74AHCT541A
Octal buffer/line driver; 3-state
Rev. 7 — 17 March 2017
1
Product data sheet
General description
The 74AHCT541A is an 8-bit buffer/line driver with 3-state outputs and TTL inputs.
The device features two output enables (OE1 and OE2). A HIGH on OEn causes the
associated outputs to assume a high-impedance OFF-state.
Designed to operate over a VCC range from 4.5 V to 5.5 V, the inputs are TTL
compatible, which allows the device to be used to translate from 3.3 V to 5 V.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times.
This device is fully specified for partial Power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the
device when it is powered down.
2
Features and benefits
Direct interface with TTL levels
Supply voltage range from 4.5 V to 5.5 V
Typical tpd of 2.8 ns at 5 V
Typical VOL(p) < 0.8 V at VCC = 5 V, Tamb = 25 °C
Typical VOH(v) > 2.3 V at VCC = 5 V, Tamb = 25 °C
Supports mixed-mode voltage operation on all ports
IOFF circuitry provides partial Power-down mode operation
Latch-up performance exceeds 250 mA per JESD 78 Class II
ESD protection:
– HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 3kV
– MM JESD22-A115-A exceeds 200 V
– CDM JESD22-C101E exceeds 2kV
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
74AHCT541APW -40 °C to +125 °C
Name
Description
Version
TSSOP20
plastic thin shrink small outline package;
20 leads; body width 4.4 mm
SOT360-1
74AHCT541A
Nexperia
Type number
74AHCT541ABQ
4
Package
Temperature
range
Name
Description
Version
-40 °C to +125 °C
DHVQFN20 plastic dual in-line compatible thermal enhanced very SOT764-1
thin quad flat package; no leads; 20 terminals;
body 2.5 x 4.5 x 0.85 mm
Functional diagram
2
3
4
5
6
A0
Y0
A1
Y1
A2
Y2
A3
Y3
A4
Y4
18
17
16
15
14
1
19
7
8
9
1
19
A5
A6
A7
Product data sheet
Y6
Y7
13
12
11
OE1
OE2
Figure 1. Logic symbol
74AHCT541A
Y5
EN
2
18
3
17
4
16
5
15
6
14
7
13
8
12
9
11
mna900
mna898
Figure 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 14
74AHCT541A
Nexperia
5
Pinning information
5.1 Pinning
1
terminal 1
index area
1
20 VCC
A0
2
19 OE2
A1
3
18 Y0
A2
4
17 Y1
A3
5
16 Y2
A4
6
15 Y3
A5
7
14 Y4
A6
8
13 Y5
A7
9
12 Y6
GND 10
11 Y7
2
19 OE2
A1
3
18 Y0
A2
4
17 Y1
A3
5
16 Y2
A4
6
15 Y3
A5
7
A6
8
A7
9
14 Y4
GND(1)
13 Y5
12 Y6
Y7 11
OE1
A0
GND 10
74AHCT541A
20 VCC
OE1
74AHCT541A
aaa-026505
Transparent top view
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
aaa-020866
Figure 3. Pin configuration TSSOP20
Figure 4. Pin configuration DHVQFN20
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
OE1
1
output enable input (active LOW)
A0 to A7
2, 3, 4, 5, 6, 7, 8, 9
data input
GND
10
ground (0 V)
Y0 to Y7
18, 17, 16, 15, 14, 13, 12, 11
data output
OE2
19
VCC
supply voltage
74AHCT541A
Product data sheet
3 / 14
74AHCT541A
Nexperia
6
Functional description
Table 3. Functional table
[1]
Control
Input
Output
OE1
OE2
An
Yn
L
L
L
L
L
L
H
H
X
H
X
Z
H
X
X
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
Conditions
output voltage
active mode
Max
Unit
-0.5
+7.0
V
[1]
-0.5
+7.0
V
[2] [3]
-0.5
VCC + 0.5
V
[2]
-0.5
+7.0
V
input voltage
VO
Min
power-down or 3-state mode
IIK
input clamping current
VI < 0 V
-20
mA
IOK
output clamping current
VO < 0 V
-20
mA
IO
output current
VO = 0 V to VCC
±25
mA
ICC
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
500
mW
Ptot
[1]
[2]
[3]
[4]
8
total power dissipation
Tamb = -40 °C to +125 °C
[4]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
The output voltage ratings may be exceeded if the output current ratings are observed.
This value is limited to 7.0 V maximum.
For TSSOP20 package: above 100 °C the value of Ptot derates linearly with 10 mW/K.
For DHVQFN20 package: above 110 °C the value of Ptot derates linearly with 12.5 mW/K.
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
74AHCT541A
Product data sheet
Conditions
Min
Max
4.5
5.5
V
V
active mode
VCC
V
V
Unit
4 / 14
74AHCT541A
Nexperia
Symbol
Parameter
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
9
Conditions
VCC = 5.0 V ± 0.5 V
Min
Max
Unit
-40
+125
°C
ns/V
Static characteristics
Table 6. Static characteristics
Symbol Parameter
Conditions
25 °C
Min Typ
-40 °C to +85 °C -40 °C to +125 °C Unit
Max
Min
Max
Min
Max
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2
2
2
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
HIGH-level
output voltage
IO = -50 μA
4.4
4.5
4.4
4.4
V
3.94
3.8
3.7
V
0.1
0.1
V
0.36
0.44
0.55
V
IO = -8 mA
VOL
LOW-level
output voltage
IO = 50 μA
IO = 8 mA
IOZ
OFF-state
VCC = 5.5 V; VI = VIH or VIL;
output current VO = GND to 5.5 V
±0.25
±2.5
±2.5
μA
IOFF
power-off
leakage
current
VI or VO = GND to 5.5 V;
VCC = 0 V
0.5
5
5
μA
II
input leakage
current
VI = VCC or GND;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2
μA
ΔICC
additional
per input pin; VI = 3.4 V;
supply current IO = 0 A; VCC = 5.5 V;
other pins at VCC or GND
1.35
1.5
1.5
mA
74AHCT541A
Product data sheet
5 / 14
74AHCT541A
Nexperia
10 Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V. For test circuit see Figure 7.
Symbol Parameter Conditions
25 °C
[1]
Min Typ
tpd
propagation
delay
An to Yn; see Figure 5
Min
Max
Min
Max
2.8
6.9
1
8
1
8
ns
4.4
7.9
1
9
1
9
ns
3.9
11.3
1
13
1
13
ns
5.5
12.3
1
14
1
14
ns
CL = 15 pF
3.6
7.5
1
8
1
8
ns
CL = 50 pF
5.4
11.9
1
13.5
1
13.5
ns
1
1
1
ns
CL = 50 pF
enable time
Max
[2]
CL = 15 pF
ten
OEn to Yn; see Figure 6
[2]
CL = 15 pF
CL = 50 pF
disable time OEn to Yn; see Figure 6
tdis
[2]
tsk(o)
skew
CI
input
VI = VCC or GND;
capacitance VCC = 5 V
2
6
6
6
pF
CO
output
VO = VCC or GND;
5
pF
CPD
power
per buffer;
dissipation
CL = 0 pF; f = 10 MHz;
capacitance VI = GND to VCC
9
pF
[1]
[2]
[3]
VCC = 4.5 V to 5.5 V;
CL = 50 pF
[3]
Typical values are measured at Tamb = 25 °C and VCC = 5 V.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD × VCC × fi + å (CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
74AHCT541A
Product data sheet
6 / 14
74AHCT541A
Nexperia
Table 8. Noise characteristics
Symbol Parameter
Conditions
Tamb = 25 °C
Unit
Min
Typ
Max
VCC = 5 V; CL = 50 pF
VOL(p)
LOW-level output voltage (peak)
0.5
1.5
V
VOL(v)
LOW-level output voltage (valley)
-1.5
-0.3
V
VOH(v)
HIGH-level output voltage (valley)
4.5
V
VIH(AC)
AC HIGH-level input voltage (dynamic)
2
V
VIL(AC)
AC LOW-level input voltage (dynamic)
0.8
V
10.1 Waveforms and test circuit
VI
VM
An input
GND
t PHL
t PLH
VOH
VM
Yn output
VOL
mna901
Measurement points are given in Table 9.
VOL and VOH are typical voltage output levels that occur with the output load.
Figure 5. Propagation delay input (An) to output (Yn)
VI
OEn input
VM
GND
t PLZ
output
LOW-to-OFF
OFF-to-LOW
t PZL
VCC
VM
VX
VOL
t PHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
t PZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
mna902
Figure 6. Enable and disable times
74AHCT541A
Product data sheet
7 / 14
74AHCT541A
Nexperia
Table 9. Measurement points
Input
Output
VM
VM
VX
VY
1.5 V
0.5VCC
VOL + 0.3 V
VOH - 0.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
VI
G
DUT
VCC
VO
RL
RT
S1
open
CL
001aad983
Test data is given in Table 10.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance
S1 = Test selection switch
Figure 7. Test circuit for measuring switching times
Table 10. Test data
Input
VI
Load
tr, tf
GND to 3.0 V 3.0 ns
74AHCT541A
Product data sheet
S1 position
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
15 pF, 50 pF
1 kΩ
open
GND
VCC
8 / 14
74AHCT541A
Nexperia
11 Package outline
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Figure 8. Package outline SOT360-1 (TSSOP20)
74AHCT541A
Product data sheet
9 / 14
74AHCT541A
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
20 terminals; body 2.5 x 4.5 x 0.85 mm
B
D
SOT764-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
e1
C
e
b
2
9
v
w
C A B
C
y1 C
y
L
1
10
Eh
e
19
12
X
Dh
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
A(1)
A1
b
max 1.00 0.05 0.30
nom 0.90 0.02 0.25
min 0.80 0.00 0.18
mm
c
D(1)
Dh
E(1)
Eh
e
e1
L
v
0.2
4.6
4.5
4.4
3.15
3.00
2.85
2.6
2.5
2.4
1.15
1.00
0.85
0.5
3.5
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT764-1
MO-241
sot764-1_po
European
projection
Issue date
03-01-27
14-12-12
Figure 9. Package outline SOT764-1 (DHVQFN20)
74AHCT541A
Product data sheet
10 / 14
74AHCT541A
Nexperia
12 Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charge Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHCT541A v.7
20170317
Product data sheet
74AHCT541A v.6
Modifications:
• Added type number 74AHCT541ABQ (SOT764-1)
74AHCT541A v.6
20161102
Modifications:
• Type number 74AHCT541ABQ removed.
74AHCT541A v.5
20160613
Modifications:
• Table 6: II limits corrected (errata).
74AHCT541A v.4
20160419
Modifications:
• Table 6: conditions for additional supply current (ΔICC) corrected.
74AHCT541A v.3
20160224
Modifications:
• Table 7: CPD value corrected (errata).
74AHCT541A v.2
20160127
Modifications:
• Table 7: conditions CPD corrected (errata).
74AHCT541A v.1
20151223
74AHCT541A
Product data sheet
Product data sheet
Product data sheet
Product data sheet
Product data sheet
Product data sheet
Product data sheet
74AHCT541A v.5
74AHCT541A v.4
74AHCT541A v.3
74AHCT541A v.2
74AHCT541A v.1
11 / 14
74AHCT541A
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AHCT541A
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
12 / 14
74AHCT541A
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AHCT541A
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
13 / 14
74AHCT541A
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 4
Static characteristics .......................................... 5
Dynamic characteristics .....................................6
Waveforms and test circuit ................................ 7
Package outline ...................................................9
Abbreviations .................................................... 11
Revision history ................................................ 11
Legal information .............................................. 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 17 March 2017
Document identifier: 74AHCT541A
