SNO-1303-C
SNO-1303-C
    SOFNG(硕方)
    CONN_13.5x12.29MM_SM
    SD/SIM/TF卡插座 13.5x12.29mm 24V 50mA 7Pin
SNO-1303-C 数据手册
www.Sofng.com C Operation:NANO-SIM SOCKETS & ARD SOCKETS Push-Push 外焊式 LTEM NO.:SNO-1303-C 带检测功能 (Consumer Electronics) (13.5L× (13.5L×12.3W× 12.3W×1.37H & NANO-SIM Sockets) MEMORY-CARD-SOCKETS 表面贴装 SMT Technical parameter ╲ LEVEL A[better product] ╲ PROJECT Contact Rating Electrical Initial Contact Resistance Properties Insulation Resistance B[average product] 侧向操作 LATERAL 50mA, 24V DC 50mΩ max. 80mΩ max. 精密部品 NICETY 100MΩ min.500V DC Withstand Voltage 500V AC for 1 minute 350 V AC for 1 minut There No Load 5,000 Cycles 3,500 Cycles Rated Load 3,500 Cycles 2,500 Cycles 可靠 STABILIZE Durable Performance 適合環保 RoHS -35℃~+75℃(Operating Temp: Sterage temp. Page1 ) Unit:mm 0.08 ● ● ● SOFNG ELECTRONIC TECHNOLOGY Co., LTD CIRCUIT BOARD SIZE (Vertical view) Operating Force Inward 8.0~12.0N.(1N.=100gram-force) Exiting 5.0~7.0N.(1N.=100gram-force) Solder-ability IR Reflow:255℃,5sec. (Max.) Manual:350℃,3sec. DECIMALS CD GND WIHOUT CARD Pin definition SIM ANGLES .X :±0.20 X.° .XX :±0.10 X.X° :±1.0° :±1.5° .XXX :±0.05 .XXX° :±0.5° CD GND CARD INSERTED SWTICH OPERATION DIAGRAM CARD Pin No. Pin NAME Type Description C ① 卡電源 1 VCC C ② 復位 1 RST C ③ 時鐘 1 CLK C ⑤ 接地 1 GND C ⑥ Vpp 1 VPP C ⑦ 輸入/輸出 1 I/O CD PIN 插卡检测 1 CARD DETECT NANO-SIM Material declaration NAME MATERIAL PLATING ① 接触端子 Terminal C5210-EH (t=0.15mm)磷铜【镍基 Ni50u〞镀金 1u〞】 G/F ② 上盖 Cover SUS304-H(t=0.12mm)不锈钢【GND 焊点镀金 1u〞】 AU/Ni ③ 基座 Housing LCP 耐热塑胶 (UL94V-0) BLACK SET ④ 弹簧 Spring SUS304-EH 不锈钢 OD=0.20mm - ⑤ 滑块 Slider LCP 耐热塑胶 (UL94V-0) BLACK SET ⑥ 线型拉杆 Drag Link SUS304-EH 不锈钢 OD=0.25mm - 注記 NOTICE Reel label RoHS label 1000PCS/reel Vacuum Packed Bag RoHS label 1.碩方公司擁有最終解釋權;The SOFNG company reserves the right of final interpretation; 2.文件禁止外洩、轉載;Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. Cardboard box label
SNO-1303-C 价格&库存
很抱歉,暂时无法提供与“SNO-1303-C”相匹配的价格&库存,您可以联系我们找货
