.com
5
Datasheet
XL4101
Package Information
TO263-5L
Rev 1.2
www.xlsemi.com
6
很抱歉,暂时无法提供与“XL4101”相匹配的价格&库存,您可以联系我们找货
