74AHC1G4210-Q100
10-stage divider and oscillator
Rev. 2 — 27 June 2019
Product data sheet
1. General description
74AHC1G4210-Q100 is a 10-stage divider and oscillator. It consists of a chain of 10 flip-flops.
Each flip-flop divides the frequency of the previous flip-flop by two, consequently the
10
74AHC1G4210-Q100 counts up to 2 = 1024. The single inverting stage (X1 to X2) functions as
a crystal oscillator or an input buffer for an external oscillator. When used as a buffer the output X2
should be left floating. The frequency of the output (Q) is the frequency applied to X1 divided by
1024. The divider advances on the negative-going transition of X1.
The X1 input is overvoltage tolerant. This feature allows the use of this device as a voltage level
translator in mixed voltage environments.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F: exceeds 2000 V
• CDM JESD22-C101E: exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD 78 Class II
3. Ordering information
Table 1. Ordering information
Type number
Package
74AHC1G4210GW-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
4. Marking
Table 2. Marking codes
Type number
Marking[1]
74AHC1G4210GW-Q100
C1
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AHC1G4210-Q100
Nexperia
5. Functional diagram
X1
1
X2
2
Q
4
10-STAGE
COUNTER
aaa-022698
Fig. 1.
Logic symbol
X2
FF1
X1
D
D
FF2
FF10
D
CP
CP
CP
Q1
Q2
Q10
Q
aaa-022699
Fig. 2.
Logic diagram
6. Pinning information
6.1. Pinning
74AHC1G4210
X1
1
X2
2
GND
3
5
VCC
4
Q
aaa-022700
Fig. 3.
Pin configuration SOT353-1
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
X1
1
clock input/oscillator pin
X2
2
oscillator pin
GND
3
ground (0 V)
Q
4
divider output
VCC
5
supply voltage
74AHC1G4210_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 11
74AHC1G4210-Q100
Nexperia
7. Functional description
1
2
4
8
16
32
64
128
256
512
1024
2048
3072
4096
5120
X1
Q
aaa-022702
Fig. 4.
Timing diagram
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
-20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
Conditions
[1]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT353-1 (TSSOP5) package: above 74 °C the value of Ptot derates linearly with 3.3 mW/K.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall
rate
74AHC1G4210_Q100
Product data sheet
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
V
VCC
V
-40
+25
+125
°C
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
3 / 11
74AHC1G4210-Q100
Nexperia
10. Static characteristics
Table 6. Static characteristics
Symbol Parameter
VIH
VIL
VOH
Conditions
25 °C
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 3.0 V
2.4
2.4
2.4
V
VCC = 5.5 V
4.4
4.4
4.4
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 3.0 V
0.6
0.6
0.6
V
VCC = 5.5 V
1.1
1.1
1.1
V
Q; VI = VIH or VIL
HIGH-level
output voltage
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
1.9
2.0
1.9
1.9
V
2.9
3.0
2.9
2.9
V
4.4
4.5
4.4
4.4
V
IO = -2.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -3.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
Q; VI = VIH or VIL
LOW-level
output voltage
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
IO = 2.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 3.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
μA
HIGH-level
input voltage
LOW-level
input voltage
X1
X1
X2; VI = VIH or VIL
VOL
X2; VI = VIH or VIL
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
μA
CI
input
capacitance
3
8
8
8
pF
74AHC1G4210_Q100
Product data sheet
X1; VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
X1
4 / 11
74AHC1G4210-Q100
Nexperia
11. Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; tr = tf = ≤ 3.0 ns. For test circuit see Fig. 7. For waveforms see Fig. 5 and Fig. 6.
Symbol Parameter
tpd
propagation
delay
Conditions
25 °C
Typ
Max
Min
Max
Min
Max
CL = 15 pF
3
7
1
11
1
13
ns
CL = 50 pF
7
13
1
16
1
18
ns
2
5
1
7
1
9
ns
6
10
1
11
1
12
ns
CL = 15 pF
24
41
1
50
1
59
ns
CL = 50 pF
26
45
1
53
1
63
ns
CL = 15 pF
17
27
1
33
1
39
ns
CL = 50 pF
19
30
1
38
1
44
ns
VCC = 3.0 V to 3.6 V
4
5
7
ns
VCC = 4.5 V to 5.5 V
3
4
5
ns
VCC = 3.3 V
125
100
70
MHz
VCC = 5 V
165
125
100
MHz
4
pF
5
pF
X1 to X2
[1]
[2]
[3]
CL = 15 pF
CL = 50 pF
X1 to Q
[1]
fmax
CPD
pulse width
maximum
frequency
[2]
[3]
X1 HIGH or LOW
X1
CL = 50 pF; fi = 1 MHz;
power
VI = GND to VCC
dissipation
capacitance
VCC = 3.3 V
VCC = 5 V
[1]
[2]
[3]
[4]
Min
tW
-40 °C to +85 °C
[4]
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD x VCC x fi + CL x VCC x fi/1024 where:
fi = input frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volt.
74AHC1G4210_Q100
Product data sheet
5 / 11
74AHC1G4210-Q100
Nexperia
11.1. Waveforms and test circuit
VI
1/f max
VI
VM
X1 input
X1 input
GND
tW
GND
tPHL
VOH
VM
VM
Q output
VOL
VOL
aaa-022703
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that
occur with the output load.
Fig. 5.
tPLH
tPHL
tPLH
VOH
X2 output
VM
Input X1 to output X2 propagation delay times
aaa-022704
Fig. 6.
Input X1 to output Q propagation delay times
Table 8. Measurement points
Inputs
Output
VI
VM
VM
GND to VCC
0.5 × VCC
0.5 × VCC
VCC
PULSE
GENERATOR
VI
DUT
VO
RT
CL
mna101
Test data is given in Table 7. Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig. 7.
Test circuit for measuring switching times
74AHC1G4210_Q100
Product data sheet
6 / 11
74AHC1G4210-Q100
Nexperia
12. Crystal oscillator
12.1. Typical crystal oscillator circuit
A typical crystal oscillator schematic is shown in Fig. 8. R1 is the power limiting resistor, its value
depends on the frequency and required stability against changes in VCC or average ICC. For
starting and maintaining oscillation a minimum transconductance is necessary, so R1 should not be
too large. A practical value for R1 is 2.2 kΩ.
74AHC1G4210
X1 1
Rbias = 560 kΩ
2
X2
VCC
Rbias
0.47 µF
100 kΩ to 1 MΩ
R1
2.2 kΩ
C1
22 pF to 37 pF
output
100 µF
VI
(f = 1 kHz)
A IO
GND
C2
100 pF
mna050
gfs = ΔIO / ΔVI at VO is constant.
See also Fig. 10.
aaa-022705
Fig. 8.
input
External component connection for a crystal
oscillator
Fig. 9.
Test set-up for measuring forward
transconductance
aaa-022706
gfs
(mA/V)
(1)
16
(2)
12
(3)
8
4
2
3
4
5
VCC (V)
6
Tamb = 25 °C.
(1) Maximum.
(2) Typical.
(3) Minimum.
Fig. 10. Typical forward transconductance as function of the supply voltage
74AHC1G4210_Q100
Product data sheet
7 / 11
74AHC1G4210-Q100
Nexperia
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig. 11. Package outline SOT353-1 (TSSOP5)
74AHC1G4210_Q100
Product data sheet
8 / 11
74AHC1G4210-Q100
Nexperia
14. Abbreviations
Table 9. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC1G4210_Q100 v.2 20190627
Product data sheet
74AHC1G4210_Q100 v.1
Modifications:
Typo corrected in Fig. 4.
74AHC1G4210_Q100 v.1 20180726
74AHC1G4210_Q100
Product data sheet
Product data sheet
9 / 11
74AHC1G4210-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
16. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74AHC1G4210_Q100
Product data sheet
10 / 11
74AHC1G4210-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 1
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 6
12. Crystal oscillator........................................................ 7
12.1. Typical crystal oscillator circuit.................................. 7
13. Package outline.......................................................... 8
14. Abbreviations.............................................................. 9
15. Revision history..........................................................9
16. Legal information......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 27 June 2019
74AHC1G4210_Q100
Product data sheet
11 / 11
很抱歉,暂时无法提供与“74AHC1G4210GW-Q10H”相匹配的价格&库存,您可以联系我们找货
