HC-49US
Features
xternal dimensions: 11.5 x 4.5 x 3.68mm.
E
Frequency range: 3.579545MHz ~ 64MHz.
. Surface mount type crystal units.
. A great number of standard frequencies.
12 YX
.0 C
XX
X
. High frequency pullability and low equivalent series resistance.
. Highly mass production capability.
. Applications: PC, STB, LCDM and Cable Modem.
Electrical Specifications
Item / Type
HC-49US
Nominal Frequency Range
3.579545
~ 64 MHz
Vibration Mode
AT Fundamental
Load Capacitance
12 pF, 20 pF, or specify
Frequency Tolerance (at 25 ℃)
±1
0 ppm, ± 20 ppm, or specify
Frequency Versus Temperature Characteristics
Operating Temperature
- 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify
Storage Temperature
Shunt Capacitance
7 pF Max.
Level Of Drive
1 ~ 500 μW (100 μW typical)
Frequency Aging (at 25 ℃)
± 3 ppm / year Max.
Equivalent Series Resistance(ESR)
3rd Overtone
Fundamental
3.579545
Ω
Ω
Ω
Ω
Ω
Ω
Ω
Ω
Dimensions
4.5
YXC
12.0XXX
3.5
Units: mm
1/2
HC-49US
★ PART NUMBER GUIDE 部件号示例
Frequency
Stability Pin
Overall
(ppm)
Quartz Crystal Resonator Dimensions Frequency Load Capacitance
(Hz)
(Pf)
X
12M
49SD
H C -4 9 U S=11.5 × 4 .5 DI P SEAM TYPE
e.g. X4 9 SD12MSD2SC
S
D
2
Frequency tolerance
B
±10PPM
D
±20PPM
Load Capacitance (Pf)
X
7.4pF
G
12.5pF
L
9pF
10pF
M
12pF
O
P
15pF
Material
Operating Temp.
Range
S
C
Operating temperature
C
-20~ +70 ℃
-40~ +85 ℃
I
-40~ +125℃
A
-40~ +105℃
F
★ WAVE SOLDERING PROFILE 波峰焊特性
Temperature (℃)
260℃ max
220℃
180℃
③
①
②
Times (S)
Pb free reflow
A
①
Preheat
160~180℃
②
Primary heat 220℃
60sec. max
③
Peak
10sec. max.
260℃
2/2
120sec. max
很抱歉,暂时无法提供与“X49SD147456MSD2SC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.28350
- 30+0.27300
- 100+0.25200
- 500+0.23100
- 1000+0.22050
