RS8901
Nano-Power, CMOS Input, RRIO,
Push-Pull Output Comparator
FEATURES
DESCRIPTION
Low supply current
400nA (TYP) at VS = 1.4V
Low input offset voltage : Vos(max) = 5mV
Rail-to-Rail Input and output
SUPPLY RANGE: +1.4V to +5.5V
SPECIFIED UP TO +125°C
MicroSIZE
The RS8901 offers a wide supply range, low
quiescent current 400nA (TYP), and rail-to-rail
inputs. All of these features come in industrystandard and extremely small packages, making this
device an excellent choice for low-voltage and lowpower applications for portable electronics and
industrial systems.
PACKAGES: SOT23-5/SC70-5
Featuring a push-pull output stage, the RS8901
allows for operation with absolute minimum power
consumption when driving any capacitive or resistive
load.
APPLICATIONS
OVERVOLTAGE AND UNDERVOLTAGE
DETECTION
MULTIVIBRATORS
OVERCURRENT DETECTION
SYSTEM MONITORING
BATTERY POWERED SYSTEM
The devices are ideal for system monitoring, include
tablets, portable medical, smart phones. The
RS8901 is specified at the full temperature range of
−40°C to +125°C under single power supplies of
1.4V to 5.5V.
PIN CONFIGURATIONS
RS8901
5 V+
OUT 1
V- 2
+IN 3
4 -IN
SOT23-5/SC70-5
REV A.1
1
www.run-ic.com
RS8901
ABSOLUTE MAXIMUM RATINGS (1)
Supply Voltage, V+ to V-...............................................7.0V
Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V
Current (2)…………………....…..... ±10mA
Storage Temperature ……….…………… −65°C to +150°C
Operating Temperature ……….………… −40°C to +125°C
Junction Temperature................................................150°C
Lead Temperature (Soldering, 10s) ……………........260°C
ESD Susceptibility
HBM …......................................................................3000V
MM ……………………….........………………...……….400V
ESD SENSITIVITY CAUTION
ESD damage can range from subtle performance
degradation to complete device failure. Precision
integrated circuits may be more susceptible to
damage because very small parametric changes
could cause the device not to meet its published
specifications.
(1) Stresses above these ratings may cause permanent damage. Exposure
to absolute maximum conditions for extended periods may degrade
device reliability. These are stress ratings only, and functional
operation of the device at these or any other conditions beyond those
specified is not implied.
(2) Input terminals are diode-clamped to the power-supply rails. Input
signals that can swing more than 0.5V beyond the supply rails should
be current-limited to 10mA or less.
PACKAGE/ORDERING INFORMATION
PRODUCT
RS8901
TEMPERATURE
PACKAGE
PACKAGE
RANGE
LEAD
MARKING
RS8901XF
-40℃~125℃
SOT23-5
8901
Tape and Reel,3000
RS8901XC5
-40℃~125℃
SC70-5
8901
Tape and Reel,3000
ORDERING NUMBER
2
PACKAGE OPTION
www.run-ic.com
RS8901
ELECTRICAL CHARACTERISTICS
(At TA = +25C, Vs=1.4V to 5.5V, VCM=Vs/2, CL = 15pF, unless otherwise noted.)
PARAMETER
CONDITIONS
RS8901
MIN
TYP
MAX
UINTS
5.5
V
1500
nA
POWER SUPPLY
Vs
Operating Voltage Range
IQ
Quiescent Current
PSRR
Power-Supply Rejection Ratio
1.4
400
Vs=1.4V to 5.5V,
Vcm=(V-)+0.5V
68
90
dB
INPUT
Vos
ΔVos/ΔT
IB
Vcm
Input Offset Voltage
Vcm=Vs/2
±2
Input Offset Voltage Drift
Vcm=Vs/2, -40°C ≤ TA ≤125°C
2
Input Bias Current
1
±5
mV
µV/°C
10
pA
(V+)+0.1
V
Common-Mode Voltage
Range
TA = –40°C to 125°C
Output Swing From Upper
Rail
Vs=1.4V,Io=0.1mA
70
75
mV
Vs=5.0V,Io=2.5mA
140
170
mV
Output Swing From Lower
Rail
Vs=1.4V,Io=-0.1mA
35
40
mV
Vs=5.0V,Io=-2.5mA
85
115
mV
Short Circuit Sink Current
Vs=5.0V
45
mA
Short Circuit Source Current
Vs=5.0V
40
mA
VS = 5.0 V, Overdrive = 10 mV
13
VS = 5.0 V, Overdrive = 100 mV
6
VS = 2.5 V, Overdrive = 10 mV
12
VS = 2.5 V, Overdrive = 100 mV
5
VS = 1.4 V, Overdrive = 10 mV
13
VS = 1.4 V, Overdrive = 100 mV
6
22
15
18
15
18
(V-)-0.1
OUTPUT
VOH
VOH
ISC
SWITCHING
TPHL
TPLH
Propagation Delay H To L
Propagation Delay L To H
µs
TR
Rise Time
Overdrive = 100 mV
200
ns
TF
Fall Time
Overdrive = 100 mV
200
ns
3
www.run-ic.com
RS8901
TYPICAL CHARACTERISTICS
At TA = +25C, Vs=5V, VCM = VS/2, CL=15pF unless otherwise noted.
Propagation Delay (TPLH)
Propagation Delay (TPHL)
Overdrive=10mv
Vs=5v
4us/div
4us/div
SINK CURRENT vs TEMPERATURE
SOURCE CURRENT vs TEMPERATURE
52
48
50
46
Source Current(mA)
Sink Current(mA)
Vs=5v
2V/div
10mV/div
2V/div
10mV/div
Overdrive=10mv
48
46
44
42
40
38
44
42
40
38
36
34
36
32
-40 -20
20 40 60 80 100 120 140
Temperature(C)
-40 -20
4
Temperature(C)
www.run-ic.com
RS8901
PACKAGE OUTLINE DIMENSIONS
SOT23-5
D
1.90
b
2.59
E1
E
0.99
0.95
0.69
e
e1
RECOMMENDED LAND PATTERN (Unit: mm)
0.2
A A2
L
A1
Symbol
c
θ
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
5
www.run-ic.com
RS8901
SC70-5
D
1.30
b
1.9
E
E1
0.75
Pin1
Index Area
0.65
0.4
e
e1
0.2
A A2
c
θ
L
A1
Symbol
L1
Min
Max
Min
Max
A
0.900
1.100
0.035
0.043
A1
0.000
0.100
0.000
0.004
A2
0.900
1.000
0.035
0.039
b
0.150
0.350
0.006
0.014
c
0.080
0.150
0.003
0.006
D
2.000
2.200
0.079
0.087
E
1.150
1.350
0.045
0.053
E1
2.150
2.450
0.085
0.096
e
0.650(BSC)
0.026(BSC)
e1
1.300(BSC)
0.051(BSC)
L
0.260
L1
θ
0.460
0.010
0.525
0°
0.018
0.021
8°
6
0°
8°
www.run-ic.com
很抱歉,暂时无法提供与“RS8901XF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60000
- 100+0.56000
- 300+0.52000
- 500+0.48000
- 2000+0.46000
- 5000+0.44800
