PBSS5160T
60 V, 1 A PNP low VCEsat (BISS) transistor
Rev. 04 — 15 January 2010
Product data sheet
1. Product profile
1.1 General description
PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a small
SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package.
NPN complement: PBSS4160T.
1.2 Features
Low collector-emitter saturation voltage VCEsat
High collector current capability IC and ICM
High efficiency due to less heat generation
Reduces Printed-Circuit Board (PCB) area required
Cost-effective replacement for medium power transistors BCP52 and BCX52
1.3 Applications
Major application segments:
Automotive
Telecom infrastructure
Industrial
Power management:
DC-to-DC conversion
Supply line switching
Peripheral driver:
Driver in low supply voltage applications (e.g. lamps and LEDs)
Inductive load drivers (e.g. relays, buzzers and motors)
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
open base
−60
V
−1
A
−2
A
220
330
mΩ
VCEO
collector-emitter voltage
IC
collector current
ICM
peak collector current
t = 1 ms or limited
by Tj(max)
RCEsat
collector-emitter
saturation resistance
IC = −1 A;
IB = −100 mA
[1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[1]
PBSS5160T
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Graphic symbol
3
3
1
1
2
2
006aab259
3. Ordering information
Table 3.
Type number
PBSS5160T
Package
Name
Description
Version
plastic surface-mounted package; 3 leads
SOT23
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PBSS5160T
*U6
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCBO
Min
Max
Unit
collector-base voltage open emitter
−80
V
VCEO
collector-emitter
voltage
open base
−60
V
VEBO
emitter-base voltage
open collector
−5
V
IC
collector current
[1]
−0.9
A
[2]
−1
A
−2
A
−300
mA
−1
A
ICM
IB
base current
IBM
peak base current
Conditions
t = 1 ms or limited
by Tj(max)
PBSS5160T_4
Product data sheet
2 of 11
Nexperia B.V. 2017. All rights reserved
PBSS5160T
Nexperia
Table 5.
Limiting values …continued
Symbol
Parameter
Conditions
Ptot
total power dissipation Tamb ≤ 25 °C
Min
Max
Unit
[1]
270
mW
[2]
400
mW
[1][3]
1.25
W
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
[3]
Operated under pulse conditions: duty cycle δ ≤ 20 %, pulse width tp ≤ 10 ms.
mle128
500
Ptot
(mW)
400
(1)
300
(2)
200
100
80
120
160
Tamb (°C)
(1) FR4 PCB, mounting pad for collector 1 cm2
(2) FR4 PCB, standard footprint
Fig 1.
Power derating curves
PBSS5160T_4
Product data sheet
3 of 11
PBSS5160T
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance from
junction to ambient
Rth(j-a)
in free air
Min
Typ
Max
Unit
[1]
465
K/W
[2]
312
K/W
[1][3]
100
K/W
[1]
[2]
[3]
mle127
103
Zth
(K/W)
102
δ=1
0.75
0.5
0.33
0.2
0.1
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
tp (s)
103
Fig 2.
Transient thermal impedance as a function of pulse duration; typical values
PBSS5160T_4
Product data sheet
4 of 11
PBSS5160T
Nexperia
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol Parameter
ICBO
Conditions
collector-base cut-off VCB = −60 V; IE = 0 A
current
VCB = −60 V; IE = 0 A;
Tj = 150 °C
Min
Typ
Max
Unit
−100
nA
−50
μA
ICES
collector-emitter
cut-off current
VCE = −60 V; VBE = 0 V
−100
nA
IEBO
emitter-base cut-off
current
VEB = −5 V; IC = 0 A
−100
nA
hFE
DC current gain
VCE = −5 V
IC = −1 mA
VCEsat
collector-emitter
saturation voltage
200
350
IC = −500 mA
[1]
150
250
IC = −1 A
[1]
100
160
IC = −100 mA; IB = −1 mA
−110
−160
mV
IC = −500 mA;
IB = −50 mA
−120
−175
mV
IC = −1 A; IB = −100 mA
[1]
−220
−330
mV
RCEsat
collector-emitter
[1]
220
330
mΩ
VBEsat
base-emitter
saturation voltage
IC = −1 A; IB = −50 mA
−0.95
−1.1
V
VBEon
base-emitter
turn-on voltage
VCE = −5 V; IC = −1 A
−0.82
−0.9
V
fT
transition frequency
VCE = −10 V;
IC = −50 mA; f = 100 MHz
150
220
MHz
Cc
collector capacitance VCB = −10 V; IE = ie = 0 A;
f = 1 MHz
9
15
pF
[1]
PBSS5160T_4
Product data sheet
5 of 11
PBSS5160T
Nexperia
mle124
600
hFE
−2
IC IB (mA) = − 20 −24 −28 −32 −36 −40
(A)
mle125
−1.6
(1)
−16
400
−12
−1.2
(2)
−8
−0.8
200
−4
(3)
−0.4
−10−1
−1
−10
−102
−103
−104
IC (mA)
VCE = −5 V
−1
−2
−3
−4
−5
VCE (V)
Tamb = 25 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 3.
DC current gain as a function of collector
current; typical values
mle122
−1.2
Fig 4.
Collector current as a function of
collector-emitter voltage; typical values
mle123
−1.2
VBEsat
(V)
VBE
(V)
−1
(1)
−0.8
(1)
(2)
(2)
−0.8
(3)
(3)
−0.6
−0.4
−0.4
−10−1
−1
−10
−102
−103
−104
IC (mA)
−0.2
−10−1
VCE = −5 V
−1
−103
−104
IC (mA)
−102
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Fig 5.
−10
Base-emitter voltage as a function of collector
Fig 6.
Base-emitter saturation voltage as a function
of collector current; typical values
PBSS5160T_4
Product data sheet
6 of 11
PBSS5160T
Nexperia
mle126
−10
VCEsat
mle119
−1
VCEsat
(V)
(V)
−10−1
−1
(2)
−10−1
−10−2
(1)
(3)
(2) (1)
(3)
−10−2
−10−1
−1
−10
−102
−103
−104
IC (mA)
−10−3
−10−1
−1
IC/IB = 20
IC/IB = 10
(1) Tamb = 100 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 7.
−10
−103
−104
IC (mA)
−102
(3) Tamb = −55 °C
Collector-emitter saturation voltage as a
function of collector current; typical values
mle120
−10
Fig 8.
mle121
103
RCEsat
(Ω)
VCEsat
(V)
102
−1
10
−10−1
(1)
1
(1)
(2)
(2)
−10−2
−10−1
−1
−10
−102
−103
−104
IC (mA)
Tamb = 25 °C
(3)
10−1
−10−1
−1
−10
−103
−104
IC (mA)
−102
IC/IB = 20
(1) IC/IB = 100
(1) Tamb = 100 °C
(2) IC/IB = 50
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 9.
Fig 10. Collector-emitter saturation resistance as a
PBSS5160T_4
Product data sheet
7 of 11
PBSS5160T
Nexperia
8. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
0.15
0.09
04-11-04
Fig 11. Package outline SOT23 (TO-236AB)
9. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PBSS5160T
[1]
Package Description
SOT23
4 mm pitch, 8 mm tape and reel
Packing quantity
3000
10000
-215
-235
For further information and the availability of packing methods, see Section 12.
PBSS5160T_4
Product data sheet
8 of 11
PBSS5160T
Nexperia
10. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBSS5160T_4
20100115
Product data sheet
PBSS5160T_N_3
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 1 “Quick reference data”: amended
Section 4 “Marking”: amended
Figure 4: updated
Figure 11: superseded by minimized package outline drawing
Section 9 “Packing information”: added
Section 11 “Legal information”: updated
PBSS5160T_N_3
20080718
Product data sheet
PBSS5160T_2
PBSS5160T_2
20040527
Product specification
PBSS5160T_1
PBSS5160T_1
20030623
PBSS5160T_4
Product data sheet
9 of 11
PBSS5160T
Nexperia
11. Legal information
11.1
Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
11.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
11.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
11.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
12. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PBSS5160T_4
Product data sheet
10 of 11
Nexperia
PBSS5160T
13. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
11.1
11.2
11.3
11.4
12
13
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Contact information. . . . . . . . . . . . . . . . . . . . . 10
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 15 January 2010
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PBSS5160T,215 PBSS5160TVL
