UMW
R
UMW MB05M-MB10M
0.8 A Single-Phase Glass Passivated Bridge Rectifiers
Rectifier Reverse Voltage 50 to 1000V
Features
N !"#$%!&'(
MB-1
This series is UL listed under the Recognized
Component Index, file number E142814
Ideal for surface mount application
The plastic material used carries Underwriters
Laboratory flammability recognition 94V-0
Surge overload ratings to 30 amperes
High temperature soldering guaranteed 265 C/10
seconds at 5 lbs (2.3kg) tension
E
Mechanical Data
Case: Molded plastic
Terminals: Plated leads solderable per MIL-STD-202,
Method 208
Polarity: Marked on body
Mounting Position: Any
A
B
C
D
E
F
G
H
K
L
N
.195
.095
.144
.179
.039
.090
.017
.132
.006
.137
1
.020
.205
.105
.161
.190
.049
.106
.029
.148
.016
.147
5
.028
4.95
2.41
3.65
4.55
0.99
2.30
0.43
3.35
0.15
3.48
1
0.51
5.21
2.67
4.10
4.83
1.24
2.70
0.74
3.75
0.41
3.73
5
0.71
Maximum Ratings & Thermal Characteristics
Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz.
For Capacitive load derate current by 20%.
Parameter
Symbol MB05M MB1M MB2M
MB4M
MB6M
MB8M MB10M unit
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS bridge input voltage
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
Maximum DC blocking voltage
Maximum average forward rectified
output current at TA=40 C (*3)
IF(AV)
0.5
0.8*
Peak forward surge current single sine-wave
superimposed on rated load (JEDEC Method)
IFSM
30
A
I t
10
A sec
ReJA
110
C /W
Cj
25.0
pF
Rating for fusing ( t
很抱歉,暂时无法提供与“UMW MB10M(0.8A)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10281
- 500+0.09246
- 5000+0.08556
- 10000+0.08211
- 30000+0.07866
- 50000+0.07659
