SS26/SMA
SS26/SMA
    YENJI(台湾元基)
    SMA(DO-214AC)
    表面贴装肖特基势垒整流器电压-20至100伏电流-1.0安培
SS26/SMA 数据手册
SS12 THRU S100 SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE - 20 to 100 Volts CURRENT - 1.0 Ampere FEATURES l l l l l l l l l l Plastic package has Underwriters Laboratory Flammability Classification 94V-O For surface mounted applications Low profile package Built-in strain relief Metal to silicon rectifier majority carrier conduction Low power loss, High efficiency High current capability, low VF High surge capacity For use in low voltage high frequency inverters, free wheeling, and polarity protection applications High temperature soldering: 260 ¢J /10 seconds at terminals SMA/DO-214AC MECHANICAL DATA Case: JEDEC DO-214AC molded plastic Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color bank denotes cathode Standard packaging: 12mm tape (EIA-481) Weight: 0.002 ounce, 0.064 gram MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ¢J ambient temperature unless otherwise specified. Resistive or inductive load. Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current at TL (See Figure 1) Peak Forward Surge Current 8.3ms single half sinewave superimposed on rated load(JEDEC method) Maximum Instantaneous Forward Voltage at 1.0A (Note 1) Maximum DC Reverse Current TA=25 ¢J (Note 1) At Rated DC Blocking Voltage TA=100 ¢J Maximum Thermal Resistance (Note 2) Operating Junction Temperature Range Storage Temperature Range SYMBOLS SS12 SS13 SS14 SS15 SS16 SS18 SS19 S100 UNITS 20 30 40 50 60 80 90 100 Volts VRRM 14 21 28 35 42 56 64 71 Volts VRMS 20 30 40 50 60 80 90 100 Volts VDC I(AV) 1.0 Amps IFSM 30.0 Amps VF 0.5 IR R £KJL R £KJA TJ TSTG NOTES: 1. Pulse Test with PW=300 £g sec, 2% Duty Cycle. 2. Mounted on P.C.Board with 5.0mm2 (.013mm thick) copper pad areas. 1/2 0.70 0.5 20.0 28 88 -50 to +125 -50 to +150 0.85 Volts mA ¢J /W ¢J ¢J SS12 THRU S100 RATING AND CHARACTERISTIC CURVES INSTANTANEOUS FORWARD CURRENT AMPERES AVERAGE FORWARD CURRENT AMPERES 20 1.0 0.75 SINELE PHASE HALF WAVE 60Hz RESISTIVE OR 0.50 INDUCTIVE LOAD P.C.B MOUNTED ON 0.2×0 .2"(5.0×5 .0mm) COPPER 0.25 PAD AREAS 0 0 20 40 60 80 100 120 SS12~SS14 10 SS15~SS16 SS18~S100 1.0 TJ = 25 ¢J PULSE WIDTH = 300£gs 1% DUTY CYCLE 0.1 140 .1 LEAD TEMPERATURE, ¢J .5 .7 .8 .9 1.1 1.3 1.5 Fig. 2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS PEAK FORWARD SURGE CURRENT, AMPERES 30 25 8.3ms SINGLE HALF SINE WAVE 20 JEDEC METHOD 15 10 5 2 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz Fig. 3-MAXIMUM NON-REPETITIVE SURGE CURRENT CAPACTANCE, pF 400 200 TJ = 25 ¢J 100 80 60 40 20 10 0.1 1.9 INSTANTANEOUS FORWARD VOLTAGE, VOLTS Fig. 1-FORWARD CURRENT DERATING CURVEE 1 1.7 0.4 1.0 4 10 40 60 100 REVERSE VOLTAGE ,VOLTS Fig. 4-TYPICAL JUNCTION CAPACITANCE 2/2 120
SS26/SMA 价格&库存
很抱歉,暂时无法提供与“SS26/SMA”相匹配的价格&库存,您可以联系我们找货
SS26/SMA
  • 10+0.19200
  • 50+0.17760
  • 200+0.16560
  • 600+0.15360
  • 1500+0.14400
  • 3000+0.13800
