TS2306A230g
TS2306A230g
    SHOUHAN(首韩)
    SMD,SW2_2X3mm
    按钮头类型:圆形按钮 电路结构:单刀单掷 触点额定电流:50mA @ 12VDC 按钮作用方向:立式垂直
TS2306A230g 数据手册
深圳市首韩科技有限公司 PRODUCT SPECIFICATION 产品承认书 TACT SWITCH 轻触开关 2*3*0.65 160gf 文件编号 FILE NO. 发布日期 DATE OF ISSUE 文件版本 EDITION 产品编码 PART NO 页码 PEGE 2/7 2013 年 11 月 12 日 第 A 版第 0 次修订 2*3*0.65 160gf 1. General Characteristics 一般特性: 适用范围: 1.1、This specification is applied to the requirements for TACTILE SWITCH (MECHANICAL CONTACT) 此规格书适用于机械式轻触开关的相关要求 1.2 Operating Temperature Range: -30℃to85℃ 使用温度范围: -30℃to 85℃ 1.3 Operating Relative Humidity: ≤85%RH 相对湿度:≤85%RH 1.4 Test Conditions: Unless otherwise specified, the atmospheric conditions for making measurements and tests are as follows: 实验条件:若没有特别说明,则试验大气条件如下: Ambient Temperature: 5~35℃,Relative Humidity: 45~85% 环境温度: 5~35℃,相对湿度: 45~85% Air Pressure: 86~106Kpa (860~1060mbar) 大气压力: 86~106Kpa (860~1060mbar) 2. Appearance, Structure and Dimensions 外观,结构及尺寸: 2.1 Appearance: The switch shall have good finishing, and no rust, crack or plating defects. 外观:产品外观良好,无锈蚀、裂纹和镀层缺陷。 2.2 Structure & Dimensions: Refer to individual product drawing. 结构及尺寸:参见产品图纸 2.3 Markings: Refer to individual product drawing. 标识:参见产品图纸。 3. Ratings 额定负荷 DC12V 50mA 4. Electrical Characteristics 电气特性 No. 4.1 4.2 Item 项目 Contact Resistance 接触电阻 Resistance Insulation 绝缘电阻 Criteria 标准 Test Method 实验方法 在以 5V 10mA 的直流电源或不低于 1KHz 的交流电源的电路 中,以一个等于 2 倍按力的静负荷施加于手柄中心 100mΩ Max. Applying a static load of 2 times operating force to the center of the stem, measurements shall be made by 5V DC 10mA or more than 1KHZ AC small-current contact resistance meter. Measurement shall be made following application of 100V DC potential, across terminals, and across terminals and cover, for one 100MΩ Min. minute. 在端子之间施加 DC 100V /1min 的条件下,测量端子之间底座、盖板的 电阻值. 4.3 Dielectric Voltage 抗电强度 No dielectric breakdown shall occur. 无击穿现象发 生。 250VAC (50~60Hz,cut –off current 2mA) is applied between non-connected terminals and between terminals and the metal frame for 60 ±5s. 在相互绝缘的所有接线端子之间 250V(50-60Hz ) 交流电, 各接 线端子与外壳或非载流金属零件之间加载 250V(50-60Hz ) 交流 电,持续时间 60±5S。 深圳市首韩科技有限公司 PRODUCT SPECIFICATION 产品承认书 TACT SWITCH 轻触开关 2*3*0.65 160gf 文件编号 FILE NO. 发布日期 DATE OF ISSUE 文件版本 EDITION 产品编码 PART NO 页码 PEGE 3/7 2013 年 11 月 12 日 第 A 版第 0 次修订 2*3*0.65 160gf 5. Mechanical Characteristics 机械特性 No. Item 项目 Criteria 标准 Apply a static load on the midpoint of the actuator (or tip of Operating 5.1 Force Test Method 实验方法 160±50gf 操作力 the shaft) to supply a pressure vertically from its free position to operating position. 在操作元件末端沿操作方向均匀施加静载荷,使操作元 件转换到动作位置。 The value to which the force in the actuator midpoint (or tip Return 5.2 Force of the shaft) must be reduced to allow the contact to the 40 gf Min 回弹力 normal position. 在操作元件末端沿操作方向均匀减少静载荷,使操作元 件从动作位置转换到自由位置。 开关垂直于操作方向放置,以一个等于 2 倍按力的静负 5.3 5.5 5.6 Operation Position 操作位置 Terminal Strength 端子强度 Vibration Proof 振动 0.15±0.05mm 荷施加在开关驱动件顶端中心,测量顶端移动的距离。 Placing the switch such that the direction of switch operation is vertical and then applying static load of 2times operating force to the center of the stem; the travel distance for the switch to come to a stop shall be measured. Shall be free from terminallooseness,damageandins ulator breakage.Nofunctional defective occur 端子无松动,损坏及绝缘层的 破裂。无功能性不良 A static load of 0.5N shall be applied to the tip of terminal in a desired direction for 10 ± 1s. The test shall be done once per terminal. 以 0.5N 作用力沿轴向逐渐施加于接线端末端 10±1s(作 用力方向为离开开关向外指向),每个接线端子测量一 次。 After test, Contact resistance:200 mΩMax. I No functional defective occur No abnormalities shall be recognized in appearance and construction. 实验后: 接触电阻:200 mΩ Max. 无功能性不良。 表面及结构无明显变形 Switch shall be secured to a testing machine by a normal mounting device and method. Switch shall be measured after following test. (1) Vibration frequency range 10~55 Hz (2) Total amplitude 1.5mm (3) Sweep ratio: 10~55~10Hz Approx. 1 min (4) Method of changing the sweep vibration frequency: logarithmic or linear (5) Direction of vibration: Three perpendicular directions including actuating direction. (6) Duration: 2 hours (6 hours in total) 开关采用常规的安装方法牢固地安装在试验设备上,并 在下述参数条件下进行试验: ⑴ 振频 10-55Hz ⑵ 振幅 1.5mm ⑶ 振动变化速率:10-55-10Hz 大约 1 分钟 ⑷ 变频方法:对数或线性型式 ⑸ 振动方向:三个相互垂直的方向,其中一个方向应是 促动元件运动的方向。 ⑹ 时间:每个方向 2 小时(共 6 小时)。 深圳市首韩科技有限公司 PRODUCT SPECIFICATION 产品承认书 TACT SWITCH 轻触开关 No. Item 项目 2*3*0.65 160gf Criteria 标准 文件编号 FILE NO. 发布日期 DATE OF ISSUE 文件版本 EDITION 产品编码 PART NO 页码 PEGE 2013 年 11 月 12 日 第 A 版第 0 次修订 2*3*0.65 160gf Test Method 实验方法 Switch shall be measured after following test: (1) Mounting Method: Normal (2) Acceleration: 490m/s2 (50G) (3) Duration: 11ms (4) Test Direction: 6 directions 5.7 Mechanical Shock 冲击 5.8 Solder Ability 可焊性 4/7 After test, Contactresistance:200mΩMax. No functional defective occur Shall be free from mechanical abnormalities. 实验后: 接触电阻:200 mΩMax. 无功能性不良。 表面无变形且操作无异常。 (5)Number of shocks: 3 times per direction (18 times in total) 试件在下述参数条件下进行试验: ⑴ 安装方法:常规方法 ⑵ 加速度:490m/ s2 (50G) ⑶ 时间:11ms ⑷ 实验方向:图示 6 方向 ⑸ 冲击次数:每个方向 3 次(总共 18 次) Switch shall be tested according to the following request: 1(1) Equipment: Auto-Dip Chamber 2(1) Solder: Normal 3(1) Flux: Rosin Flux having a nominal composition of 25% solids by mass of water white rosin in methyl alcohol solution. 4(1) Soldering Temperature: 260 ± 5°C 5(1) Immersing Time: 3 ±1s 6(1) Immersion Depth: Immersion depth shall be at copper plating portion of More than 90% of immersed PCB after mounting. part shall (Thickness of PCB=1.6mm) be covered with solder. 开关在下述参数条件下进行试验: 超过 90% 的浸锡面积被焊料 ⑴ 设备:自动焊接机 所覆盖。 ⑵ 焊料:常规 ⑶ 焊剂:焊剂,质量百分比为 25% 松香,75% 甲醇 的无色透明溶液。 ⑷ 焊接温度:260±5℃ ⑸ 浸渍时间:3±1s ⑹ 浸渍深度: 接线端应浸到离开关根部 1.6mm 处。。 深圳市首韩科技有限公司 PRODUCT SPECIFICATION 产品承认书 TACT SWITCH 轻触开关 No. 5.9 Item 项目 Solder Heat Resistance 耐焊接热 2*3*0.65 160gf 文件编号 FILE NO. 发布日期 DATE OF ISSUE 文件版本 EDITION 产品编码 PART NO Criteria 标准 页码 PEGE 5/7 2013 年 11 月 12 日 第 A 版第 0 次修订 2*3*0.65 160gf Test Method 实验方法 Please practice according to below condition: (1) Preheat :150℃ 90-120s (2) Soldering heat : 260℃ Max 10S. (3) Immersion depth: Up to the surface of the board 焊接方法: No abnormalities shall be ⑴ 预热: 150℃ 90-120s observed in appearance and ⑵ 最高焊接温度: 260℃ Max 5S. ⑶ 浸渍深度:PCB 表面) operation. No functional defective occur 无外观 及功能损坏。 无功能性不良。 ( c) 300 260 c 10 SEC MAX 200 220 c 10 SEC MAX 20秒 以下 100 0 (120 second)秒 TIME 时间 3-4min 回流焊曲线图 5.10 Resistance to Flux 抗焊剂能力 switch shall be tested according to the following request: (1)switch Equipment: Auto-Dip Chamber (2)Solder: Normal (3)Flux: Rosin Flux having a nominal composition of 25% solids by mass of water white rosin in methyl alcohol solution. (4)Soldering Temperature: 260 ± 5°C Flux shall not be risen up to (5)Immersing Time: 3 ±1s contact. (6)Immersion Depth: The switch shall be free from Immersion depth shall be at copper plating portion of abnormalities in operation. PCB after mounting. 焊剂不得上升进入开关内部, (Thickness of PCB) 影响 开关在下述参数条件下进行试验: 接触转换。 ⑴ 设备:自动焊接机 试件在操作过程中不应发生 ⑵ 焊料:常规 变形。 ⑶ 焊剂:焊剂,质量百分比为 25%松香,75%甲醇 的无色透 明溶液。 ⑷ 焊接温度:260±5℃ ⑸ 浸渍时间:3±1s ⑹ 浸渍深度: 接线端应浸到离开关根部 处。 深圳市首韩科技有限公司 PRODUCT SPECIFICATION 产品承认书 TACT SWITCH 轻触开关 2*3*0.65 160gf 文件编号 FILE NO. 发布日期 DATE OF ISSUE 文件版本 EDITION 产品编码 PART NO 页码 PEGE 6/7 2013 年 11 月 12 日 第 A 版第 0 次修订 2*3*0.65 160gf 6. Durability characteristics No. 6.1 6.2 Item 项目 Mechanical Life 机械寿命 Electronics Life 电气寿命 Criteria 标准 After test, Contactresistance:500mΩ Max. Insulation resistance: 100MΩ Min. Tolerance of operating force Disintegration shall be within 30% of specified value No functional defective occur The switch shall be free from abnormalities in appearance construction. 实验后: 接触电阻:500mΩ Max. 绝缘电阻: 100MΩ Min. 操作力衰变应在±30%以内。 无功能性不良。 开关外观及结构应无损坏。 Test Method 实验方法 100,000 cycles of operation shall be performed continuously at a rate of 60 cycles per minute without load. 在不带负荷的条件下,速度为 60 次/分,在寿命试 验设备上连续转换 100,000 次。 100,000 cycles of operation shall be performed continuously at a rate of 60 cycles per minute with load as follow DC6V 50mA 在带以下负荷的条件下,速度为 60 次/分,在寿命 试验设备上连续转换 100,000 次。 DC6V 50mA `7. Weather Proof Characteristics 耐候性能: No. 7.1 7.2 7.3 Item 项目 Criteria 标准 Cold Proof 低温 Hot Proof 高温 Moisture Resistance 恒定湿热 After test, Contactresistance:200mΩ Max. Insulation resistance: 100MΩ Min. No functional defective occur The switch shall be free from abnormalities in appearance &construction. 实验后: 接触电阻:200mΩ Max. 绝缘电阻: 100MΩ Min. 无功能性不良。 开关外观及结构应无损坏。 Test Method 实验方法 After testing at –20 ± 2°C for 48 hours, the switch shall be allowed to stand under normal temperature and humidity conditions for 1 hour, and measurement shall be made within 1 hour after that. Water drops shall be eliminated. 试件在-20±2℃的温控箱内保持 48 小时,然后在正 常温度和湿度下恢复 1 小时,并在此后 1 小时内对 试品进行测量,水滴应消失。 After testing at 70 ± 2°C for 48 hours, the switch shall be allowed to stand under normal temperature and humidity conditions for 1 hour, and measurement shall be made within 1 hour after that. 试件在 70±2℃的温控箱内保持 48 小时,然后在正 常温度和湿度下恢复 1 小时,并在此后 1 小时内对 试品进行测量,水滴应消失。 After testing at 40± 2°C ,90~95% RH for 48 hours, the switch shall be allowed to stand under normal temperature and humidity conditions for 1 hour, and measurement shall be made within 1 hour after that. Water drops shall be eliminated. 试件在 40±2℃,90-95%RH 的温控箱内保持 48 小 时,然后在正常温度和湿度下恢复 1 小时,并在此 后 1 小时内对试品进行测量,水滴应消失。 深圳市首韩科技有限公司 PRODUCT SPECIFICATION 产品承认书 TACT SWITCH 轻触开关 2*3*0.65 160gf 文件编号 FILE NO. 发布日期 DATE OF ISSUE 文件版本 EDITION 产品编码 PART NO 页码 PEGE 7/7 2013 年 11 月 12 日 第 A 版第 0 次修订 2*3*0.65 160gf 7. Durability characteristics No. 7.4 Item 项目 Temperature Cycling 温度转换 Criteria 标准 After test, Contactresistance:200mΩ Max. Insulation resistance: 10MΩ Min. No functional defective occur The switch shall be free from abnormalities in appearance & construction. 实验后: 接触电阻:200mΩ Max. 绝缘电阻: 100MΩ Min. 无功能性不良。 开关外观及结构应无损坏。 Test Method 实验方法 After 5 cycles of following conditions, the switch shall be allowed to stand under normal temperature and humidity conditions for 1 hour, and measurement shall be made within 1 hour after that. Water drops shall be eliminated. 试件按下述实验条件试验 5 次,然后在正常温度和 湿度下恢复 1 小时,并在此后 1 小时内对试品进行 测量,水滴应消失 30 min 30 min Room Temp -20 c±3 c 10-15min 10-15min 1 cycle 7.5 Salt Mist 盐雾实验 The switch shall be checked after following test: (1) Temperature: 35± 2°C (2) Salt Solution: 5±1% (Solids by mass) (3) Duration: 4±1 hour After test, salt deposit shall be removed by running water. 试件在下述实验后测量: No remarkable corrosion shall ⑴ be 温度:35±2℃ ⑵ recognized in metal part. 在金属件上没有影响开关性 盐溶液浓度:5±1%(质量百分比) ⑶ 能的斑点 时间:4±1 小时 实验后的盐沉积物用水冲掉。 SPECIFICATIONS 1.Operating temperature range:-30 c to+85 c 2.Rating:DC12V 50mA 1 2 3.Insulation resistance:100MΩ min 100V DC 4.Dielectric strength:250V AC for 1min. 5.Contact resistance:500mΩMax 6.Operating force:160±50gf 7.Travel:0.15±0.05mm 8.Operating life:160gf:100,000 Cycle Min PCB.circuit prohibited area 零件名 视角 标记 处数 更改文件号 未注公差 X. X.X X.XX X.XXX 角度 ±0.10 ±0.05 ±0.03 ±0.005 ±0.5° 签名 产品名称: 产品型号: 页 次: 日期 2*3*0.65 1/1 图号 见上表 见上表 设计 裴 涛 材料 核对 李国强 表面处理 审核 标准化 刘小军 比例 10:1 单位 批准 罗孝金 杨涛 mm 版本 A1 深圳市首韩科技有限公司
TS2306A230g 价格&库存
很抱歉,暂时无法提供与“TS2306A230g”相匹配的价格&库存,您可以联系我们找货
