74HC4067-Q100; 74HCT4067-Q100
16-channel analog multiplexer/demultiplexer
Rev. 1 — 22 May 2015
Product data sheet
1. General description
The 74HC4067-Q100; 74HCT4067-Q100 is a single-pole 16-throw analog switch (SP16T)
suitable for use in analog or digital 16:1 multiplexer/demultiplexer applications. The switch
features four digital select inputs (S0, S1, S2 and S3), sixteen independent inputs/outputs
(Yn), a common input/output (Z) and a digital enable input (E). When E is HIGH, the
switches are turned off. Inputs include clamp diodes. This enables the use of current
limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Input levels S0, S1, S2, S3 and E inputs:
For 74HC4067-Q100: CMOS level
For 74HCT4067-Q100: TTL level
Low ON resistance:
80 (typical) at VCC = 4.5 V
70 (typical) at VCC = 6.0 V
60 (typical) at VCC = 9.0 V
Specified in compliance with JEDEC standard no. 7A
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Multiple package options
Typical ‘break before make’ built-in
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
Nexperia
4. Ordering information
Table 1.
Type number
Package
74HC4067D-Q100
Temperature range
Name
Description
Version
40 C to +125 C
SO24
plastic small outline package; 24 leads;
body width 7.5 mm
SOT137-1
40 C to +125 C
TSSOP24
plastic thin shrink small outline package;
24 leads; body width 4.4 mm
SOT355-1
40 C to +125 C
DHVQFN24 plastic dual in-line compatible thermal enhanced SOT815-1
very thin quad flat package; no leads;
24 terminals; body 3.5 5.5 0.85 mm
74HCT4067D-Q100
74HC4067PW-Q100
74HCT4067PW-Q100
74HC4067BQ-Q100
74HCT4067BQ-Q100
5. Functional diagram
6
6
6
6
很抱歉,暂时无法提供与“74HCT4067D-Q100J”相匹配的价格&库存,您可以联系我们找货
