SPECIFICATION
AND PERFORMANCE
SERIES:
115B Series
FILE:
115B Series_spec
DATE:
2012/12/12
Scope:
This specification covers the requirements for product performance, test
methods and quality assurance provisions of 115B Series.
Performance and Descriptions:
The product is designed to meet the electrical, mechanical and environmental
performance requirements specification. Unless otherwise specified, all tests are
performed at ambient environmental conditions.
RoHS:
All material in according with the RoHS environment related substances list
controlled.
MATERIAL
AND
FINISH
INSULATOR
Material Housing: LCP UL94V-0. Black
Cover: LCP UL94V-0. Black
CONTACT
Material Contact: phosphor bronze C5191
Plating
SHELL OR COVER
Gold plating on contact area, nickel under plating
overall.
Material
Plating
RATING
Current Rating: 0.5A per pin
Voltage Rating: 30V DC/AC
Operating Temperature: -40℃ to +85℃
Storage Temperature: -40℃ to +85℃
The information contained herein is exclusive property of. Do not copy and print except that Attend accepts.
本文件係屬立威科技股份有限公司所有;非經同意,不得以任何覆寫、拷貝、翻印等方式私自據有。亦不得擅加毀損、塗改。
-1 -
SPECIFICATION
AND PERFORMANCE
SERIES:
115B Series
FILE:
115B Series_spec
DATE:
2012/12/12
ELECTRICAL
Item
Requirement
Test Condition
Contact Resistance
Initial:
30 mΩ Maximum
After test:
30 mΩ Maximum
(EIA 364-23 )
Subject mated contacts assembled in
housing to 20mV maximum open circuit at
100 mA maximum The object of this test is
to detail a standard method to measure
the electrical resistance across a pair of
mated contacts such that the insulating
films, if present will not be broken or
asperity melting will not occur.
Insulation Resistance
Insulation Resistance: (EIA 364-21 )
1000MΩMin
Apply a 500V DC between adjacent
terminals and between terminals to
ground
Dielectric
Withstanding
Voltage
No flashover or
insulation breakdown
(EIA 364-20 )
Apply a voltage 500V AC R.M.S for 1
minute between adjacent terminals and
between terminals to ground
MECHANICAL
Item
Durability
Requirement
Test Condition
No physical damage.
(EIA 364-09 )
Insertion and extraction are repeated
5000 cycles with the actually card at the
speed rate of 700 min cycles/hour.
Exchange the actually card every
2000cycles.
-2 -
SPECIFICATION
Vibration
SERIES:
115B Series
FILE:
115B Series_spec
DATE:
2012/12/12
AND PERFORMANCE
No Damage
Contact Resistance:
30milliohms MAX
Change from initial:
30milliohms
Discontinuity:
1microsecond Max.
(EIA-364-28)
Amplitude:1.52mm P-P or 1.47mm/s^2
Sweep time:10~55~10Hz in 20 minutes
Duration:12 time in each
(total of 36 times)
Electrical: DC 100 mA current
Load shall be flowed during the test
ENVIRONMENTAL
Item
Thermal Shock
Requirement
Test Condition
No evidence of damage. (EIA 364-32 I)
Subject mated connectors should be
tested according to the condition listed
below:
Temperature: -25 ~ 85℃
Cycles: 5 cycles
Exposure time at temp. 30 minutes.
Humidity
(EIA 364-31)
Mate a dummy card and expose to 60±2℃
No appearance
damaged
for 96 hours Relative humidity 90.
Upon completion of the exposure period,
the test specimens shall be conditioned at
anibient room conditions for 1 to
2hours,after which the specified
measurements shall be performed
-3 -
SPECIFICATION
Heat Resistance
AND PERFORMANCE
SERIES:
115B Series
FILE:
115B Series_spec
DATE:
2012/12/12
(EIA 364-17 )
Mate a dummy card and expose to 70±2℃
No appearance
damaged
for 96Hr Upon completion of the exposure
period,the test specimens shall be
conditioned at ambient room conditions
for 1 to 2Hr,after which the specified
measurements shall be performed.
SOLDER ABILITY
Item
Solderability
Requirement
Test Condition
The surface of the
portion to be soldered
shall at least 95%
covered
(EIA 364-52 )
After one hour steam aging.
The object of test procedure is to detail a
unfirm test methods for determining sim
card connector solderability.
The test procedure contained here utilizes
the solder dip technique. It is not intended
to test or evaluate solder cup, solder
eyelet, other hand-soldered type or SMT
type terminations.
Resistance to
Soldering Heat
260℃±5℃ 10Sec
Peak temperature: 260℃±5℃ 10Sec
Soldering temperature: 230℃
Preheating temperature: 150~180℃
-4 -
SPECIFICATION
AND PERFORMANCE
SERIES:
115B Series
FILE:
115B Series_spec
DATE:
2012/12/12
-5 -
很抱歉,暂时无法提供与“115B-AAA0-R01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+49.39173
- 10+14.33672
- 30+8.17368
- 70+7.72784
- 国内价格
- 1+35.86659
- 30+34.62981
- 100+32.15625
- 500+29.68269
- 1000+28.44591
