XL6005
XL6005
    XLSEMI(芯龙)
    TO252-5L
    180KHz 60V 4A开关电流升压LED恒流驱动器
XL6005 数据手册
Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Features „ „ „ „ „ „ „ „ „ „ „ „ „ „ Wide 3.6V to 32V Input Voltage Range 0.22V FB adjustable LED drive current Directly drive 11 Series 1W LED at VIN>=12V Fixed 180KHz Switching Frequency Max. 4A Switching Current Capability Up to 94% efficiency Excellent line and load regulation EN PIN TTL shutdown capability & With PWM Dimming Function Internal Optimize Power MOSFET Built in Soft-Start Function Built in Frequency Compensation Built in Thermal Shutdown Function Built in Current Limit Function Available in TO252-5L package General Description The XL6005 regulator is fixed frequency PWM Boost (step-up) LED constant current driver, capable of driving Series 1W/3W/5W LED units with excellent line and load regulation. The regulator is simple to use because it includes internal frequency compensation and a fixed-frequency oscillator so that it requires a minimum number of external components to work. The XL6005 could directly drive 11 Series 1W LED units at VIN>=12V . The PWM control circuit is able to adjust the duty ratio linearly from 0 to 90%. An enable function, an over current protection function is built inside. An internal compensation block is built in to minimize external component count. Applications „ „ „ „ LED Lighting Boost constant current driver Monitor LED Backlighting 7’ to 15’ LCD Panels Figure1. Package Type of XL6005 Rev 1.6 www.xlsemi.com 1 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Pin Configurations Figure2. Pin Configuration of XL6005 (Top View) Table 1 Pin Description Pin Number 1 Pin Name GND 2 EN 3 SW 4 VIN 5 FB Description Ground Pin. Enable Pin. Drive EN pin low to turn off the device, drive it high to turn it on. Floating is default high. Power Switch Output Pin (SW). Supply Voltage Input Pin. XL6005 operates from a 3.6V to 32V DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Feedback Pin (FB). The feedback threshold voltage is 0.22V. Rev 1.6 www.xlsemi.com 2 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Function Block Figure3. Function Block Diagram of XL6005 Typical Application Circuit L1 47uh/3A D1 SS36 COUT 47uF /50V VIN +12V CIN 47uF /25V C1 105 SW 3 4 C2 105 Series 11 1W LED XL6005 5 1 GND FB 2 EN RS ON OFF 350mA ILED=0.22/RS Figure4. XL6005 Typical Application Circuit Rev 1.6 www.xlsemi.com 3 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Ordering Information Order Information XL6005E1 Marking ID XL6005E1 Package Type TO252-5L Packing Type Supplied As 2500 Units on Tape & Reel XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant. Absolute Maximum Ratings(Note1) Parameter Symbol Vin VFB VEN VOutput PD Value -0.3 to 36 -0.3 to Vin -0.3 to Vin -0.3 to 60 Internally limited Unit V V V V mW Input Voltage Feedback Pin Voltage EN Pin Voltage Output Switch Pin Voltage Power Dissipation Thermal Resistance (TO252-5L) (Junction to Ambient, No Heatsink, Free Air) Operating Junction Temperature Storage Temperature Lead Temperature (Soldering, 10 sec) ESD (HBM) RJA 50 ºC/W TJ TSTG TLEAD -40 to 125 -65 to 150 260 >2000 ºC ºC ºC V Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operation is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Rev 1.6 www.xlsemi.com 4 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 XL6005 Electrical Characteristics Ta = 25℃;unless otherwise specified. Symbol Parameter Test Condition Min. Typ. Max. Unit 209 220 231 mV - 92 - % System parameters test circuit figure4 Feedback Voltage VFB Efficiency ŋ Vin = 5V to 12V, Vout=24V Iload=100mA Vin=12V ,Vout=24V Iout=1A Electrical Characteristics (DC Parameters) Vin = 12V, GND=0V, Vin & GND parallel connect a 100uf/50V capacitor; Iout=100mA, Ta = 25℃; the others floating unless otherwise specified. Parameters Symbol Test Condition Min. Typ. 3.6 Max. Unit 32 V Input operation voltage Vin Shutdown Supply Current ISTBY VEN=0V 70 100 uA Quiescent Supply Current Iq VEN =2V, VFB =Vin 2.5 5 mA 180 216 Khz Oscillator Frequency Fosc Switch Current Limit IL VFB =0 4 Output Power NMOS Rdson Vin=12V, ISW=4A 110 VEN High (Regulator ON) Low (Regulator OFF) 1.4 0.8 IH VEN =2V (ON) 3 10 uA IL VEN =0V (OFF) 3 10 uA DMAX VFB=0V 90 EN Pin Threshold EN Pin Input Leakage Current Max. Duty Cycle 144 Rev 1.6 A 120 mohm V % www.xlsemi.com 5 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application for VIN=12V to driver 11 x 1W series LED units L1 47uh/3A D1 SS36 COUT 47uF /50V VIN +12V CIN 47uF /25V SW 3 Series 11 1W LED XL6005 5 4 1 GND C1 105 C2 105 FB 2 EN RS ON OFF 350mA ILED=0.22/RS Figure5. XL6005 System Parameters Test Circuit (12V ~11 x 1W LED) Typical System Application for VIN>=12V to driver 6 x 3W series LED units L1 47uh/3A D1 SS36 COUT 100uF /50V VIN +12V CIN 47uF /25V C1 105 SW 3 4 C2 105 Series 6 3W LED XL6005 5 1 GND FB 2 EN RS ON OFF 1050mA ILED=0.22/RS Figure6. XL6005 System Parameters Test Circuit (12V ~ 6 x 3W LED) Rev 1.6 www.xlsemi.com 6 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application for VIN>=24V to driver 10 x 3W series LED units Figure7. XL6005 System Parameters Test Circuit (24V ~ 10 x 3W LED) Typical System Application for VIN>=12V to driver 11 series x 40 parallel White LED Array Figure8. XL6005 System Parameters Test Circuit (VIN>=12V ~ 11 x 40 White LED) Rev 1.6 www.xlsemi.com 7 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application for SEPIC Buck-Boost LED Driver L1A 33uh/2A L1B 33uh/2A D1 SS38 COUT 100uF /50V SW 3 VIN 4 VIN CIN 47uF /35V C1 105 CDC 22uF/50V XL6005 1 GND C2 105 Series 6 1W/3W LED FB 5 2 EN RS ON OFF 350/1050mA ILED=0.22/RS Buck-Boost LED Driver Input 8V ~ 30V Output Drive series 6 1W/3W LED Figure9. XL6005 System Parameters Test Circuit (Buck-Boost LED Driver) Typical System Application for VIN>=12V to driver 8 x 2W series LED units With Dimming Function Figure10. XL6005 System Test Circuit (12V ~ 8 x 2W LED with Dimming Function) Rev 1.6 www.xlsemi.com 8 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Typical System Application (LED OVP) LED OVP function can be used in typical system application with external components. The output voltage can be limited in a suitable value by choose different zener diode when the output LED open. the zener diode voltage choosed by output led voltage's 1.3 times. Figure11. XL6005 System Test Circuit (LED OVP) Rev 1.6 www.xlsemi.com 9 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Package Information TO252-5L Rev 1.6 www.xlsemi.com 10 Datasheet 180KHz 60V 4A Switching Current Boost LED Constant Current Driver XL6005 Important Notice XLSEMI reserve the right to make modifications, enhancements, improvements, corrections or other changes without notice at any time. XLSEMI does not assume any liability arising out of the application or use of any product described herein; neither does it convey any license under its patent rights, nor the rights of others. XLSEMI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using XLSEMI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. XLSEMI warrants performance of its products to the specifications applicable at the time of sale, in accordance with the warranty in XLSEMI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent XLSEMI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. For the latest product information, go to www.xlsemi.com. Rev 1.6 www.xlsemi.com 11
XL6005 价格&库存
很抱歉,暂时无法提供与“XL6005”相匹配的价格&库存,您可以联系我们找货
