1N4007W-A7
1N4007W-A7
    HOTTECH(合科泰)
    SOD123FL
    通用整流二极管
1N4007W-A7 数据手册
M7L GENERAL PURPOSE RECTIFIER DIODE FEATURES  Surface Mount device  Low Reverse voltage leakage current  Glass passivated junction  High forward surge current capability  Low forward voltage drop SOD-123FL MECHANICAL DATA      Case: SOD-123FL Case Material: Molded Plastic. UL flammability Classification Rating: 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 Weight: 0.0155 grams (approximate) MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Parameter Symbol Value Unit Maximum Recurrent Peak Reverse Voltage VRRM 1000 V DC Blocking Reverse Voltage VR 1000 V RMS Reverse Voltage VR(RMS) 700 V Maximum Average Forward Rectified Current Non-Repetitive Peak Forward Surge Current @t@=8.3ms IF 1 A IFSM 30 A Thermal Resistance From Junction To Ambient Reverse Recovery Time(@IF=0.5A, IR=1.0A,IRR=0.25A) RθJA 55 °C/W trr 2.5 uS Junction Temperature TJ -55 ~+150 °C Storage Temperature TSTG -65 ~+175 °C ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) Parameter Symbol Min Typ Max Unit Conditions Forward voltage VF 1.0 V IF=1A Reverse current Diode capacitance IR CD 5 uA pF VR=1000V VR=4VDC,f=1MHz ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 15 E-mail:hkt@heketai.com 1/4 M7L GENERAL PURPOSE RECTIFIER DIODE Typical Characteristics Fig. 2 – Maximum Non-repetitive Peak Forward Surge Current Average Forward Rectified Current (A) Average Forward Rectified Current (A) Fig. 1 – Forward Current Derating Curve 60 Hz Resistive or Inductive Load 1.0 0.5 8.0mm2 (.013mm thick) land areas 0 0 TJ = TJ max 8.3ms Single Half Sine-wave (JEDEC Method) 30 15 0 1 25 50 75 100 125 150 175 CASE TEMPERATURE:Tc(°C) Instantaneous Reverse Current (µA) 10 1.0 0.1 TJ = 25°C Pulse width = 300µs 1% Duty Cycle 0.01 0.001 0.6 0.8 1.0 1.2 1.4 Instantaneous Forward Voltage Transient thermal impedance(° 10 1.0 0.1 100 10 Tj=125℃ 1.0 Tj=75℃ 0.1 Tj=25℃ 0.01 1.6 Fig 5. –typical transient thermal impedance 100 100 Fig 4. – Typical Reverse Characteristics 0 20 40 60 80 100 Percent of Rated Peak Reverse Voltage (%) Fig 6. – Typical Junction Capacitance Junction Capacitance (pF) Instantaneous Forward Current (A) Fig 3. – Typical Instantaneous Forward Characteristics 10 Number of Cycles at 60Hz 100 10 TJ = 25°C f = 1.0 MHz Vsig = 50mVp-p 1.0 0.01 0.1 1.0 10 t,Pulse duration,sec ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 100 0.1 1 10 Reverse Voltage (V) E-mail:hkt@heketai.com 2/4 M7L GENERAL PURPOSE RECTIFIER DIODE SOD-123FL Package Outline Dimensions Symbol Dimensions In Millimeters Min. Max. A 0.75 B Dimensions In Inches Max. 0.95 Min. 0.029 1.60 2.00 0.063 0.079 C 2.60 3.00 0.103 0.119 D 0.90 1.20 0.036 0.047 E 0.12 0.22 0.005 0.009 F G 0.8Typ 3.50 0.037 0.032Typ 3.90 0.138 0.159 SOD-123FL Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 3/4 M7L GENERAL PURPOSE RECTIFIER DIODE SOD-123FL Tape and Reel SOD-123FL Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SOD-123FL 2.10 4.00 1.25 Ø1.50 1.75 3.50 4.00 4.00 2.00 8.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SOD-123FL Tape Leader and Trailer SOD-123FL Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 9.50 12.30 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 4/4
1N4007W-A7 价格&库存
很抱歉,暂时无法提供与“1N4007W-A7”相匹配的价格&库存,您可以联系我们找货
