XL6007
400KHz 60V 2A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter
Features
General Description
The XL6007 regulator is a wide input range,
current mode, DC/DC converter which is
capable of generating either positive or
negative output voltages. It can be configured
as either a boost, flyback, SEPIC or inverting
converter. The XL6007 built in N-channel
power MOSFET and fixed frequency
oscillator, current-mode architecture results in
stable operation over a wide range of supply
and output voltages.
The XL6007 regulator is special design for
portable electronic equipment.
Wide 3.6V to 24V Input Voltage Range
Positive or Negative Output Voltage
Programming with a Single Feedback Pin
Current Mode Control Provides Excellent
Transient Response
1.25V reference adjustable version
Fixed 400KHz Switching Frequency
Maximum 2A Switching Current
SW PIN Built in Over Voltage Protection
Excellent line and load regulation
EN PIN TTL shutdown capability
Internal Optimize Power MOSFET
High efficiency up to 90%
Built in Frequency Compensation
Built in Soft-Start Function
Built in Thermal Shutdown Function
Built in Current Limit Function
Available in SOP8L package
Applications
Automotive and Industrial Boost
Buck-Boost / Inverting Converters
Portable Electronic Equipment
Figure1. Package Type of XL6007
Rev 1.2
www.xlsemi.com
1
XL6007
Pin Configurations
EN
1
8
GND
VIN
2
7
GND
FB
3
6
SW
NC
4
5
SW
XL6007
Figure2. Pin Configuration of XL6007 (Top View)
Table 1 Pin Description
Pin Number
Pin Name
1
EN
2
VIN
3
4
FB
NC
5,6
SW
7,8
GND
Description
Enable Pin. Drive EN pin low to turn off the device, drive it
high to turn it on. Floating is default high.
Supply Voltage Input Pin. XL6007 operates from a 3.6V to 24V
DC voltage. Bypass Vin to GND with a suitably large capacitor
to eliminate noise on the input.
Feedback Pin (FB). The feedback threshold voltage is 1.25V.
No Connected.
Power Switch Output Pin (SW). Output is the switch node that
supplies power to the output.
Ground Pin.
Rev 1.2
www.xlsemi.com
2
XL6007
Function Block
Figure3. Function Block Diagram of XL6007
Typical Application Circuit
Figure4. XL6007 Typical Application Circuit (Boost Converter)
Rev 1.2
www.xlsemi.com
3
XL6007
Ordering Information
Order Information
XL6007E1
Marking ID
XL6007E1
Package Type
SOP8L
Packing Type Supplied As
2500 Units on Tape & Reel
XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant.
Absolute Maximum Ratings(Note1)
Parameter
Symbol
Vin
VFB
VEN
VOutput
PD
Value
-0.3 to 26
-0.3 to Vin
-0.3 to Vin
-0.3 to 60
Internally limited
Unit
V
V
V
V
mW
Input Voltage
Feedback Pin Voltage
EN Pin Voltage
Output Switch Pin Voltage
Power Dissipation
Thermal Resistance (SOP-8L)
(Junction to Ambient, No Heatsink, Free Air)
Operating Junction Temperature
Storage Temperature
Lead Temperature (Soldering, 10 sec)
ESD (HBM)
RJA
100
ºC/W
TJ
TSTG
TLEAD
-40 to 125
-65 to 150
260
>2000
ºC
ºC
ºC
V
Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage
to the device. This is a stress rating only and functional operation of the device at these or any
other conditions above those indicated in the operation is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect reliability.
Rev 1.2
www.xlsemi.com
4
XL6007
XL6007 Electrical Characteristics
Ta = 25℃;unless otherwise specified.
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Unit
1.213
1.25
1.287
V
90
System parameters test circuit figure4
Feedback
Voltage
VFB
Efficiency
ŋ
Vin = 12V to 16V, Vout=18V
Iload=0.1A to 0.5A
Vin=12V ,Vout=18.5V
Iout=0.5A
Electrical Characteristics (DC Parameters)
Vin = 12V, GND=0V, Vin & GND parallel connect a 220uf/50V capacitor; Iout=0.5A, Ta =
25℃; the others floating unless otherwise specified.
Parameters
Symbol
Test Condition
Min.
Typ.
3.6
Max.
Unit
24
V
Input operation voltage
Vin
Shutdown Supply Current
ISTBY
VEN=0V
70
100
uA
Quiescent Supply Current
Iq
VEN =2V,
VFB =Vin
2.5
5
mA
400
480
Khz
Oscillator Frequency
Fosc
Switch Current Limit
IL
VFB =0
2
Output Power NMOS
Rdson
Vin=12V,
ISW=2A
110
VEN
High (Regulator ON)
Low (Regulator OFF)
1.4
0.8
IH
VEN =2V (ON)
3
10
uA
IL
VEN =0V (OFF)
3
10
uA
DMAX
VFB=0V
90
EN Pin Threshold
EN Pin Input Leakage
Current
Max. Duty Cycle
320
Rev 1.2
A
120
mohm
V
www.xlsemi.com
5
XL6007
Schottky Diode Selection Table
Current
1A
3A
Surface Through VR (The same as system maximum input voltage)
Mount Hole
20V
30V
40V
50V
1N5817
1N5818
1N5819
60V
1N5820
1N5821
1N5822
MBR320
MBR330
MBR340 MBR350
MBR360
SK32
SK33
SK34
SK36
30WQ03
30WQ04 30WQ05
31DQ03
31DQ04
31DQ05
SR303
SR304
SR305
Typical System Application
SR302
SK35
SR306
– Boost (Output 18.5V/0.5A)
Figure5. XL6007 Typical System Application (Boost Converter)
Rev 1.2
www.xlsemi.com
6
XL6007
Typical System Application – SEPIC Buck-Boost (Input 10V~18V, Output 12V/0.5A)
Figure6. XL6007 Typical System Application (SEPIC Buck-Boost Converter)
Typical System Application for Inverting Converter
– SEPIC Inverting Topology (Input 10V~18V, Output + -12V/0.6A)
L1C
D1 1N5822
VOUT -12V
COUT
220uf/50V
CDC 22uf/50V
VOUT +12V
L1A
SW
5,6
VIN
2
CDC 22uf/50V
XL6007 3
7,8
GND
VIN
CIN
47uf /50V
105
D1 1N5822
L1B
R2 8.6K
FB
1
EN
R1
1K
105
COUT
220uf/50V
ON
OFF
SEPIC + - Converter
Input 10V ~ 18V
Output +-12V / 0.6A
VOUT=1.25*(1+R2/R1)
Figure7. XL6007 Typical System Application (SEPIC Inverting Converter)
Rev 1.2
www.xlsemi.com
7
XL6007
Package Information
SOP8 Package Mechanical Dimensions
Rev 1.2
www.xlsemi.com
8
很抱歉,暂时无法提供与“XL6007”相匹配的价格&库存,您可以联系我们找货
