PCMFxUSB3B/C series
Common-mode EMI filter for differential channels with
integrated bidirectional ESD protection
Rev. 2 — 29 January 2019
Product data sheet
1. General description
Common-mode ElectroMagnetic Interference (EMI) filters with integrated bidirectional ElectroStatic
Discharge (ESD) protection for one, two and three differential channels. The devices are designed
to provide low insertion loss for differential high-speed signals on each channel while unwanted
common-mode signals are attenuated.
Each differential channel incorporates two signal lines that are coupled by integrated coils. Diodes
provide protection to downstream components from ESD voltages up to ±20 kV on each signal line.
Table 1. Product overview
Type number
Number of channels Package Name
PCMF1USB3B/C
1
WLCSP5
PCMF2USB3B/C
2
WLCSP10
PCMF3USB3B/C
3
WLCSP15
2. Features and benefits
One, two and three differential channels common-mode EMI filters with integrated ESD
protection
ESD protection up to ±20 kV contact discharge according to IEC 61000-4-2
Superior common-mode suppression over a wide frequency range
Superior RF performance compared to other integrated filters or discrete filters with external
ESD protection
Extremely high symmetry between line pairs
Industry-standard Wafer-Level Chip-Scale Packages: WLCSP5, 10 and 15 for smaller footprint
3. Applications
Smartphone, cellular and cordless phone
USB 3.2, USB 2.0, HDMI 2.0, HDMI 1.4
General-purpose downstream ESD protection for differential data lines
Tablet PC and Mobile Internet Device (MID)
MIPI M-PHY and D-PHY as used in Camera Serial Interface (CSI) and Display Serial Interface
(DSI)
PCMFxUSB3B/C series
Nexperia
Common-mode EMI filter for differential channels with integrated bidirectional ESD protection
4. Pinning information
Table 2. Pinning
Pin
Symbol
Description
Simplified outline
Graphic symbol
PCMF1USB3B/C (WLCSP5_2-1-2)
A1
CH1_IN+
channel 1+, external
A2
CH1_IN-
channel 1-, external
B1
GND_CH1
ground channel 1
C1
CH1_OUT+
channel 1+, internal
C2
CH1_OUT-
channel 1-, internal
2
B1
A1
C1
A2
C2
1
A
B
C
Transparent top view
WLCSP5_2-1-2
B1
aaa-028492
PCMF2USB3B/C (WLCSP10_4-2-4)
A1
CH1_IN+
A2
CH1_IN-
A3
CH2_IN+
channel 2+, external
A4
CH2_IN-
channel 2-, external
B1
GND_CH1
ground channel 1
B2
GND_CH2
ground channel 2
C1
CH1_OUT+
C2
CH1_OUT-
C3
CH2_OUT+
channel 2+, internal
C4
CH2_OUT-
channel 2-, internal
4
B2
A1, 3
C1, 3
A2, 4
C2, 4
3
2
B1
1
B1, B2 - no internal connection
A
B
C
aaa-028493
WLCSP10_4-2-4
PCMF3USB3B/C (WLCSP15_6-3-6)
A1
CH1_IN+
A2
CH1_IN-
A3
CH2_IN+
A4
CH2_IN-
A5
CH3_IN+
channel 3+, external
A6
CH3_IN-
channel 3-, external
B1
GND_CH1
ground channel 1
B2
GND_CH2
ground channel 2
B3
GND_CH3
ground channel 3
C1
CH1_OUT+
C2
CH1_OUT-
C3
CH2_OUT+
C4
CH2_OUT-
C5
CH3_OUT+
channel 3+, internal
C6
CH3_OUT-
channel 3-, internal
PCMFxUSB3B/C_SER
Product data sheet
6
B3
A1, 3, 5
C1, 3, 5
A2, 4, 6
C2, 4, 6
5
4
B2
3
B1, B2, B3 - no internal connection
aaa-028494
2
B1
1
A
B
C
WLCSP15_6-3-6
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 20
PCMFxUSB3B/C series
Nexperia
5. Ordering information
Table 3. Ordering information
Type number
Package
Name
Description
PCMF1USB3B/C
WLCSP5
wafer level chip-size package; 5 bumps (2-1-2)
PCMF2USB3B/C
WLCSP10
wafer level chip-size package; 10 bumps (4-2-4)
PCMF3USB3B/C
WLCSP15
wafer level chip-size package; 15 bumps (6-3-6)
6. Marking
Table 4. Marking codes
Type number
Marking code
PCMF1USB3B/C
PF1B
PCMF2USB3B/C
PF2B
PCMF3USB3B/C
PF3B
7. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VI
input voltage
Conditions
VESD
electrostatic discharge
voltage
Min
Max
Unit
-4
4
V
IEC 61000-4-2, level 4;all
input pins to ground
contact discharge
-20
kV
air discharge
-20
kV
output pins to ground
PCMFxUSB3B/C_SER
Product data sheet
contact discharge
-2
2
kV
air discharge
-2
2
kV
-9.5
9.5
A
IPPM
rated peak-pulse
current
tp = 8/20 μs
Tstg
storage temperature
-40
+125
°C
Tamb
ambient temperature
-40
+125
°C
3 / 20
PCMFxUSB3B/C series
Nexperia
8. Characteristics
8.1. Channel characteristics
Table 6. Channel characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
parameter
Conditions
Min
Typ
Max
Unit
RS(ch)
channel
series
resistance
single line; input to output
2.6
Ω
Cd
diode
capacitance
f = 1 MHz; VI =
2.5 V
[1] -
0.3
pF
IRM
reverse
leakage
current
per line;
VI = 4 V
1
100
nA
VBR
breakdown
voltage
IR = 1 mA
6
9
V
Rdyn
dynamic
resistance
TLP; positive
transient
[2] -
0.22
Ω
TLP; negative
transient
[2] -
0.22
Ω
[1]
[2]
This parameter is guaranteed by design
100 ns Transmission Line Pulse (TLP); 50 Ω; pulser at 70 ns to 90 ns.
8.2. Frequency characteristics
Table 7. Frequency characteristics
Symbol Parameter
Conditions
Min
Typ
Max
Unit
8.1
GHz
Differential mode: Sdd21
f-3dB
[1]
PCMFxUSB3B/C_SER
Product data sheet
cut-off frequency
[1] -
Normalized to attenuation at 1 MHz.
4 / 20
PCMFxUSB3B/C series
Nexperia
aaa-028346
Sdd21
(dB)
aaa-028347
Scc21
(dB)
-1
-10
-2
-20
-3
-30
-4
-5
107
Fig. 1.
108
109
1010
f (Hz)
-40
108
1011
Differential mode insertion loss; typical values
Fig. 2.
1010
f (Hz)
Common-mode insertion loss; typical values
aaa-028348
115
aaa-028363
Zdif
(Ω)
Sdd21
(dB)
-10
105
Z reference
-20
95
-30
-40
108
85
43.9
109
f (Hz)
CH1 to CH2
Fig. 3.
Differential crosstalk; typical values
PCMFxUSB3B/C_SER
Product data sheet
Z DUT
44.1
44.3
44.5
1010
t (ns)
44.7
tr = 200 ps
Fig. 4.
Differential Time Domain Reflectometer (TDR)
plot; typical values
5 / 20
PCMFxUSB3B/C series
Nexperia
Fig. 5.
USB 3.2 eye diagram 10 Gbps, test board with PCMFxUSB3B/C; typical values
Fig. 6.
USB 3.2 eye diagram 10 Gbps, test board without device; typical values
PCMFxUSB3B/C_SER
Product data sheet
6 / 20
PCMFxUSB3B/C series
Nexperia
Fig. 7.
USB 3.2 eye diagram 5 Gbps, test board with PCMFxUSB3B/C; typical values
Fig. 8.
USB 3.2 eye diagram 5 Gbps, test board without device; typical values
PCMFxUSB3B/C_SER
Product data sheet
7 / 20
PCMFxUSB3B/C series
Nexperia
1080p, 6 Gbps
Fig. 9.
HDMI 2.0 eye diagram TP1, test board with PCMFxUSB3B/C; typical values
1080p, 6 Gbps
Fig. 10. HDMI 2.0 eye diagram TP1, test board without device; typical values
PCMFxUSB3B/C_SER
Product data sheet
8 / 20
PCMFxUSB3B/C series
Nexperia
1080p, 6 Gbps
Fig. 11. HDMI 2.0 eye diagram TP2, test board with PCMFxUSB3B/C; typical values
1080p, 6 Gbps
Fig. 12. HDMI 2.0 eye diagram TP2, test board without device; typical values
PCMFxUSB3B/C_SER
Product data sheet
9 / 20
PCMFxUSB3B/C series
Nexperia
aaa-028357
25
I
(A)
aaa-028358
I
(A)
15
-10
10
-15
5
-20
10
15
VCL (V)
25
-25
-25
Transmission Line Pulse (TLP) = 100 ns;
measured CH_IN to GND
Fig. 13. Dynamic resistance with positive clamping;
typical values
I
(A)
-15
-10
-5
VCL (V)
Fig. 14. Dynamic resistance with negative clamping;
typical values
aaa-028359
80
-20
aaa-028360
I
(A)
60
-20
40
-40
60
VCL (V)
80
Very-Fast Transmission Line Pulse
(VF-TLP) = 5 ns;
-80
-80
-60
-40
-20
VCL (V)
(VF-TLP) = 5 ns;
Fig. 15. Dynamic resistance with positive clamping;
typical values
Fig. 16. Dynamic resistance with negative clamping;
typical values
The device uses an advanced clamping structure showing a negative dynamic resistance.
This snap-back behavior strongly reduces the clamping voltage to the system behind the ESD
protection during an ESD event. Do not connect unlimited DC current sources to the data lines to
avoid keeping the ESD protection device in snap-back state after exceeding breakdown voltage
(due to an ESD pulse for instance).
PCMFxUSB3B/C_SER
Product data sheet
10 / 20
PCMFxUSB3B/C series
Nexperia
aaa-028361
10
I
(A)
aaa-028362
I
(A)
8
-2
6
-4
4
-6
2
-8
4
6
8
VCL (V)
10
IEC61000-4-5; tp = 8/20 μs; positive pulse
Fig. 17. Dynamic resistance with positive clamping;
typical values
PCMFxUSB3B/C_SER
Product data sheet
-10
-10
-8
-6
-4
-2
VCL (V)
IEC61000-4-5; tp = 8/20 μs; negative pulse
Fig. 18. Dynamic resistance with negative clamping;
typical values
11 / 20
PCMFxUSB3B/C series
Nexperia
9. Application information
The device is designed to provide high-level ESD protection for differential high-speed data line
pairs such as:
USB 3.2
HDMI 2.0
Transition-Minimized Differential Signaling (TMDS)
DisplayPort
external Serial Advanced Technology Attachment (eSATA)
Low Voltage Differential Signaling (LVDS)
When designing the Printed-Circuit Board (PCB), give careful consideration to impedance matching
and signal coupling. Do not connect the protected signal lines to unlimited current sources like, for
example, a battery.
Fig. 19. Application diagram: protecting the differential data lines of a USB Type-C
connector evaluation dongle with PCMF1USB3B/C
Since the SuperSpeed TX/RX lines are separated by GND or VBUS from the Hi-Speed lines,
PCMF1USB3B/C makes it easy to achieve same signal lengths, straight routing, and optimal
positioning for ESD protection directly at the connector.
PCMFxUSB3B/C_SER
Product data sheet
12 / 20
PCMFxUSB3B/C series
Nexperia
10. Package outline
WLCSP5: wafer level chip-size package; 5 bumps (2-1-2)
PCMF1USB3B/C
D
bump A1
index area
A1
E
A
detail X
e
1/2 e
b
C
e1
B1
B
e2
A
bump A1
index area
1
2
X
1 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
A1
b
D
E
e
e1
e2
max 0.64 0.42 0.31 0.82 1.22
nom 0.61 0.41 0.26 0.77 1.17 0.40 0.40 0.80
min 0.58 0.40 0.21 0.72 1.12
pcmf1usb3b-c_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
18-03-23
PCMF1USB3B/C
Fig. 20. Package outline WLCSP5
PCMFxUSB3B/C_SER
Product data sheet
13 / 20
PCMFxUSB3B/C series
Nexperia
WLCSP10: wafer level chip-size package; 10 bumps (4-2-4)
PCMF2USB3B/C
D
bump A1
index area
A1
E
A
detail X
e
b
C
e1
B1
B
B2
e2
A
bump A1
index area
1
2
3
4
e3
X
1/2 e
1 mm
scale
Unit
mm
A
A1
b
D
E
e
e1
e2
max 0.64 0.42 0.31 1.62 1.22
nom 0.61 0.41 0.26 1.57 1.17 0.40 0.40 0.80
min 0.58 0.40 0.21 1.52 1.12
e3
0.80
pcmf2usb3b-c_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
18-03-23
PCMF2USB3B/C
Fig. 21. Package outline WLCSP10
PCMFxUSB3B/C_SER
Product data sheet
14 / 20
PCMFxUSB3B/C series
Nexperia
WLCSP15: wafer level chip-size package; 15 bumps (6-3-6)
PCMF3USB3B/C
D
bump A1
index area
A1
E
A
detail X
e
1/2 e
b
C
B1
B
B2
e1
B3
e2
A
1
bump A1
index area
2
3
4
5
6
e3
X
1 mm
scale
Unit
mm
A
A1
b
D
E
e
e1
e2
e3
max 0.64 0.42 0.31 2.42 1.22
nom 0.61 0.41 0.26 2.37 1.17 0.40 0.40 0.80 0.80
min 0.58 0.40 0.21 2.32 1.12
pcmf3usb3b-c_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
18-03-23
PCMF3USB3B/C
Fig. 22. Package outline WLCSP15
PCMFxUSB3B/C_SER
Product data sheet
15 / 20
PCMFxUSB3B/C series
Nexperia
11. Soldering
WLCSP5: Solder footprint and stencil aperture
PCMF1USB3B/C
Hx
P
see
detail X
P
solder land (SL)
Hy
solder paste deposit (SP)
solder land plus solder paste
SL = SP
solder resist opening (SR)
SR
occupied area
detail X
Dimensions in mm
P
SL
SP
SR
Hx
recommend stencil thickness: 0.1 mm
Hy
18-03-23
0.40 0.25 0.25 0.325 1.00 1.40
pcmf1usb3b-c_fr
Fig. 23. Soldering footprint WLCSP5 (PCMF1USB3B/C)
WLCSP10: Solder footprint and stencil aperture
PCMF2USB3B/C
Hx
P
see
detail X
P
solder land (SL)
Hy
SL = SP
SR
occupied area
P1
Dimensions in mm
P
P1
SL
SP
SR
Hx
Hy
detail X
18-03-23
0.40 0.80 0.25 0.25 0.325 1.80 1.40
pcmf2usb3b-c_fr
Fig. 24. Soldering footprint WLCSP10 (PCMF2USB3B/C)
PCMFxUSB3B/C_SER
Product data sheet
16 / 20
PCMFxUSB3B/C series
Nexperia
WLCSP15: Solder footprint and stencil aperture
PCMF3USB3B/C
Hx
P
see
detail X
P
solder land (SL)
Hy
SL = SP
SR
occupied area
P1
Dimensions in mm
P
P1
SL
SP
SR
Hx
Hy
detail X
18-03-23
0.40 0.80 0.25 0.25 0.325 2.60 1.40
pcmf3usb3b-c_fr
Fig. 25. Soldering footprint WLCSP15 (PCMF3USB3B/C)
PCMFxUSB3B/C_SER
Product data sheet
17 / 20
PCMFxUSB3B/C series
Nexperia
12. Revision history
Table 8. Revision history
Document ID
Release
date
Data sheet status
Change
notice
Supersedes
PCMFxUSB3B_C_SER v.2
20190129
Product data sheet
PCMFxUSB3B_C_SER v.1
Modifications:
20180507
PCMFxUSB3B/C_SER
Product data sheet
Limiting values: Tamb updated.
Channel characteristics: Sentence inserted; RS(ch) inserted.
Frequency characteristics: Sentence inserted; Fig 2 updated.
Product data sheet
18 / 20
PCMFxUSB3B/C series
Nexperia
13. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
PCMFxUSB3B/C_SER
Product data sheet
19 / 20
PCMFxUSB3B/C series
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Pinning information......................................................2
5. Ordering information....................................................3
6. Marking.......................................................................... 3
7. Limiting values............................................................. 3
8. Characteristics.............................................................. 4
8.1. Channel characteristics............................................... 4
8.2. Frequency characteristics............................................4
9. Application information............................................. 12
10. Package outline........................................................ 13
11. Soldering................................................................... 16
12. Revision history........................................................18
13. Legal information......................................................19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 29 January 2019
PCMFxUSB3B/C_SER
Product data sheet
20 / 20
