PCMF1USB3BA/CZ
PCMF1USB3BA/CZ
    NEXPERIA(安世)
    WLCSP5
    共模电感 2.2Ω Original WLCSP5
PCMF1USB3BA/CZ 数据手册
PCMFxUSB3BA/C series Common-mode EMI filter for differential channels with integrated bidirectional ESD protection Rev. 3 — 25 November 2019 Product data sheet 1. General description Common-mode ElectroMagnetic Interference (EMI) filters with integrated bidirectional ElectroStatic Discharge (ESD) protection for one, two and three differential channels. The devices are designed to provide low insertion loss for differential high-speed signals on each channel while unwanted common-mode signals are attenuated. Each differential channel incorporates two signal lines that are coupled by integrated coils. Diodes provide protection to downstream components from ESD voltages up to ±15 kV on each signal line. Table 1. Product overview Type number Number of channels Package Name PCMF1USB3BA/C 1 WLCSP5 PCMF2USB3BA/C 2 WLCSP10 PCMF3USB3BA/C 3 WLCSP15 2. Features and benefits • • • • • • One, two and three differential channels common-mode EMI filters with integrated ESD protection ESD protection up to ±15 kV contact discharge according to IEC 61000-4-2 Superior common-mode suppression over a wide frequency range Superior RF performance compared to other integrated filters or discrete filters with external ESD protection Extremely high symmetry between line pairs Industry-standard Wafer-Level Chip-Scale Packages: WLCSP5, 10 and 15 for smaller footprint 3. Applications • • • • • Smartphone, cellular and cordless phone USB3.2, USB2.0, HDMI2.0, HDMI1.4 General-purpose downstream ESD protection for differential data lines Tablet PC and Mobile Internet Device (MID) MIPI M-PHY and D-PHY as used in Camera Serial Interface (CSI) and Display Serial Interface (DSI) PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 4. Pinning information Table 2. Pinning Pin Symbol Description Simplified outline Graphic symbol PCMF1USB3BA/C (WLCSP5_2-1-2) A1 CH1_IN+ channel 1+, external A2 CH1_IN- channel 1-, external B1 GND_CH1 ground channel 1 C1 CH1_OUT+ channel 1+, internal C2 CH1_OUT- channel 1-, internal 2 B1 A1 C1 A2 C2 1 A B C Transparent top view WLCSP5_2-1-2 B1 aaa-028492 PCMF2USB3BA/C (WLCSP10_4-2-4) A1 CH1_IN+ channel 1+, external A2 CH1_IN- channel 1-, external A3 CH2_IN+ channel 2+, external A4 CH2_IN- channel 2-, external B1 GND_CH1 ground channel 1 B2 GND_CH2 ground channel 2 C1 CH1_OUT+ channel 1+, internal C2 CH1_OUT- channel 1-, internal C3 CH2_OUT+ channel 2+, internal C4 CH2_OUT- channel 2-, internal 4 B2 A1, 3 C1, 3 A2, 4 C2, 4 3 2 B1 1 B1, B2 - no internal connection A B C aaa-028493 Transparent top view WLCSP10_4-2-4 PCMF3USB3BA/C (WLCSP15_6-3-6) A1 CH1_IN+ channel 1+, external A2 CH1_IN- channel 1-, external A3 CH2_IN+ channel 2+, external A4 CH2_IN- channel 2-, external A5 CH3_IN+ channel 3+, external A6 CH3_IN- channel 3-, external B1 GND_CH1 ground channel 1 B2 GND_CH2 ground channel 2 B3 GND_CH3 ground channel 3 C1 CH1_OUT+ channel 1+, internal C2 CH1_OUT- channel 1-, internal C3 CH2_OUT+ channel 2+, internal C4 CH2_OUT- channel 2-, internal C5 CH3_OUT+ channel 3+, internal C6 CH3_OUT- channel 3-, internal PCMFXUSB3BA_C_SER Product data sheet 6 B3 A1, 3, 5 C1, 3, 5 A2, 4, 6 C2, 4, 6 5 4 B2 3 B1, B2, B3 - no internal connection aaa-028494 2 B1 1 A B C Transparent top view WLCSP15_6-3-6 All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 2 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 5. Ordering information Table 3. Ordering information Type number Package Name Description PCMF1USB3BA/C WLCSP5 wafer level chip-size package; 5 bumps (2-1-2) PCMF2USB3BA/C WLCSP10 wafer level chip-size package; 10 bumps (4-2-4) PCMF3USB3BA/C WLCSP15 wafer level chip-size package; 15 bumps (6-3-6) 6. Marking Table 4. Marking codes Type number Marking code PCMF1USB3BA/C PF1A PCMF2USB3BA/C PF2A PCMF3USB3BA/C PF3A 7. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VI input voltage VESD electrostatic discharge voltage Conditions Min Max Unit -4 4 V IEC 61000-4-2, level 4;all input pins to ground • contact discharge -15 15 kV • air discharge -15 15 kV IEC 61000-4-2, level 4;all output pins to ground PCMFXUSB3BA_C_SER Product data sheet • contact discharge -2 2 kV • air discharge -2 2 kV -7.5 7.5 A IPPM rated peak-pulse current tp = 8/20 μs Tstg storage temperature -40 +125 °C Tamb ambient temperature -40 +125 °C All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 3 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 8. Characteristics 8.1. Channel characteristics Table 6. Channel characteristics Tamb = 25 °C unless otherwise specified. Symbol parameter Conditions Min Typ Max Unit RS(ch) channel series resistance single line; input to output - 2.2 - Ω Cd diode capacitance f = 1 MHz; VI = 2.5 V [1] - 0.3 - pF IRM reverse leakage current per line; VI = 4 V - 1 100 nA VBR breakdown voltage IR = 1 mA 6 9 - V Rdyn dynamic resistance TLP; positive transient [2] - 0.29 - Ω TLP; negative transient [2] - 0.29 - Ω [1] [2] This parameter is guaranteed by design 100 ns Transmission Line Pulse (TLP); 50 Ω; pulser at 70 ns to 90 ns. 8.2. Frequency characteristics Table 7. Frequency characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 10 - GHz Differential mode: Sdd21 f-3dB [1] PCMFXUSB3BA_C_SER Product data sheet cut-off frequency [1] - Normalized to attenuation at 1 MHz. All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 4 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection aaa-029770 0 aaa-029771 0 Scc21 (dB) Sdd21 (dB) -10 -2 -20 -4 -30 -6 107 Fig. 1. 108 109 1010 f (Hz) -40 107 1011 Differential mode insertion loss; typical values Fig. 2. 109 1010 f (Hz) 1011 Common-mode insertion loss; typical values aaa-029773 115 aaa-029772 0 108 Zdif (Ω) Sdd21 (dB) -20 105 Z reference -40 95 Z DUT -60 -80 108 85 44.2 109 1010 f (Hz) CH1 to CH2 Fig. 3. Differential crosstalk; typical values PCMFXUSB3BA_C_SER Product data sheet 44.4 44.6 t (ns) 1011 44.8 tr = 200 ps Fig. 4. Differential Time Domain Reflectometer (TDR) plot; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 5 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection aaa-029774 25 I (A) I (A) 20 -5 15 -10 10 -15 5 -20 0 0 4 8 12 VCL (V) -25 -16 16 Transmission Line Pulse (TLP) = 100 ns; measured CH_IN to GND Fig. 5. Dynamic resistance with positive clamping; typical values I (A) -12 -8 -4 VCL (V) 0 Transmission Line Pulse (TLP) = 100 ns; measured CH_IN to GND Fig. 6. Dynamic resistance with negative clamping; typical values aaa-029776 60 aaa-029777 0 I (A) 40 -20 20 -40 0 0 10 20 VCL (V) -60 -30 30 Very-Fast Transmission Line Pulse (VF-TLP) = 5 ns; measured CH_IN to GND Fig. 7. aaa-029775 0 -20 -10 VCL (V) 0 Very-Fast Transmission Line Pulse (VF-TLP) = 5 ns; measured CH_IN to GND Dynamic resistance with positive clamping; typical values Fig. 8. Dynamic resistance with negative clamping; typical values The device uses an advanced clamping structure showing a negative dynamic resistance. This snap-back behavior strongly reduces the clamping voltage to the system behind the ESD protection during an ESD event. Do not connect unlimited DC current sources to the data lines to avoid keeping the ESD protection device in snap-back state after exceeding breakdown voltage (due to an ESD pulse for instance). PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 6 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection aaa-029778 8 I (A) I (A) 6 -2 4 -4 2 -6 0 0 2 4 6 VCL (V) 8 IEC61000-4-5; tp = 8/20 μs; positive pulse Fig. 9. aaa-029779 0 Dynamic resistance with positive clamping; typical values PCMFXUSB3BA_C_SER Product data sheet -8 -8 -6 -4 -2 VCL (V) 0 IEC61000-4-5; tp = 8/20 μs; negative pulse Fig. 10. Dynamic resistance with negative clamping; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 7 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 9. Application information The device is designed to provide high-level ESD protection for differential high-speed data line pairs such as: • • • • • • USB 3.2 HDMI 2.0 Transition-Minimized Differential Signaling (TMDS) DisplayPort external Serial Advanced Technology Attachment (eSATA) Low Voltage Differential Signaling (LVDS) When designing the Printed-Circuit Board (PCB), give careful consideration to impedance matching and signal coupling. Do not connect the protected signal lines to unlimited current sources like, for example, a battery. Fig. 11. Application diagram: protecting the differential data lines of a USB Type-C connector evaluation dongle with PCMF1USB3BA/C Since the SuperSpeed TX/RX lines are separated by GND or VBUS from the Hi-Speed lines, PCMF1USB3BA/C makes it easy to achieve same signal lengths, straight routing, and optimal positioning for ESD protection directly at the connector. PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 8 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 10. Package outline WLCSP5: wafer level chip-size package; 5 bumps (2-1-2) PCMF1USB3BA/C D bump A1 index area A1 E A detail X e 1/2 e b C e1 B1 B e2 A bump A1 index area 1 2 X 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b D E e e1 e2 max 0.64 0.42 0.31 0.82 1.22 nom 0.61 0.41 0.26 0.77 1.17 0.40 0.40 0.80 min 0.58 0.40 0.21 0.72 1.12 pcmf1usb3ba-c_po Outline version References IEC JEDEC JEITA European projection Issue date 19-03-20 19-04-02 PCMF1USB3BA/C Fig. 12. Package outline WLCSP5 PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 9 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection WLCSP10: wafer level chip-size package; 10 bumps (4-2-4) PCMF2USB3BA/C D bump A1 index area A1 E A detail X e b C B1 B e1 B2 e2 A bump A1 index area 1 2 e3 3 4 X 1/2 e 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b D E e e1 e2 max 0.64 0.42 0.31 1.62 1.22 nom 0.61 0.41 0.26 1.57 1.17 0.40 0.40 0.80 min 0.58 0.40 0.21 1.52 1.12 e3 0.80 pcmf2usb3ba-c_po Outline version References IEC JEDEC JEITA European projection Issue date 19-03-20 19-04-02 PCMF2USB3BA/C Fig. 13. Package outline WLCSP10 PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 10 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection WLCSP15: wafer level chip-size package; 15 bumps (6-3-6) PCMF3USB3BA/C D bump A1 index area A1 E A detail X e 1/2 e b C B1 B B2 e1 B3 e2 A 1 bump A1 index area 2 e3 3 4 5 6 X 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b D E e e1 e2 e3 max 0.64 0.42 0.31 2.42 1.22 nom 0.61 0.41 0.26 2.37 1.17 0.40 0.40 0.80 0.80 min 0.58 0.40 0.21 2.32 1.12 pcmf3usb3ba-c_po Outline version References IEC JEDEC JEITA European projection Issue date 19-03-20 PCMF3USB3BA/C Fig. 14. Package outline WLCSP15 PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 11 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 11. Soldering WLCSP5: Solder footprint and stencil aperture PCMF1USB3BA/C Hx P see detail X P solder land (SL) Hy solder paste deposit (SP) solder land plus solder paste SL = SP solder resist opening (SR) SR occupied area detail X Dimensions in mm P SL SP SR Hx recommend stencil thickness: 0.1 mm Hy 19-03-20 19-04-02 0.40 0.25 0.25 0.325 1.00 1.40 pcmf1usb3ba-c_fr Fig. 15. Soldering footprint WLCSP5 (PCMF1USB3BA/C) WLCSP10: Solder footprint and stencil aperture PCMF2USB3BA/C Hx P see detail X P solder land (SL) Hy solder paste deposit (SP) solder land plus solder paste SL = SP solder resist opening (SR) SR occupied area P1 Dimensions in mm P P1 SL SP SR Hx Hy detail X recommend stencil thickness: 0.1 mm 19-03-20 19-04-02 0.40 0.80 0.25 0.25 0.325 1.80 1.40 pcmf2usb3ba-c_fr Fig. 16. Soldering footprint WLCSP10 (PCMF2USB3BA/C) PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 12 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection WLCSP15: Solder footprint and stencil aperture PCMF3USB3BA/C Hx P see detail X P solder land (SL) Hy solder paste deposit (SP) solder land plus solder paste SL = SP solder resist opening (SR) SR occupied area P1 Dimensions in mm P P1 SL SP SR Hx Hy detail X recommend stencil thickness: 0.1 mm 19-03-20 0.40 0.80 0.25 0.25 0.325 2.60 1.40 pcmf3usb3ba-c_fr Fig. 17. Soldering footprint WLCSP15 (PCMF3USB3BA/C) PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 13 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection 12. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes PCMFXUSB3BA_C_SER v.3 20191125 Product data sheet - PCMFXUSB3BA_C_SER v.2 Modifications: • PCMFXUSB3BA_C_SER v.2 20190814 Product data sheet - PCMFXUSB3BA_C_SER v.1 PCMFXUSB3BA_C_SER v.1 20190408 Objective data sheet - - PCMFXUSB3BA_C_SER Product data sheet Figure 2: corrected y-axis label All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 14 / 15 PCMFxUSB3BA/C series Nexperia Common-mode EMI filter for differential channels with integrated bidirectional ESD protection Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Pinning information......................................................2 5. Ordering information....................................................3 6. Marking.......................................................................... 3 7. Limiting values............................................................. 3 8. Characteristics.............................................................. 4 8.1. Channel characteristics............................................... 4 8.2. Frequency characteristics............................................4 9. Application information............................................... 8 10. Package outline.......................................................... 9 11. Soldering................................................................... 12 12. Revision history........................................................14 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 November 2019 PCMFXUSB3BA_C_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 25 November 2019 © Nexperia B.V. 2019. All rights reserved 15 / 15
PCMF1USB3BA/CZ 价格&库存
很抱歉,暂时无法提供与“PCMF1USB3BA/CZ”相匹配的价格&库存,您可以联系我们找货
PCMF1USB3BA/CZ
    • 4500+1.143204500+0.13867
    • 9000+1.137869000+0.13802
    • 13500+1.1378313500+0.13802
    • 18000+1.1378118000+0.13801
    • 22500+1.1377822500+0.13801
