Plastic-Encapsulate Transistors
FEATURES
2SC945 (NPN)
Complementary to 2SA733
MARKING: CR
MAXIMUM RATINGS (TA=25
unless otherwise noted)
Parameter
Symbol
Value
Unit
Collector-Base Voltage
VCBO
60
V
Collector-Emitter Voltage
VCEO
50
V
Emitter-Base Voltage
VEBO
5
V
Collector Current -Continuous
IC
150
mA
Collector Power Dissipation
PC
0.2
W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 to +150
ELECTRICAL CHARACTERISTICS (Tamb=25
Parameter
1. BASE
SOT-23
2. EMITTER
3. COLLECTO
unless otherwise specified)
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V CBO
IC=100uA, IE=0
60
V
Collector-emitter breakdown voltage
V CEO
IC=1mA , IB=0
50
V
Emitter-base breakdown voltage
V EBO
IE=0.1mA, IC=0
5
V
Collector cut-off current
ICBO
VCB=60V, IE=0
0.1
uA
ICER
VCE=55V,R=10MΩ
0.1
uA
Emitter cut-off current
IEBO
VEB=5V ,
IC=0
0.1
uA
hFE(1)
VCE=6 V ,
IC=1mA
130
hFE(2)
VCE=6 V ,
IC=0.1mA
40
DC current gain
400
Collector-emitter saturation voltage
VCE(sat)
IC=100mA, IB=10mA
0.3
V
Base-emitter saturation voltage
VBE(sat)
IC=100mA, IB=10mA
1
V
fT
Transition frequency
Collector output capacitance
Cob
Noise figure
NF
CLASSIFICATION OF
VCE=6V,IC=10mA,f =30 MHz
150
MHz
VCB=10V,IE=0,f=1MHZ
VCE=6V,IC=0.1mA
4
Rg=10kΩ,f=1kMHZ
3.0
pF
10
dB
hFE(1)
Rank
O
Y
CR
BL
Range
70-140
120-240
200-400
350-700
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
2SC945 Typical
Characteristics
Static Characteristic
(mA)
IC
27uA
24uA
Ta=25℃
300
DC CURRENT GAIN
COLLECTOR CURRENT
8
21uA
18uA
6
IC
Ta=100℃
COMMON
EMITTER
Ta=25℃
30uA
10
hFE ——
1000
hFE
12
15uA
12uA
4
100
9uA
30
6uA
2
VCE=6V
IB=3uA
4
6
8
10
COLLECTOR-EMITTER VOLTAGE
VCEsat ——
VCE
10
0.7
12
IC
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
Ta=100℃
Ta=25℃
30
β=10
10
Cob / Cib
15
100
30
COLLECTOR CURRENT
IC
COLLECTOR POWER DISSIPATION
PC (W)
(pF)
C
CAPACITANCE
Cib
5
Cob
Ta=25℃
600
Ta=100℃
400
β=10
0.3
1
10
3
PC
0.25
10
150
IC
COLLECTOR CURRENT
Ta=25℃
100
(mA)
800
(mA)
f=1MHz
IE=0 /IC=0
IC
VBEsat ——
200
0.1
150
VCB / VEB
10
1000
10
30
COLLECTOR CURRENT
100
3
1
(V)
300
1
3
100 150
30
IC
(mA)
Ta
0.20
0.15
0.10
0.05
0.00
0.3
1
REVERSE BIAS VOLTAGE
10
3
V
(V)
GUANGDONG HOTTECH
50
75
AMBIENT TEMPERATURE
INDUSTRIAL CO., LTD
100
Ta
125
150
Page:P2-P2
很抱歉,暂时无法提供与“2SC945”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04049
- 100+0.03779
- 300+0.03509
- 500+0.03240
- 2000+0.03105
- 5000+0.03024
