Datasheet
400KHz 32V 2A Switching Current Boost LED Constant Current Driver
XL6001
Features
General Description
The XL6001 regulator is fixed frequency PWM
Boost (step-up) LED constant current driver,
capable of driving Series 1W LED units with
excellent line and load regulation. The regulator is
simple to use because it includes internal frequency
compensation and a fixed-frequency oscillator so
that it requires a minimum number of external
components to work.
The XL6001 could directly drive 5~8 Series 1W
LED units at VIN>12V .
Wide 3.6V to 24V Input Voltage Rang
0.22V Constant Current Sense Voltage
Directly drive 3~8 Series 1W LED
Fixed 400KHz Switching Frequency
Max. 2A Switching Current Capability
Up to 92% efficiency
Excellent line and load regulation
EN PIN TTL shutdown capability
Internal Optimize Power MOSFET
Built in LED Open Protection
Built in Soft-Start Function
Built in Frequency Compensation
Built in Thermal Shutdown Function
Built in Current Limit Function
Available in SOP8 package
The PWM control circuit is able to adjust the
duty ratio linearly from 0 to 90%. An enable
function, an over current protection function
is built inside. An internal compensation
block is built in to minimize external
component count.
Applications
LED Lighting
Boost constant current driver
Monitor LED Backlighting
7’ to 15’ LCD Panels
Figure1. Package Type of XL6001
Rev 1.3
www.xlsemi.com
1
Datasheet
XL6001
Pin Configurations
EN
1
8
GND
VIN
2
7
GND
FB
3
6
SW
NC
4
5
SW
XL6001
Figure2. Pin Configuration of XL6001 (Top View)
Table 1 Pin Description
Pin Number
Pin Name
1
EN
2
VIN
3
4
FB
NC
5,6
SW
7,8
GND
Description
Enable Pin. Drive EN pin low to turn off the device, drive it
high to turn it on. Floating is default high.
Supply Voltage Input Pin. XL6001 operates from a 3.6V to 24V
DC voltage. Bypass Vin to GND with a suitably large capacitor
to eliminate noise on the input.
Feedback Pin (FB). The feedback threshold voltage is 0.22V.
No Connected.
Power Switch Output Pin (SW). Output is the switch node that
supplies power to the output.
Ground Pin.
Rev 1.3
www.xlsemi.com
2
Datasheet
XL6001
Function Block
Figure3. Function Block Diagram of XL6001
Typical Application Circuit
Figure4. XL6001 Typical Application Circuit
Rev 1.3
www.xlsemi.com
3
Datasheet
XL6001
Ordering Information
Order Information
XL6001E1
Marking ID
XL6001E1
Package Type
SOP8L
Packing Type Supplied As
2500 Units on Tape & Reel
XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant.
Absolute Maximum Ratings(Note1)
Parameter
Symbol
Vin
VFB
VEN
VOutput
PD
Value
-0.3 to 26
-0.3 to Vin
-0.3 to Vin
-0.3 to 32
Internally limited
Unit
V
V
V
V
mW
Input Voltage
Feedback Pin Voltage
EN Pin Voltage
Output Switch Pin Voltage
Power Dissipation
Thermal Resistance (SOP8)
(Junction to Ambient, No Heatsink, Free Air)
Operating Junction Temperature
Storage Temperature
Lead Temperature (Soldering, 10 sec)
ESD (HBM)
RJA
100
ºC/W
TJ
TSTG
TLEAD
-40 to 125
-65 to 150
260
>2000
ºC
ºC
ºC
V
Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage
to the device. This is a stress rating only and functional operation of the device at these or any
other conditions above those indicated in the operation is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect reliability.
Rev 1.3
www.xlsemi.com
4
Datasheet
XL6001
XL6001 Electrical Characteristics
Ta = 25℃;unless otherwise specified.
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Unit
209
220
231
mV
92
System parameters test circuit figure4
Feedback
Voltage
VFB
Efficiency
ŋ
Vin = 5V to 12V, Vout=24V
Iload=100mA
Vin=12V ,Vout= 6*1W LED
Iout=0.3A
Electrical Characteristics (DC Parameters)
Vin = 12V, GND=0V, Vin & GND parallel connect a 47uf/25V capacitor; Iout=50mA, Ta =
25℃; the others floating unless otherwise specified.
Parameters
Symbol
Test Condition
Min.
Typ.
3.6
Max.
Unit
24
V
Input operation voltage
Vin
Shutdown Supply Current
ISTBY
VEN=0V
70
100
uA
Quiescent Supply Current
Iq
VEN =2V,
VFB =Vin
2.5
5
mA
400
480
Khz
Oscillator Frequency
Fosc
Switch Current Limit
IL
VFB =0
2
Output Power NMOS
Rdson
Vin=12V,
ISW=2A
110
VEN
High (Regulator ON)
Low (Regulator OFF)
1.4
0.8
IH
VEN =2V (ON)
3
10
uA
IL
VEN =0V (OFF)
3
10
uA
DMAX
VFB=0V
90
EN Pin Threshold
EN Pin Input Leakage
Current
Max. Duty Cycle
320
Rev 1.3
A
120
mohm
V
www.xlsemi.com
5
Datasheet
XL6001
Typical System Application for VIN=5V to driver 2~3 x 1W series LED units
Figure5. XL6001 System Parameters Test Circuit (2~3 x 1W LED)
Typical System Application for VIN=12V to driver 4~8 x 1W series LED units
Figure6. XL6001 System Parameters Test Circuit (4~8 x 1W LED)
Rev 1.3
www.xlsemi.com
6
Datasheet
XL6001
With PWM Dimming
Figure7. XL6001 System Parameters Test Circuit (4~8 x 1W LED with PWM Dimming)
Typical System Application for SEPIC Buck-Boost LED Driver
Figure8. XL6001 System Parameters Test Circuit (Buck-Boost LED Driver)
Rev 1.3
www.xlsemi.com
7
Datasheet
XL6001
Package Information
SOP8 Package Mechanical Dimensions
Rev 1.3
www.xlsemi.com
8
Datasheet
XL6001
Important Notice
XLSEMI reserve the right to make modifications, enhancements, improvements, corrections or
other changes without notice at any time. XLSEMI does not assume any liability arising out of
the application or use of any product described herein; neither does it convey any license under
its patent rights, nor the rights of others. XLSEMI assumes no liability for applications assistance
or the design of Buyers’ products. Buyers are responsible for their products and applications
using XLSEMI components. To minimize the risks associated with Buyers’ products and
applications, Buyers should provide adequate design and operating safeguards. XLSEMI
warrants performance of its products to the specifications applicable at the time of sale, in
accordance with the warranty in XLSEMI’s terms and conditions of sale of semiconductor
products. Testing and other quality control techniques are used to the extent XLSEMI deems
necessary to support this warranty. Except where mandated by applicable law, testing of all
parameters of each component is not necessarily performed.
For the latest product information, go to www.xlsemi.com.
Rev 1.3
www.xlsemi.com
9
很抱歉,暂时无法提供与“XL6001”相匹配的价格&库存,您可以联系我们找货
