US1A-US1M
SURFACE MOUNT ULTRA FAST RECTIFIER
FEATURES
Glass Passivated Die Construction
Super-Fast Recovery Time For High Efficiency
Low Forward Voltage Drop and High Current Capability
Ideally Suited for Automated Assembly
Plastic Material: UL Flammability Classification Rating 94V-0
DO-214AC (SMA)
MECHANICAL DATA
Case: DO-214AC Molded plastic
10
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Weight: 70mg (approx.)
Cathode
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive
load. For capacitive load, derate current by 20%.
US1A
US1B
US1D
US1G
US1J
US1K
US1M
Unit
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified
Current at T A =75 °C
I F(AV)
1.0
A
Peak Forward Surge Current 8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC)
I FSM
30.0
A
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum DC Reverse Current at
Rated DC Blocking Voltage
IR
Parameter
Symbol
Maximum Repetitive Peak Reverse Voltage
T A = 25 °C
T A =100 °C
1.3
1.0
1.7
5.0
50.0
V
µA
Maximum reverse recovery time (NOTE1)
t rr
Typical Junction Capacitance (NOTE2)
CJ
15.0
pF
Maximum Thermal Resistance (NOTE3)
R θJL
50.0
°C/W
Operating and Storage Temperature Range
T J, TS
-65 to + 150
°C
50
75
nS
Note: 1.Reverse recovery condition I F =0.5A,I R =1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/3
US1A-US1M
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Typical Characteristics
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
US1A-US1D
US1G
US1J-US1M
0.01
0.6
1.0
1.4
1.8
2.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.2
1,000
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
2/3
US1A-US1M
SMA Package Outline Dimensions
10
52
4.50
7
( DIMENSIONS ARE IN MILLIMETER )
SMA Embossed Carrier Tape
P0
P1
d
E
MAX.3°
A
MAX.3°
T
F
W
C
B
R
A
P
DIMENSIONS
ARE
IN
MILLIMETER
TYPE
A
B
C
d
E
F
P
P0
P1
T
W
SMA
3.0
5.4
2.4
1.5
1.5
5.65
4
4
2
0.3
12
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.05
±0.1
±0.1
±0.1
±0.05
±0.2
SMA Reel
D2
D
W1
DIMENSIONS
REEL OPTION
D1
ARE
IN
MILLIMETER
D
D1
D2
W1
7’’ DIA
178
50 min.
13
16.8
TOLERANCE
±2
±0.1
±0.5
±2
3/3
很抱歉,暂时无法提供与“US1D”相匹配的价格&库存,您可以联系我们找货
