74AHC1G4214
14-stage divider and oscillator
Rev. 3 — 26 April 2018
1
Product data sheet
General description
74AHC1G4214 is a 14-stage divider and oscillator. It consists of a chain of 14 flip-flops.
Each flip-flop divides the frequency of the previous flip-flop by two, consequently the
14
74AHC1G4214 counts up to 2 = 16384. The single inverting stage (X1 to X2) functions
as a crystal oscillator or an input buffer for an external oscillator. When used as a buffer
the output X2 should be left floating. The frequency of the output (Q) is the frequency
applied to X1 divided by 16384.The divider advances on the negative-going transition of
X1.
The X1 input is overvoltage tolerant. This feature allows the use of this device as a
voltage level translator in mixed voltage environments.
2
Features and benefits
Wide supply voltage range from 2.0 V to 5.5 V
Overvoltage tolerant inputs to 5.5 V
High noise immunity
CMOS low power dissipation
ESD protection:
– HBM JESD22-A114F: exceeds 2000 V
– CDM JESD22-C101E: exceeds 1000 V
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3
Ordering information
Table 1. Ordering information
Type number
74AHC1G4214GW
4
Package
Temperature range
Name
Description
Version
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
Marking
Table 2. Marking codes
Type number
Marking
74AHC1G4214GW
C4
[1]
[1] The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AHC1G4214
Nexperia
5
Functional diagram
X1
1
X2
2
Q
4
14-STAGE
COUNTER
aaa-022713
Figure 1. Logic symbol
X2
FF1
X1
D
D
FF2
FF14
D
CP
CP
CP
Q1
Q2
Q10
Q
aaa-022714
Figure 2. Logic diagram
6
Pinning information
6.1 Pinning
74AHC1G4214
X1
1
X2
2
GND
3
5
VCC
4
Q
aaa-022715
Figure 3. Pin configuration SOT353-1
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
X1
1
clock input/oscillator pin
X2
2
oscillator pin
GND
3
ground (0 V)
Q
4
divider output
VCC
5
supply voltage
74AHC1G4214
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 13
74AHC1G4214
Nexperia
7
Functional description
1
2
4
8
16
32
64
128
256
512
1024
2048
4096
8192 16384
X1
Q
aaa-022717
Figure 4. Timing diagram
8
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
-20
mA
±20
mA
±25
mA
VI < -0.5 V
[1]
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
-0.5 V < VO < VCC + 0.5 V
ICC
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
250
mW
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
[2]
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] For TSSOP5 package: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
74AHC1G4214
Product data sheet
3 / 13
74AHC1G4214
Nexperia
9
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall
rate
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
10 Static characteristics
Table 6. Static characteristics
Symbol Parameter
VIH
VIL
VOH
Conditions
25 °C
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 3.0 V
2.4
2.4
2.4
V
VCC = 5.5 V
4.4
4.4
4.4
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 3.0 V
0.6
0.6
0.6
V
VCC = 5.5 V
1.1
1.1
1.1
V
HIGH-level
Q; VI = VIH or VIL
output voltage
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
1.9
2.0
1.9
1.9
V
2.9
3.0
2.9
2.9
V
4.4
4.5
4.4
4.4
V
IO = -2.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -3.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
HIGH-level
input voltage
LOW-level
input voltage
X1
X1
X2; VI = VIH or VIL
74AHC1G4214
Product data sheet
4 / 13
74AHC1G4214
Nexperia
Symbol Parameter
VOL
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
LOW-level
Q; VI = VIH or VIL
output voltage
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
IO = 2.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 3.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
μA
X2; VI = VIH or VIL
II
input leakage
current
X1; VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
μA
CI
input
capacitance
3
8
8
8
pF
X1
11 Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; tr = tf = ≤ 3.0 ns. For test circuit see Figure 7. For waveforms see Figure 5 and Figure 6.
Symbol Parameter
tpd
propagation
delay
Conditions
25 °C
Typ
Max
Min
Max
Min
Max
3
7
1
11
1
13
ns
7
13
1
16
1
18
ns
2
5
1
7
1
9
ns
6
10
1
11
1
12
ns
33
55
1
67
1
78
ns
35
60
1
71
1
82
ns
CL = 15 pF
23
36
1
44
1
52
ns
CL = 50 pF
25
40
1
51
1
58
ns
X1 to X2
VCC = 3.0 V to 3.6 V
[2]
CL = 50 pF
VCC = 4.5 V to 5.5 V
[3]
CL = 15 pF
CL = 50 pF
X1 to Q
[1]
[2]
CL = 15 pF
CL = 50 pF
Product data sheet
Min
[1]
CL = 15 pF
74AHC1G4214
-40 °C to +85 °C
[3]
5 / 13
74AHC1G4214
Nexperia
Symbol Parameter
tW
pulse width
fmax
maximum
frequency
Conditions
25 °C
Typ
Max
Min
Max
Min
Max
4
5
7
ns
3
4
5
ns
125
100
70
MHz
165
125
100
MHz
4
pF
5
pF
X1 HIGH or LOW
X1
VCC = 3.3 V
power
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
dissipation
capacitance
VCC = 3.3 V
VCC = 5 V
[1]
[2]
[3]
[4]
Min
VCC = 5 V
CPD
-40 °C to +85 °C
[4]
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD x VCC x fi + CL x VCC x fi/16384 where:
fi = input frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volt.
74AHC1G4214
Product data sheet
6 / 13
74AHC1G4214
Nexperia
11.1 Waveforms and test circuit
VI
1/f max
VI
VM
X1 input
X1 input
GND
tW
GND
tPHL
tPLH
tPHL
tPLH
VOH
VOH
VM
X2 output
VM
VM
Q output
VOL
VOL
aaa-022703
Measurement points are given in Table 8.
aaa-022704
VOL and VOH are typical output voltage levels that occur with VOL and VOH are typical output voltage levels that occur with
the output load.
the output load.
Figure 5. Input X1 to output X2 propagation delay times Figure 6. Input X1 to output Q propagation delay times
Table 8. Measurement points
Output
Inputs
VI
VM
VM
GND to VCC
0.5 x VCC
0.5 x VCC
VCC
PULSE
GENERATOR
VI
DUT
VO
RT
CL
mna101
Test data is given in Table 7. Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Figure 7. Test circuit for measuring switching times
74AHC1G4214
Product data sheet
7 / 13
74AHC1G4214
Nexperia
12 Crystal oscillator
12.1 Typical crystal oscillator circuit
A typical crystal oscillator schematic is shown in Figure 8. R1 is the power limiting
resistor, its value depends on the frequency and required stability against changes in VCC
or average ICC. For starting and maintaining oscillation a minimum transconductance is
necessary, so R1 should not be too large. A practical value for R1 is 2.2 kΩ.
74AHC1G4214
X1 1
Rbias = 560 kΩ
2
X2
VCC
Rbias
0.47 µF
100 kΩ to 1 MΩ
R1
2.2 kΩ
C1
22 pF to 37 pF
input
VI
(f = 1 kHz)
output
100 µF
A IO
GND
C2
100 pF
mna050
gfs = ΔIO / ΔVI at VO is constant.
See also Figure 10.
aaa-022718
Figure 8. External component connection for a crystal
oscillator
Figure 9. Test set-up for measuring forward
transconductance
aaa-022706
gfs
(mA/V)
(1)
16
(2)
12
(3)
8
4
2
3
4
5
VCC (V)
6
Tamb = 25 °C.
(1) Maximum.
(2) Typical.
(3) Minimum.
Figure 10. Typical forward transconductance as function of the supply voltage
74AHC1G4214
Product data sheet
8 / 13
74AHC1G4214
Nexperia
13 Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Figure 11. Package outline SOT353-1 (TSSOP5)
74AHC1G4214
Product data sheet
9 / 13
74AHC1G4214
Nexperia
14 Abbreviations
Table 9. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15 Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC1G4214 v.3
20180426
Product data sheet
74AHC1G4214 v.2
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74AHC1G4214 v.2
20161026
Modifications:
• Type number 74AHC1G4214GM removed.
74AHC1G4214 v.1
20160415
74AHC1G4214
Product data sheet
Product data sheet
Product data sheet
74AHC1G4214 v.1
10 / 13
74AHC1G4214
Nexperia
16 Legal information
16.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AHC1G4214
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
11 / 13
74AHC1G4214
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AHC1G4214
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74AHC1G4214
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
12.1
13
14
15
16
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Marking .................................................................1
Functional diagram ............................................. 2
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 2
Functional description ........................................3
Limiting values .................................................... 3
Recommended operating conditions ................ 4
Static characteristics .......................................... 4
Dynamic characteristics .....................................5
Waveforms and test circuit ................................ 7
Crystal oscillator ................................................. 8
Typical crystal oscillator circuit .......................... 8
Package outline ...................................................9
Abbreviations .................................................... 10
Revision history ................................................ 10
Legal information .............................................. 11
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 26 April 2018
Document identifier: 74AHC1G4214
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC1G4214GWH
