Datasheet
0.6A 150KHz 80V Buck DC to DC Converter
XL7025
Features
General Description
The XL7025 is a 150KHz fixed frequency
PWM buck (step-down) DC/DC converter,
capable of driving a 0.6A load with high
efficiency, low ripple and excellent line and
load regulation. Requiring a minimum
number of external components, the regulator
is simple to use and include internal
frequency
compensation
and
a
fixed-frequency oscillator.
Wide 10V to 80V Operation Voltage
Output Adjustable from 1.25V to 20V
Maximum Duty Cycle 100%
Minimum Drop Out 1V
Fixed 150KHz Switching Frequency
Maximum 0.6A Output Current
Recommend Maximum 0.6A Output
Current At 5V Output,48V Input
Recommend Maximum 0.3A Output
Current At 15V Output,48V Input
Internal Optimize HV Power Transistor
High efficiency up to 85%
Excellent line and load regulation
Built in thermal shutdown function
Built in output short Protection Function
Built in current limit function
TO252-5L package
The PWM control circuit is able to adjust the
duty ratio linearly from 0 to 100%. An over
current protection function is built inside.
When output short protection function
happens, the operation frequency will be
reduced from 150KHz to 45KHz. An internal
compensation block is built in to minimize
external component count.
Applications
Ebike Controller Power Supply
Telecom / Networking Equipment
Figure1. Package Type of XL7025
Rev 1.0
www.xlsemi.com
1
Datasheet
XL7025
Pin Configurations
Figure2. Pin Configuration of XL7025 (Top View)
Table 1 Pin Description
Pin Number
Pin Name
1
VIN
2
SW
3
GND
4
FB
5
OGND
Description
Supply Voltage Input Pin. XL7025 operates from a 10V to 80V
DC voltage. Bypass Vin to GND with a suitably large capacitor
to eliminate noise on the input.
Power Switch Output Pin (SW). Output is the switch node that
supplies power to the output.
Ground Pin. Care must be taken in layout. This pin should be
placed outside of the Schottky Diode to output capacitor ground
path to prevent switching current spikes from inducing voltage
noise into XL7025. The exposed PAD is GND.
Feedback Pin (FB). Through an external resistor divider
network, Feedback senses the output voltage and regulates it.
The feedback threshold voltage is 1.25V.
Output Ground Pin.
Rev 1.0
www.xlsemi.com
2
Datasheet
XL7025
Function Block
Figure3. Function Block Diagram of XL7025
Typical Application Circuit
VIN
1
2
SW
D1
S210
XL7025
VIN
16V~80V
CIN
100uF/100V
C1
104
3
5
GND
L1 100uH/1A
4
R2
30K
1%
CFF
33nF
C3
105
COUT
100uF/35V
VOUT
15V/0~0.3A
FB
OGND
R1
2.7K
1%
R3
0.28Ω
1%
INPUT 16V~80V
OUTPUT 15V/0~0.3A
VOUT=1.25*(1+R2/R1)
R3 for limit maximum output current, R3 choose 0.15ohm in VOUT≤5V application; R3 choose
0.28ohm in VOUT>5V application.
Figure4. XL7025 Typical Application Circuit
Rev 1.0
www.xlsemi.com
3
Datasheet
XL7025
Ordering Information
Order Information
XL7025E1
Marking ID
XL7025E1
Package Type
TO252-5L
Packing Type Supplied As
2500 Units on Tape & Reel
XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant.
Absolute Maximum Ratings(Note1)
Parameter
Symbol
Vin
VFB
VEN
VSW
PD
Value
-0.3 to 85
-0.3 to Vin
-0.3 to Vin
-0.3 to Vin
Internally limited
Unit
V
V
V
V
mW
Input Voltage
Feedback Pin Voltage
EN Pin Voltage
Output Switch Pin Voltage
Power Dissipation
Thermal Resistance (TO252-5L)
(Junction to Ambient, No Heatsink, Free Air)
Maximum Junction Temperature
Operating Junction Temperature
Storage Temperature
Lead Temperature (Soldering, 10 sec)
ESD (HBM)
RJA
50
ºC/W
TJ
TJ
TSTG
TLEAD
-40 to 150
-40 to 125
-65 to 150
260
>3000
ºC
ºC
ºC
ºC
V
Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage
to the device. This is a stress rating only and functional operation of the device at these or any
other conditions above those indicated in the operation is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect reliability.
Rev 1.0
www.xlsemi.com
4
Datasheet
XL7025
XL7025 Electrical Characteristics
Ta = 25℃;unless otherwise specified.
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Unit
1.225
1.25
1.275
V
86
83
80
System parameters test circuit figure4
VFB
FB Voltage
ŋ
Efficiency
ŋ
Efficiency
ŋ
Efficiency
Vin =20V to 80V,Vout=15V
Iload=0.1A to 0.3A
Vin=36V ,Vout=15V
Iout=0.3A
Vin=48V ,Vout=15V
Iout=0.3A
Vin=60V ,Vout=15V
Iout=0.3A
Electrical Characteristics (DC Parameters)
Vin = 48V, GND=0V, Vin & GND parallel connect a 33uf/100V capacitor; Iout=0.2A, Ta =
25℃; the others floating unless otherwise specified.
Parameters
Input operation voltage
VIN UVLO
Quiescent Supply Current
Symbol
Test Condition
Vin
Min.
Max.
Unit
80
V
8
9
V
2.5
5
mA
150
180
KHz
10
Vin_uvlo
Iq
Typ.
VFB=2V
Oscillator Frequency
Fosc
Switch Current Limit
IL
VFB=0
R3=0.15Ω
0.667
A
VCE
VFB=0V
Iout=0.5A
0.87
V
DMAX
VFB=0V
100
Output Saturation Voltage
Max. Duty Cycle
120
Rev 1.0
www.xlsemi.com
5
Datasheet
XL7025
Typical Performance Characteristics
Quiescent Supply Current VS Temperature
Quiescent Supply Current(mA)
5
VIN=48V
4
3
2
1
-25
50
75
100
125
Temperature(℃)
Figure5. Quiescent Current Curve
Feedback Voltage Change VS Temperature
3.0
Feedback Voltage Change(%)
2.5
2.0
VIN=48V,VOUT=5V,IOUT=0.1A
Normalized at TA=25℃
1.5
1.0
0.5
0.0
-0.5
-1.0
-1.5
-2.0
-2.5
-3.0
-50
-25
50
75
100
125
Temperature(℃)
Figure6. Feedback Voltage Curve
Rev 1.0
www.xlsemi.com
6
Datasheet
XL7025
Typical System Application(VOUT=15V/0.3A)
VIN
1
2
L1 100uH/1A
SW
D1
S210
XL7025
VIN
16V~80V
CIN
100uF/100V
C1
104
3
5
4
CFF
33nF
C3
105
COUT
100uF/35V
VOUT
15V/0~0.3A
FB
OGND
GND
R2
30K
1%
R1
2.7K
1%
R3
0.28Ω
1%
INPUT 16V~80V
OUTPUT 15V/0~0.3A
VOUT=1.25*(1+R2/R1)
Figure7. XL7025 System Application (VIN=16V~80V, VOUT=15V/0.3A)
Efficiency VS Output current
95
90
85
80
75
Efficiency(%)
70
65
60
55
VIN=24V,VOUT=15V,IOUT=0.1~0.3A
VIN=36V,VOUT=15V,IOUT=0.1~0.3A
VIN=48V,VOUT=15V,IOUT=0.1~0.3A
VIN=60V,VOUT=15V,IOUT=0.1~0.3A
VIN=72V,VOUT=15V,IOUT=0.1~0.3A
50
45
40
35
30
25
0.15
0.20
0.25
0.30
Ouput current(A)
Figure8. XL7025 System Application (Efficiency VS Output Current)
Rev 1.0
www.xlsemi.com
7
Datasheet
XL7025
Typical System Application(VOUT=5V/0.6A)
VIN
1
2
L1 100uH/1A
SW
D1
S210
XL7025
VIN
10V~80V
CIN
100uF/100V
C1
104
3
5
GND
4
R2
10K
1%
CFF
33nF
C3
105
COUT
100uF/16V
VOUT
5V/0~0.6A
FB
OGND
R1
3.3K
1%
R3
0.15Ω
1%
INPUT 10V~80V
OUTPUT 5V/0~0.6A
VOUT=1.25*(1+R2/R1)
Figure9. XL7025 System Application (VIN=10V~80V, VOUT=5V/0.6A)
90
85
80
75
70
Efficiency(%)
65
60
55
VIN=12V,VOUT=5V,IOUT=0.1A~0.6A
VIN=24V,VOUT=5V,IOUT=0.1A~0.6A
VIN=36V,VOUT=5V,IOUT=0.1A~0.6A
VIN=48V,VOUT=5V,IOUT=0.1A~0.6A
VIN=60V,VOUT=5V,IOUT=0.1A~0.6A
VIN=72V,VOUT=5V,IOUT=0.1A~0.6A
50
45
40
35
30
25
0.15
0.20
0.25
0.30
0.35
0.40
0.45
0.50
0.55
0.60
Output current(A)
Figure10. XL7025 System Application (Efficiency VS Output Current)
Rev 1.0
www.xlsemi.com
8
Datasheet
XL7025
Package Information
Package Information (TO252-5L)
Rev 1.0
www.xlsemi.com
9
Datasheet
XL7025
Important Notice
XLSEMI reserve the right to make modifications, enhancements, improvements, corrections or
other changes without notice at any time. XLSEMI does not assume any liability arising out of
the application or use of any product described herein; neither does it convey any license under
its patent rights, nor the rights of others. XLSEMI assumes no liability for applications assistance
or the design of Buyers’ products. Buyers are responsible for their products and applications
using XLSEMI components. To minimize the risks associated with Buyers’ products and
applications, Buyers should provide adequate design and operating safeguards. XLSEMI
warrants performance of its products to the specifications applicable at the time of sale, in
accordance with the warranty in XLSEMI’s terms and conditions of sale of semiconductor
products. Testing and other quality control techniques are used to the extent XLSEMI deems
necessary to support this warranty. Except where mandated by applicable law, testing of all
parameters of each component is not necessarily performed.
For the latest product information, go to www.xlsemi.com.
Rev 1.0
www.xlsemi.com
10
