SR2200
2.0A Schottky Barrier Rectifiers
DO-15
FEATURES
Low forward voltage drop
High current capability
High reliability
High surge current capability
Epitaxial construction
MECHANICAL DATA
Case: Molded plastic
Epoxy: UL94V-1 rate flame retardant
Lead: Lead solderable per MIL-STD-202
method 208 guaranteed
Polarity: As Marked
Mounting position: Any
Weight: 0.093 grams (Approximately)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25°C ambient temperature unless otherwise specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Working Peak Reverse Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
Superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage (IF = 2 Amps, TA = 25°C)
Maximum Instantaneous Forward Voltage (IF = 2 Amps, TA = 125°C)
Maximum DC Reverse Current at Rated DC
TA = 25°C
Blocking Voltage (Note 3)
TA = 125°C
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance RJL (Note 2)
Voltage Rate of Chance (Rated VR)
Operating Temperature Range TJ
Storage Temperature Range TSTG
VALUES
UNITS
200
200
200
2
V
V
V
A
50
A
0.90
0.72
0.2
8
70
10
10000
-50 ~ +150
-65 ~ +175
V
mA
pF
°C /W
V/us
°C
°C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 5.0V D.C.
2. Thermal Resistance Junction to Lead.
3. Pulse test: 300us pulse width, 1% duty cycle.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
RATINGS AND CHARACTERISTIC CURVES
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-15
3000/AMMO
30000
42X28X31
12.00
10.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“SR2200”相匹配的价格&库存,您可以联系我们找货
