74CB3Q3257-Q100
4-bit 1-of-2 FET multiplexer/demultiplexer with charge pump
Rev. 1 — 20 February 2019
Product data sheet
1. General description
The 74CB3Q3257-Q100 is a quad high-bandwidth single-pole, double-throw FET bus switch. The
device features one select input (S) and one output enable input (OE). The switch is disabled when
the OE input is HIGH. An internal charge-pump increases the gate voltage of the NMOS pass
transistor. The result is improved RON and RON(flat) performance and the ability to switch 5 V signals
when VCC = 3.3 V.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
• Specified from -40 °C to +85 °C
Wide supply voltage range from 2.3 V to 3.6 V
Overvoltage switching on switch ports:
• 0 V to 5 V switching with VCC = 2.5 V
• 0 V to 5 V switching with VCC = 3.3 V
4 Ω (typical) ON resistance
3.5 pF (typical) OFF-state capacitance
High bandwidth 0.5 GHz (maximum)
Low input/output capacitance minimizes loading and signal distortion
Fast switching frequency fmax = 20 MHz (maximum)
Low power consumption ICC = 0.4 mA (typical)
Control inputs can be driven by TTL or 5 V/3.3 V CMOS outputs
IOFF supports partial power-down mode operation
Latch-up performance exceeds 100 mA per JESD 78E Class II Level A
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM ANSI/ESDA/Jedec JS-001 Class 2 exceeds 2 kV
3. Applications
Communication infrastructure
Bus isolation
Memory interleaving
Sensor multiplexing
4. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
74CB3Q3257PW-Q100 -40 °C to +85 °C
Name
Description
Version
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74CB3Q3257-Q100
Nexperia
5. Functional diagram
1A
1B1
1B2
2A
2B1
2B2
3A
3B1
3B2
4A
4B1
4B2
S
OE
Fig. 1.
aaa-027232
Logic symbol
nB1
nA
nB2
CHARGE
PUMP
S
OE
CONTROLLOGIC
aaa-027233
Fig. 2.
Logic diagram (one switch)
74CB3Q3257_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 13
74CB3Q3257-Q100
Nexperia
6. Pinning information
6.1. Pinning
74CB3Q3257
S
1
16 VCC
1B1
2
15 OE
1B2
3
14 4B1
1A
4
13 4B2
2B1
5
12 4A
2B2
6
11 3B1
2A
7
10 3B2
GND
8
9
3A
aaa-027234
Fig. 3.
Pin configuration TSSOP16 (SOT403-1)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
S
1
select input
1B1
2
independent input or output
1B2
3
1A
4
common output or input
2B1
5
2B2
6
2A
7
GND
8
ground (0 V)
3A
9
3B2
10
3B1
11
4A
12
4B2
13
4B1
14
OE
15
output enable input (active-LOW)
VCC
16
supply voltage
74CB3Q3257_Q100
Product data sheet
3 / 13
74CB3Q3257-Q100
Nexperia
7. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Input
Channel on
S
OE
L
L
nA = nB1
H
L
nA = nB2
X
H
Z (switch off)
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
IIK
input clamping current
ISK
switch clamping current
ISW
switch current
ICC
supply current
IGND
Conditions
Min
Max
Unit
-0.5
+4.6
V
[1]
-0.5
+7.0
V
[2]
-0.5
+7.0
V
VI < -0.5 V
-50
mA
VI < -0.5 V
-50
mA
±120
mA
+100
mA
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
Min
Max
Unit
2.3
3.6
V
V
V
-40
+85
°C
VCC = 2.3 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
[1]
[2]
[3]
S, OE input
Tamb = -40 °C to +85 °C
[3]
The minimum input voltage rating may be exceeded if the input current rating is observed.
The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed.
For TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 60 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74CB3Q3257_Q100
Product data sheet
Conditions
S, OE input
S, OE input
4 / 13
74CB3Q3257-Q100
Nexperia
10. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground 0 V).
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb =-40 °C to +85°C
Unit
Min
Typ
Max
Min
Max
V
VIH
HIGH-level input VCC = 2.3 V to 2.7 V
voltage
1.7
2
V
VIL
LOW-level input
voltage
0.7
V
0.8
V
VIK
input clamping
voltage
nA, nBn; VCC = 3.6 V; II = -18 mA
-1.8
V
II
input leakage
current
S, OE; VCC = 3.6 V;
VI = GND to 5.5 V
±1
μA
IOFF
power-off
leakage current
per pin; VCC = 0 V;
VSW or VI = 0 V to 5.5 V
±1
μA
IS(OFF)
OFF-state
leakage current
nA, nBn; VCC = 3.6 V; see Fig. 4
±1
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
VSW = GND or VCC; VCC = 3.6 V
0.4
0.6
mA
ΔICC
additional supply S, OE; VCC = 3.6 V;
current
one input at 3 V,
other inputs at GND or VCC
30
μA
CI
input
capacitance
2.5
3.5
pF
nA
5.5
7
pF
nBn
3.5
5
pF
10.5
13
pF
VCC = 3.3 V; VSW = GND or VCC;
VI = 0 V, 3.3 V, 5.5 V
S, OE
CS(OFF)
CS(ON)
OFF-state
capacitance
VCC = 3.3 V; VSW = 0 V, 3.3 V, 5.5 V
ON-state
capacitance
74CB3Q3257_Q100
Product data sheet
nA, nBn
5 / 13
74CB3Q3257-Q100
Nexperia
10.1. Test circuit and graph
aaa-027237
10
ICC
(mA)
8
6
VCC
S
VIL or VIH
(1)
4
(2)
nA
nBn
IS
2
OE
GND
VIH
VI
4
8
12
16
fi (MHz)
Tamb = 25 °C; VCC = 3.3 V; nA and nBn not
connected.
(1) S input switching (50% duty cycle)
(2) OE input switching (50% duty cycle)
aaa-027236
VI = 5.5 V or GND and VO = GND or 5.5 V
Fig. 4.
VO
Test circuit for measuring OFF-state leakage
current (one channel)
Fig. 5.
Typical supply current as function of (S, OE)
input frequency
10.2. ON resistance
Table 7. ON resistance
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6.
Symbol Parameter
RON
ON resistance
Conditions
Tamb = 25 °C
Tamb = -40 °C to +85 °C Unit
Min
Typ
Max
Min
Max
VCC = 2.3 V; see Fig. 7
VI = 0 V; ISW = 30 mA
[1]
4
8
Ω
VI = 1.7 V; ISW = -15 mA
[1]
4.4
9
Ω
[2]
4
6
Ω
VI = 2.4 V; ISW = -15 mA
[2]
4.7
8
Ω
VCC = 3.0 V; see Fig. 7
[1]
[2]
Typical values are measured at VCC = 2.5 V.
Typical values are measured at VCC = 3.3 V.
74CB3Q3257_Q100
Product data sheet
6 / 13
74CB3Q3257-Q100
Nexperia
10.3. ON resistance test circuit and graph
aaa-027239
16
RON
(Ω)
12
VSW
VCC
VIL or VIH
(1)
8
S
nA
(2)
nBn
4
OE
GND
VIL
ISW
VI
RON = VSW / ISW
Test circuit for measuring ON resistance
(one channel)
1
2
3
4
VI (V)
5
Tamb = 25 °C
(1) VCC = 2.5 V
(2) VCC = 3.3 V
aaa-027238
Fig. 6.
Fig. 7.
Typical ON resistance as a function of input
voltage
11. Dynamic characteristics
Table 8. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit, see Fig. 10.
Symbol Parameter
tpd
propagation delay
Conditions
Min
Max
0.12
ns
0.20
ns
1.5
6.5
ns
VCC = 3.0 V to 3.6 V
1.5
5.5
ns
1.5
6.5
ns
1.5
5.5
ns
1.5
6.5
ns
1.5
5.5
ns
nA to nBn or nBn to nA; see Fig. 8
[1] [2]
S to nA; see Fig. 8
ten
enable time
OE to nA, nBn; see Fig. 9
S to nBn; see Fig. 9
74CB3Q3257_Q100
Product data sheet
Unit
[1]
[3]
[3]
7 / 13
74CB3Q3257-Q100
Nexperia
Symbol Parameter
tdis
disable time
Conditions
Min
Max
1.0
6.0
ns
1.0
6.0
ns
1.0
6.0
ns
1.0
6.0
ns
10
MHz
MHz
[4]
[3]
[4]
[4]
maximum frequency S, OE; VO > VCC; VI = 5 V; RL ≥ 1 MΩ;
CL = 0 pF
fmax
[1]
[2]
Unit
tpd is the same as tPLH and tPHL.
The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance,
when driven by an ideal voltage source (zero output impedance).
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
11.1. Waveforms and test circuit
VI
input
VM
VM
0V
tPHL
tPLH
VOH
VM
output
VM
VOL
001aai367
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 8.
The data input (nA or nBn) to output (nBn or nA) propagation delays
VI
VM
S, OE input
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
switch
enabled
switch
disabled
switch
enabled
aaa-027240
Fig. 9.
Enable and disable times
74CB3Q3257_Q100
Product data sheet
8 / 13
74CB3Q3257-Q100
Nexperia
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
0.5 × VCC
0.5 × VCC
VOL + 0.3 V
VOH - 0.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 10. Test circuit for measuring switching times
Table 10. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPZH, tPHZ
2.3 V to 2.7 V
VCC
≤ 2.5 ns
30 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74CB3Q3257_Q100
Product data sheet
Load
VEXT
9 / 13
74CB3Q3257-Q100
Nexperia
12. Package outline
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 11. Package outline SOT403-1 (TSSOP16)
74CB3Q3257_Q100
Product data sheet
10 / 13
74CB3Q3257-Q100
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74CB3Q3257_Q100 v.1
Product data sheet
74CB3Q3257_Q100
Product data sheet
20190220
11 / 13
74CB3Q3257-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74CB3Q3257_Q100
Product data sheet
12 / 13
74CB3Q3257-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................1
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 4
8. Limiting values............................................................. 4
9. Recommended operating conditions..........................4
10. Static characteristics..................................................5
10.1. Test circuit and graph................................................ 6
10.2. ON resistance............................................................6
10.3. ON resistance test circuit and graph......................... 7
11. Dynamic characteristics.............................................7
11.1. Waveforms and test circuit........................................ 8
12. Package outline........................................................ 10
13. Abbreviations............................................................ 11
14. Revision history........................................................11
15. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 20 February 2019
74CB3Q3257_Q100
Product data sheet
13 / 13
