XL6004
XL6004
    XLSEMI(芯龙)
    TO252-5L
    400KHz 60V 3A开关电流升压LED恒流驱动器
XL6004 数据手册
Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Features General Description n n n n n n n n n n n n n The XL6004 regulator is fixed frequency PWM Boost (step-up) LED constant current driver, capable of driving Series 1W/3W LED units with excellent line and load regulation. The regulator is simple to use because it includes internal frequency compensation and a fixed-frequency oscillator so that it requires a minimum number of external components to work. The XL6004 could directly drive 12 Series 1W LED units at VIN>12V. n Wide 3.6V to 32V Input Voltage Range 0.22V FB adjustable LED drive current Directly drive up to 16 Series 1W LED Fixed 400KHz Switching Frequency Max. 3A Switching Current Capability Up to 92% efficiency Excellent line and load regulation EN PIN TTL shutdown capability Internal Optimize Power MOSFET Built in Soft-Start Function Built in Frequency Compensation Built in Thermal Shutdown Function Built in Current Limit Function Available in TO252-5L package The PWM control circuit is able to adjust the duty ratio linearly from 0 to 95%. An enable function, an over current protection function is built inside. An internal compensation block is built in to minimize external component count. Applications n n n n LED Lighting Boost constant current driver Monitor LED Backlighting 7’ to 15’ LCD Panels Figure1. Package Type of XL6004 1 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Pin Configurations Figure2. Pin Configuration of XL6004 (Top View) Table 1 Pin Description Pin Number 1 Pin Name GND 2 EN 3 SW 4 VIN 5 FB Description Ground Pin. Enable Pin. Drive EN pin low to turn off the device, drive it high to turn it on. Floating is default high. Power Switch Output Pin (SW). Supply Voltage Input Pin. XL6004 operates from a 3.6V to 32V DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Feedback Pin (FB). The feedback threshold voltage is 0.22V. 2 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver Function Block Figure3. Function Block Diagram of XL6004 Typical Application Circuit Figure4. XL6004 Typical Application Circuit 3 XL6004 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Ordering Information Package Temperature Range Part Number Lead Free XL6004E1 XL6004TRE1 Marking ID Lead Free XL6004E1 XL6004E1 Packing Type Tube Tape & Reel XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant. Absolute Maximum Ratings(Note1) Parameter Symbol Vin VFB VEN VOutput PD Value -0.3 to 36 -0.3 to Vin -0.3 to Vin -0.3 to 60 Internally limited Unit V V V V mW Input Voltage Feedback Pin Voltage EN Pin Voltage Output Switch Pin Voltage Power Dissipation Thermal Resistance (TO252-5L) (Junction to Ambient, No Heatsink, Free Air) Operating Junction Temperature Storage Temperature Lead Temperature (Soldering, 10 sec) ESD (HBM) RJA 50 ºC/W TJ TSTG TLEAD -40 to 125 -65 to 150 260 >2000 ºC ºC ºC V Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operation is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. 4 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 XL6004 Electrical Characteristics Ta = 25℃;unless otherwise specified. Symbol Parameter Test Condition Min. Typ. Max. Unit 209 220 231 mV - 92 - % System parameters test circuit figure4 Feedback Voltage VFB Efficiency ŋ Vin = 5V to 12V, Vout=24V Iload=100mA Vin=12V ,Vout=24V Iout=0.5A Electrical Characteristics (DC Parameters) Vin = 12V, GND=0V, Vin & GND parallel connect a 100uf/50V capacitor; Iout=100mA, Ta = 25℃; the others floating unless otherwise specified. Parameters Input operation voltage Symbol Test Condition Vin Min. Typ. 3.6 Max. Unit 32 V Shutdown Supply Current ISTBY VEN=0V 70 100 uA Quiescent Supply Current Iq VEN =2V, VFB =Vin 2.5 5 mA 400 480 Khz Oscillator Frequency Fosc Switch Current Limit IL VFB =0 3 Output Power NMOS Rdson Vin=12V, ISW=3A 110 VEN High (Regulator ON) Low (Regulator OFF) 1.4 0.8 IH VEN =2V (ON) 3 10 uA IL VEN =0V (OFF) 3 10 uA DMAX VFB=0V 90 EN Pin Threshold EN Pin Input Leakage Current Max. Duty Cycle 320 5 A 120 mohm V % Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Schottky Diode Selection Table Current 1A 3A Surface Through VR (The same as system maximum input voltage) Mount Hole 20V 30V 40V 50V 1N5817 1N5818 1N5819 √ 60V √ 1N5820 1N5821 1N5822 √ MBR320 MBR330 MBR340 MBR350 MBR360 SK32 SK33 SK34 SK36 30WQ03 30WQ04 30WQ05 31DQ03 31DQ04 31DQ05 SR303 SR304 SR305 √ √ √ √ SR302 SK35 SR306 Typical System Application for VIN=5V to driver 8 x 1W series LED units Figure5. XL6004 System Parameters Test Circuit (5V ~ 8 x 1W LED) 6 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Typical System Application for VIN=12V to driver 12 x 1W series LED units Figure6. XL6004 System Parameters Test Circuit (12V ~ 12 x 1W LED) Typical System Application for VIN=12V to driver 6 x 3W series LED units Figure7. XL6004 System Parameters Test Circuit (12V ~ 6 x 3W LED) 7 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Typical System Application for VIN=24V to driver 16 x 1W series LED units Figure8. XL6004 System Parameters Test Circuit (24V ~ 16 x 1W LED) Typical System Application for SEPIC Buck-Boost LED Driver Figure9. XL6004 System Parameters Test Circuit (Buck-Boost LED Driver) 8 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver XL6004 Typical System Application for VIN=12V to driver 12 series x 24 parallel White LED Array Figure10. XL6004 System Parameters Test Circuit (12V ~ 12 x 24 White LED) Typical System Application for VIN=12V to driver 12 x 1W series LED units With Dimming Function Figure11. XL6004 System Test Circuit (12V ~ 12 x 1W LED with Dimming Function) 9 Datasheet 400KHz 60V 3A Switching Current Boost LED Constant Current Driver Package Information TO252-5L 10 XL6004
XL6004 价格&库存
很抱歉,暂时无法提供与“XL6004”相匹配的价格&库存,您可以联系我们找货
